ACC fault on UK 2023/73 VW T6.1 after 2x radar replacements post crash
Craig.
Cardiff(ish), South Wales, UK.
C?ID=288281
Hi all, I am stumped.
2023 73 plate UK VW T6.1
Vehicle had a front end impact, all damaged parts replaced.
Front radar was the only electrical component that was replaced due to the radar module being damaged beyond repair. This was replaced again after the faults below would not clear.
Used radar fitted, supplied by garage, part numbers checked and perfect match. Software number matched but H number is different, put that down to different year of manufacturer and one is Made in Germany and one is Made in China. Done used Radar units previously and had no issues.
ODIS used for Component Protection, coding, parameters etc and calibration (Dynamic). All completed correctly with no reported issues about the process. Dynamic calibration completed twice on 2nd radar module, both times went through fine.
However, the ACC is still not working. Autoscan:
Tuesday,25,November,2025,19:43:52:50827
VCDS Version: 25.3.2.0 (x64)  HEX-NET CB: 0.4672.4
VIN: WV1ZZZ7HZR   License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 22 44 5F 69 75
VIN: WV1ZZZ7HZR   Mileage: 64875km-40311miles
Address 01: Engine (J623-DMZA)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 023 MR    HW: 05L 907 309 AD
   Component: R4 2.0l BTD   H80 2582
   Revision: NBH80---    CVN: 29E7E1DB991E9EBCA3C795CF64CF85E9A3C795CF43FB2DAA
   Coding: 002500340376050800000000000000000000000000000000
   Shop #: WSC 00012 790 00047
   ASAM Dataset: EV_ECM20BTD01105L906023MR 006001
   ROD: EV_ECM20BTD01105L906023JC.rod
   VCID: 04447D6B8FDD94BBF7-8050
   VINID: 9E606AAAA1D8AA26000C02020CDA1FE277
29083 - Coolant Temp Sensor 1 for Intercooler
          P00DE 00 [10100111] - Electrical Malfunction
                    Mileage: 64875 km
                    Date: 2025.11.25
                    Time: 19:37:13
                    Engine speed: 0.00 /min
                    Coolant temperature: 69  C
                    Intake air temperature: 15  C
                    Voltage terminal 30: 12.620 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Coolant temperature sensor 1: B1: on cylinder head: raw value: 69.3  C
                    Heat delivery temperature in cooling system: -273.1  C
                    Outside temperature sensor 1: B1: raw value: 7.0  C
                    Fuel consumption: 0.00 l/h
                    Fuel temperature sensor 1: B1: raw value: 27.9  C
                    Engine oil temperature: 82.9  C
Readiness: 1110 1011
   Part No SW: 0DV 300 012 B    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3702
   Revision: 00H06V15    CVN: D00EAF6B
   ROD: EV_TCMDQ500021.rod
   VCID: 3228EBB365E9EA0B15-8066
Address 03: ABS Brakes (J104)       Labels: 7LX-614-517-V1.clb
   Part No SW: 7LA 614 517 B    HW: 7LA 614 517
   Component: ESC_high      H01 0800
   Serial number: 08504132231025
   Coding: 10554752C84AE685085CE2A613696726393724B8
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
   ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
   VCID: 3E30CF83A1B13E6BE1-806A
1209 - Databus
          [SCL_ACC_Anhalteweg_Error]
                    Reset counter: 187
                    Mileage: 64875 km
                    Date: 2025.11.25
                    Time: 19:40:47
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426 J    HW: 7LA 907 426 J
   Component: AC Manuell    H01 0701
   Coding: B03110000810030001000840504001050000000000011000800000000000
   ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
   ROD: EV_AirCondiBHTCVN54XT6PA_VN46.rod
   VCID: 4AD89353ED7982CB4D-801E
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V1.clb
   Part No SW: 2Q0 937 090 E    HW: 2Q0 937 090 C
   Component: BCM A0 Std+   H12 0963
   Serial number: 02102330304090 Dataset Number: V03935404HJ 0001
   ASAM Dataset: EV_BCMA0 208001
   ROD: EV_BCMA0_208_VW27.rod
   VCID: 3424EDAB9FFDE43B07-8060
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S4Y23M11D09H22M50S44
   Coding: 0018DD
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000073458285
   Coding: 1F0007
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000074079593
   Coding: 050007
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 0000000000000JQD78YN
   Serial number: 00000000000040597250
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H10 0075
   Serial number: 000150058323287 Dataset Number: V03935313KK 0001
   Coding: 8451051911
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_009_SK25.rod
   VCID: 53E68E373A33C3033E-8006
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935351GN 0001
   Coding: 3000670A00FF8748949C815580508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_VW41.rod
   VCID: 73A62EB7DA73A303DE-8026
2111 - Databus
          [FAULT_ESP_CONS_ACC]
                    Reset counter: 187
                    Mileage: 64875 km
                    Date: 2025.11.25
                    Time: 19:40:37
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 40  C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.03 m/s
                    Adaptive distance regulation: status: ACC_irreversible error
0928 - Databus
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                    Reset counter: 187
                    Mileage: 64875 km
                    Date: 2025.11.25
                    Time: 19:41:30
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 41  C
                    Longitudinal acceleration: 0.00 m/s
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 187
                    Mileage: 64875 km
                    Date: 2025.11.25
                    Time: 19:41:30
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 AN    HW: 2Q0 959 655 AN
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935346ZR 0001
   Coding: 8800C00000000000BC0000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 095A6C5FA8FFC9D384-805C
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 941 B    HW: 7LA 920 941 B
   Component: KOMBI         202 8500
   Coding: 27A40A0A2580260001882A011401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VN46.rod
   VCID: 3FCEB287A6BB3763EA-806A
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 G
   Component: GW MQB High   527 5504
   Serial number: 24102311601403 Dataset Number: V03935367RM 0001
   Coding: 030100344F056A0401100058100F00010001070000000000000000000000
   Shop #: WSC 00012 790 00418
   GVL: 01C43C0000000000C00080008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_SK25.rod
   VCID: 7F4EF287E63BF763AA-802A
   Generator:
   Component: 5-00-11-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AB    HW: 3G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440036256233470
   Coding: 2C0D00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 7734330200230824024D
   Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
   Component: Haldex4Motion H56 7822
   Serial number: HA1-00029.08.23 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_VN46.rod
   VCID: 4ED09F431111AEEB11-801A
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 G    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7160
   Dataset Number: V03935340DA 0001
   Coding: 0102
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_SteerAssisMNB 002015
   ROD: EV_SteerAssisMNB.rod
   VCID: 46C0A763F96166ABA9-8012
   Part No SW: 3CN 035 869 E    HW: 3CN 035 869 E
   Component: MU-E-D-ER     720 0970
   Serial number: 14092300020502 Dataset Number: V03935416AU 0001
   Coding: 066401003C00000041110101008000001F0000C60000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VN46.rod
   VCID: 48DCA95BF37570DB5B-801C
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383 C    HW: 5H0 907 383
   Component: Anhaenger     H12 0058
   Serial number: 000000000006301 Dataset Number: V03935309CF 0001
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW41.rod
   VCID: 2E10FFC371D1CEEB71-807A
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 282 C    HW: 5WA 035 282
   Component: OCUGen3Low    H16 0200
   Serial number: 0000000308NVRG1 Dataset Number: V03935418CR 0001
   Coding: 06462000196818208005460160000607
   ASAM Dataset: EV_OCUGen3Low 003008
   ROD: EV_OCUGen3Low.rod
   VCID: 44C4BD6BCF5D54BBB7-8010
End----------(Elapsed Time: 01:35, VBatt start/end: 12.6V/12.6V)-----------
------------------------------5 Faults Found-------------------------------
The above are the only fault codes that are persistent.
Code in 01 ignored as that is to be repaired by the garage where the vehicle is.
Code in 03 will not erase. ODIS test plan points to ACC.
1209 - Databus
Reset counter: 187
Mileage: 64875 km
Date: 2025.11.25
Time: 19:40:47
Codes in 13 will erase but code below immediately returns when ACC is switched on, with the other 2 individually sometimes coming back and sometimes not. ODIS test plan points to ABS.
2111 - Databus
Reset counter: 187
Mileage: 64875 km
Date: 2025.11.25
Time: 19:40:37
The test plans are just going round in circles with no solution, just tells me to "Continue with test plan in other module".
From Google translate, it is related to "Stopping Distance"?
This is the 2nd radar to be coded, same result so I am inclined to think it is not the radar module.
Checked for relevant TPIs, couldn't see any but if anyone knows of one then please let me know, Software updates checked via SVM for both 03 and 13, nothing found. Coding checked in ABS online, all good.
HELP!
downtime
Finland
C?ID=280813
I've seen once before a case where online function restore wrote wrong FeCs for the radar and this way the coding did not match. And I presume you did do function restore to the radar on top of CP and SVM?
Can you check from module 13 measurement values, what do the SWaP statuses show?
We need the full VIN to help
Craig.
C?ID=288281
Hi,
Yes, the FEC's are done as part of the "Replace Module" test plan and I also did it separately via FES after the first road test and the results were the same:
The Following FS ID(s) is/are enabled:
FSC 1: 10009008 / MRR package 8: ACChigh (ACC S&G)+FrontAssist incl.
FSC 2: 10009205 / AWV version "AWV1,2,3, vFGS, vFRS
I repeated the steps individually in case the "Replace Module" test plan wasn't doing everything fully and no joy.
This was the case with BOTH the replacement radar units, which reduces the likelihood of the radar being the issue but the FECs being wrong I hadn't considered!
I'll be revisiting the vehicle tomorrow so will check the SWaP statuses. Thanks!
Craig.
C?ID=288281
I'm happy to send the VIN via PM but due to previous issues with VW Warranty I no longer post full VINs online.
May I ask what you need from it? As I may already have the information.
How could posting the VIN affect the VW warranty, it isn't GDPR relevant data? From the VIN, professionals can see the cars full build data and VAG specialists like myself, can see the Digital Service System data.
Craig.
C?ID=288281
"it isn't GDPR relevant data"
I didn't say it was and not answering your question on a public forum, due to the same reasons and it would take too long to get into.
"From the VIN, professionals can see the cars full build data and VAG specialists like myself, can see the Digital Service System data."
Your reply didn't answer my question and as a time served VAG specialist that prides myself on mutual industry respect and support of other professionals, I don't appreciate your tone suggesting I am neither but It can be difficult to convey context on an online forum so I hope that tone has been misunderstood.
Issues were resolved prior to my return to the vehicle so it's fixed but no details on how, which is annoying.
Thread can be closed, thanks.
downtime
Finland
C?ID=280813
Hi,
I know it's abit late but FECs look correct. Would be interesting to know what was done to get it working?
Dr Sheldon
Windsor UK
C?ID=334979
By a time served or non time served VAG Tech ?
Craig.
C?ID=288281
Thanks for confirming, I couldn't see any issues with the FECs either.
I reached out to the garage and they've said that repairing this wiring fault in the above autoscan cured the ACC issue:
No further details other than the sensor right behind the EGR pipe and had a split in the wiring.
I would have liked to have been involved with the final repair so I could have seen the resolution myself but everything requested of me was done on the previous visit (CP, parameters and coding of the Radar Module plus the dynamic calibration as an extra task as they didn't initially request it) so they saw no need for me to return.
