Resolved Audi A5 EPC light on (2009 2.0T)
Resolved
rohana4b7
South Africa
C?ID=614161
hi there nice people
i just cant get this car fixed:
  • repaired several broken plugs
  • changed
    • coli plugs,
    • spark plugs,
    • one injecter on no two,
    • map sensor(still reading overboost)
    • intake temp sensor( still reading like minus25),
  • cleared several error codes,
  • repaired camshaft sensor,
  • removed 13pin plug
    • soldered in new wires correct gauge,
    • plug was broken and wires was briged
  • checked relays and fuses under ecu
  • tested workin
  • car starts like after 100 cranks but limp mode power and dies then wont start again,
  • car was abused by my point of view
anyways can somebody please give further advise as to what to check further,
only left with checking timing chain tomorrow then its defeated me
Monday,01,December,2025,17:54:24:10167
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: WAUZZZ8T69A034318 License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 55 56 77
VIN: WAUZZZ8T69A034318 Mileage: 186850km-116103miles
09-Cent. Elect. -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
Address 01: Engine (CL0MA-CDNC) Part No SW: 8K2 907 115 AJ Component: 2.0l R4/4V TF H14 0002
Revision: E1H14--- CVN: F7BDB4B4
Coding: 0114000C18070160
Shop #: WSC 52229 000 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
ROD: EV_ECM20AVS.rod
VCID: 77AF3B591F4F3FC2BF9-8022
VINID: 9D196AAAA2241894400C40C1208E344CE4
Labels:| 06H-907-115-V1.clb
HW: 8K2 907 115 D
18 Faults Found:
U1113 00 [00101111] - -
Fault Frequency: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:08
Engine speed: 0.00 /min
Normed load value: 0.0 %Vehicle speed: 0 km/h
Coolant temperature: 48 °C
Intake air temperature: -21 °C
Ambient air pressure: 820 mbar
Voltage terminal 30: 11.826 V
4124 - Sensor Reference Voltage B
P0651 00 [10101111] - Open Circuit
Mileage: 186792 km
Date: 2008.05.27
Time: 00:40:20
Coolant temperature: 36 °C
Intake air temperature: -30 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 8.104 V
5456 - Starter Will Not Turn
P3054 00 [00100000] - Jammed or Electrical Malfunction
Mileage: 186844 km
Date: 2008.05.27
Time: 00:56:05
Coolant temperature: 30 °C
Intake air temperature: -27 °C
Voltage terminal 30: 8.528 V
7150 - Please Check DTC Memory of Steering Wheel Electronics
P1698 00 [00101111] - -
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:08
Ambient air pressure: 820 mbarVoltage terminal 30: 11.803 V
4629 - ECM Power Relay Load Circuit
P068A 00 [01100101] - Opens Too Early
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 12.133 V
2670 - Throttle Position Sensor (G69)
P0122 00 [01100000] - Signal too Low
Mileage: 186792 km
Date: 2008.05.27
Time: 01:03:58
Coolant temperature: 33 °C
Voltage terminal 30: 7.868 V
2674 - Angle Sensor 2 for Throttle (G188)
P0222 00 [01100000] - Signal Too Low
Mileage: 186792 km
Date: 2008.05.27
Time: 01:03:58
2778 - Engine Coolant Temp. Sensor (G62)
P0118 00 [01100100] - Signal too High
Freeze Frame:Fault Priority: 2
Mileage: 186792 km
Date: 2008.05.27
Time: 01:07:14
2975 - Intake Manifold Flap; Bank 1
P2004 00 [01101101] - Stuck Open
Mileage: 186792 km
Date: 2008.05.27
Time: 00:06:26
Engine speed: 915.00 /min
Normed load value: 5.9 %
Coolant temperature: 42 °C
Intake air temperature: -24 °C
Voltage terminal 30: 13.169 V
2979 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [00100000] - Electrical Malfunction
Mileage: 186792 km
Date: 2008.05.27
Time: 01:07:12
5670 - Boost Pressure Regulation
P0234 00 [11100101] - Limit Exceeded (Overboost Condition)
Mileage: 186792 km
Date: 2008.05.27Time: 00:00:15
Intake air temperature: -22 °C
Voltage terminal 30: 11.685 V
4166 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [00100000] - Signal too High
Mileage: 186792 km
Date: 2008.05.27
Time: 00:40:21
4173 - Manifold Pressure / Boost Sensor (G31)
P0236 00 [10101111] - Implausible Signal
Mileage: 186800 km
Date: 2008.05.27
Time: 00:16:00
Vehicle speed: 71 km/h
Voltage terminal 30: 11.944 V
4187 - Intake Air Temp. Sensor (G42)
P0113 00 [10101111] - Signal too High
Mileage: 186854 km
Date: 2008.05.27
Time: 00:00:01
Coolant temperature: 20 °C
Ambient air pressure: 840 mbar
Voltage terminal 30: 11.096 V
4236 - EVAP Purge Control Valve (N80)
P0444 00 [10101111] - Circuit Open
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:25
Engine speed: 144.00 /min
Normed load value: 37.3 %
Voltage terminal 30: 10.036 V
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [00101111] - Malfunction
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:10
Voltage terminal 30: 11.779 V
4261 - System Voltage
P0562 00 [01100101] - Too Low
Mileage: 186792 km
Date: 2008.05.27
Time: 01:15:35
Ambient air pressure: 830 mbarVoltage terminal 30: 7.374 V
8169 - System Voltage
P0562 00 [00100000] - Too Low
Voltage terminal 30: 0.000 V
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Part No SW: 8K0 907 379 AC Labels:. 8K0-907-379-V1.clb
HW: 8K0 907 379 AC
Component: ESP8 front H04 0060
Coding: 064D00
Shop #: WSC 06325 000 00000
VCID: 7AA9226D2CDD22AAC07-802E
10 Faults Found:
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 40
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 03:50:35
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x000A
Hex Value: 0x637D
Hex Value: 0x00FF
Fault Frequency: 82
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27Time: 01:00:28
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0026
Hex Value: 0x23AB
Hex Value: 0x00FF
Fault Frequency: 76
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 01:00:28
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0016
Hex Value: 0x02AB
Hex Value: 0x00FF
Fault Frequency: 35
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 01:43:46
Hex Value: 0x0000
Hex Value: 0x3282
Hex Value: 0x001B
Hex Value: 0x0268
Hex Value: 0x00FF
Reset counter: 65
Mileage: 186844 km
Date: 2008.05.27
Time: 00:56:06
Hex Value: 0x0040Hex Value: 0x2286
Hex Value: 0x1229
Hex Value: 0x1666
Hex Value: 0x00FF
Fault Frequency: 40
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 03:50:35
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x000A
Hex Value: 0x637D
Hex Value: 0x00FF
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - Intermittent - MIL ON
Fault Status: 10101100
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Hex Value: 0x0000
Hex Value: 0x0300
Hex Value: 0x003E
Hex Value: 0xB0A0
Hex Value: 0x00FF
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Hex Value: 0x0000
Hex Value: 0x0300
Hex Value: 0x003F
Hex Value: 0xB0A0
Hex Value: 0x00FF03159 - TPMS Functionality in ESP
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:14:54
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x001A
Hex Value: 0x0DA9
Hex Value: 0x00FF
Fault Frequency: 28
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:07:51
Hex Value: 0x00C0
Hex Value: 0x6202
Hex Value: 0x021A
Hex Value: 0x33AB
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Part No SW: 8K0 907 064 C Component: BCM2 1.1 H80 0145
Coding: 031000
VCID: 303DC045BA2128FA3E3-8064
Labels:. 8K0-907-064-05.clb
HW: 8K0 907 064 C
Subsystem 1 - Part No SW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000078742012
HW: 8T0 959 754 D
Subsystem 2 - Part No SW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041
Serial number: 0208000098348004
HW: 8K0 905 852 D
002 - Lower Limit Exceeded - IntermittentFreeze Frame:
Fault Frequency: 199
Reset counter: 65
Mileage: 186733 km
Date: 2024.02.01
Time: 22:33:04
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Fault Frequency: 212
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:42:23
Fault Frequency: 137
Reset counter: 25
Mileage: 186732 km
Date: 2008.05.27
Time: 00:56:46
02811 - Control Module for Electronic Steering Column Lock (J764)
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 23:31:15
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation -
Intermittent
Fault Status: 00100101
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.27
Time: 00:21:46-------------------------------------------------------------------------
Address 08: Auto HVAC (J255) Part No SW: 8T2 820 043 S Labels:. 8Tx-820-043-3Z.clb
HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0150
Revision: D0000000 Serial number: 01081120081320
Coding: 64060000
VCID: 42D99A8D048DAA6AD87-8016
11 Faults Found:
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:01:23
Fault Frequency: 29
Reset counter: 65
Mileage: 186191 km
Date: 2023.12.28
Time: 16:23:28
Fault Frequency: 99
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:00:50
Fault Frequency: 67
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:27:59
Voltage: 8.40 VTemperature: 27.0°C
Fault Frequency: 8
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.27
Time: 20:30:37
Temperature: 21.0°C
Fault Frequency: 27
Reset counter: 25
Mileage: 186748 km
Date: 2008.05.27
Time: 00:00:04
Fault Status: 01101000
Fault Frequency: 32
Reset counter: 25
Mileage: 186748 km
Date: 2008.05.27
Time: 00:00:04
Temperature: 21.0°C
03269 - Functionality Linited due to Energy Management
Reset counter: 65
Mileage: 186748 km
Date: 2008.05.27
Time: 00:00:49
Fault Status: 00100010Fault Priority: 2
Fault Frequency: 19
Reset counter: 65
Mileage: 186748 km
Date: 2008.05.27
Time: 00:45:26
Temperature: 24.0°C
Temperature: 99.0°C
Absolute Pres.: 0.8 bar
RPM: 680 /min
Current: 0.000 A
Temperature: 33.0°C
03220 - Stop Valve for Coolant for Climatronic (N422)
Fault Status: 00101001
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:10:08
Reset counter: 65
Mileage: 186793 km
Date: 2008.05.27
Time: 00:16:08
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000169063
Coding: 260050914034AF010009000000005D5D0F1D038800010141000000
VCID: 2F3FC339A71F3702279-807A
Subsystem 1 - Part No SW: 8T2 955 119 C 1KX-955-119.CLB
Component: WWS 181108 H11 0040
Serial number: SWF08110180088
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 8K0-955-559.CLB
HW: 8J2 955 119 Labels:
HW: 8K0 955 559 Labels:Component: RLS H04 0003
Serial number: 10326807
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AA Component: E1 - LDS H07 0080
Serial number: 00000000002511080217
HW: 8K0 941 531 AA
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 01101100
Reset counter: 24
Mileage: 186792 km
Date: 2008.05.27
Time: 20:50:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 64
Mileage: 186748 km
Date: 2008.05.27
Reset counter: 64
Mileage: 186748 km
Date: 2008.05.27
Reset counter: 64
Mileage: 186748 km
Date: 2008.05.27
Fault Status: 01101100Fault Priority: 2
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Reset counter: 24
Mileage: 186748 km
Date: 2008.05.28
Time: 01:25:00
Reset counter: 178
Mileage: 183086 km
Date: 2008.05.29
Time: 01:48:00
00042 - Left Parking Light Lamp (M43)
Reset counter: 24
Mileage: 186792 km
Date: 2008.05.27
Time: 00:04:00
01232 - A/C Compressor Regulator Valve (N280)
Fault Status: 00101100
Reset counter: 25
Mileage: 1048574 km
Address 10: Park/Steer Assist (J446) Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52940833705401
Labels:. 8K0-919-475.clbCoding: 000001
VCID: 3A29E26D6C5DE2AA807-806E
Fault Frequency: 65
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:28:43
Temperature: 27.0°C
Fault Frequency: 158
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:42:39
Temperature: 33.0°C
Reset counter: 65
Mileage: 186748 km
Temperature: 77.0°C
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1CTC3E Dataset Number: 8T0909602C 0020
Coding: 30323433363030303030554A305238543053
VCID: 3C25E47566E9DC9A92B-8068Crash sensor for side airbag: driver side:
Serial number: 6334MSME42736F0EO
Serial number: 6344MSME4253455FH
Serial number: 6352QSME52174F26J
Serial number: 6362QSME3F134C1EV
Serial number: 63832SME1C074622Y
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [10001001] - Open or Short to Plus
Mileage: 186792 km
Date: 2008.05.27
Time: 01:00:50
13697280 - Component Protection
U1101 00 [00001000] - Active
Mileage: 186792 km
Date: 2008.05.27
Time: 00:07:56
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Powersupply lower threshold fall short of]
Fault Frequency: 32
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 01:43:29
Address 16: Steering wheel (J527) Part No SW: 8K0 953 568 F Labels:. 8K0-953-568.clb
HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HKP0008Q
Coding: 000016
VCID: 3D23E9717D73D592A55-8068
Component: E221 - MFL H02 00036 Faults Found:
014 - Defective
Fault Status: 01101110
Reset counter: 178
Mileage: 183086 km
Date: 2008.05.29
Time: 01:46:29
(no units): 44.0
Text: 2C91FFFFFFFF00C0FF
Fuel Consump.: 650.3 l/100
Raw, Index/Key Err.: 255 255 000
Text: 26E4007E007E002A00
Raw, Index/Key Err.: 228 000 126
Raw, Form. N/A: 000 126 000
Power: -388.2 kW
Fault Frequency: 37
Reset counter: 64
Mileage: 183086 km
Date: 2008.05.29
Time: 01:54:59
(no units): 44.0
Power: -388.2 kW
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 01:17:22
Fault Status: 00100010Fault Priority: 4
Fault Frequency: 107
Reset counter: 65
01426 - Controls in Steering Wheel (E221)
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:52
Fault Status: 00101101
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:01:23
Address 17: Instruments (J285) Part No SW: 8T0 920 931 HW: 8T0 920 931
Component: KOMBIINSTR. H31 0224
Revision: 00100000 Serial number: 9D216FTC8
Coding: 2F05000003000008010000
VCID: 74B50C550EB954DA9AB-8020
Labels:. 8T0-920-xxx-17.clb
Fault Frequency: 71
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:27:52
Reset counter: 61
Mileage: 186739 kmTime Indication: 0
Date: 2008.05.27
Time: 00:15:17
00771 - Fuel Level Sensor (G)
Fault Status: 00101110
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.28
Time: 15:55:42
Fault Status: 00101010
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 07:50:48
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.28
Time: 22:46:02
Fault Frequency: 42
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:07:49
Address 19: CAN Gateway (J533) Part No SW: 8T0 907 468 M Labels:. 8T0-907-468.clb
HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G08B10831C
Coding: 000303
Shop #: WSC 06325 000 00000VCID: 4BC7B7A933C76B222B1-801E
14 Faults Found:
Fault Frequency: 96
Reset counter: 64
Mileage: 183087 km
Date: 2008.05.29
Time: 08:04:00
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 64
Reset counter: 64
Mileage: 183091 km
Date: 2008.05.30
Time: 04:13:00
Fault Frequency: 27
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:30:56
02252 - Generator
Fault Frequency: 14
Reset counter: 65
Mileage: 186748 km
Date: 2008.05.27
Time: 00:01:00
02252 - Generator
Reset counter: 64
Mileage: 186748 km
Date: 2008.05.27Time: 00:00:30
02252 - Generator
Fault Status: 00100011
Reset counter: 64
Mileage: 186748 km
Date: 2008.05.27
Time: 00:00:30
Reset counter: 64
Mileage: 186748 km
Date: 2008.05.27
Time: 00:10:50
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 20:13:59
01304 - Radio
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:08
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.27
Time: 16:32:0300576 - Terminal 15
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.28
Time: 03:19:00
00458 - Control Module for Battery Monitoring (J367)
Fault Frequency: 29
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:16:51
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
01312 - Powertrain Data Bus
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:01
Address 2E: Media Player 3 (R199) Part No SW: 8T0 035 785 Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020202
VCID: 78AD386512D130BAB63-802C
Labels:. 8T0-035-785.clb
HW: 8T0 035 785
4 Faults Found:00446 - Function Limitation due to Under-Voltage
Fault Frequency: 95
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:45:34
Fault Frequency: 86
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 01:20:40
Reset counter: 65
Mileage: 181764 km
Date: 2008.05.27
Time: 02:08:32
01304 - Radio
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:15
Address 42: Door Elect, Driver (J386) Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008160961
Coding: 011C02224001120102
VCID: 41DB9581018BB172C1D-8014
Labels:. 8K0-959-793.clb
00446 - Function Limitation due to Under-Voltage000 - - - Intermittent
Reset counter: 65
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:28:19
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Revision: 00002001 Serial number: 0116169522
Coding: 011A068200390444013000
Subsystem 2 - Part No SW: 8R0 959 591 Component: J245EE16SKB10 H01 0180
HW: 8R0 959 591
11 Faults Found:
Fault Frequency: 18
Reset counter: 65
Mileage: 186854 km
Date: 2008.05.27
Time: 00:00:54
02738 - Bulb for Tail/Brake Light; Left
Fault Status: 11101100
Reset counter: 178
Mileage: 183086 km
Date: 2008.05.29Time: 01:47:06
02739 - Bulb for Tail/Brake Light; Right
Reset counter: 24
Mileage: 183086 km
Date: 2008.05.29
Time: 01:47:06
014 - Defective
Fault Frequency: 11
Reset counter: 25
Mileage: 183086 km
Date: 2008.05.29
Time: 01:47:10
02616 - Fuel Tank Cap; Unlock
Reset counter: 65
Mileage: 183087 km
Date: 2008.05.30
Time: 00:35:47
03156 - Sensor for Anti-Theft System (G578)
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 01:48:33
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 03:53:2700166 - Access/Start Authorization Switch (E415)
Reset counter: 65
Mileage: 186796 km
Date: 2008.05.27
Time: 00:00:36
03177 - Relay for Power Outlets (J807)
Fault Status: 00101011
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 01:19:44
00218 - Humidity Sensor (G355)
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 01:12:52
03020 - Local databus 2
Fault Frequency: 17
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:05
Address 47: Sound System (J525) Part No SW: 8T0 035 223 AB Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6E811E3D60957E0A6CF-803A
Labels:. 8T0-035-223-ASC.clb
HW: 8T0 035 223
5 Faults Found:00532 - Supply Voltage B+
Fault Frequency: 67
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 01:21:42
Voltage: 7.70 V
Temperature: 38.0°C
Bin. Bits: 00000010
Bin. Bits: 00000011
Bin. Bits: 00000000
00418 - Front Right DSP Mid-Bass Speaker (R102)
Reset counter: 25
Mileage: 183087 km
Date: 2008.05.30
Time: 00:37:39
Voltage: 12.10 V
Temperature: 37.0°C
Bin. Bits: 00000000
01304 - Radio
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.27
Time: 00:04:56
Voltage: 11.60 V
Temperature: 16.0°C
Bin. Bits: 00000001
02247 - Subwoofer (R148/R157)
Fault Frequency: 14
Reset counter: 25
Mileage: 186792 kmTime Indication: 0
Date: 2008.05.27
Time: 00:00:08
Voltage: 11.20 V
Temperature: 21.0°C
Bin. Bits: 00000001
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:27:18
Voltage: 6.10 V
Temperature: 30.0°C
Bin. Bits: 00000010
Address 52: Door Elect, Pass. (J387) Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008135457
VCID: 40DD90850A81B87ACE3-8014
Labels:. 8K0-959-792.clb
Reset counter: 65
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:28:19-------------------------------------------------------------------------
Address 53: Parking Brake (J540) Part No SW: 8K0 907 801 F Labels: 8K0-907-801-V1.clb
HW: 8K0 907 801 F
Component: EPB Audi B8 H06 0070
Revision: 00000003 Serial number: 00000000274707
VCID: 3239CA4DB42D1AEA487-8066
Fault Status: 11101101
Reset counter: 25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:14:12
Voltage: 9.50 V
Count: 58
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:01:29
Voltage: 12.10 V
Count: 62
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
00576 - Terminal 15
Fault Frequency: 11
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 03:50:30Freeze Frame:
Voltage: 11.60 V
Count: 48
Hex Value: 0x0273
Hex Value: 0x0008
Hex Value: 0x1010
Fault Frequency: 31
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 02:53:44
Voltage: 8.00 V
Count: 44
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000001
Shop #: WSC 06324 000 00000
VCID: 77AF3B5913CF3FC2BF9-8022
Labels: 8K0-907-357.clb
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 179
Mileage: 183087 km
Date: 2008.05.29
Time: 02:07:41
Fault Status: 11101010
Reset counter: 190
Mileage: 183088 kmTime Indication: 0
Date: 2008.05.30
Time: 01:19:45
Fault Frequency: 219
Reset counter: 25
Mileage: 186732 km
Date: 2008.05.27
Time: 00:32:38
Reset counter: 61
Mileage: 186737 km
Date: 2008.05.27
Time: 00:11:21
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:27:28
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 195 H HW: 8T2 035 195 H
Component: Symphony3 H02 0210
Revision: 00000004 Serial number: AUZ5Z4H1060224
Coding: 0402008201048D00435B070800
Subsystem 1 - Part No SW: 8T0 919 603 A Component: Display
8 Faults Found:
HW: 8T0 919 603 AReset counter: 65
Mileage: 185448 km
Date: 2023.12.03
Time: 01:23:11
00468 - CD-ROM Drive (R92)
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:00:05
Fault Frequency: 104
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:46:16
Fault Frequency: 46
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:56:46
Reset counter: 65
Mileage: 186732 km
Date: 2008.05.27
Time: 00:06:32
Bin. Bits: 00
Fault Status: 00100000Fault Priority: 6
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:02:06
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
00625 - Vehicle Speed Signal
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:30:52
Reset counter: 65
Mileage: 186792 km
Date: 2008.05.27
Time: 00:10:15
Part No SW: 8T0 862 335 C HW: 8T0 862 335 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005046089
Coding: 0010390
VCID: 3A29E26D605DE2AA807-806E
Fault Frequency: 28
Reset counter: 65Mileage: 186732 km
Date: 2008.05.27
Time: 00:55:58
Reset counter: 64
Mileage: 186732 km
Date: 2008.05.27
Time: 01:42:54
01304 - Radio
Fault Frequency: 26
Reset counter: 64
Mileage: 186792 km
Date: 2008.05.27
Time: 00:04:54
End----(Elapsed Time: 01:39, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)---
-----------------------------129 Faults Found----------------------------
Monday,01,December,2025,18:21:36:10167
04-Steering Angle -- Status: OK 000005-Acc/Start Auth. -- Status: Malfunction 0010
HW: 8K2 907 115 D
7 Faults Found:
U1113 00 [00100111] - -
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:04
Coolant temperature: 21 °C
Ambient air pressure: 850 mbar
Voltage terminal 30: 11.732 V
P0651 00 [10100111] - Open Circuit
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:04
Engine speed: 0.00 /minNormed load value: 0.0 %
P1698 00 [00100111] - -
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:05
P0234 00 [10100111] - Limit Exceeded (Overboost Condition)
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:06
Voltage terminal 30: 11.756 V
P0236 00 [00100111] - Implausible Signal
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:09
Intake air temperature: -40 °CAmbient air pressure: 850 mbar
P0113 00 [00100111] - Signal too High
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:06
P0070 00 [00100111] - Malfunction
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:05
HW: 8K0 907 379 AC
Coding: 064D00
Fault Frequency: 1Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:23:06
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x000A
Hex Value: 0x6395
Hex Value: 0x00FF
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:23:06
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0026
Hex Value: 0x2395
Hex Value: 0x00FF
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:23:06
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0016
Hex Value: 0x0295
Hex Value: 0x00FF
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27Time: 00:23:08
Hex Value: 0x0000
Hex Value: 0x2282
Hex Value: 0x001A
Hex Value: 0x3395
Hex Value: 0x00FF
Coding: 031000
HW: 8K0 907 064 C
HW: 8T0 959 754 D
HW: 8K0 905 852 D
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:24:37
HW: 8T2 820 043 S
Coding: 64060000
Reset counter: 25
Mileage: 186854 kmTime Indication: 0
Date: 2008.05.27
Time: 00:26:04
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:26:04
Temperature: 1.0°C
Coding: 00FD11
Coding: 02532C
HW: 8K0 941 531 AA
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:27:00
012 - Electrical Fault in CircuitFreeze Frame:
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:27:00
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:27:00
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:27:00
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:27:00
------Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Mileage: 186854 km
Date: 2008.05.27
Time: 00:29:16
HW: 8K0 953 568 F
Coding: 000016
014 - Defective
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:31:00Freeze Frame:
(no units): 44.0
Power: -388.2 kW
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:32:13
HW: 8T0 907 468 H
Coding: 000303
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:34:27-------------------------------------------------------------------------
Revision: 00000000
Coding: 020202
HW: 8T0 035 785
HW: 8R0 959 591
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:35:30
Reset counter: 25Mileage: 186854 km
Date: 2008.05.27
Time: 00:35:25
Revision: S2100000
Coding: 0203010102
HW: 8T0 035 223
HW: 8K0 907 801 F
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:37:13
Voltage: 11.90 V
Count: 58
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010-------------------------------------------------------------------------
Coding: 0000001
Reset counter: 65
Mileage: 186854 km
Date: 2008.05.27
Time: 00:37:55
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:37:55
000 - - - MIL ON
Reset counter: 25
Mileage: 186854 km
Date: 2008.05.27
Time: 00:37:55
HW: 8T0 919 603 ANo fault code found.
Coding: 0010390
End----(Elapsed Time: 01:27, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)---
------------------------------29 Faults Found----------------------------
Monday,01,December,2025,17:58:06:10167
VCDS Version: Release 25.3.2 (x64) Running on Windows 11 x64
Address 01: Engine Labels: 06H-907-115-V1.clb
Control Module Part Number: 8K2 907 115 AJ HW: 8K2 907 115 D
Component and/or Version: 2.0l R4/4V TF H14 0002
Software Coding: 0114000C18070160
Work Shop Code: WSC 52229 000 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002 (AU48)
18 Faults Found:
Fault Frequency: 26
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:08
Mileage: 186792 km
Date: 2008.05.27
Time: 00:40:20
Unlearning counter according OBD: 405456 - Starter Will Not Turn
Mileage: 186844 km
Date: 2008.05.27
Time: 00:56:05
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:08
Voltage terminal 30: 12.133 VUnlearning counter according OBD: 40
Mileage: 186792 km
Date: 2008.05.27
Time: 01:03:58
Mileage: 186792 km
Date: 2008.05.27
Time: 01:03:58
Mileage: 186792 km
Date: 2008.05.27
Time: 01:07:14
Mileage: 186792 km
Date: 2008.05.27
Time: 00:06:26
Mileage: 186792 km
Date: 2008.05.27
Time: 01:07:12
Mileage: 186792 kmDate: 2008.05.27
Time: 00:00:15
Mileage: 186792 km
Date: 2008.05.27
Time: 00:40:21
Mileage: 186800 km
Date: 2008.05.27
Time: 00:16:00
P0113 00 [10101111] - Signal too HighMIL ON - Confirmed - Tested Since Memory Clear
Mileage: 186854 km
Date: 2008.05.27
Time: 00:00:01
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:25
Mileage: 186792 km
Date: 2008.05.27
Time: 00:00:10
Ambient air pressure: 820 mbarVoltage terminal 30: 11.779 V
Mileage: 186792 km
Date: 2008.05.27
Time: 01:15:35
Monday,01,December,2025,18:00:25:10167VCDS Version: Release 25.3.2 (x64) Running on Windows 11 x64
Fault Codes have been Erased
Mileage: 186854 km
Date: 2008.05.27
Time: 00:21:04
No offense, but what a blizzard of text, I can't tell where it starts or stops. :eek:
Please repost your Auto-Scan ; and do not use the "print" tab , use the copy tab then follow these directions:
Bruce
Near Philadelphia, PA, USA
I edited it to make it more readable.
Do as you choose guys.
I have no advice to offer.
Reactions: Jef
Jef
HQ
.... IMHO... delete those Auto-Scans and repost them in the normal format that we are use to reading. VCDS automatically saves Auto-Scans. >> CLICK THIS LINK, SEE SECTION 3 << Find those clean text Auto-Scans and copy/paste them.
Please post one or more scans in a legible format. I don't know what you did to butcher them so badly -- all the leading white space / indentation is missing; every line has extra line breaks; the places where an extra line break is expected don't have them. This makes the ones you posted very difficult to read.
Go to your Scans sub-folder:
C:\Ross-Tech\VCDS\Scans\
There you will find every Auto-Scan you've ever done. Open the relevant one(s) with Notepad and Copy & Paste the contents here.
Reactions: Jef
rohana4b7
South Africa
C?ID=614161
my appologies, yes it just didnt want to upload from my phone, icloud is having poke at me will try again
rohana4b7
South Africa
C?ID=614161
still cant get the file format right?
rohana4b7
South Africa
C?ID=614161
ok I hope this work this time
so after wiring diagrams etc etc i opened all the looms and traced them back to the ecu, there i found three of them earth wires but still no earth so i ended up hard wiring an earth wire from that point just beffore the ecu connector to the local earth point for jump starting and VOILA THE SENSORS STARTED WORKING, but still epc and limp mode perstains with a bunch of other faults
Tuesday,16,December,2025,10:24:31:10167
2E-Media Player 3 -- Status: Malfunction 1010
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-V1.clb
   Part No SW: 8K2 907 115 AJ    HW: 8K2 907 115 D
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:21:51
                    Coolant temperature: 20  C
                    Intake air temperature: 26  C
                    Voltage terminal 30: 10.884 V
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:11:20
                    Intake air temperature: 25  C
                    Voltage terminal 30: 9.164 V
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [00100111] - Malfunction
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:33:57
                    Engine speed: 717.50 /min
                    Normed load value: 8.6 %
                    Coolant temperature: 66  C
                    Intake air temperature: 32  C
                    Voltage terminal 30: 12.792 V
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:21:51
                    Voltage terminal 30: 10.837 V
          P2004 00 [00100111] - Stuck Open
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:24:05
                    Engine speed: 379.00 /min
                    Normed load value: 33.7 %
                    Voltage terminal 30: 12.368 V
Readiness: 1110 0001
   Part No SW: 8K0 907 379 AC    HW: 8K0 907 379 AC
   Coding: 064500
   Shop #: WSC 06325 123 12345
                    Reset counter: 34
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:30:19
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x000A
                    Hex Value: 0x63A5
                    Hex Value: 0x00FF
                    Reset counter: 34
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:30:19
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0026
                    Hex Value: 0x23A5
                    Hex Value: 0x00FF
                    Reset counter: 34
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:30:19
                    Hex Value: 0x0000
                    Hex Value: 0x4782
                    Hex Value: 0x0016
                    Hex Value: 0x02A5
                    Hex Value: 0x00FF
   Coding: 031000
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Coding: 64060000
                    Fault Status: 01100010
                    Reset counter: 34
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:32:46
                    Temperature: 25.0 C
                    Temperature: 61.0 C
                    RPM: 680 /min
                    Current: 0.000 A
                    Temperature: 22.0 C
   Subsystem 1 - Part No SW: 8T2 955 119 C    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Coding: 00FD11
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
                    Reset counter: 35
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:35:00
   Serial number: 63732SME0D143820U
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 16:54:25
   Coding: 000016
            014 - Defective
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:44
                    (no units): 44.0
                    Power: -388.2 kW
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:50
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:17:27
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Coding: 000303
                    Reset counter: 34
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:11:05
02078 - Media Player Position 3 (R120)
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:00:05
01304 - Radio
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:00:05
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:32:54
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:32:55
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:19:08
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Revision: 00000000
   Coding: 020202
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:14:55
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:19:51
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:20:17
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:21:11
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
9 Faults Found:
                    Fault Frequency: 13
                    Reset counter: 73
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:44
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:14:45
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:14:45
            014 - Defective
                    Reset counter: 33
                    Mileage: 186857 km
                    Date: 2008.05.27
                    Time: 00:22:42
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2025.12.15
                    Time: 15:48:32
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2025.12.15
                    Time: 15:48:32
03123 - Terminal 30 - 2
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:14:25
03124 - Terminal 30 - 3
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:14:25
00926 - Terminal 30
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 00:14:25
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Revision: S2100000
   Coding: 0203010102
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.29
                    Time: 20:54:52
                    Voltage: 11.90 V
                    Temperature: 23.0 C
                    Bin. Bits: 00000001
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.29
                    Time: 20:54:52
                    Voltage: 11.90 V
                    Temperature: 23.0 C
                    Bin. Bits: 00000001
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:21:46
                    Voltage: 8.40 V
                    Temperature: 40.0 C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2025.12.15
                    Time: 15:36:20
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:20:55
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:44
                    Voltage: 13.30 V
                    Count: 58
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:21:38
                    Voltage: 8.40 V
                    Count: 44
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0000001
                    Fault Status: 11100101
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:45
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:45
            000 - - - MIL ON
                    Reset counter: 32
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:45
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:18:55
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
                    Reset counter: 34
                    Mileage: 186854 km
                    Date: 2008.05.27
                    Time: 00:07:46
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:17:08
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:17:58
   Coding: 0010390
                    Reset counter: 74
                    Mileage: 186858 km
                    Date: 2008.05.27
                    Time: 17:20:29
End----------(Elapsed Time: 01:37, VBatt start/end: 13.1V/13.1V)-----------
------------------------------48 Faults Found------------------------------
rohana4b7
South Africa
C?ID=614161
so alot of
problems fixing first had to install a new serpentine belt then tried starting but to no avail, i had a look at the accelerator pedal voltages and only have volts 0.7mV on line one and zero on two could this be the smoking gun?
rohana4b7
South Africa
C?ID=614161
fixed😁
that accelerator pedal was acting up so i got a revised second hand one and it started in one sec after installation
so the peddle has two measurement systems, hall effect at rest or idle no 1 should read about 0.735 mV
and no 2 to read half that at about 0.369mV
and the should always stay in lock step with each other reaching about 4.5 and 2.25mV respectively
this pedal had the power to pull down all the sensors on its line making the car seem dead butall it did was cut fuel and spark to the engine due to a mismatch or rather i should say a dead short or open line on no 2 sensor
leason learned
know all sensors assosiated on a lne and sometimes the answer is right at your feet😁
hope this helps anybody in the future
cheers!
