FUEL GUAGE STOPPED WORKING AFTER REMAP HELP REQUIRED ANYONE PLEASE??
KEENY
HUC-2H
MORNING ALL,
AFTER SOME ADVICE REGARDING FUEL GUAGE NOT WORKING AFTER REMAPPING A VW TRANSPORTER 2017 2.0 TDI WITH DELPHI DCM 6.2V ECU OBD VR FILE..
CUSTOMER CAME IN FOR REMAP ON THIS VEHICLE, HE HAD 1/4 TANK OF FUEL ON GUAGE BUT NOW SHOWING ZERO AFTER MAPPING VR FILE WITH AUTOTUNER ?
IVE DONE PLENTY OF THESE BEFORE NO PROBLEM BUT SOMEHOW THIS FILE GOT CORRUPTED SOMEHOW WHILST FLASHING OBD VR?
I HAVE INCLUDED LOG BUT WOULD ANYONE KNOW IF I CAN PATCH BACK WITH VCDS OR WHAT NEEDS TO BE DONE TO RESTORE GUAGE AGAIN ? IVE FLASHED ORI BACK TO TRY BUT SAME SCENARIO..
KEENY
HUC-2H
Tuesday,25,November,2025,16:24:00:62905
VCDS Version: 25.3.2.0 (x64)
VIN: WV2ZZZ7HZHH059342   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 5F 61
VIN: WV2ZZZ7HZHH059342   Mileage: 116780km-72563miles
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (2D2D2-CXFA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KH    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6184
   Revision: 23002001
   Coding: 0025401C430401080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KH 004013
   ROD: EV_ECM20TDI03004L906056KF.rod
   VCID: 7DF1A788EC04D773B8-8028
   VINID: 9E60AAAAA1D8A986001490C408CE689742
27277 - System Voltage
          P0562 00 [00100111] - Too Low
                    Date: 2000.01.00
                    Engine speed: 0.00 /min
                    Coolant temperature: 56 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 12.335 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 1.01 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.000 bar
                    Absolute intake pressure: 99 kPa abs
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 0
                    Index of next requested engine mode: 0
                    Index of engine target mode: 0
16289 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [00100111] - Malfunction / Open Circuit
                    Mileage: 116785 km
                    Date: 2103.01.02
                    Time: 13:44:27
                    Engine speed: 826.75 /min
                    Normed load value: 36.5 %
                    Coolant temperature: 55 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 13.304 V
                    Wraf state-Delphi Wraf State: WRAF_REF_CELL_STG_TEST
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
                    O2 sensor 1 bank 1 dwnstrm cat.: raw value: 10.000 counts
                    Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.: 0.000 A
                    Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor): 0.062 Lambda / 0.000 V
27101 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
          P2251 00 [00100111] - Open Circuit
                    Mileage: 116785 km
                    Date: 2103.01.02
                    Time: 13:44:05
                    Normed load value: 24.3 %
                    Coolant temperature: 50 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 14.593 V
                    Wraf state-Delphi Wraf State: WRAF_DISCHARGE_INPUT_CAP
Readiness: N/A
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5301
   Revision: 00H11V01    CVN: A5BFDF55
   ROD: EV_TCMDQ500021.rod
   VCID: 3D716788AC841773F8-8068
   Revision: 00000000    Serial number: 42556000001095
   Coding: 347E4098656784872C78027AA68421D3790000
   Shop #: WSC 02739 790 50316
   VCID: 3F8D1D80A6880563EA-806A
0397 - TPMS Warning
          C102D F0 [10001001] - Pressure Loss
                    Reset counter: 190
                    Mileage: 116785 km
                    Date: 2025.11.25.
                    Time: 13:43:01
   Serial number: 05091613470118
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF3A084E102CC6BA1-802A
   Part No SW: 7E0 907 047 AH    HW: 7E0 907 047 AH
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 70EF8EBCAB56AA1B23-8024
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 267160696
   Coding: A0FCF93A0A613493922849646C2B8CD48D20698960CC4960320400BF0800
   Shop #: WSC 22234 221 23456
   VCID: 2A5B5CD4450A90CBAD-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU014091662583758
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU013091662578169
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 7E1 951 171
   Subsystem 6 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160000320320026063
   Coding: A40000
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261620001184
   Coding: 108108
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71E98BB8A05CA3132C-8024
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01S H08 0018
   Revision: --------    Serial number: 003V400198MZ Dataset Number: 7E0003V____ 0909
   Coding: 000000000000000000000000000000003153
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3B756990B2901943C6-806E
   Serial number: 3495ZRB400M571NGMOKN
   Serial number: 3505ZRB401C579DAB9NI
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Coding: 440F010300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 3A7B6C94BDAA204BDD-806E
13654544 - Databus
                    Reset counter: 190
                    Mileage: 116785 km
                    Date: 2025.11.25.
                    Time: 13:43:01
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
   Component: STH-T5GP2     003 0009
   Coding: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B5559D042F089C356-807E
0036 - Fuel Level too Low
          P1250 00 [00001000] - -
                    Reset counter: 230
                    Mileage: 116785 km
                    Date: 2025.11.25.
                    Time: 00:00:46
                    Parking heater: operating condition: OFF
                    71
                    Coolant temperature of parking heater: 53 °C
                    Engine running status: detected
                    Fuel level: 3 l
                    Heating performance: 0 W
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 68DFE6DC9B8662DB7B-803C
                    Reset counter: 230
                    Mileage: 116785 km
                    Date: 2020.04.17.
                    Time: 12:24:19
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 187
                    Mileage: 116769 km
                    Date: 2020.03.01.
                    Time: 06:56:48
   Component: IMMO          H03 1104
   VCID: 6ADB9CD48D8A50CB6D-803E
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
End-------------------------(Elapsed Time: 03:33)--------------------------
------------------------------8 Faults Found-------------------------------
Spacewalker
Poland
C?ID=159607
MORNING ALL,
wow...... really need SCREAMING with CapsLock ? we not blind
1 - update your VCDS device
2 - cluster no need ECU to show fuel level, simple look drawing to see where fuel sender is going to
3 - webasto is taking fuel level from cluster, because cluster broadcasting fuel leevel over CAN
hope that help
2kaa52
Ceska Republica, Praha
C?ID=319193
MORNING ALL,
VR Files Always a surprise 😏
Dr Sheldon
Windsor UK
C?ID=334979
Look at the data in Instrument Cluster
