2013 VW Tiguan P0121/EGR Problems
Jameel
England
C?ID=622695
Hello, I've been having issues over the last few months with P0121. I've recently purchased 2013 Tiguan 2.0 TDI. I took it to a shop 2 months ago and they said the throttle body was caked and they cleaned it out. This resolved the issue for a couple of months, but it is now beginning to re-occur. I did monitor it on VAG DPF for sometime and I noticed that our DPF also seems to be filling up pretty fast. Much faster than my 2010 golf we previously had. I also noticed that the EGR valve always showed at 60% at idle in VAG DPF. I recently decided to get VCDS and although I'm almost entirely clueless, i did manage to check the output value for throttle valve position and it shows 92.5% at idle. Decreases as I accelerate. My understanding is that this is not normal. Any reccomendations? I'm thinking I may be able to do the throttle body clean again myself. Would an adaptation help any, or is my EGR shot?
Thursday,13,November,2025,21:46:41:08261
VCDS Version: 25.3.2.0  HEX-V2 CB: 0.4671.5
VIN: WVGZZZ5NZEW034730   License Plate: SK63 XBT
Mileage: 142670km-88651mi   Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4C 52 53 56
          61 62 72
VIN: WVGZZZ5NZEW034730   Mileage: 142670km-88651miles
   Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9977
   Revision: 41H28---    Serial number: 00000000000000 CVN: 37112754
   Coding: 00190032040701080000
   Shop #: WSC 00706 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018E 003010
   ROD: EV_ECM20TDI01103L906018E_VW36.rod
   VCID: 2C06D98F4689333A02B-8078
   VINID: 9E65EAAAA15EA959C00C41C30048836400
5286 - Throttle Position Sensor (G69)
          P0121 00 [01101000] - Implausible Signal
          [Throttle/Pedal Position Sensor/Switch "A"Circuit Range/Performance]
                    Fault Frequency: 37
                    Mileage: 140605 km
                    Date: 2025.11.13.
                    Time: 09:06:12
                    Engine speed: 0.00 /min
                    Coolant temperature: 68  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 12.940 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Throttle valve adapter: specified value: 0.00 %
                    Throttle valve adapter: actual value: 1.18 %
                    Throttle valve adapter: offset closed: -12.07 %
                    Throttle valve adapter: status-Bits 0-7: 0
                    Throttle valve adapter: status-Bits 0-7: 55
                    Throttle valve adapter: status-Bits 0-7: 2
                    Throttle valve adapter: status-Bits 0-7: 8
                    Throttle valve adapter: uncond voltage actual value: 984.2 mV
Readiness: 0 1 0 0 0
   Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
   Component: J104   C6 450M VD04 0011
   Revision: --H07---    Serial number: 00000007381341
   Coding: 0040254
   VCID: 6E821387BC95012A6CF-803A
                    Reset counter: 44
                    Mileage: 142675 km
                    Date: 2020.04.05.
                    Time: 00:05:26
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.50 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   VCID: 79A830DBF95B5692C9D-802C
9473137 - Motor for Left Temperature Flap
          B108C 71 [00001000] - Actuator Stuck
                    Reset counter: 39
                    Mileage: 142540 km
                    Date: 2025.11.13.
                    Time: 12:14:14
9473393 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Reset counter: 39
                    Mileage: 142540 km
                    Date: 2025.11.13.
                    Time: 12:14:14
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 48180A3B8025F1C0408800C0340081644BD1AA88436D81206480C7000041
   VCID: 42DA9737D48DD54AD87-8016
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 05091  013 0204
   Serial number: N2955119    204!
   Coding: 009795
   Component: RLS 050913 05  54  0403
   Coding: 02304D
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 2
                    Mileage: 142651 km
                    Date: 2020.04.05.
                    Time: 09:03:01
                    Voltage: 14.80 V
                    Fault Status: 00101010
                    Reset counter: 29
                    Mileage: 142315 km
                    Date: 2020.04.05.
                    Time: 12:36:35
                    Voltage: 14.75 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231324902877
   Coding: 149203
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_002_VW36.rod
   VCID: 44D6912FCE19DB7AEAB-8010
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__209 VW10 HI   2318
   Revision: 27019000    Serial number: 003N5PHP7AD%
   Coding: 0012345
   VCID: 005E5D3F9601075A8E3-8054
   Subsystem 1 - Serial number: 6332MTS645352383
   Subsystem 2 - Serial number: 6342MTS623392393
   Subsystem 3 - Serial number: 6351HTS6JQDP8CKJ
   Subsystem 4 - Serial number: 6361HTS61RDP8CKR
   Part No SW: 5K0 953 521 BM    HW: 5K0 953 569 D
   Revision: FF010042    Serial number: 20130831200113
   Coding: 1082040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 78AE35DFC2514F9AB63-802C
   Coding: 820000
   Part No SW: 5N0 920 983 D    HW: 5N0 920 983 D
   Component: KOMBI         H04 0611
   Coding: 411F01
   VCID: 3632FBE788C579EA64F-8062
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 030913F2001966
   Coding: 356003
   VCID: 7AAA2FD7FCDD5D8AC07-802E
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4DC0B40B11D31A32355-8018
   Component: IMMO          H04 0611
   VCID: 6A8A1F978CFDED0A307-803E
   Revision: A1001003    Serial number: 7665192348
   Coding: 020100
   VCID: 2B04DA93430734020B1-807E
   Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
   Component: RNS315-EU   H73 0407
   Serial number: VWZAZ2N0477689
   Coding: 0400040104000C0000009002
   ROD: EV_RNS315EUV2UDS_VW32.rod
   VCID: 3530FCEB95C372F26D5-8060
   Component: EUR_W_V4  0050
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0504
   Revision: 13110009    Serial number: 0007363469
   Coding: 0202B4
   VCID: 382EF5DF82D18F9A763-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000008194024
   Coding: 000090
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 202    3501
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 40DE9D3FD681C75ACE3-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0504
   Revision: 15110009    Serial number: 0007351023
   Coding: 0202B4
   VCID: 3928F0DBB9DB969289D-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000008177337
   Coding: 000090
   Revision:   H19       Serial number: 00000001378531
   Coding: 0026167
   VCID: 3632FBE7844579EA64F-8062
   Component: Batt.regelung H58 1642
   Coding: 030F1859
   VCID: 71B808FBA1AB1ED271D-8024
   Component: J367-BDM  H07 0180
   Serial number: 40219045531491865068
End----------(Elapsed Time: 01:33, VBatt start/end: 14.6V/14.7V)-----------
------------------------------6 Faults Found-------------------------------
Rossatron
Scotland
C?ID=610069
I would be intrigued to see how the garage cleaned the EGR valve out on your engine. It's tucked up behind the rear of the engine partially under the DPF with a large cooler attached. I've never ever seen anyone clean one on that engine especially on a Tiguan as the transfer case is also in the way which makes it several hours work just to get it out never mind clean it and refit it. What did they charge you to do the job ?
The fault code above is for the throttle body located at the front of the engine on the plastic inlet manifold. It's likely restricted with carbon build up. Remove the metal pipe going into the manifold and check for carbon - or take pics and post here.
Jameel
England
C?ID=622695
Sorry you're right I got mixed up. It was the throttle body they cleaned. They showed me before and after picture, it was bad. But the issue came back within a couple months. I check my DPF in VAG DFP and although we don't do a tonne of long drives, it's always regenning and we always have more than half a tank. Just some basics I learned with my golf
Dr Sheldon
Windsor UK
C?ID=334979
Lets have a good look at the DTC
5286 - Throttle Position Sensor (G69) P0121 00 [01101000] - Implausible Signal [Throttle/Pedal Position Sensor/Switch "A"Circuit Range/Performance]
Please show me where in that fault code there is any mention of a EGR or Throttle Body being restricted or needing a clean !!
What as that a Sweet Shop ?? I am horrified that a "shop" would make that mistake !!
That DTC Refers to the Throttle Pedal !! Possibly the Position Sensor for the Throttle Plate or correlation of the two !!
It mentions "Sensor" - "Switch" - "Circuit" - "Implausible Signal"
Jameel
England
C?ID=622695
Well they only charged me £60 for the throttle body clean(No diagnosis fee), and it did resolve the issue temporarily. Also, as mentioned, the throttle body was very caked up and did actually need cleaning anyway. It seems you are suggesting that I choose a different shop next time, that there is a deeper issue. I just typed P0121 into Youtube and there's about 100 videos on how to clean the throttle body and nothing else.
I mention EGR just from my own Googling as my idle valve positions seem to indicate a problem. I'm no expert, maybe that's a TPS issue not an EGR issue.
I forgot to mention but the error code also started to give us stop start issues. When we stopped in traffic, the engine would stop, but when you put your foot back on the clutch, the engine would not restart. Told us to restart manually with the key. This issue also resolved with the throttle body clean and has not yet returned.
Dr Sheldon
Windsor UK
C?ID=334979
Indeed there could be 100 million videos !! - That is no concern of mine !!
Again. your car, your choice, your headache.
I am suggesting that one should take note of the DTC and diagnose accordingly !!
If that were in my workshop I would be studying intensely the Throttle Pedal and Flap signals back pinned at the ECU with a scope and looking to recreate the fault and identify the culprit.
VCDS graph looking at the same may paint the picture - You got to do the work and look.
From that point the fix is imminent !
Dr Sheldon
Windsor UK
C?ID=334979
I would say that is not abnormal !! It is showing 92.5 % Closed at idle so 17.5% Open !
However that 92.5% is not a measurement. It is a calculation of the 2 signals. You want to be looking at the raw data not the calculation !!
The calculation can only be of use when there are no faults in the car !!
Jameel
England
C?ID=622695
I am just beginning to look at these things in VCDS but itll be a while before I'm anywhere close to competent. I'm gonna take it into a different garage and hope they do a better job than the previous one. They offered to bypass the EGR when I collected the car, bit of a red flag considering it could be a different issue entirely as you have said.
On a positive note, I did manage to recode my battery woth VCDS which I why I purchased it. Saved me £50 so it's already paying for itself. Though the ross tech video on youtube wasnt much help, I had to navigate to channel 4 to find the drop down and just change the AH and change one digit onthe serial
If the throttle valve is cleaned in an unapproved way, such as with compressed air or in an ultrasonic tank, the chemical can be forced into the motor and contaminate the potentiometer. I would fit a new TB 03L 128 063 T, £333.60 retail inc. much less aftermarket such as a Conti/VDO 2803605001302
Rossatron
Scotland
C?ID=610069
Here you go:
Dr Sheldon
Windsor UK
C?ID=334979
The word "Possible" is used 6 times in that document (one Page)
The word "Pedal" is in the DTC but not in that Document - Something not right !! Discrepancies of that nature can and do cause chaos.
My way of dealing with that fault, I am certain, will lead me to a first time fix !!
In my mind there is no alternative, if there is room for improvement in my technique then I am listening !
I would for sure add an amp Clamp to look at the motor along side its Command which is likely PWM driven.
Jameel
England
C?ID=622695
I'll add to the special notes at the bottom that there was a recall for the EGR or something on 2013 Tiguan's, I only know this because I spent a couple weeks looking into my issues before this post. This would surely have been dealt with a long time ago by the previous/original owner.
I also found this on the tiguan forums that I'd forgotten about. His stop/start issue followed by P0121 is very similar to what was happening to me. I think we need a petrol, but I'm hoping it's a different issue because weve not long had the car and im very mindful of checking my DPF often and it's not having issues yet.1000011306.jpg
Dr Sheldon
Windsor UK
C?ID=334979
I also found this on the tiguan forums that I'd forgotten about. His stop/start issue followed by P0121 is very similar to what was happening to me. I think we need a petrol, but I'm hoping it's a different issue because weve not long had the car and im very mindful of checking my DPF often and it's not having issues yet.View attachment 3538
How about we pay little attention to a bloke who so far hasn't fixed the fault, or got the fault fixed in his car !!
Dr Sheldon
Windsor UK
C?ID=334979
That information is Vin Specific and readily available at ERWIN.
