- Feb 4, 2025
- 3
- 0
- Pembrokeshire, Wales
- C?ID=604205
First post - HI EVERYONE! Engine MIL appeared on my partners car yesterday (2025.12.06), I don't understand why the [01-Engine] and [AC-Reductant Control] Freeze Frames are dated 2025.12.03 and 2025.12.02 respectively. No other warning lights on the dashboard. We got the car in August 2025 and haven't been prompted to top of the DEF/AdBlue in the 4,000 miles or so she's done in it so far. Could the level just be low?
I was able to clear the Fault codes with only the [17-Instruments] 005 Fault re-appearing with the car idling in the driveway. I'm concious this could re-appear after taking the car for a drive.
Any suggestions on what to do/check next would be greatly appreciated.
Sunday,07,December,2025,10:43:42:62773
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: WAUZZZ8R3EA025462 License Plate:
Mileage: 172530km-107205mi Repair Order: EngineMIL
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
AC
VIN: WAUZZZ8R3EA025462 Mileage: 172530km-107205miles
04-Steering Angle -- Status: OK 0000Q
AC-Reductant Control -- Status: Malfunction 0010
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JN HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2929
Revision: 45H25--- CVN: 7201776F38D3FF82B09F27B7
Coding: 2A254012242601080000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JN 003003
ROD: EV_ECM20TDI01103L906018JN.rod
VCID: 7F5CDCDA97722FA2F79-802A
VINID: 9D196AAAA2220D5440085106081F69C42C
16925 - Reductant Level Sensor
P203B 00 [10101100] - Implausible Signal
Fault Frequency: 57
Mileage: 172185 km
Date: 2025.12.03
Time: 12:41:15
Engine speed: 1489.00 /min
Vehicle speed: 59 km/h
Coolant temperature: 78 C
Intake air temperature: 18 C
Voltage terminal 30: 14.420 V
Outside temperature: 10.0 C
Pressure sensor for reducing agent: measured pressure: 4998 hPa
Sensor for reducing agent tank temperature: temperature: 11.4 C
Reducing agent pump: activation: 50.00 %
Sensor for reducing agent fill level: voltage: 13107.0 mV
Readiness: 1 1 0 0 0
Part No SW: 8R1 927 156 J HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H01 0002
Revision: --H01--- CVN: 00007DED
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 43D4902ABB1A8B42D31-8016
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AE HW: 8R0 907 379 AE
Component: ESP8 quattro H09 0030
Coding: 21154401
VCID: 0354502AFB1A4B42931-8056
Part No SW: 8K0 907 064 GG HW: 8K0 907 064 FG
Component: BCM2 2.0 H12 0633
Coding: 01B54040000000000000
VCID: 7BA428CA83EA3382DB1-802E
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0513000049000021
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000131686006
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 AH HW: 8K2 820 043 AH
Revision: D0000000 Serial number: 01150720132507
Coding: 342502E000
VCID: 6FBC0C9AC7925F22679-803A
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000651468502
Coding: 260000108034AFE01781400000001D0D009D470827090201000008004400030100000024000000
Shop #: WSC 06335 123 12345
VCID: 77AC34FABFC217E2BF9-8022
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130708 H11 0050
Serial number: 90243015130625180058
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21549065
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001107130766
Serial number: 9809CAB6000000000001
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H47 0610
Serial number: 003JPDB0B8EI Dataset Number: 8R0909602E 0010
Coding: 30473431313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48CE8706823CA81A063-801C
Serial number: 6334MSME7C0617118
Serial number: 6344MSME7D233319F
Serial number: 6352QSME7B315772K
Serial number: 6362QSME65343D56N
Serial number: 63732SME28330674W
Serial number: 63832SME28330144P
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862MGI000YH
Coding: 000037
VCID: 48CE870682BCA81A063-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 P HW: 8R0 920 981 P
Component: KOMBIINSTR. H35 0563
Revision: 00300000 Serial number: WX930MG7E
Coding: 33AF220002012600010000
VCID: 47CC843A8FA2A7620F9-8012
00003 - Control Module
Fault Status: 01100101
Reset counter: 202
Mileage: 167698 km
Date: 2025.08.12
Time: 15:05:52
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y137040022
Coding: 80CF07FF00
VCID: 4ACABD0E9CB05A0A107-801E
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 40186C09161461703957
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13196000936011200181
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000068025962
Coding: 011002204001440004
VCID: 50FEAF667AEC60DA5E3-8004
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H38 0507
Revision: 00001000 Serial number: 0010662408 Dataset Number: 8R0909852H 0021
Coding: 100000010001
Shop #: WSC 06334 123 12345
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B24E8CAC3EAF3829B1-806E
18689 - Terminal 30
U140A 00 [00001000] - Open Circuit
[Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
Fault Frequency: 94
Reset counter: 163
Mileage: 168589 km
Date: 2025.09.17
Time: 10:07:55
0.20 V
Revision: 00002001 Serial number: 0311751692
Coding: 013B0622A0B930148420053680040047
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000068027734
Coding: 011002204401440004
VCID: 4FFCAC1A67D27F22479-801A
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 20000000307394 Dataset Number: 8R0909522A 0002
ROD: EV_ParkiBrake_AU48.rod
VCID: 3928F2C2C9D6C19289D-806C
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109GP0D7700500
Coding: 010103020100000001
VCID: 261229BE28E85E6AD4F-8072
Part No SW: 8R2 035 666 F HW: 8R2 035 666 C
Component: H-BN-EU H46 0739
Revision: -------- Serial number: 206GY0D7534128
Coding: 16010106000581ED05808B5E00000403E40000020000000000
VCID: 3C26EBD6C664F4BA92B-8068
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Component: DU7 High H42 0104
Serial number: A130G 0D2785943
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000001567395
Component: CD-Database 5298
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000068411342
Coding: 010002204001240004
VCID: 46D2893E88A8BE6AF4F-8012
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B24E8CAC36AF3829B1-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000068411344
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 131650071 Dataset Number: 8R0909571D 0014
ROD: EV_RDCMA00100.rod
VCID: 2B04D88A338A63020B1-807E
65543 - Reductant Level Sensor
P203B 00 [00001000] - Implausible Signal
[SCR-Levelsensor AktivtankSignal Out of Range Wert unplausibel]
Reset counter: 164
Mileage: 172158 km
Date: 2025.12.02
Time: 17:38:36
Voltage terminal 30A: 14.7 V
Voltage terminal 30B: 14.7 V
Voltage terminal 87: 14.5 V
Reductant_pwm_duty_cycle: 22.5 %
Reductant_speed_pump_motor: 1408 /min
Reductant_pump_output_stage_temperature: 24 C
Reductant_heater_control_1_output_stage_temperature: 27 C
Reductant_tank_temperature_sensor_actual_value: 9 C
Reductant_temperature_ambient: 5 C
Reductant_current_pump_motor_A: 0.5 A
Reductant_current_pump_motor_B: 0.4 A
Reductant_current_pump_motor_C: 0.4 A
Reductant_heater_control_1_actual_power_value: 0.0 A
Reductant_heater_control_2_actual_power_value: 0.0 A
Reductant_transfer_pump_current: 0.0 A
Reductant_pressure_sensor_actual_value: 4950 mbar
Reductant_voltage_sensor_supply: 5.0 V
Reductant_voltage_sensor_gnd: 0.0 V
Reductant_level_sensor_actual_raw_voltage: 2.9 V
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: On
DIAG_Lines_L: On
DIAG_Tank_H: On
DIAG_Tank_L: On
MO_SCR_Dosierpumpe_Zustand: 03
MO_SCR_Tankheizung: OFF
MO_SCR_Leitungsheizung: OFF
MO_SCR_Transferpumpe: OFF
reserviert 1 0: On
Reserviert 2: OFF
Can signal MO_SCR_Dosierpumpe_Soll: 50.0 %
End----(Elapsed Time: 01:57, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
------------------------------4 Faults Found-------------------------------
