VW Polo V 6R1 / 2011 / 105hp / CBZB EA111.
I bought the car with engine failure, broken pistons cylinder 3 and 4.
No codes in VCDS after rebuild.
The problem is that the car dont start, it cranks but does not fire and idle. It like there is a fuel delivery problem.
After cranking I do see white smoke in the tailpipe and inside the cylinders if i remove the sparks.
Done and checked so far:
* Honed cylinders.
* Changed all Pistons, rings, bearings and timing components within the specs from the VW workshop manual.
* Checked compression after rebuild (about 12,2 bar on all cylinders.
* Timing is good, checked and re-checked with cam-lock tools and gauge to check TDC.
* Injectors checked by a company and tested spray-pattern = all good.
* Sparks and Coil changed and checked with stroboscope light.
* All sparks get wet in the cylinders.
* Pressuretestet the coolent system @ 1bar in 1hour, no drop.
* check fuelsystem (about 5bar LP and 100bar HPFP with gauge)
* Swapped HPFP to a spare I had, same result (swapped back to original)
* LPPF seems OK, it pumps.
* Drained the fueltank and draind the system and put new fuel in and primed.
Please help, I'm lost...
* Honed cylinders.
Sunday,07,December,2025,21:05:41:33748
VCDS Version: 25.3.1.1 (x64)
Data version: 20250415 DS365.0
VIN: WVWZZZ6RZBY031471 License Plate: RKPOLO
Mileage: 145290km-90279mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY031471 Mileage: 145290km-90279miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 E HW: 03F 906 070 D
Component: SIMOS10.20H02 9856
Revision: -------- Serial number: CVN: 1A3D7AC9
Coding: 002500D6200400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM12TFS02103F906070E 003013
ROD: EV_ECM12TFS02103F906070BQ_003.rod
VCID: 2447E5A42F582BBB8E-8070
VINID: 9E69EAAAA1A2A92A400C110704B2D0CCEA
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 Q HW: 0AM 927 769 D
Component: GSG DSG AG7 403 9060
Revision: 00040034 Serial number: CU501006045934
Shop #: WSC 35401 001 1048576
VCID: 377D22E845CE50233B-5106
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417000B3842914E982D200401300
Shop #: WSC 80093 222 69422
VCID: 06039F2CB5A4F9ABF0-8052
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 Climatronic H08 03050305
Revision: V0000000
VCID: 326B13FC6DACB50B0C-8066
No Faults Found
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 168105340
Coding: 24B02BBF08A10000003806007C2B0DD00040410F60840000200000000000
Shop #: WSC 12345 123 61029
VCID: 408F4934D300179B8A-8014
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU010.06.1015883
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU001.06.1012791
Coding: 08BC30
Subsystem 3 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0001444
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU029.05.1012091
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU028.05.1013140
Coding: 08BC32
Reset counter: 253
Mileage: 145293 km
Date: 2020.04.29.
Time: 02:22:25
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag00K H09 0020
Revision: -------- Serial number: 003GY000GDEA Dataset Number: v00304986R0 0001
Coding: 00304B
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4B956E18E246C4C36F-801E
Serial number: 3572SRB40000BBC0B8EP
Serial number: 3582SRB40000BBA4C8CR
Serial number: 3515RRB40556R0C2A1K%
Serial number: 3525RRB40596R0C258M8
Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
Component: KOMBI H04 0304
Coding: 140E00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
VCID: 377D22E88ECE50233B-8062
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 002200
VCID: 70EFD9F4A320C71B3A-8024
Component: IMMO H04 0304
VCID: 6ADBCB9C8DFC3DCB74-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6D1A88EA9E98E363-807A
Address 56: Radio
End-------------------------(Elapsed Time: 03:04)--------------------------
-------------------------------1 Fault Found-------------------------------
Surely you do not need it spelt out for you ? I assume you know the smell of petrol ?
