2017 touran: left side heat ok, right side blows cold air. Is there a common fault/solution for this?
   #21
Dr Sheldon
Windsor UK
C?ID=334979
Is there a common fault/solution for this?​
Forget that process !! It is a foolish way to live !
Find YOUR fault !
Calculate YOUR Solution !
Apply the Remedy !!
There ^^ is no foolishness !!
   #22
Dr Sheldon
Windsor UK
C?ID=334979
Ok since I have only owned older cars, and now newer cars are getting older, I have just found out about VWs amazing design leap (NOT!) that involved putting a weak bag of loose silica beads in the coolant tank!
After a few years the bag breaks and the beads migrate to the heater core. AND CLOG IT UP SO YOU HAVE NO HEAT IN THE MIDDLE OF FREEZING WINTER
So now I have the lovely job of trying to fix this (outside) Thanks VW, your designers are really special!
German cars are a heap of shite !! All of them. Keep buying them, Keep Feeding them, and they will keep raping you !!
It is a trait they have !!
  • Disagree
scoobykids
C?ID=574407
But it makes the coolant "Wartungsfrei!" :rolleyes:
haha id rather do the maintenance!
just removed bag from bottle. it looks intact? :confused::confused:
scoobykids
C?ID=574407
can VCDS check the temperature readings at various air temperature sensors in the heating system? Im wondering if there is a defective thermistor etc
I found this below (think its for 2015 Audi) is it relevant to 2017 touran?
MVB 034 four vent temperatures:
034.1 Dashboard left (G385)
034.2 Dashboard right (G386)
034.3 Footwell left (G261)
034.4 Footwell right (G262)
Dr Sheldon
Windsor UK
C?ID=334979
Not quite !
However the HVAC control module does monitor the various temp sensors. If the sensor is fitted it will very likely be monitored. If it is monitored there is a strong chance that the Module will impart that information to a Diagnostic Tool. VCDS then can display that for you as an MVB / Datastream ... ...
   #26
Depends whether your HVAC control has sensors like that. VCDS can only tell you what the car knows.
Part No SW: 5G0 907 044 CJ HW: 5G0 907 044 CJ
Component: Climatronic H04 1801
Revision: 00001K10
Coding: 08020104203110011005100000101022
VCID: 71BB1908C12411F271D-8024
Looks like you have:
IDE00976 -- Left front vent temperature (C)
IDE00977 -- Right front vent temperature (C)
IDE00981 -- Footwell vent temperature (C)
IDE01065 -- Rear vent temperature (C)
scoobykids
C?ID=574407
are there any other air temp sensors? in front of the heater core to tell the actual temp of the air being blown through?
or any sensor that isnt in the footwell or air vent?
   #28
The only thing I see that looks like a possibility is this:
IDE00982 -- Temperature downstream of evaporator (C)
However, I don't know whether that's also downstream of the heater core.
Dr Sheldon
Windsor UK
C?ID=334979
It is more common for the flaps to go wrong ! VM's made of plastic and put in a hot airstream - Superb Engineering ?
   #30
Dr Sheldon
Windsor UK
C?ID=334979
* VM's make them from Plastic *
   #33
scoobykids
C?ID=574407
evaporator is the aircon core right, presumably this sit in series with the heater core air flow?
