C7 s6 image processing cannot be reached
blackstage2
Massachusetts, USA
chasing a no acc and audi brake guard issue. Just bought this 13 s6 and have been sorting some issues. The problems im having dont seem to be the common issue of the camera module failing.
I have 2 codes im chasing and both say no communication. When using vcds i cant communicate with the image processing module. The codes i pulled from the CAN network.
85-On Board Cam. -- Status: Cannot be reached 0100
8E-Image Processing -- Status: Cannot be reached 0100
4888 - Camera control module
          U107A 00 [00001001] - No communication
                    Reset counter: 223
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:43:05
                    Voltage terminal 30: 14.4 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 16 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
6653 - Image processing control module
          U1079 00 [00001001] - No communication
                    Reset counter: 223
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:43:05
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
davisev5225
C?ID=263265
Please post a full, unedited auto-scan.
blackstage2
Massachusetts, USA
Sunday,30,November,2025,18:42:39:11930
VCDS Version: 25.3.2.0 (x64)
VIN: WAUF2AFCXDN041589   License Plate:
Mileage: 174725km-108569mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2834 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUF2AFCXDN041589   Mileage: 174725km-108569miles
Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H61 0009
   Revision: NCH61---    CVN: 5C6E6329
   Coding: 0A2500326546000E1000
   Shop #: WSC 82976 802 690857
   ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
   ROD: EV_ECM40TFS0114G0906014B.rod
   VCID: 2149064A30E77093FC-8074
   VINID: 9D1956091593A14780101148249B82B400
Readiness: 1100 1100
   Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
   Component: 0B5 40TFSINAR H01 0014
   Revision: --H01---    CVN: 0000A73D
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001025
   ROD: EV_TCMDL501021.rod
   VCID: 3D71DA3AAC5F3473F8-8068
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 65B64F01A66DF2804B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 387FCB2E837D115B2B-806C
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Coding: 0D882006000000000000
   VCID: 7BF51422FACBFA4386-802E
   Serial number: 2312000163235011
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 26071200041648
   Coding: 688120B84D
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 62CB494675612B8BA5-8036
0369 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:56:26
                    Voltage terminal 30: 14.60 V
                    Outside temperature: 7.0 °C
                    Engine speed: 661 /min
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001388305
   Coding: 09072091073C9FE2A90008C7A0003800CF98D208A20802218001085C7B00
   VCID: 6FED3072BEB396E33A-803A
   Component: WWS57X 120717  H36 0080
   Serial number:         120718133739
   Coding: 0045F7
   Serial number: 20456716
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 27 07 2012  00000277
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2EPX02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000024071200010804
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000019071200010291
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103816000001674983
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 8D088C36000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061220500688
   Coding: A8C90A
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003_AU57.rod
   VCID: 77FD0812CEE3DE23E2-8022
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Serial number: 00000000000000 Dataset Number: 4G0909863C  0033
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X_002_AU57.rod
   VCID: 285F1B6E53DD81DBBB-807C
10 Faults Found:
24320 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 12.098 V
24576 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
24832 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
25088 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
25344 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
25600 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
25856 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
26112 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
26368 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:50
91648 - Function Restricted due to Missing Message(s)
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 18:31:52
                    Voltage terminal 15: 12.078 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D800291UN Dataset Number: 4G0909602E  0007
   Coding: 303234373131303030324A55304C34473053
   VCID: 3365FC029A1BF2031E-8066
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H15 0045
   Serial number: 6940000Y120000GUWP0U
   Serial number: 3575HRB405J1EVLCFOPV
   Serial number: 3585HRB40691EA4U81RI
   Serial number: 3515JRB40671D2AS7GE7
   Serial number: 3525JRB40651D2ASBPEJ
   Serial number: 3554VRB40571D2B6AP75
   Serial number: 3564VRB40531D2B6H90T
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372LGO0004E
   Coding: 00043C
   VCID: 387FCB2E8B7D115B2B-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 22 05 2012  B0179632
   Part No SW: 4G0 920 981 M    HW: 4G0 920 981 M
   Component: TBenUsaAccNv  H76 0515
   Revision: 28460207    Serial number: 658230712596018
   Coding: 0BC709059F41D705020200
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 3561C21A946FEC3330-8060
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001225518 Dataset Number: 4G0909515H  0067
   Coding: 00E1034800
   Shop #: WSC 45201 001 1048576
   GVL: FDAFE8CCFEE2600D5100
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72EB3906A581BB0BD5-8026
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790889559
                    Reset counter: 223
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:43:05
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 223
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:43:05
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 001807120001015 Dataset Number: 4G0909104A  0017
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   ROD: EV_AllWheelDiffeQSPFR_AU57.rod
   VCID: 275D18525EC38EA3B2-8072
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0076
   Serial number: 30071200040168
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 377DC8128E631E2322-8062
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [00001001] - Signal Amplitude Too High
                    Reset counter: 224
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:43:12
                    Voltage terminal 30: 14.56 V
                    Outside temperature: 6.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11701
                    Right Rear Upper Body Vent Motor-Specified value: 11701
                    Right Rear Upper Body Vent Motor-Stop open: 11424
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Dataset Number: 4G0909553F  0034
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_AU57.rod
   VCID: 2E53ED767139DFEB71-807A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000034701062
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77FD0812C6E3DE23E2-8022
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA7E0031CV Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 306FF30EA30DC91B63-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F02.08.1200H01000AMS15374ÿ
   Subsystem 4 - Serial number: S15374ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F17005E00628002000013
   VCID: 4581B2DACC8F7CB3A0-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0019735559 Dataset Number: 4G0909852H  0027
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326BF9066501FB0B15-8066
   Revision: 00002001    Serial number: 0181172677
   Coding: 0106023A00FA408580B00880020503000000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000098990
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO17290711
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001794819
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000003018
   Coding: 030000
   VCID: 1C3737BE1F855D7B2F-8048
   Component: TSG BF        H03 0506
   Coding: 011F17005E00628002000002
   VCID: 4683B5D6F18977ABA9-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000426384 Dataset Number: 4G0909522B  0002
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B55E462422BAAC356-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120727-0001-082
   Coding: 12216F601002A400
   ROD: EV_HeadlRegulBasic_AU35.rod
   VCID: 2C57E77E4725ADFB5F-8078
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156G00C7619076
   Coding: 020007010000000001
   VCID: 2149064A38E77093FC-8074
   Part No SW: 4G0 035 746 B    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0549
   Revision: --------    Serial number: 194G.0C7508071
   Coding: 060200000203F9EF75128B1E00000003100001000000000000
   VCID: 2643155651C997AB89-8072
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC94029FDN
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LGU000IZ
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Component: TSG HL        H03 0506
   Coding: 010F17004000628002000002
   VCID: 4999BEEAE09798D344-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J27G20I
   Coding: 1080004
   VCID: 2643155691C997AB89-8072
   Component: TSG HR        H03 0506
Address 85: On Board Cam.
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X_002_AU57.rod
   VCID: 2643155659C997AB89-8072
27136 - Function Restricted due to Missing Message(s)
                    Reset counter: 223
                    Mileage: 174725 km
                    Date: 2025.11.30
                    Time: 14:43:06
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 14.332 V
                    Velocity_vehicle_reference: -0.00 m/s
Address 8E: Image Processing
   Dataset Number: 4G0909614B  0005
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169F60A6007C0136C-8064
   Dataset Number: 4G0909615B  0005
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 120623201771
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000549304 Dataset Number: 4G0909578A  0009
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU57.rod
   VCID: 66C35556994957AB49-8032
End-------------------------(Elapsed Time: 07:21)--------------------------
------------------------------15 Faults Found------------------------------
RGH0
Australia
C?ID=433612
:popcorn:
So both 85 - On Board Cam. and 8E - Image Processing are completely off-line. Time to pull a set of wiring diagrams and see what they have in common. Perhaps a fuse? Something else feeding power to both of them? Or perhaps a CAN bus connection?
davisev5225
C?ID=263265
First off, you'd benefit from upgrading to a current generation HEX-V2 or HEX-NET interface. You'll get additional diagnostic information that your older cable is incapable of processing.
That said, it looks like your Imaging Processing module is indeed offline. If I remember the C7 info correctly, the windshield camera does not have a dedicated CANBUS connection and instead does all its diagnostic communication through the 8E imaging processing module, and it also shows offline. That 8E module is located underneath the carpet in the front-right (passenger) footwell. Check for water - you can't just feel the carpet, you'll need to remove the seat and some of the door sill trim, and actually lift the carpet to look underneath. There should be a plastic box underneath the carpet with a wire harness going into it - that's the 8E module. Look for moisture ingress or other signs of damage.
blackstage2
Massachusetts, USA
That was going to be my next step. Doesn’t look like its the common issue thar most people have. I checked all the fuses yesterday and seem good. Have to get my hands on a wiring diagram and see whats going on.
blackstage2
Massachusetts, USA
So theres no water around it now but the hardware that holds it down is rusty. Thinking it was in water at some point
davisev5225
C?ID=263265
Pull the connectors and inspect them. You'll probably find signs of corrosion in/on the pins and/or wires.
blackstage2
Massachusetts, USA
Finally got a chance to pull the module. Connector and terminals look good. I also couldn’t really see any corrosion on the circuit board. The body plug underneath the module has been removed. So definitely has been under water
davisev5225
C?ID=263265
Not confirmed, since you're not reporting any visible signs of past water intrusion other than the rusty mounting hardware (which can also happen just from ambient humidity and the water you track in with your shoes). Time to test (continuity at minimum, load test if possible) all the power and ground lines that go to the module. Verify it is receiving power.
davisev5225
C?ID=263265
Anyone know if its possible to install a used image processing module? Or if i can code it with vdcs?
Install: yes.
Code: yes.
Adapt: probably not.
It's likely that the module would need to be parameterized (VCDS can't do this, only dealer software can), and I'm not sure if it has CP on it or not - if it does, that also requires a dealer visit to clear.
