Audi A3 8V TPMS Retrofit
Kiaran
C?ID=616126
Im looking at retrofitting an TPMS system in my 2014 Audi A3 and was just wondering if anyone had an tips for me. i did find all the coding i needed but have lost it
Westbury, UK
I assume you mean direct TPMS with wheel pressure sensors?
Difficult to advise without knowing how your A3 is configured, so please post an Auto-Scan.
2kaa52
Ceska Republica, Praha
C?ID=319193
Tip 1: Post a complete unedited Autoscan
Kiaran
C?ID=616126
yeah its going to be direct.
im just waiting for a new vcds to be delivered as someone robbed it out my shed should be here in a few days. ill post one it arrives
If that did occur, you can report the SN here to the Administrator and they can deactivate that interface.
(note: if it was a genuine RT VCDS).
Kiaran
C?ID=616126
Thank you for the advice and I don’t have the s/n as I got it secondhand and they can’t use it anyways as all the vins have been used up
golfi_vend
Tartu, Estonia
C?ID=195131
Kiaran
C?ID=616126
Tuesday,09,December,2025,16:17:48:52289
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4660.5
VIN: WAUZZZ8V7EA045422   License Plate:
Mileage: 157739km-98014mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7EA045422   Mileage: 157739km-98014miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X22 5520
   Revision: 83X22---    CVN: 4B545CBB
   Coding: 021D0012032501082000
   Shop #: WSC 54927 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002_AU37.rod
   VCID: 7AAA2C9EAC539DCA41F-802E
   VINID: 9D196AAAA2261D544010510208A5A17504
   Part No SW: 0D9 300 040 K    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4028
   Revision: 05652104    Serial number: TFK01307021761 CVN: 0000D49B
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1C3D0A573118E2161-804A
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
   Revision: 00000000    Serial number: 62033000000B53
   Coding: 10F18AA224240A71017B060241C5290851245080608294F2026100080508
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 7BA4299AA369A4C25A9-802E
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H13 0031
   Revision: 20023000    Serial number: 00000000122200
   Coding: 00100104002000011000000000001100
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FBC0DCAE711C862E61-803A
   Humidity sensor: exterior:
   Serial number: 70280EB6000000000001
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011320500084 Dataset Number: 8V0909514C  0063
   Coding: 07001A42C20120DD03044004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77AC35AA9F4180A23E1-8022
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130705  041 0580
   Serial number:         130717150813
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
   Serial number: 11 05 2013  00000508
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY131754BYR
   Serial number: 00000000000057373990
   Humidity sensor: interior:
   Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20441161
          B1263 01 [009] - Electrical Failure
                    Reset counter: 71
                    Mileage: 157525 km
                    Date: 2025.11.28
                    Time: 15:39:18
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: g ltiges Funktelegramm
                    Voltage: 12.5 V
                    Outside temperature: 7.5  C
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831321002292 Dataset Number: 8V0909526C  0034
   Coding: 0000040011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 382EF696D2DF4FDAF7B-806C
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER016CSL Dataset Number: 8V0909602A  0027
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 49C88352B935C652985-801C
   Subsystem 1 - Part No SW: -----------    HW: 480 002 507 13
   Serial number: 35767000000B036CCC0+
   Subsystem 2 - Part No SW: -----------    HW: 480 002 507 13
   Serial number: 358670000008407CCC0+
   Subsystem 3 - Part No SW: -----------    HW: 480 402 507 13
   Serial number: 3516502B11074481534S
   Subsystem 4 - Part No SW: -----------    HW: 480 402 507 13
   Serial number: 3526502AD1074483E078
   Subsystem 5 - Part No SW: -----------    HW: 480 402 906 13
   Serial number: 3556502B1106FA45D129
   Subsystem 6 - Part No SW: -----------    HW: 480 401 307 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C1107DB55B25C
   Subsystem 7 - Part No SW: -----------    HW: 480 401 307 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502C3107DB556205
   Subsystem 8 - Part No SW: -----------    HW: 480 401 307 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 23065029D106FA40C2FJ
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 25071304400489 Dataset Number: ----------
   Coding: A418
   ROD: EV_SMLSKLOMQB_009.rod
   Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
   Component: KOMBI         H03 2211
   Coding: 27A401082A8046000100E800000000
   VCID: 47CC856AAF2130228E1-8012
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000793659 Dataset Number: 8V0909515C  0044
   Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
   GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B24E99AE3E964C21A9-806E
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 19 07 2013  D0272743
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051735651
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 13071301100373 Dataset Number: 8V0909872D  0025
   Coding: 00100E204001040100001002
   VCID: 3D20E782FDFD6AF224D-8068
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Dataset Number: 8V0909852F  0015
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 06071301100840 Dataset Number: 8V0909873D  0024
   Coding: 001006204001040100001002
   VCID: 3C26EA86E6E763FA133-8068
   Component: LWR-ECU       005 0070
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865E  0029
   Coding: 019C000001000000
   VCID: 75B03FA2854DF2B22CD-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 A    HW: 8V0 035 874
   Component: MU-S-ND-ER    040 0370
   Serial number: A7F02907130607 Dataset Number: 8V1909545A  0028
   Coding: 01730001FF00000021111101000A00002F0004460100010006
   Shop #: WSC 10621 001 1048576
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3A2AEC9EECD35DCA01F-806E
   Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
   Component:  ECE 2014  --- 0036
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DG602CWH
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000005071300020369
End----------(Elapsed Time: 01:33, VBatt start/end: 14.8V/14.8V)-----------
Kiaran
C?ID=616126
   Coding: 0A47F7
                    Reset counter: 71
                    Mileage: 157525 km
                    Date: 2025.11.28
                    Time: 15:39:18
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.5 V
   Coding: 0000040011
   Coding: A418
   Generator:
   Coding: 81
Kiaran
C?ID=616126
JUST AN UPDATE
i Have had my MIB1 upgraded to an MIB2 HIGH as i found out the TPMS wont work on MIB1 is it still possable to put TMPS in
Monday,22,December,2025,17:20:45:52289
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
Mileage: 158011km-98183mi   Repair Order:
VIN: WAUZZZ8V7EA045422   Mileage: 158011km-98183miles
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AAA2C9EAC539DCAC07-802E
   VCID: 1F1C3D0A573118E2979-804A
   VCID: 7BA4299AA369A4C2DB1-802E
   VCID: 6FBC0DCAE711C862679-803A
   VCID: 77AC35AA9F4180A2BF9-8022
   Coding: 0A47F7
   Coding: 0000040011
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 382EF696D2DF4FDA763-806C
   VCID: 49C88352B935C65219D-801C
   Coding: A418
   VCID: 47CC856AAF2130220F9-8012
   VCID: 3B24E99AE3E964C29B1-806E
   Generator:
   VCID: 3D20E782FDFD6AF2A55-8068
   Coding: 81
   VCID: 3C26EA86E6E763FA92B-8068
   ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
   VCID: 75B03FA2854DF2B2AD5-8020
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 035 B    HW: 8V1 035 035
   Component: MU-P-LND-EU   054 1106
   Serial number: A698H0H2529872 Dataset Number: 8V2909545Q  0027
   Coding: 01736001FF00000011111101000A00002F0026C701700100DE
   Shop #: WSC 02343 210 576921
   VCID: 3138CBB231A59E9231D-8064
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Multimedia display unit 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY202VKJ
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL110111600010045
   Compact disc data bank:
   Component: Gracenote2  --- 1016
1600 - Data Set Implausible
          B2012 00 [00001001] - -
          [Control module (data record download) - implausible data record for sound audio parameters]
                    Reset counter: 97
                    Mileage: 158011 km
                    Date: 2025.12.22
                    Time: 17:17:52
                    Voltage terminal 30: 13.2 V
End----------(Elapsed Time: 01:29, VBatt start/end: 13.1V/13.1V)-----------
-------------------------------1 Fault Found-------------------------------
