VCDS-Mobile Problem(s)
   #41
toulouse
France
C?ID=431984
Hi, the data were for some reason (α version) not stored on the cload, forced an upload now OK. More later.
The autoscan with the α version:
VCDS-Mobile
Log Viewer V0.6
Username: toulouse
Logout
#hndoc:?docid=0000B4E7&xt=hnh:2FDE7E6E6E63D4379883C6725B3CD72B764F48D64357ED5167B39827B72C0036
Wed,May,06,2026,22:49:10
VCDS Mobile 0.4714.0.5
VCDS Mobile: 0.4714
Data Version: 00000066
VIN: WV2ZZZ7HZMH062721
Scan: 01 02 03 08 09 13 15 17 18 19 22 3D 44 55 5F 75 A5
01-Engine -- Status: Cannot be reached 0110
3D-Special Function -- Status: Malfunction 0010
Address 01: Engine  (J623-DNAA)    Labels: 05-01.lbl
    Part No SW: 05L 906 023 JQ    HW: 05L 907 309 F
    Component: R4 2.0l TDI   H80 2672
    Revision: N1H80---
    Coding: 0025001C0366050800000000000000000000000000000000
    Shop #: WSC 03999 006 1048576
    ASAM Dataset: EV_ECM20TDI01105L906023JQ 006002
    ROD: EV_ECM20TDI01105L906023JQ.rod
    VCID: 8043A30391390BA83711E9-80D5
34193 - Implausible Data Received from ESP Control Module
    U0416 00 [032] -
Address 02: Auto Trans  (J743-)    Labels: 0D-02.clb
    Part No SW: 0DV 300 012 A    HW: 0GC 927 711 H
    Component: GSG DQ500     H06 3701
    Revision: 00H06V11
    ROD: EV_TCMDQ500021_VN46.rod
    VCID: 3125B6C7EA13D22008FF74-8064
No fault codes found.
Address 03: ABS Brakes  (J104)    Labels: 7L-03.lbl
    Part No SW: 7LA 614 517 B    HW: 7LA 614 517
    Component: ESC_high      H01 0800
    Coding: 10556752C84DEE87085BE6A613677706383727B8
    Shop #: WSC 00012 790 00152
    ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
    ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
    VCID: 3E3F9DFB2B4D3D58857DC7-806B
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
    U0428 00 [008] -
Address 08: Auto HVAC  (J301)    Labels: 7L-08.lbl
    Part No SW: 7LA 907 426 E    HW: 7LA 907 426 E
    Component: AC Manuell    H01 0602
    Coding: 903010000810230001000800504001050000000000031500A00000000000
    ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
    ROD: EV_AirCondiBHTCVN54XT6PA_VN46.rod
    VCID: 45CDF2174E9B6E80C4A790-8010
460036 - Local Data Bus 2
    U10C7 00 [009] - No Communications
Address 09: Cent. Elect.  (J519)    Labels: 2Q-09.clb
    Part No SW: 2Q5 937 090 A    HW: 2Q5 937 090 A
    Component: BCM T6PA Std+ H11 0943
    ASAM Dataset: EV_BCMA0 206001
    ROD: EV_BCMA0_206_VN46.rod
    VCID: 352D82D71E7BFE00540720-8060
    Subsystem 1 -     Part No SW: 5Q0-955-559-C    Labels: 5Q0-955-547.clb
    Component: RLS          054 0206
    Serial Number: S7Y20M12D07H01M09S31
    Coding: 0018EE
    Subsystem 2 -     Part No SW: 7L2-959-405
    Component: FHSG_DRV     001 0002
    Serial Number: 00000000000046419304
    Coding: 130000
    Subsystem 3 -     Part No SW: 7L2-959-406
    Component: FHSG_PSG     001 0002
    Serial Number: 00000000000045370393
    Coding: 090000
    Subsystem 4 -     Part No SW: 5Q0-951-172
    Serial Number: 000000000ZY203100N0Z
    Subsystem 5 -     Part No SW: 5Q0-951-605-A
    Serial Number: 00000000000048959462
535060 - Databus
608776 - Child Safety / Anti Car-Jacking for Sliding Door; Rear Passenger Side
    B1A75 29 [008] - Signal Implausible
Address 13: Auto Dist. Reg  (J428)    Labels: 2Q0-907-572.clb
    Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
    Component: ACCCONTIMQB   H03 0372
    Coding: 3200670101FF8748949C815580508700000000000000000014
    Shop #: WSC 00012 790 00202
    ROD: EV_ACCMRRCONTIVW376_003.rod
    VCID: 43C9EC0F40AF50B0EAB38E-8016
2101 - Databus
0928 - Databus
2055 - Databus
Address 15: Airbags  (J234)    Labels: None
    Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
    Component: VW22Airbag    016 0506
    Revision: --------
    Coding: 88CCC00000000000800000CF000C40000065
    ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
    ROD: EV_AirbaVW22BPAVW27X_VN46.rod
    Subsystem 1 -     Part No SW: --------------
    Component: SideSensor_Df1E2 0887
    Serial Number: 3577Y50C9369CE22F2FX
Address 17: Instruments  (J285)    Labels: 7L-17.lbl
    Part No SW: 7LA 920 751 A    HW: 7LA 920 751 A
    Component: KOMBI         303 8400
    Coding: 04A4090A65A0000801882A031400000000000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 009071
    ROD: EV_DashBoardVDDMQBAB_VN46.rod
    VCID: 3D3D9AF7264B26409C77C8-8068
Address 18: Aux. Heat  (J364)    Labels: None
    Part No SW: 5WA 963 271 C    HW: 5WA 963 271 C
    Component: STH-VW37x     006 0012
    Coding: 3143221854121512DCE519
    ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
    ROD: EV_AuxilHeateWOSVW38X_002_VN46.rod
    VCID: 4CDBC7336DF19FC81BE92D-8019
Address 19: CAN Gateway  (J533)    Labels: 3Q0-907-530-V1.clb
    Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
    Component: GW MQB High   521 5423
    Coding: 030100544F05730401100058100F00010001070000000000000000000000
    ROD: EV_GatewNF_VN46.rod
    VCID: 74AB7FD35581A708A39995-8021
    Subsystem 1 -     Component: 5-00-11-00-04
    Subsystem 2 -     Part No SW: 3G0-959-442-N
    Component: E221__MFL-PR6H07 0110
    Serial Number: PR6-0440036343201804
    Coding: 2C0D00
    Subsystem 3 -     Part No SW: 7E0-915-181-L
    Component: J367-BDMContiH03 1051
    Serial Number: 771972000020120303A0
131748 - Control Module for Auxiliary Heater
    U1099 00 [009] - No Communications
8531970 - Quiescent Current
    U1406 00 [008] - Too High
Address 22: AWD  (J492)    Labels: 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
    Component: Haldex4Motion H56 7822
    Coding: 0005
    VCID: 4EDFCD3B9BEDADD8751D37-801B
Address 3D: Special Function  (J608)    Labels: None
    Part No SW: 2N0 907 427 P    HW: 2N0 907 427 H
    Component: KFG       H24 0306
    Coding: 04002000000000200200000860B8134E50000000
    ASAM Dataset: EV_SpeciFunctFlextVN54X 007029
    ROD: EV_SpeciFunctFlextVN54X_007_VN46.rod
14 Faults Found:
393498 - Function Restricted due to Insufficient Voltage
    U1400 00 [009] -
394010 - Terminal 30
    C1141 13 [008] - Open Circuit
394266 - Terminal 30-2
    B17DA 13 [009] - Open Circuit
209942 - Control unit for battery monitoring
    U1050 00 [009] - No Communication
210198 - Voltage Converter with Outlet
    U1109 00 [009] - No Communications
212246 - Databus
    U1101 00 [008] - Active
73217 - Energy Management Parallel Warning Triggered
    B1A50 00 [009] - -
242710 - Control unit for battery monitoring
242949 - Databus
    U1201 00 [009] - No Communications
328980 - 328980 - Unknown faultcode
329236 - 329236 - Unknown faultcode
329492 - 329492 - Unknown faultcode
329748 - 329748 - Unknown faultcode
Address 44: Steering Assist  (J500)    Labels: 2N0-909-143.clb
    Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
    Component: EPS_MQB_ZFLS  751 7150
    Coding: 1106
    ASAM Dataset: EV_SteerAssisMNB 002012
    ROD: EV_SteerAssisMNB_VN46.rod
Address 55: Xenon Range  (J745)    Labels: 7P6-907-357.clb
    Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
    Revision: --------
    Coding: 0C8A020009200003
    ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
    VCID: 41C5E6075AB342A0F89FA4-8014
Address 5F: Information Electr.  (J794)    Labels: 3C-5f.lbl
    Part No SW: 3CN 035 869 A    HW: 3CN 035 869 A
    Component: MU-E-D-ER     720 0890
    Coding: 06640500FF00000041110101008000001F0000D40000010000
    ASAM Dataset: EV_MUEnt4CGen2LGE 001044
    ROD: EV_MUEnt4CGen2LGE_VN46.rod
    VCID: 44CBEF1345A15788D3B985-8011
1637 - Interface for External Media
    U11B8 00 [008] - No Communications
Address 75: Telematics  (J949)    Labels: None
    Part No SW: 5WA 035 282    HW: 5WA 035 282
    Component: OCUGen3Low    H14 0092
    Coding: 06462000196818208005460160000607
    Shop #: WSC 00000 000
    ASAM Dataset: EV_OCUGen3Low 002036
    ROD: EV_OCUGen3Low_002_VN46.rod
    VCID: 014526071A3382A0B81F64-8054
    U1400 00 [008] -
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: None
    Part No SW: 2Q0 980 653 B    HW: 2Q0 980 653
    Component: MQB MFK 3.0   H13 1202
    Coding: 00010888004A4020909F00000030002006018000000000000000000000000000
    ASAM Dataset: EV_MFK3ValeoMQB 007042
    ROD: EV_MFK3ValeoMQB_007_VN46.rod
    VCID: 342BBFD31501E708631955-8061
1123157 - Databus
1123173 - Databus
1123077 - Databus
End--(Elapsed Time: 02:03, VBatt start/end: 11.9/12.0 Vign: 12.1)-
VCDS-Cloud is a service of Ross-Tech, LLC
   #42
toulouse
France
C?ID=431984
Hi, sorry for the somewhat delayed follow up.
  • autoscan does work with the alpha version, will this become at some time the beta or standard version; i.e. can I perform at some moment a normal update (I was on alpha channel till 19th May)
    • VIN is OK and visible
    • mileage is missing
  • advanced measuring values works more or less, however units are missing and even if the values have a link when you click on the value you do not get any extra information. I tried this on address 08 (airco) and 3D (special functions)
  • the HUD system seems more or less not to work (tested on 08 and 3D as well)
    • data windows do not show data you assigned to them
    • data windows disappear
    • gauge is not displaying the value that is attached to it
  • is there any hope that the HUD system will be working in the future, or is there a subset of HUD displays that are working
enclosed the latest autoscan file:
#hndoc:?docid=0000B5B2&xt=hnh:4BFF277B4B6D2F03043AB5ABD15559CE1E7325361CD857852CD39997F566347F
Sat,May,30,2026,10:55:08
VCDS Mobile: 0.4714
    Revision: N1H80---
    Revision: 00H06V11
    Subsystem 1 -     Part No SW: 7LA-906-453-A
    Component: E857         H01 0206
    Serial Number: 00002040121234312102
    Coding: 0018EE
    Coding: 130000
    Coding: 090000
    Revision: --------
    Coding: 2C0D00
    Coding: 0005
    Subsystem 1 -     Part No SW: 7C0-907-155
    Component: U13DCAC      H05 0870
    Serial Number: A056120
    Subsystem 2 -     Part No SW: 7E0-915-181-M
    Serial Number: 77194501002012030284
    B1A50 00 [009] - -
    Coding: 1106
    Revision: --------
End--(Elapsed Time: 02:02, VBatt start/end: 12.2/12.1 Vign: 11.9)-
Have a nice evening,
Paul
   #43
toulouse
France
C?ID=431984
Hi, any tips to get the HUD system working?
Regards,
Paul
   #44
edit, I didn't see A.S. above!
2nd Edit: I would recommend you post a complete Auto-Scan using the full version of VCDS (on your PC) as the module for the HUD is not showing on your mobile version.
Shaun
Can you maybe post a screenshot of the HUD you are trying to use that isn't working, as well as a measuring values readout of the data you are trying to display?
toulouse
France
C?ID=431984
Hi, I'm getting a bit frustrated, HUD is even no reproducible.
The results:
full autoscan:
Friday,05,June,2026,21:29:46:49117
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4714.5
VIN: WV2ZZZ7HZMH062721   License Plate:
Mileage: 196729km-122241mi   Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 13 15 17 18 19 22 3D 44 55 5F 75 A5 D6 D7 800B
VIN: WV2ZZZ7HZMH062721   Mileage: 196729km-122241miles
800B-Aux air heater 2 -- Status: OK 0000
Address 01: Engine (J623-DNAA)       Labels:. 05L-907-309-V1.clb
   Revision: N1H80---    CVN: 43A2E916F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
   VCID: 0052EA68AA88FEDACF3-8054
   VINID: 9E60AAAAA1D8A9D6001821C2044F295D23
   Revision: 00H06V11    CVN: 6119FBE9
   ROD: EV_TCMDQ500021.rod
   VCID: 31347FAC51A2A75270D-8064
Address 03: ABS Brakes (J104)       Labels: 7LX-614-517-V1.clb
   Serial number: 08503942201218
   VCID: 3E2E549090FC482AFDF-806A
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   ROD: EV_AirCondiBHTCVN54XT6PA.rod
   VCID: 45DC3B7CF52A1BF2BC5-8010
   Rear A/C Control Head 1:
   Subsystem 1 - Part No SW: 7LA 906 453 A    HW: 7LA 906 453 A
   Serial number: 00002040121234312102
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V1.clb
   Serial number: 00102034500198 Dataset Number: V03935338JL 0001
   ROD: EV_BCMA0_206_VW27.rod
   VCID: 353C4BBCA5CA8B722C5-8060
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Serial number: S7Y20M12D07H01M09S31
   Coding: 0018EE
   Driver door control module:
   Subsystem 2 - Part No SW: 7L2 959 405     HW: 7L2 959 163
   Serial number: 00000000000046419304
   Coding: 130000
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L2 959 406     HW: 7L2 959 164
   Serial number: 00000000000045370393
   Coding: 090000
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY203100N0Z
   Serial number: 00000000000048959462
   Dataset Number: V03935335RG 0001
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D82564FB1E25C2921-8016
196740 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SENSOR_BLOCKAGE]
                    Reset counter: 45
                    Mileage: 196667 km
                    Date: 2026.06.04
                    Time: 18:16:21
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 30 °C
                    Vehicle speed: 28.20 m/s
                    Longitudinal acceleration: 0.13 m/s²
                    Adaptive distance regulation: status: ACC_switch-off_reaction
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Revision: --------    Dataset Number: V03935330EJ 0001
   ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   Subsystem 1 - Part No SW: -----------    HW: 442 062 710 20
   Serial number: 3577Y50C9369CE22F2FX
   Subsystem 2 - Part No SW: -----------    HW: 442 062 710 20
   Serial number: 3587Y51AB369CE3134AK
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 3D2C539C9DFA5332E45-8068
9456681 - Key
          B104C 29 [00001000] - Implausible Signal
                    Mileage: 196717 km
                    Date: 2026.06.05
                    Time: 09:27:46
Address 18: Aux. Heat (J364)       Labels:| 5WA-963-27x-V1.clb
   Serial number: 000000000000048
   ROD: EV_AuxilHeateWOSVW38X_002_VW38.rod
   VCID: 4CCA0E58D640EABA63B-8018
   Serial number: 12122010521419 Dataset Number: V03935338TK 0001
   GVL: 01C03C0000100000408090008004C80000000000100000000000000000000000
   ROD: EV_GatewNF_SK25.rod
   VCID: 74BAB6B8EE30D27ADBB-8020
   Generator:
   Subsystem 2 - Part No SW: 3G0 959 442 N    HW: 3G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440036343201804
   Coding: 2C0D00
   Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Serial number: 771972000020120303A0
   Serial number: HA1-00020.10.20 Dataset Number: v1260x015G0 0000
   Coding: 0005
   ROD: EV_AllWheelContrHA1VW37X_004_VW27.rod
   VCID: 4ECE0450205CD8AA0DF-801A
Address 3D: Special Function (J608)       Labels:* Redir Fail!
   Serial number: GB24204851493 Dataset Number: V03935336WC 0001
   Subsystem 5 - Part No SW: 7C0 907 155     HW: 7C0 907 155
   Serial number: A056120
   Subsystem 6 - Part No SW: 7E0 915 181 M    HW: 7E0 915 181 M
   Serial number: 77194501002012030284
          B1A50 00 [00001001] - -
                    Reset counter: 6
                    Mileage: 196652 km
                    Date: 2026.06.04
                    Time: 16:22:03
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Dataset Number: V03935309JN 0001
   Coding: 1106
   ROD: EV_SteerAssisMNB.rod
   Revision: --------    Serial number: -------------- Dataset Number: V03935338PG 0001
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41D42F6CE10237D280D-8014
   Serial number: 20122000021222 Dataset Number: V03935337R  0001
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 44DA2678FE1022FAABB-8010
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Serial number: 0000000011NVWP0 Dataset Number: V03935338MW 0001
   ROD: EV_OCUGen3Low_002_VW27.rod
   VCID: 0154EF6CA182F7D2C0D-8054
   Serial number: E57829512203390 Dataset Number: V03935338AD 0001
   ROD: EV_MFK3ValeoMQB_007_VN3S.rod
   VCID: 343A76B8AEB0927A1BB-8060
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 659CDBFC55EA3BF25C5-8030
   Component: LED1R         H08 9202
Address 800B: Aux air heater 2 (J604)       Labels:| 7C0-963-273.clb
   Part No SW: 7C0 963 273 C    HW: 7C0 963 273 C
   Component: LSH_DIESEL    008 0026
   Dataset Number: 0026        0026
   Coding: 2200
   ASAM Dataset: EV_LSHECCSMNB 002018
   ROD: EV_LSHECCSMNB_002_VN46.rod
   VCID: 2B086DC4738ECD824A1-807E
End----------(Elapsed Time: 02:04, VBatt start/end: 12.3V/12.5V)-----------
------------------------------3 Faults Found-------------------------------
Address 13: DTCs cleared
Address 17: DTCs cleared
AdvMeasData on PC:
on mobile:
HUD image:
!should have been the coolant pressure!
HUD saved disappear randomly, after restart they are visible but the content may be empty or wrong
Does somebody arrives in getting stable HUD behaviour, the idea seems great but for the moment it looks useless. Show Adv. Meas. Val. works on mobile, except the units.
Regards,
Paul
  • Agree
Reactions: TTT
   #47
Shaun
Try this in mobile: [Options] -> [Clear Dataset Cache] then delete any old HUD saves for this module and create a new HUD. Measuring values can move around between datasets now, sometimes to completely different values. Not sure if this is the cause, but it might be.
   #48
toulouse
France
C?ID=431984
Will try tomorrow, it is 11pm here
   #49
toulouse
France
C?ID=431984
Hi, I'm sorry to say, but in my opinion HUD is not operational at the current stage.
I did all you proposed, made new HUD for airco and also for the engine, nothing worked as it should:
  • sometimes the saved HUD would not be visible, and then it was visible after restarting (or not)
  • if the HUD was visible then sometimes nothing became visible when I clicked on it, or I got a screen with wrong values
  • had to spontaneous reboots of VCDS mobile (i.e. needed to logon again)
  • same behavior with the VCDS mobile app or Firefox
Screenshot_20260606_163526_Firefox.jpgScreenshot_20260606_163542_Firefox.jpgScreenshot_20260606_164208_Firefox.jpg
Regards,
Paul
  • Agree
Reactions: TTT
   #50
Shaun
Just to confirm, advanced measuring values works correctly though, right? I will look into the problems with the HUD.
Reactions: TTT
   #51
toulouse
France
C?ID=431984
Yes, AMV works. Would be nice if you could get HUD working, allows to predefine and save items you want to observe during a drive. BTW what does HUD stand for?
   #52
Shaun
HUD is an acronym for Head-Up Display. There is a test fix for the live data HUD now available on the alpha channel. I would be curious how well this works for you, and if there are any ongoing issues. If you are willing to test this, let me know and I will put your interface onto the alpha channel so that you can try this update.
   #53
toulouse
France
C?ID=431984
Yes, I want to try. Put me back on the alpha channel please. However my response can be slow (I'm working on the house of my daughter😉)
   #54
I switched your channel to Alpha for HUD testing. No rush on this but it will revert back to Beta on 2026-06-30. We can always increase that later.
   #55
toulouse
France
C?ID=431984
What version(s) I should have after a successful update?
   #57
toulouse
France
C?ID=431984
Sorry to say, but HUDs are still not working, values shown are not related to actual data (I had selected #30 and engine rpm) but had 0, 1 and 2 as result and non-relevant descriptions. I'm willing to test again after a major repair effort by you, for the moment HUDs are in my opinion not operational!
Sorry,
Paul
