Bought another headache. Maybe!!
Welder75
Canada
C?ID=261654
So, i couldn't resist. after fixing 2 New Beetles using my VCDS, i had to fix another one. Am addicted.:D
I wasn't looking for another NB, was looking to get a Audi or VW passat/jetta. but then this NB showed up in my search results. (That is a VW/audi newer then year 2000, under 200,000km and under $2000.)
found this: 2002 VW NB 2.0L 5-speed. sunroof, foglights, heated cloth seats, few small scratches in the paint, they had 3M gaurd put on the hood, bumpers, fenders. 183000kms for $1800.
phone the guy and the story goes like this, they had the car since 2007, had a few issues with it last year, the airbag light started blinking on for a while then goes out, dealer said don't worry about it they check and everythings is working fine. So, that worried him a bit. Last month , the wife went shopping and after the car wouldn't start. They ended up getting it towed home. the car when boosted would run for 5 secs then shut off. So he would get up his driveway a bit, then have to boost it again until he got it parked in the garage. they replaced the battery, same issue, start and shut off. replaced the alternator, same issue starts then stops. So it sat in the garage for for a month. they are selling the house and wanted it gone.
"Well,it sounds serious, would you take $1400 cash? i can be there tomorrow morning!" :DThe car is in my drive way.
Now the fun starts.
i did a auto-scan at the guys house, we had to hook up booster cables to his other car, the battery was dead from his kids playing in the garage and leaving the car doors open. i had to know what the auto scan said......:p
Saturday,06,February,2016,13:35:52:49733
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWCB21C02M434363   License Plate:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCB21C02M434363   Mileage: 183360km-113934miles
Address 01: Engine        Labels: 06A-906-032-AZG.clb
   Part No: 06A 906 032 GE
   Component: 2.0l R4/2V      G   4075
   Coding: 00001
   Shop #: WSC 91518
   VCID: 67DDE6B605AF9106D0-5140
   3VWCB21C02M434363     VWZ5Z0ZD051284
16804 - Catalyst System; Bank 1
            P0420 - 35-10 - Efficiency Below Threshold - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
            P1296 - 35-10 -  - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
16705 - Engine Speed Sensor (G28)
            P0321 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0004097
   Shop #: WSC 00066 000 00000
   VCID: 316948EEABEB1FB6CE-5140
   Part No: 1C0 909 605 A
   Component: 25 AIRBAG VW51 0E   0004
   Coding: 12853
   Shop #: WSC 00066
   VCID: 224BB7A2AE0DB42E47-4B00
01218 - Side Airbag Igniter; Passenger Side (N200)
            32-10 - Resistance Too High - Intermittent
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 851 CX
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 03332
   Shop #: WSC 91518
   VCID: 78FFB5CA58110EFE49-4B00
01039 - Coolant Temperature Sensor (G2)
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 91518
   VCID: 70EF8DEA306156BE81-4B00
   Part No: 1C0 959 799 G
   Component: 2K Komfortgerát HLO 0004
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B756AC629A7E5E664-4AE8
   Subsystem 1 - Part No: 1C2959802A
   Component: 2K Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801A
   Component: 2K Tõrsteuer.BF KLO 0002
8 Faults Found:
            52-10 - Supply Voltage Too High - Intermittent
            54-10 - Incorrectly Equipped - Intermittent
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
            35-00 -  -
End-------------------------(Elapsed Time: 04:19)--------------------------
WOW... do i have a mess here!:facepalm:
but i have a smile all the way home:D , all codes were "Intermittent"
Got home, unloaded the car. Installed a charge battery i had in my shed.
hooked up VCDS cleared all the codes.
turned ignition off for 30 sec, turn key to "on" , started VCDS, did another auto scan before running engine.
Saturday,06,February,2016,18:22:23:49733
   Coding: 00001
   Shop #: WSC 91518
Readiness: 0110 1101
   Coding: 0004097
   Coding: 12853
   Shop #: WSC 00066
   Coding: 03332
   Shop #: WSC 91518
   VCID: 78FFB5CA58110EFE49-4AE8
   Coding: 00006
   Shop #: WSC 91518
   VCID: 70EF8DEA306156BE81-4AE8
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B756AC629A7E5E664-4B00
End-------------------------(Elapsed Time: 04:37)--------------------------
:cool: :thumbs:
started car, stayed running, no lights flashing at me!!! is this a case of "if its to good to be true....?" my thoughts are they may have had a issue with the battery or alternator, but they never cleared the codes after replacing with new parts. thus still having the same issues. any other thoughts?
i looked at the MVB for coolant temp, it was registering a temp. I didn't let the car warm up fully, encase maybe the car is out of coolant.
Before you say anything.....YES.... the radio is not working, i haven't gone through the fuses yet. will do a good looking over tomorrow. check fluid, fuses, brakes, looks like some goo on the fuse box above the battery. have to investigate to see if it has been overheating.
thanks for reading. if any issues surface i will update.
Gone But Not Forgotten
Check the back of cluster for coolant or the car for any other water ingress causing corrosion.
Keep an eye on G28 and check it out visual + with meter.
No surprise the front valance is smiling.............
Buy in satin black to avoid paint or the one without fogs to delete them on the cheap.
Welder75
Canada
C?ID=261654
I knew it. to good to be true. checked fluids today. coolant reserve was low. topped it up.
started car. let it run for 5 mins. everything was good.
lets check the lights out..turned on headlights... bing bing ...flash flash...:banghead:
short in the lighting system, i noticed headlight on passenger side is out.(fishy after just putting in coolant and a bit of it spilled) investigation following.
RTFB. WD from switch to headlight
faults in gateway and instrument now
also turn signals and emergrncy flashers not working. fuses are good. hear a click in the flasher switch relay when i use signal lights. i lightly push in flasher switch and hold just before it engages, the flashers work for a few seconds. bad switch.
Sunday,07,February,2016,13:14:44:49733
   Coding: 00001
   Shop #: WSC 91518
   Coding: 0004097
   Coding: 12853
   Shop #: WSC 00066
   Coding: 03332
   Shop #: WSC 91518
   Coding: 00006
   Shop #: WSC 91518
   VCID: 70EF8DEA306156BE81-4B1A
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B756AC629A7E5E664-4B1A
End-------------------------(Elapsed Time: 04:18)--------------------------
i am going to replace head lamp and check wiring, replace any fuses and try try again.
tyroneturbos
C?ID=233767 (NRRT)
I try to avoid headaches but with my occupation its sometimes unavoidable but you sir go and find them lol
Good Luck with the car :)
Welder75
Canada
C?ID=261654
So....in the end... besides putting in a charged battery and clearing the fault codes...i topped up the coolant, replaced head lamp for the passenger side low beam. replaced flasher relay today now the turn signals and flashers work again. Replaced the 2 door speakers and the 2 rear speakers because 3 of them shit the bed.
This car is good to go. front brakes were new, rear is about 50%. timing belt and water pump were replace 40,000kms ago. :thumbs:
