Hi All.
New member and new user of the HEX-NET, which seem to be an amazing tool! The first read on my clutch (Gallardo LP560-4), is:
Clutch wear index: 4933
Clutch kiss point: 539
Clutch closed position: 1161
Clutch closed position (learned): 1469
HELP PLEASE!
How do I interpret this to something meaningful? I did a lot of research before posting here, however with every article/post I read is more confusing. From an AUDI R8 power transmission manual, I read that the values are in bits and shall be divided by 80 to give numbers in mm. Then subtract Clutch closed position from Clutch closed position (learned) to compute clutch wear. (1469/80=18.36mm), (1161/80=14.51mm). Clutch wear
18.36mm-14.51mm)= 3.85mm or 68.7%.
Is this correct? Could someone confirm or guide me on how to get clutch wear from the above numbers?
Thank you much for your time!
HELP PLEASE!
18.36mm-14.51mm)= 3.85mm or 68.7%. Is this correct? Could someone confirm or guide me on how to get clutch wear from the above numbers?
