2002 Golf TDi - 1.9 ALH - 5 speed. Issue is a prolonged cranking time, but ONLY on the first start of the day. Occasionally will have a stutter upon starting, but once running it sounds good. Alternator, starter, glow plugs tested out ok at VW shop. PCV was replaced, new battery installed (after previous one failed after charging at NAPA). Only fault code is in the Autoscan below:
Address 01: Engine Labels: 038-906-012-AGR.clb
Control Module Part Number: 038 906 012 FD
Component and/or Version: 1,9l R4 EDC G000SG 4102
Software Coding: 00002
Work Shop Code: WSC 00001
VCID: 57EB7786661A38729F9-4B3D
17946 - Fuel Shutoff Solenoid (N109)
P1538 - 35-10 - Open or Short to Ground - Intermittent
Wiring appear solid at the solenoid valve - have not replaced the relay (yet). I need to procure a voltmeter to test for 12v at the solenoid.
My question:
1. Would this cause the symptoms I am having, or is this just coincidence?
My question:
