Seat Leon 1P (GOLFV/VI platform) CCS HORN problem
Speedparts
Greece
C?ID=179205
Hello there.
Nice to finally have forums !
I recently retrofitted Cruise Control to the 1P Seat Leon .
It had lowline 1K0953549BM and I replaced it with highline 1K0953549BP .
I have no MFW. I put 0000022 as a recode . Everything works after adaptation etc (g85) but I have no HORN .CCS works, but also when I press SET the HORN is enabled. Sometimes when I open the blinkers.
Is there something wrong with the PINOUT ? or CODING ?
thanks :D
Speedparts
Greece
C?ID=179205
sorry I forgot to attach my autoscan: ( I cant seem to find the attach so I will copy paste )
Tuesday,13,May,2014,18:18:18:29510
VCDS Version: 14.5.0.0 (x64)
Data version: 20140501
VIN: VSSZZZ1PZ9R022830   License Plate:
Mileage: 47230km-29347mi   Repair Order:
Chassis Type: 1P (1K0)
VIN: VSSZZZ1PZ9R022830   Mileage: 47230km-29347miles
Address 01: Engine (CAX)       Labels: 03C-906-022-CAX.clb
   Part No SW: 03C 906 022 AQ    HW: 03C 906 022 B
   Component: MED17.5.20      G   2734
   Revision: D5H03---    Serial number: SEX7Z0H6311004
   Coding: 0000072
   Shop #: WSC 06402 785 00200
   VCID: 6BD510674AF6B66362-803E
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0016641
   VCID: 76E3311301B47B8B8D-8023
   Part No: 5P0 820 047 K
   Component: Climatic PQ35   012 0505
   VCID: 3561F61F5C32309344-8060
   Revision: 00H54000    Serial number: 00000005845319
   Coding: 018C0F2F00041000431D00000000000000017F075C400000000000000000
   VCID: 3365C80752462EA36A-8066
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 170608 022  0601
   Coding: 00056208
   Shop #: WSC 06402
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 221
                    Mileage: 47231 km
                    Voltage: 11.90 V
   Component: J234__A02 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPBQZCX
   Coding: 0012338
   VCID: 3B75E0277A16E6E3B2-806E
   Subsystem 1 - Serial number: 6333FTS664131508
   Subsystem 2 - Serial number: 6343FTS629551508
   Subsystem 3 - Serial number: 6353ETS6SVQ2UVNP
   Subsystem 4 - Serial number: 6363ETS6ULI3UVNH
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           051 0100
   Coding: 0000022
   Shop #: WSC 00028 028 00001
   VCID: 010952CF587A4C33A8-8054
   Part No: 1P0 920 807
   Component: KOMBIINSTRUMENT VO3 0450
   Coding: 0002101
   Shop #: WSC 80093 222 69422
   Part No SW: 1K0 907 530 Q    HW: Yâ
   Component: J533__Gateway   Ùâ
 0202
   Revision:   Ùâ
       Serial number: 0000
   Coding: E9801F060002020202
   Component: IMMO            VO3 0450
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 1T0 959 701 K    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1505
   Revision: 72009005    Serial number: 00000798888520
   Coding: 0000048
   VCID: 3F8D94376E0EFAC39E-806A
                    Fault Status: 01100101
                    Reset counter: 182
                    Mileage: 47231 km
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 00101100
                    Reset counter: 222
                    Mileage: 47231 km
                    Reset counter: 222
                    Mileage: 47231 km
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.077 H08 1901
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 98C000CC7F008505484B012004CC
   VCID: 000F57CB5370453BA7-8055
Address 52: Door Elect, Pass.        Labels: None
   Part No SW: 1T0 959 702 K    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1505
   Revision: 72009005    Serial number: 00000343688511
   Coding: 0000048
   VCID: 408F97CB13F0853BE7-8015
                    Reset counter: 182
                    Mileage: 47231 km
   Part No: 1P1 035 186 B
   Component: Radio BVX           0007
   Coding: 0020414
   VCID: 2B55D0678A76766322-807E
No Faults Found
Speedparts
Greece
C?ID=179205
The only I can think of is if this Steering Wheel with no MFW , is not compatible with the steering wheel module 1K0953549BP ? Thoughts ?
