Fuel Injector - Contribution/Balance fault code
   #21
Bracus
Canada
C?ID=392143
Here are some anomalies codes that i noticed. not sure what they all mean but there were some misfire ones and some catalytic messages that I don’t know what they all mean or if it’s just saying they are previously stored or currently stored, etc??. Any help would be appreciated if you also notice anything weird in some of these messages. I haven’t played around with VCDS a whole lot yet so I just barely skate by when it comes to things like programming changes like VIM or other settings and some of the advanced diagnostics stuff. @Dr Sheldon @Uwe @EuroX @SaVAGeSoot
Monday,17,November,2025,12:24:10:57689
Type 02 - VIN :  (Address E8)
Type 04 - Calibration ID : 7P1401C 0010AVABNOX00907807 0015NOX00907807 0035PMS00906261 4010 (Address E8)
Type 04 - Calibration ID : 0C8927755R_ 3374 (Address E9)
Type 06 - Calibration Verification Number : AF4B74E5 (Address E8)
Type 06 - Calibration Verification Number : 38D3FF82 (Address E8)
Type 06 - Calibration Verification Number : 755A2113 (Address E8)
Type 06 - Calibration Verification Number : 0E1FC39E (Address E8)
Type 06 - Calibration Verification Number : B916A756 (Address E9)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0B - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 1474
    Ignition cycle count : 7479
         NMHC Catalyst : 176 / 94
         NOx/SCR Catalyst : 898 / 1464
         NOx Adsorber : 0 / 0
         PM Filter : 201 / 91
         Exhaust Gas Sensor : 855 / 1460
         EGR and/or VVT : 691 / 1460
         Boost Pressure : 507 / 1474
         Fuel : 1019 / 1474
         Fuel : 1019 / 1474
         Fuel : 1019 / 1474
Monday,17,November,2025,12:24:57:57689
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4672.4
         Fuel : 1019 / 1474
Monday,17,November,2025,12:25:45:57689
Mode 0A: Permanent Fault Codes
Address 7E8: 1 Fault Found:
P0275 - Fuel Injector #5 (N83): Contribution/Balance Fault
Address 7E9: No fault code found.
Monday,17,November,2025,12:26:26:57689
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Failed or Incomplete
Heated catalyst monitoring:  Failed or Incomplete
Evaporative system monitoring: Not installed.
Secondary air system monitoring:  Failed or Incomplete
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring:  Failed or Incomplete
Exhaust Gas Recirculation:  Failed or Incomplete
Mode 01 - PID 01 : Readiness  --  Address 7E9
Misfire monitoring: Not installed.
Fuel System: Not installed.
Catalyst monitoring: Not installed.
Heated catalyst monitoring: Not installed.
Secondary air system monitoring: Not installed.
Oxygen sensor monitoring: Not installed.
Oxygen sensor heater monitoring: Not installed.
Exhaust Gas Recirculation: Not installed.
Monday,17,November,2025,12:29:46:57689
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Coding: 3701010101
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3C2132F266E5B27A92B-8068
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 27
                    Reset counter: 0
                    Mileage: 165366 km
                    Date: 2025.11.10
                    Time: 16:20:29
                    Control Module temperature: 13 ∞C
                    Voltage terminal 15: 13.946 V
                    Longitudinal_acceleration_vehicle_reference: -0.01 m/s≤
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H33 0035
   Serial number: 005000010801157
   Coding: 0AA118040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
   VCID: 372B2DDE5FC391227F9-8062
0161 - Video Cable for Image Processing
          C1107 02 [00001001] - Signal Failure
          [No_camera_found_on_startup]
                    Fault Frequency: 25
                    Reset counter: 0
                    Mileage: 165366 km
                    Date: 2025.11.10
                    Time: 16:20:38
                    Outside temperature: 8.5 ∞C
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 13.0 ∞C
End----------(Elapsed Time: 02:43, VBatt start/end: 14.4V/14.4V)-----------
------------------------------2 Faults Found-------------------------------
Bracus
Canada
C?ID=392143
I've suggested something on the other forum, but you fell off the planet after and started here.
I finally replied today.
Mileage: 165426km-102790mi   Repair Order:
                Address 01: Engine  (7P1 907 401 C)
12:50:42
  IDE00167   Exhaust temperature 1 bank 1 139.8 ∞C
  IDE00365   Injection quantity deviation cylinder 1 0.45 mg/stroke
  IDE00366   Injection quantity deviation cylinder 2 -1.60 mg/stroke
  IDE00367   Injection quantity deviation cylinder 3 -0.67 mg/stroke
  IDE00368   Injection quantity deviation cylinder 4 0.01 mg/stroke
  IDE00369   Injection quantity deviation cylinder 5 1.38 mg/stroke
  IDE00370   Injection quantity deviation cylinder 6 0.40 mg/stroke
   #24
Bracus
Canada
C?ID=392143
I replied as well.
did you see the other additional codes above? I was just scrolling through stuff on VCDS and started checking all the modes etc..... and it had some weird messages about the catalytic converter and a few other things seemed weird. Can you let me know if you can spot anything in those codes/messages?
   #25
Yes I did. Posting everything you can grab from VCDS just because it exists doesn't help anyone help you.... you clearly don't know what to do with VCDS, so only post information that is being requested. I see your readiness hasn't passed..... this tells me DTCs have been recently erased, and it hasn't had a lot of drive cycles since. Post details about this.
   #26
Bracus
Canada
C?ID=392143
I cleared the original post contribution/balance fault to see if it would come back. That’s all I cleared on nov 17. I’m sorry I don’t know what else you want me to scan or report. I can try and do it .... just guide me to tell me exactly what to grab! :)
   #27
Post that original fault. Is your scan from Nov 10 the latest you have?
Under engine controller and readiness
Readiness Status: 10000011 00001111 11101011 00000000
MIL Status: MIL ON
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 3
Under engine controller and advance measuring values
  IDE00584   Distance driven since erasing DTC memory 5275 km
  IDE00603   Number of driving cycles since erasing DTC memory 128
   #28
Bracus
Canada
C?ID=392143
MIL Status: MIL ON
Fuel System: Passed
The Nov 10 auto scan is my latest one I have saved. I have scanned since but that code didn’t come back after I cleared it. I wonder how long a driving cycle is.... maybe it will just come back. I don’t understand the DTC’s stored, etc. I thought I cleared them .... but is it like I just haven’t deleted the deleted codes, in a sense?
I think i just need a little guidance to take me to the next step. I can go scan and get whatever.... or i can take photos of the engine areas etc. I’ve got an oil change 165,000km and winter tires to put on. I could ask my shop that I use when outside of the dealer and see what they say. But what are the next steps in your opinion?
   #29
What are you not grasping?
You literally quoted me telling you what you need to do\post, but are now asking me what you should do next!
You should do everything I said in post #27. Post current scan and all those other things I've given you examples of.
   #30
Bracus
Canada
C?ID=392143
I had the contribution balance fault come back the other day and has since went away on it’s own again this time.
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 C    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    H21 0010
   Revision: 56H21---    CVN: AF4B74E538D3FF82755A21130E1FC39E
   Coding: 292A4012237600050000
   Shop #: WSC 95884 999 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
   ROD: EV_ECM30TDI0117P1907401C.rod
   VCID: 303916C2BAAD461A3E3-8064
   VINID: 9E65D48094A001650000510614AD580033
19185 - Fuel Injector #5 (N83)
          P0275 00 [10101100] - Contribution/Balance Fault
                    Mileage: 165486 km
                    Date: 2025.11.23
                    Time: 19:01:45
                    Engine speed: 755.50 /min
                    Normed load value: 67.5 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 62 ∞C
                    Intake air temperature: 5 ∞C
                    Voltage terminal 30: 14.640 V
                    selected gear-Bits 0-7: 255
                    Mean injection quantity: 18.92 mg/stroke
                    Engine oil temperature: 66.6 ∞C
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 64
                    Current operating mode_2-Bits 0-7: 2
                    Oxygen sensor 1 bank 1: lambda actual value: 1.479
Readiness: 1 1 0 0 1
Cool story... you've once again ignored all my suggestions! :thumbs:
Just sell the POS and get something with warranty.
   #32
Dr Sheldon
Windsor UK
C?ID=334979
I had a feeling go this way !!
@Bracus like to ask questions then ignore !! Worse, just flies off at a tangent.
Swap Injector 5 with another !
He gave a "like" to that comment and moved on with life !! He needs to be "Mushroomed!
   #33
Bracus
Canada
C?ID=392143
Guys i’m not looking to give up. I didn’t know how to grab the other things from VCDS. I’ll have another look at it today.
   #34
Bracus
Canada
C?ID=392143
MIL Status: MIL ON
Fuel System: Passed
Post #1 in this thread is the original fault.
   #36
Bracus
Canada
C?ID=392143
yeah - I cleared it in VCDS. It came back on it’s own temporarily but the engine light has went away on it’s own this time. I’m not sure what you were asking me to do next.
   #37
I've literally given you examples of what to post in #27, with direction on where to get it from....
You've also quoted me telling you this same thing, numerous times.
   #38
Bracus
Canada
C?ID=392143
I should add that for a while my car has had the rough idle where it feels like an out of rhythm drum beat also according to AI is likely a worn injector or head gasket leak or head cracked or scorned cylinder.... Here's what you were asking for though....
Mileage: 165637km-102922mi Repair Order:
Readiness Status: 10000001 00001111 11101011 11100000
MIL Status: MIL ON
Fuel System: Passed
Number of EOBD-related DTC(s): 1
15:40:20
IDE00584 Distance driven since erasing DTC memory 209 km
IDE00603 Number of driving cycles since erasing DTC memory 22
   #39
Dr Sheldon
Windsor UK
C?ID=334979
Any reason why ⬇️ you have ignored this for the third time ?
All this Data Logging is great if you want to confirm the DTC and share with others but it will not really fix the car !! I diagnose more than my fair share of cars, more than most techs because that is all I do all day.
I've never looked at data logging - just does not give me a twitch !! My opinion - A waste of time !! However I do love a Graph !! Graphs and Waveforms are sexy (to me) and they help !
   #40
Dr Sheldon
Windsor UK
C?ID=334979
And does AI tell you how to diagnose any of those three
Ai says "Likely" which is the same as "Not Likely"
Ai says dont swap Injectors - Should I now stop using my learnt and trusted diagnostic methods and go to AI for each one of my cars ??
I like AI and I use it - I love it !! It is not yet as good as I am with diagnostics - I would wipe the floor with it !!
And look at this ⬇️
What a load of Dogshit !!
