Parts Needed For Retrofitting MFSW, Highline Instrument Cluster, Climatic Or Climatronic - 09 VW Jetta S 2.5L Tiptronic
daniel20vt
Poland
C?ID=637678
I'm looking to retrofit 6-button steering wheel to my Jetta and the highline black & white instrument cluster and I wanted to make sure I have all the correct parts for this conversion and if I need anything else (my car did not come with MFSW).
  • Steering Wheel: 1K8419091
  • Module: 1K0953549CH (the current module I have in the car is 1K0953549CP)
  • Instrument Cluster: 1K8920874 (the current cluster I have in the car is 1K0920954S)
  • Instrument Cluster Adapter 36 to 32 Pins Plug cable
Also, I wanted to know if a climatic to climatronic would be a difficult conversion to do. If yes, I was thinking about retrofitting the climatic w/ heated seats buttons from the facelift MK5 Jetta/MK6 but not sure which parts I need.
2kaa52
Ceska Republica, Praha
C?ID=319193
For Cluster Swap you need New Transponders and need to make correct immobilizer transfer
  • Agree
daniel20vt
Poland
C?ID=637678
Can you please explain what are these transponders and where they should be installed?
daniel20vt
Poland
C?ID=637678
Adding the auto scan.
Saturday,29,November,2025,21:30:03:37516
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: 3VWJM71K59M129876   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJM71K59M129876   Mileage: 231380km-143772miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H02---    Serial number: VWX7Z0I024J0JF
   Coding: 0000075
   Shop #: WSC 05074 444 04974
   VCID: 3B203E463F6C88129B1-806E
   VINID: 0E69DA74705B1497410892071824ADF328
Readiness: 0010 0000
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DA4F05E61F84622E55-8028
Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B400D49240003881302EB921F00413000
   Shop #: WSC 39355 001 104857
   VCID: 7EA6F75260FE5D3AFCF-802A
   Part No SW: 1K0 820 047 JJ    HW: 1K0 820 047 JJ
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 75B4E87E59C81E62AD5-8020
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001167171
   Coding: 04058EE70000150007320000000000000008EB0F64000134000000000000
   Shop #: WSC 00066 123 12345
   VCID: 323E1362E826495A487-8066
   Component: Wischer 130109 021  0501
   Coding: 00040853
   Shop #: WSC 00066
                    Fault Status: 01101100
                    Fault Frequency: 26
                    Reset counter: 212
                    Mileage: 231326 km
                    Voltage: 11.70 V
                    Fault Frequency: 32
                    Reset counter: 212
                    Mileage: 231326 km
                    Voltage: 11.70 V
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 21 AIRBAG VW8R  038 8600
   Revision: 07038000    Serial number: 003E7M08BU09
   Coding: 0012849
   VCID: 6D84C01E3198D6A2555-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME42514316/
   Subsystem 3 - Serial number: 6342MSME42432B4CE
   Subsystem 4 - Serial number: 6351HSME1B2D6C21F
   Subsystem 5 - Serial number: 6361HSME1B451B46B
   Subsystem 6 - Serial number: 63727SME1A03417D%
   Subsystem 7 - Serial number: 63827SME1A0368762
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001031
   VCID: 025E83A2180639DA987-8056
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0I024J0JF
   Coding: 0023103
   Shop #: WSC 06967 006 1048576
   VCID: 3C223D5A3A628F2A92B-8068
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 081108F1002620
   Coding: ED807F07000202001002
   VCID: 372822760344AC727F9-8062
   Component: IMMO            3HL 1222
   Shop #: WSC 00983 006 1048576
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000517189118
   Coding: 0001205
   VCID: 6FB8DA163B9424B2679-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0E0B02C0F6019AF07-807E
   Part No SW: 1K0 959 433 DA    HW: 1K0 959 433 DA
   Component:    KSG PQ35 RDK 052 0225
   Coding: 1B900F880186003F2D04058FB088CF0488DCA0
   VCID: 72BED36228A6095A887-8026
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08102300071403
   Coding: 0001204
   VCID: 70BAD96A26AA3B4A7E3-8024
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       019 0022
   Revision: 00019000    Serial number: VWZ4Z7H6397870
   Coding: 0040401
   VCID: 201AE92AB6CACBCAAE3-8074
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003742035
   Coding: 0001168
   VCID: 76B6EF7244CE157AA4F-8022
   Component:    RDK              0453
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003660044
   Coding: 0001168
   VCID: 77A8E27643C46C72BF9-8022
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
------------------------------2 Faults Found-------------------------------
Please repost WITHOUT editing, the header information is important.
And just as important, @daniel20vt Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
daniel20vt
Poland
C?ID=637678
I reposted the auto scan with the header.
@Uwe I found the .txt autoscan file in the Scans folder and repasted it. Is that how it should look like?
Transponders are in the keys.
TBH, I'm a bit surprised that new transponders would be needed, but I've never done a cluster swap like that either. It seems to me that if a proper identity transfer is done, then the existing transponders should work? Perhaps @EuroX or @Jetta 97 can confirm or deny?
Ziddywerks
Northern NJ USA
C?ID=208579
No transponders should be needed In my opinion. If all the data was transferred from one dash to the other it should be just adaption of key to the dash. No need to for new transponders. I have done a dash swap on 2012 and 2016 jettas. All that was needed was CS and pin to adapt existing keys no need for new transponders.
If all that was done was a dash swap and only CP was removed and no data was transferred then yes 2 new transponders/keys will be needed. However such a swap in this vehicle is very easy so why would someone not do things the right way to begin with?
daniel20vt
Poland
C?ID=637678
Thank you for the information. Sounds like it's unlikely the transponders will be needed, but in case they will be needed, are they usually sold with a VW part number that I can order online/through VW dealership?
As far as the module goes, is the CH the version I should be using? Is it fully compatible with the slip ring I have in the car?
Ziddywerks
Northern NJ USA
C?ID=208579
Yes keys can be purchased through dealership yes In that instance the keys will have the vehicles CS already written into them so there is still a matter of adapting them to the vehicle. However if the data was not transferred to the donor dash keys from the dealership will use useless because CS will not match CS in the dash. So unless CS and all relevant data was transferred to donor dash keys from dealership will not help you. In that case aftermarket keys that are completely blank would be needed or keys would have to be ordered to the CS stored in the donor dash but then the key will not be cut correctly either. Again there is a right and wrong way to do such a swap on these vehicles. Nara.
daniel20vt
Poland
C?ID=637678
Any help on the control module would be highly appreciated. Per the control module version chart, the module I have in the car (CP) does not have the steering angle sensor. Does it mean I will need to CD version for the MK6 steering wheel to work since it also does not have the steering angle sensor, or the CH version will work fine even though it does have the steering angle sensor?
I'm scratching my head over that. You have an MK60EC1 ABS. I wouldn't think that ABS would be happy w/o a steering angle sensor in the steering wheel?
Dr Sheldon
Windsor UK
C?ID=334979
The SAS is only needed for ESP / Stability Control
- It tells the module which way the driver would like to go and then the Yaw, Longitudinal, Lateral etc, tell the module the actual direction.
Pure and Simple ABS has no use for the SAS.
Does that module ^ Come with ESP ? Standard, Optional or not at all - I don't know !
daniel20vt
Poland
C?ID=637678
I have ESP.
Correct, but have you ever seen an MK6EC1 ABS module that didn't include ESP? I mean it has all the other sensors for ESP internal. ESP is the only reason why it exists. Cars that didn't come with ESP used less expensive ABS modules such as the MK70.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
In this case it will need new transponders and custom built CS , 2009 has 7 byte CS vs 12 byte CS in mk6 cluster. I have done this retrofit long time ago in my car .
  • Informative
Jetta 97
C?ID=81680
Uwe,
I explain above why transponders needs to be replaced.
Ziddywerks
Northern NJ USA
C?ID=208579
How can this be unless the donor cluster is from a much newer vehicle?
