2014 A6 Avant ABS and Parking Brake help
scubbay
GB
C?ID=48993 (NRRT)
This A6 is experiencing issues with ABS and the parking brake. The parking brake light is flashing continuously when applied, triggering the message "Caution vehicle parked too steep." The yellow triangle light is also stuck on, along with the TPMS light. A message for the start-stop system and headlight range control occasionally appears as well. I will attach a full VCDS scan.
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
          6D 72
VIN: WAUZZZ4G2EN110077   Mileage: 346570km-215348miles
02-Auto Trans -- Status: OK 0000Wednesday,10,December,2025,11:50:51:43106
VCDS -- Windows-Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64)
Dealer/Shop Name: Sidekick
VIN: WAUZZZ4G2EN110077   License Plate:
Mileage: 346570km-215348mi   Repair Order:
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---    CVN: 1E5FEF43
   Coding: 12034012242401080000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
   ROD: EV_ECM20TDI01103L906018HA.rod
   VCID: 75E78FD7D4695433F0-8020
   VINID: 9D196AAAA1170957810400071C3820083A
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G1 927 155 P    HW: 0AW 927 156 K
   Component: 0AW_20TDI_RdW H08 0004
   Revision: --H08---    Serial number: 0000000546 CVN: 00001D86
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: 397F43E7B8F1F053D4-806C
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A19F016085F980DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A7D5CEBBDF7FB4BDD-806E
0518 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces.
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 0D
                    Uz: 98
0683 - Suspension Sensors
          C104B 29 [00001000] - Signal Implausible
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:09:41
                    VzRef: 04
                    Bit Info 1: 00
                    Bit Info 2: 41
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 99
                    Uz: B6
0848 - System Function Test Activated
          C101F 00 [00001001] - -
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: FF
                    Uz: 98
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: 98
0785 - Function Restriction due to Faults in Other Modules
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E5
                    Uz: 98
   Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0521
   Coding: 01B93046000000000000
   VCID: 79FF83E7F071305394-802C
   Serial number: 0213000393613016
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AJ    HW: 4G0 820 043 AJ
   Component: KLIMA 2 ZONEN H14 0094
   Serial number: 17011400110983
   Coding: 34220008A1
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 67DBD59F9EC5B6A372-8032
0276 - Engine Off Timer Performance
          P150A 00 [00001000] - -
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:22
                    Voltage terminal 30: 11.82 V
                    Terminal 15 status: Terminal 15 is on
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001511928
   Coding: 2600201040349FE00181008000001D0C0F9DC70827090201000004606100
   VCID: 6DD7A7B7B4399CF308-8038
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 131227  H36 0080
   Serial number:         140103171928
   Coding: 0045F7
   Serial number: 22167886
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 16 01 2014  00001659
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 30B80C07000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031402101522
   Coding: 08C308
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004_AU57.rod
   VCID: 71EFBBC7A00178132C-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00GCH96 Dataset Number: 4G0909602H  0002
   Coding: 3032343631324E303235554A305234473053
   VCID: 366548DB89EF1F2B39-8062
   Serial number: 3575HRB40612BJ1EE0T4
   Serial number: 3585HRB404R2AIFUH12Y
   Serial number: 3515JRB400A50QLQMI8$
   Serial number: 3525JRB400650QLQG1OT
   Serial number: 3554VRB400450R5KG98C
   Serial number: 3564VRB400450R5K819+
1049093 - Databus
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces.          Intermittent - Confirmed - Tested Since Memory Clear
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:28
1049094 - Databus
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:28
1049095 - Databus
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:28
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140117000250
   Coding: 000035
   VCID: 30697EC3638B311B63-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658090114592030
   Coding: 33A610000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3F8B2DFFA6D5DE63EA-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001238017 Dataset Number: 4G0909515H  0067
   Coding: 00CD074400
   GVL: FDA1C800DC6160010000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72EDB4CBA507430BD5-8026
   Serial number: 9709102203
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 131108000000000004A0
6655 - Sensor electronics control module
          U1077 00 [00001000] - No communication
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:08:10
                    Voltage terminal 30: 11.6 V
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 19 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0274 - FlexRay-Data bus
          U1048 00 [00001000] - defective
                    Reset counter: 167
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:08:10
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 4
Address 3B: Sensor Electronics. (J849)       Labels: 4G0-907-637.clb
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA72081YSV Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336371CF9A9D0A031E-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 479B351FF60596A352-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0008196163 Dataset Number: 4G0909852H  0027
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326D74CB6587030B15-8066
   Revision: 00002001    Serial number: 0325338559
   Coding: 013B0622A0B930008320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
Address 52: Door Elect, Pass. (J387)       Labels: 4H0-959-792.clb
   Component: TSG BF        H03 0507
   VCID: 4685381BF10F8FABA9-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000933454 Dataset Number: 4G0909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C516AB347A355FB5F-8078
459264 - Function Restriction due to Faults in Other Modules
          U1113 00 [10001001] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces.          MIL ON - Confirmed - Tested Since Memory Clear
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:43
                    Voltage terminal 30: 12.0 V
                    Internal Fault ID: 138
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested to apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
463616 - Function Restriction due to Faults in Other Modules
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:43
                    Internal Fault ID: 185
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140120-0002-008
   Coding: 112296101000A300
   ROD: EV_HeadlRegulBasic_AU35.rod
   VCID: 2D5767B77CB95CF348-8078
126986 - Front Left Ride-Height Sensor
          C1034 15 [10001001] - Open or Short to Plus
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:47
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101010101415B47082B060301010000010000
   VCID: 275B959F564576A3B2-8072
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464LZ0D2643312
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NAI0002L
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:51
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 499F3327E01160D344-801C
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 008400566 Dataset Number: 4G0909541D  0027
   Coding: 097205C010
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 35674FD794E9143330-8060
0114 - Load Space Cover
          B12EF 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 127
                    Mileage: 346570 km
                    Date: 2025.12.09
                    Time: 00:07:53
                    Voltage terminal 30: 11.70 V
   Component: TSG HR        H03 0507
End-------------------------(Elapsed Time: 04:39)--------------------------
------------------------------16 Faults Found------------------------------
Jef
HQ
Address 55: Headlight Range (J431):
Get all 3rd date handsy with that sensor and wiring, found out where the failure is and repair as needed.... then see how things go from there.
