Fuel Injector - Contribution/Balance fault code
Bracus
Canada
C?ID=392143
Hi i’m having issue with my injector #5. Can anyone have a look and give me thoughts of what is going on? i just had a leaky fuel injector seal, valve cover gasket and much more replaced all in around that area. Here’s the code:
Monday,10,November,2025,16:19:42:57689
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4672.4
Mileage: 165366km-102753mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
          56 5F 62 65 69 6C 6D 72 85 8B 8E
Mileage: 165366km-102753miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 C    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    H21 0010
   Revision: 56H21---    CVN: AF4B74E538D3FF82755A21130E1FC39E
   Coding: 292A4012237600050000
   Shop #: WSC 95884 999 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
   ROD: EV_ECM30TDI0117P1907401C.rod
   VCID: 303916C2BAAD461A3E3-8064
   VINID: 9E65D48094A001650000510614AD580033
19185 - Fuel Injector #5 (N83)
          P0275 00 [10101100] - Contribution/Balance Fault
                    Fault Frequency: 35
                    Mileage: 164622 km
                    Date: 2025.11.06
                    Time: 14:24:08
                    Engine speed: 1937.00 /min
                    Normed load value: 74.5 %
                    Vehicle speed: 118 km/h
                    Coolant temperature: 94 ∞C
                    Intake air temperature: 10 ∞C
                    Voltage terminal 30: 14.820 V
                    selected gear-Bits 0-7: 8
                    Mean injection quantity: 29.28 mg/stroke
                    Engine oil temperature: 97.4 ∞C
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 16
                    Oxygen sensor 1 bank 1: lambda actual value: 1.367
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217)       Labels: 0C8-927-7XX-V2.clb
   Part No SW: 0C8 927 755 R    HW: 0C8 927 755
   Component: AL1000 AISIN  100 3374
   CVN: B916A756
   Coding: 010200000C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 40D946020A0DD69ACE3-8014
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 42914438052356 Dataset Number: 7P0012v____ 0001
   Coding: 5B7613C349246F58DAF8C89992D7F6607301
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CC16232364502FA22B-8018
   Part No SW: 4H0 907 064 FK    HW: 4H0 907 064 EK
   Component: BCM2 2.0      H36 0560
   Coding: 0D860016000000000000
   VCID: 77ABEDDE1FC35122BF9-8022
   Subsystem 1 - Part No SW: 7P6 959 754 AR    HW: 7P6 959 754 AR
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 0514000127033013
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3214000178740010
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CD    HW: 7P6 907 040 CD
   Component: Klima 2 Zonen H23 1406
   Coding: B686000A80
   VCID: 78A9EEE2125D5E5AB63-802C
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00000981971801
   Coding: 26000096D63C5D010020480780005D4C431C6608A2014261800000008040110000000000000000
   VCID: 6A8DC4AA5C71FCCA307-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    141213  033 0021
   Serial number: 90243400150108224357
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20472526
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
   Component: E1 - LDS  H02 0040
   Serial number: 00000000001401150043
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01D5F27B
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA109402000010548994
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231500902150
   Coding: 518D04
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D14A121E15CABAEAB-8010
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3C2132F266E5B27A92B-8068
10240 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_BLR_BLK8_31]
                    Reset counter: 21
                    Mileage: 162967 km
                    Date: 2025.10.22
                    Time: 19:08:15
                    Control Module temperature: 16 ∞C
                    Voltage terminal 15: 14.606 V
                    Velocity_vehicle_reference: 31.66 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.09 m/s≤
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 251
                    Mileage: 160613 km
                    Date: 2025.09.16
                    Time: 10:24:37
                    Control Module temperature: 25 ∞C
                    Voltage terminal 15: 14.212 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag04T H10 0043
   Revision: --------    Serial number: 003NK00276U5 Dataset Number: 7P6003V____ 1643
   Coding: 000000000000000000000000000000003454
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 43D3490E1B1BCD82D31-8016
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R14A220KYGA
   Serial number: 3575LRB405J20N9298I6
   Serial number: 3585LRB404R2UUQ2A0BB
   Serial number: 3517ARB404T30TVQ8PHP
   Serial number: 3527ARB404T30TVQB9D9
   Serial number: 3557BRB401E52O771CBS
   Serial number: 3567BRB401G52O76OJDJ
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
   Component: Lenks.Modul   H06 0005
   Revision: --------    Serial number: 01374OAB000A1
   Coding: 000CFD
   VCID: 3D273FF67D7FBB72A55-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0075660 TRW 20141210
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 H    HW: 7P6 920 883 H
   Component: Kombi         H13 0515
   Revision: 13240300    Serial number: 658090115592029
   Coding: 0B1733016F080008020004
   Shop #: WSC 131071 102 209715
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526_VW52.rod
   Part No SW: 7P6 907 530 N    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H13 6042
   Revision: --------    Serial number: 00000001691734 Dataset Number: 7P6067v____ 0041
   Coding: 000103AD00
   GVL: FB5F40655D7F680000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 32008703185701310164
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000130950737
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 34311AD24E357A3A5AB-8060
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H06 0021
   Serial number: 0357633118 Dataset Number: 7P6764V____ 0009
   Coding: 030221
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 3FDB45FE77F3A962B79-806A
   Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0021
   Serial number: 0357660891
   Coding: 030221
733440 - Control Module for Lane-Change Assist
          C1114 F3 [00001000] - Limited Visibility
                    Reset counter: 29
                    Mileage: 163871 km
                    Date: 2025.10.31
                    Time: 11:54:43
733696 - Control Module 2 for Lane-Change Assist
          C1115 F5 [00001000] - Limited Visibility
                    Reset counter: 29
                    Mileage: 163871 km
                    Date: 2025.10.31
                    Time: 11:54:44
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000132762880
   Coding: 011D17205E00453005080001
   VCID: 7AADF4EA2CD14C4AC07-802E
   Revision: 00002001    Serial number: 0357767894
   Coding: 0187123A68B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
   Component: GTO BT  H20 0059
   Serial number: 22014678
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.062  H01 0008
   Serial number:     WOO34338184
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.062  H01 0008
   Serial number:     WOO34404784
   Coding: 191100
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811002235308
   VCID: 75B7E7D605CF2332AD5-8020
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000133183699
   Coding: 011D17205E00453005080000
   VCID: 48C95E2222BDEEDA063-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1511400311    Dataset Number:             A001
   Coding: 01040200
   Shop #: WSC 54572 001 1048576
   ROD: EV_ParkbA7.rod
   VCID: 363520DA58C9682A64F-8062
   Slave 3:
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0016
   Coding: 012A02010B000400
   ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156A%0F8183369
   Coding: 020007010000000001
   VCID: 2411EA92FED5EABACAB-8070
   Part No SW: 7P6 035 664 G    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0881
   Revision: --------    Serial number: 273L40EB004954
   Coding: 020200050040E9EF79022B0E00000003F00001030000000000
   VCID: 3C2132F26665B27A92B-8068
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: DU8 SV Touch  H53 0046
   Serial number: VWZ8Z9RX8002RG
   Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000132779704
   Coding: 011C17200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0003
   Serial number: 30000000080387 Dataset Number: V03935244ST 0001
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 45D75716152FF3B2FD5-8010
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H14 0137
   Revision: 7C001001    Serial number: 0357043392 Dataset Number: 7P0124v____ 0008
   Coding: 0200000200000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
   VCID: 372B2DDE5FC391227F9-8062
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
   Component: TopView       H08 0115
   Revision: 11001001    Serial number: 82330JF0199585
   Coding: 0100000000010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3D273FF67DFFBB72A55-8068
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 362400628 Dataset Number: 7p0771v____ 0012
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000132794892
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H26 0035
   Revision: --------    Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
   Coding: 69020000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 392F2BE669D7875289D-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007063972_3059
   Part No SW: 7P6 907 541 C    HW: 7P6 907 541
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002011
   ROD: EV_AdaptCruisContr2VW526_002.rod
   VCID: 3A2D34EA6CD18C4A807-806E
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H33 0035
   Serial number: 005000010801157
   Coding: 0AA118040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
0161 - Video Cable for Image Processing
          C1107 02 [00001001] - Signal Failure
          [No_camera_found_on_startup]
                    Fault Frequency: 161
                    Reset counter: 251
                    Mileage: 161271 km
                    Date: 2025.09.30
                    Time: 13:28:19
                    Outside temperature: 21.0 ∞C
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 18.0 ∞C
End----------(Elapsed Time: 02:29, VBatt start/end: 14.2V/14.0V)-----------
------------------------------6 Faults Found-------------------------------
VIN: WVGDP9BP0FD005465   Mileage: 165366km-102753miles
Readiness: 0 0 0 1 1
   CVN: B916A756
   Coding: B686000A80
   Coding: 004DBD
   Coding: 025223
   Coding: 010300
   Coding: 518D04
   Coding: 3701010101
                    Reset counter: 251
                    Mileage: 165366 km
                    Date: 2025.11.10
                    Time: 16:20:29
                    Control Module temperature: 13 ∞C
                    Voltage terminal 15: 13.946 V
                    Longitudinal_acceleration_vehicle_reference: -0.01 m/s≤
   Coding: 000CFD
   Coding: 000103AD00
   Coding: 030221
   Coding: 030221
   Coding: 191100
   Coding: 191100
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: B00000
   Coding: B00000
   Coding: 0533314003
   Coding: 69020000
   Slave 1:
   Coding: 3701010101
   ROD: EV_BTR_002.rod
                    Reset counter: 251
                    Mileage: 165366 km
                    Date: 2025.11.10
                    Time: 16:20:38
                    Outside temperature: 8.5 ∞C
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 13.0 ∞C
End----------(Elapsed Time: 02:26, VBatt start/end: 13.3V/14.4V)-----------
------------------------------2 Faults Found-------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
With those miles I wouldn't be surprised if the injector was worn or something to do with that cylinder. Contribution/balance fault is directly related to a misfire on diesel engines.
Could also just be a bad seal at the injector..?
Bracus
Canada
C?ID=392143
is this catastrophic if i do not fix it immediately? I just had the seal of that injector repaired.
Bracus
Canada
C?ID=392143
Swap Injector 5 with another !
what causes the injectors to start to fail like this? Should i be worried that metal is in fuel lines and clogging up stuff?
Dr Sheldon
Windsor UK
C?ID=334979
No need to worry - It is only a car.
If there is, or you suspect, metal in the fuel system it would be wise to look now and catch it early. Remove the IMV and look there.
Remove the fuel filter - look there too.
saidi
Ales, France
C?ID=526854
Hello, the presence of metallic particles in the pipes is very likely, indicating a worn high-pressure pump.
Dr Sheldon
Windsor UK
C?ID=334979
At ~100k miles with no confirmation that an injector has failed, no misfire codes !!
Quite a bold statement to say metallic particles are very likely !! And that he should throw a new HPFP on it !!
Complete absence of any testing !!
That is very likely, very poor help !!
Bracus
Canada
C?ID=392143
I’ve had this code as recently as august... when dealer replaced gaskets and injector seal on driver side bank of engine. The dealer said they didn’t find this code (i think they did) and they must have cleared the code and just fixed gaskets and seals... etc. I could get receipt and explain exactly.
VCID: 303916C2BAAD461A3F9-8064
8839 - Cylinder 2 Injection Timing
P020B 00 [01100000] - -
Dr Sheldon
Windsor UK
C?ID=334979
Now that is a weird code, not seen it before !
Surely with common rail the injector fires when it is commanded by the ECM ??
Is this injector firing when not commanded ?
What event(s) have to take place to set that code ?
I would now either be looking at that engine very closely with an oscilloscope and / or swapping injectors around.
I have already suggested that !
Bracus
Canada
C?ID=392143
Darn, - this is where it gets sticky for me. Dealership had my vehicle under warranty. They replaced gaskets and valve cover and injector seals and maybe other things like that. BUT!!! - I gave it to them this this code stored and they deleted this code while it was there and gave it back to me fixed and said they never saw this code..... Do you think that’s fishy enough to suspect they didn’t want to fix that one under the diesel emission extended warranty because it’s something serious with the engine or would have been an expensive warranty fix?
Bracus
Canada
C?ID=392143
No i do not think !! I test, I measure, I work with Science !!
Give it back to them with that code stored - and repeat !
but they erased that code and it’s gone. that’s from august.
If it hasn't come back, why worry about it? :confused:
Dr Sheldon
Windsor UK
C?ID=334979
If it was erased in August and hasn't come back then do you need to worry ?
However !!
  • How much warranty do you have left ?
  • How many miles since it was cleared in August ?
Bracus
Canada
C?ID=392143
However !!
My warranty ended august 20 and they gave it back twice after this repair early september. I was shocked when after the initial diagnosis they said that fault code wasn’t even detected. They also blatantly turned off the DPF code I had currently on the display panel. I was a little pissed but they were fixing all the leaks so I tried to trust them. I had no choice because they actually tried to not even cover all the leaks under warranty. it’s been rough dealing with the dealership.
Only drove about 3000km since repair.
Bracus
Canada
C?ID=392143
But long enough to know that the fault is very likely non existent and resolved ??
Not sure what you are implying there ??
it went in the shop with the DPF light on the dashboard and they gave it back to me under this warranty claim but said the DPF light wasn’t even on. Without needing to explain.... the light was definitely on when i gave it to them.
I've suggested something on the other forum, but you fell off the planet after and started here.
