MMI Optical Bus Errors after Battery Replacement – No Sound / Audio Looping
stom1
Pirate
Walking the Plank
Bulgaria
LP/SN
Hi everyone,
After replacing the battery on my 2007 Audi Q7 TDI, the car was without power for about two hours.
Once I installed the new battery, I ran an Optical Bus Diagnostic and got the following results:
Thursday, 13, November, 2025, 18:42:35:12345
VCDS Version: Release 24.10.0 (x64)
Data version: 20251001 DS350.0
VIN: WAUZZZ4L67DXXXXXX License Plate: -
Mileage: 241,000 km Repair Order: -
Control Module Part Number: 4L0 910 468
Component and/or Version: J533__Gateway H06 0040
Optical Bus Diagnostic: Standard
Controller Electrical Optical
19-CAN Gateway OK ERROR
07-Control Head (High/D3) OK ERROR
0E-Media Player 1 OK OK
47-Sound System OK ERROR
56-Radio OK ERROR
37-Navigation
The MMI system itself is working, but the radio plays sound for about 3 seconds, then cuts out for about 1 second — and this loop repeats endlessly.
The CD changer accepts and ejects discs just fine, but there’s no audio output.
Has anyone experienced this issue before?
Any ideas on what might be causing the optical bus errors or the repeating sound dropouts?
I suspect it might be related to a MOST ring break or possibly a power supply issue with the amplifier.
Thanks in advance for your help!
Scan performed with VCDS.
Dr Sheldon
Windsor UK
C?ID=334979
e,
Post a copy of the invoice for the battery
stom1
Pirate
Walking the Plank
Bulgaria
LP/SN
VARTA DYNAMIC AGM​
Range: 90-110Ah
Polarity: R+
Vehicle type: CARS
Dimensions: 393x175x190
Warranty - months: 36.0
Pole type: 1
Mounting: B13
Voltage: 12.0
Height: 175
Depth: 190
Capacity: 110Ah
Starting current: 920A
As noted in post #2 (Boki Ar) .
Dr Sheldon
Windsor UK
C?ID=334979
YES !
  • Disagree
stom1
Pirate
Walking the Plank
Bulgaria
LP/SN
We need full Auto Scan to be able to help.
[REMOVED] only scans from legitimate Ross-Tech interfaces are permitted.
Mike R
Virgo Supercluster
C?ID=126524
If you decide to buy a real Ross-Tech product through Ross-Tech or one of our officially recognized distributors we will be happy to help you. Let us know if you do so that we can update your status here on the forum.
-Mike
