Golf Plus 1.9 TDI BXE 2008
ianm
Arford, Hampshire, UK
C?ID=632902
Hi all,
I recently acquired a 2008 Golf Plus 1.9 TDI, and I've had it for about two weeks now. During this time, I’ve experienced two instances where the car has cut out completely and refused to restart immediately.
On the first occasion, I thought the fuel gauge might be faulty, so I added more diesel. After a minute or so of cranking, the engine started, but it ran with noticeable hesitation and a slight misfire, especially when accelerating in 3rd and 4th gears under load. Since then, I’ve driven around 250 miles, and while the hesitation persists, it only occurs during acceleration or heavier load.
Tonight, after a 60-mile drive home at light throttle, the car ran perfectly. However, when I made a quick stop and then tried to restart, the car cut out again. This time, it took about a minute of cranking before it started again, and I was able to drive home with no issues. The car idles fine and usually starts on the first attempt, although it has occasionally needed a second try since I got it.
I’ve already changed the fuel filter, but it didn’t seem to affect the hesitation. I also performed an auto-scan, and I’ve attached the results below.
Has anyone encountered similar issues or have any advice on how to dig deeper? I’m wondering if it could be related to a specific part or system that might need attention. The car has been regularly serviced and is in excellent condition, with 87,000 miles on the clock.
Any help would be greatly appreciated!
Thanks in advance,
Ian
Tuesday,09,December,2025,17:50:17:50713
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: WVWZZZ1KZ8W527153   License Plate:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
42-Door Elect, Driver -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 QA    HW: 028 101 208 5
   Component: R4 1,9L EDC G000SG  1139
   Revision: --H14---    Serial number: VWX7Z0G73NN7UI
   Coding: 0000031
   Shop #: WSC 48323 003 1048576
   VCID: 6E8212CE8C9B64EA6CF-803A
   VINID: 9E69EAAAA05BA889C50870450C1CBD1867
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0021234
   Shop #: WSC 01392 785 00200
   VCID: 73B403BAE7B94902831-8026
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BA42B9ACFE90142DB1-802E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007337543
   Coding: E4890F2700041800470A00000F000000000859035C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 6FBC0FCA8B916DE2679-803A
   Subsystem 1 - Part No: 5M0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 200707 021  0501
   Coding: 00038805
   Subsystem 2 - Part No: 1K0 955 559 AD  Labels: 1K0-955-559-AF.CLB
   Component: RLS     130807 014  1201
   Coding: 06500389
   Component: 1K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1DYXZ-
   Coding: 0012619
   Shop #: WSC 01373 785 00200
   VCID: 3D20E582917DCF72A55-8068
   Subsystem 1 - Serial number: 6332MSME22736E5AK
   Subsystem 2 - Serial number: 6342MSME2274433A7
   Subsystem 3 - Serial number: 6351HSME0F7F0A25L
   Subsystem 4 - Serial number: 6361HSME0F7E4E6A
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   VCID: 74B600A6E2B74E3A9AB-8020
Address 17: Instruments
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 070219F1000160
   Coding: 359003
   VCID: 79A83192C9D53352C9D-802C
                    Fault Status: 00110100
                    Reset counter: 50
                    Mileage: 138491 km
                    Time: 13:31:17
                    Reset counter: 50
                    Mileage: 138491 km
                    Time: 13:31:17
                    Reset counter: 57
                    Mileage: 138491 km
                    Time: 10:38:13
   Part No SW: 1K0 920 964 B    HW: 1K0 920 964 B
   Component: IMMO            VDD 1212
   Revision: V0002000    Serial number: VWX7Z0G73NN7UI
   VCID: 2C06D8C67A0756FA02B-8078
   Part No SW: 5K0 959 701 G    HW: 5K0 959 701 G
   Component: Tuer-SG         009 2108
   Coding: 0000692
   VCID: 3632FAAEB44B1C2A64F-8062
01552 - Motor for Central Locking; Drivers Door (V56); Lock
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
   Coding: 819002005103087F2D04840570085FC690FCA0
   VCID: 0354537AB7197982931-8056
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
                    Reset counter: 50
                    Mileage: 138491 km
                    Time: 13:31:17
                    Reset counter: 50
                    Mileage: 138491 km
                    Time: 13:31:17
   Component: Tuer-SG         006 1214
   Coding: 0000692
   VCID: 3928F1928555F35289D-806C
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No: 5M0 035 186 C
   Component: Radio GR0       033 0033
   Revision: 0003303S    Serial number: VWZ2Z2G1219163
   Coding: 0040400
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1203
   Coding: 0000144
   Shop #: WSC 01392 785 1012552
   VCID: 382EF496BE5FEA5A763-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----------(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.0V)-----------
------------------------------10 Faults Found------------------------------
When driving, be aware of the RPM value of the rev counter and try to see if when it cuts out, if the RPM reading drops directly to zero or if it continues to read a value consistent with the engines rotation whilst still in gear.
ianm
C?ID=632902
From what I can remember it dropped to 0. I needed to get the car off the road so very difficult to log the detail. The alternator light and engine check were on but no codes registered? it showed a "STOP" signal on the dash as i was cranking to get it started again and went out when it coughed back to life. Could the diesel pump in the tank be causing fuel starvation for the hesitation and intermittently not working at all when it cuts out?
Westbury, UK
I have done some got some live data tracking does any of this help?
No, it's a huge post that I can't make any sense of?
ianm
C?ID=632902
I will try and sort the live data. I am new to the VCDS system. Thanks for the guidance.
ianm
C?ID=632902
I think i may have sorted the hesitation / Misfire. I noticed the feed and return pipes were the wrong way around on the fuel pump! Would this of possibly made the car cut out as well??
Yes, I see that a lot, often when breakdown people have been in there. The first time, it really had me stumped, you would think it would run.
