- Nov 1, 2023
- 7
- 1
- Atlanta, GA, USA
- C?ID=538410
Hello all, I'm hoping someone can assist with a problem I'm having.
The Vehicle is a 2003 VW Eurovan- Vin: WV2NB47063H016966
We had a problem with the ecu and sent it out for repair. Unfortunately it wasn't able to be repaired and a replacement was sourced. When trying to get an autoscan it says "Function not supported by the Gateway". I am able to access the different modules individually. I'm trying to "align" the new ecu with the cluster, immobilizer and abs module. Vehicle runs for split second and shuts off.
Fault Codes in immobilizer are
"01314 Engine control module 65-10 UnAuthorized - Intermittent"
"01202 - Diagnostic Cable 44-10 - Short Circut Intermittent"
Fault Codes in ECU
" 18058 - Powertrain Data Bus P1650 - 35-00 Missing Message From Instrument Cluster"
"18057 Power Train Data Bus P1649-35-00 Missing Message From ABS Controller"
"17978 Engine Start Blocked By Immobilizer P1570 - 35-00"
Engine CH91 = 4
Do I need login code to access adaptations menu; if so how can I find it?
Thanks ahead for any help, its much appreciated.
Fault Codes in ECU
Engine CH91 = 4
