No Response from Module
fabltd
C?ID=242094
Hi
I have been trying to get a module working 6C Back-up Cam.
VCDS just reports No Response from Controller.
I have added a CAN Sniffer to the infotainment bus and I can see when VCDS trys to connect it sends:
ID=512(DEC), Data=49C00010000301
The module responds:
ID=585(DEC), Data=00D7F876FC0401
I can varify the module is reponding because if I unplug it ID 585 does not appear.
I have had the theroy that becuase this is on the bench Terminal 15 is missing. The Can GW reports T15 voltage I am unsure if its reporting T15 on the CAN Bus.
This modue is from a PQ35 car ( Audi TT 8J)
I have conflicting information though as to how to varify if this is the case.
I would appricate if any one has sniffed the infotainment bus.
Thank you
Somehow, I don't think this is Product Support.
For one thing, your question is utterly devoid of context.
And what kind of car is it in now? Or is there no car at all and you have some kind of test bench?
fabltd
C?ID=242094
My Applogies
This is on our test bench. We have the module and a Can Gatway connected to VCDS.
I am simply unable to connect to the module from VCDS and lack any further reason as to why it is not responding. When I can see a response from the module when sniffing the CAN Bus.
Is there any more Verbose logging in VCDS other than just "Not Responding"
What kind of CAN Gateway?
Are you sure the Infotainment bus is the correct one for this?
Some modules require a "virtual" terminal 15 via CAN messages; these usually come from some other module, not the Gateway. Exactly which module varies depending on the car.
fabltd
C?ID=242094
Hi
Yes can Gateway also from TT 8J - " Some modules require a "virtual" terminal 15 via CAN messages; these usually come from some other module, not the Gateway" I think this maybe my issue. I have ordered a Steering colum module with key to see if I can find the missing virtual Terminal 15.
Is there any way to check for virtual T15 ?
I don't know. Traffic on the internal CAN buses is not something we normally concern ourselves with.
fabltd
C?ID=242094
Hi
So I have verified T15 and I can see the can message for this 0x2C3.
I am still not getting a response from the module.
The Gateway is coded. The module appeats to respond as above but VCDS still refuses to communicate.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
VCDS doesn't refuse things. The module in your specific setup might due to the circumstances you created. As I mentioned in your other thread (which you neglected to mention here), your setup (vehicle side) is unsupported and we will not assist with this any further. This is not a VCDS problem/topic related to our product and/or vehicle support diagnostic wide. You are retrofitting something never meant to be in your specific car/setup.
fabltd
C?ID=242094
Thank you for your not so helpfull response.
I am simply trying to understand why a CAN bus message that returns to VCDS does not appear to result in a connection.
I shall give up posting here as there appears to be a very negative approch.
