- Dec 16, 2014
- 11,141
- 10,400
- Westbury, UK
- C?ID=1423
You seriously expect us to read a huge impenetrable block of text like that? No way!!!i have and this is the result. however, prior to having the center bearing replaced, in the past it wasnt uncommon to for it to have a high def consumption code and def temp sensor code and ill be honest ive procrastinated replacing it because i knew that eventually we would be doing a diesel delete so ive put it off as long as i could , after they replaced the shaft bearing, [of which during they would hae had to remove and unplug the nox 2 sensor to drop exhaust for space to remove the driveshaft], is when the nox sensor problem started throwing codes, the egr codes are new ones that i will need to look into but im guessing the dpf has at minimum cracked cause i consistently wash away soot from the rear pipes/ rear hatch area at the carwash, which i visit normally a few times a month. i did a scr efficiency test and when i logged the nox sensors both sensors appeared to be responding including nox sensor 2, of which someone suggested that it was dead but it was showing feedback durig the scr efficiency test. it behaves like it could have some wirng issues which i understand is not uncommon amongst this model, thats not much issue for myself with my years of schooling to be an electrician. however a new problem has arose and im wondering if its related or part of the faults on the specific channels/lines but the infotainment screen has went black and is completley nonresponsive the CD thing in the glovebox responds when buttons pushed . theres an error on the optical bus that vcds says error on optical bus component instruments is all it says. ive pulled fuses and replaced em anyways, info screen is still dead. i have optical testing loops, im gonna test the amp unit thats in the hatch right hand side area. im more concerned though that, thats not where the problem is. and i only assume it is not because, a few months ago, i tried to turn on the rear wiper and it didnt respond until i got going down the road then blipped out mid way across the back glass so the arm got stuck mid stroke, my particularly orderly child noticed it and forced the arm down as he walked past the rear to enter the car [he dislikes things out of place] but that ended up fucking up the wiper motor so next time we got in the car and started it it started making this god awfully loud motor bind noise and would run until im guessing a timed relay shut it off and so i ordered a new wiper motor but ended up, just unplugging the broken one and tbh i forgot about it til now, but to the jist of what i am suspecting is there is a ground fault/failing/corroded somewhere in the rear right side because shortly after i unplugged the wiper motor, rear turn signal bulbs and reverse lights went dead, not all at once, but within a few days of each other. i noticed it was odd for the lights to do that but shelved the thought until today when my radio wouldnt come on or respond. looking from a big picture perspective of the culmunative problems, the suv appears to be having electrical faults particularly amongst components located partiularly along the right side of the vehicle. the rear camera has glitched a few times before and now vcds cannot comm with the camera as well so considering my background in electrical systems. this leads me to believe theres either power connection issues to these components. but most likely theres a grounding issue. anyone have copies of images of grounding locations among the right side of the suv? or any insight that i may have missed/oblivious to? but considering the issues with voltage and the codes being thrown on the controller, does anyone know or have pictures of where the wiring loom connection/junction points are on that side of the car?
You need to make use of the Enter key on your keyboard to break up your posts into separate blocks of text that we can read without getting eye strain.
Please help us to be able to help you...
