Hi all,
I cannot match the key to cluster from Passat B5 FL on the bench (I'm doing little project and there is no car, just parts connected together).
I have PIN from this cluster and new transponder but when I enter the numbers of keys i get ERROR in test field.
MVB says that the transponder is good to be programmed, there is no lockout time neither, fixed and variable code values are 0, and immo status is 6.
Also I can remove key from coil and cluster is not showing any changes until I cycle the power OFF and ON.
Any ideas what makes the key matching not possible when cluster is removed out of the car??
