- May 19, 2017
- 65
- 14
- Luxembourg
- C?ID=306473
Hi
Had 2 injectors failure, (1 & 4) - CR didn't go over 1100hpa pressure.
Friendly workshop replaced HPFP, CR sensor, CR pressure regulator and 2 injectors...
Now I have
Did read this:
forums.ross-tech.com
Any other suggestions ?
Now I have
Address 01: Engine (J623-DAVA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SH HW: 04L 907 445 P
Component: R4 2.0l BTD H01 9973
Revision: 23203001
Coding: 002A403C6374050800000000000000000000000000000000
Shop #: WSC 37739 004 1048576
ASAM Dataset: EV_ECM20BTD03004L906056SH 007006
ROD: EV_ECM20BTD030_VN54.rod
VCID: 055498BDF5AA3C52805-8050
VINID: 9E606AAAA8E9A9E2400070C7006C6B64A5
32110 - Particulate Filter (Bank 1)
P226D 00 [11101100] - Damaged or Substrate Missing
Mileage: 103815 km
Date: 2025.12.06
Time: 16:52:22
Engine speed: 1727.75 /min
Vehicle speed: 87 km/h
Coolant temperature: 90 C
Intake air temperature: 9 C
Ambient air pressure: 890 mbar
Voltage terminal 30: 14.500 V
Particle sensor: time in op. mode measurement: 0.0 s
Particle sensor: measuring current calculated: 0.0 A
Particle sensor: cleaning deviation reaction time: 0.631
Particle sensor: exhaust temperature: 16.5 C
Particulate sensor: status condition automation: Regeneration following soot particles plausibility check
Particulate sensor: status condition automation: 4
Readiness: N/A
Did read this:
VW T6 2018, excessive soot after HPFP repair
VW T6 2018, 100k km total distance on my own, 2 months ago it stoped working on some cylinders, then return to normal work, and after 500km stoped again. Checking components, appear metal filings in injectors, HPFP failure. - replaced HPFP - replaced CR with valve and sensor - flushed all pipes...
