- Aug 26, 2022
- 17
- 0
- Sydney, Australia
- C?ID=522258
Firstly ill preface this by stating that i am very much a novice when it comes to this stuff. I can perform some very basic functions, but i can follow instructions.
I have a 2025 RS3 that is showing some strange codes.
I got the car in August and at about 1900km i did a scan, mainly to make sure VCDS was going to work on this car. It does, happy days. I noticed at the time there were a number of fault codes. I knew from my past car that its not uncommon for new cars to come with stored codes from various factory testing procedures. I stored the scan, cleared the codes and moved on.
Fast forward to last weekend... I am testing a diverter valve for Turbosmart in Australia so i was required to do a scan to clear any fault codes before doing the test. I noticed then that there was a couple of codes that had reoccurred. I saved the scan, cleared the codes and then ran the testing i was asked to do by Turbosmart. Interestingly none of the codes have anything to do with the diverter valve im testing.
Following the test, i ran another scan and a couple of the fault codes had reappeared. The one that concerns me most is the ABS fault, as i got a pop up waring of "missing ROD data". I then checked the very first scan i did at 1900km and the fault was present then when the car was bone stock. So it is obviously nothing i have done.
I realise there is not a lot of infor out there on this model of car just yet, so i am posting this in the hope to start building up the database of available knowledge out there.
If anyone has any input on these faults i would love to hear from you.
Last scan below...
Last scan below...
Sunday,09,November,2025,15:09:16:29246
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: WUAZZZGY8SA910332 License Plate:
Chassis Type: GY-AU38P PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 4B 52
5F 65 6C 75 82 A5 BB BC CA D6 D7 DE 811E 811F 8120 8121 8126 8127 C002 C003
VIN: WUAZZZGY8SA910332 Mileage: 8659km-5380miles
CA-Sunroof -- Status: OK 0000
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-DNWC) Labels: Redir Fail!
Part No SW: 5WA 907 404 A HW: 07K 907 309 P
Component: R5 2.5l TFSI H80 0002
Revision: D3H80001 Dataset Number: 07K909102L 0003 CVN: 44672BB48CBB1CE8
Coding: 0A2540322466050336300000000000000000000000000000
ASAM Dataset: EV_ECM25TFS0115WA907404A 001004
ROD: EV_ECM25TFS0115WA907404A.rod
VCID: 46D55B485820CEDAF4F-8012-R SFD+SFD2
VINID: 9E546AAAA5E92234490400C308743BB3F7
Readiness: 0010 0001
Part No SW: 0DL 906 558 AH HW: 0DL 300 014 R
Component: GSG DQ500 H06 0663
CVN: 1683E571
ASAM Dataset: EV_TCMDQ500064 001002
ROD: EV_TCMDQ381064.rod
VCID: 0A4DAF780CB86ABAD07-805E-R SFD
Parking lock:
Subsystem 1 - Part No SW: 5QS 907 483 A HW: 5QS 907 483
Component: SB_Auto H03 0060
Serial number: 9598224800874010
Selector lever:
Subsystem 2 - Part No SW: 8Y0 713 059 H HW: 8Y0 713 059 F
Component: AUDI_SBW_SAAM H06 0370
Serial number: 01571YCT00308-------
Address 03: ABS Brakes (J104) Labels:. 5WA-614-517-V2.clb
Part No SW: 8Y0 614 517 K HW: 8Y0 614 517 C
Component: ESC H31 0084
Serial number: 60535000010494 Dataset Number: 8Y0909504U 0002 CVN: 6B800DD6658C97A0
Coding: 54E8512CA44B2A9C0003559C9CA702C58A8F373489A800
ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006031
ROD: EV_Brake1ESCMQB37WUNECE_AU38P.rod
VCID: 44D141406E1CFCCAEAB-8010-R SFD+SFD2
1981 - Function Restricted due to Insufficient Voltage
U1400 00 [00100100] - -
[Uv_related_fail_replace]
Reset counter: 39
Mileage: 8639 km
Date: 2025.11.09
Time: 14:30:17
Vehlicle_speed: 0.0 km/h
Resolution Mileage: 296 m
Voltage_value_KL.30_ESC_V: 9.0 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: not completed successfully
Comparison_transverse_accleration: not completed successfully
Comparison_yaw_rate_sensor: not completed successfully
LWS_comparison: not completed successfully
Internal_failure_code: 01 F3
00 E0 00 00 04 88 10 08 80 00 00 00 00 2C 00 08 32 00 21 00 04
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AD HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0771
Serial number: --------------- Dataset Number: 8Y0909577C 0017
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w.rod
VCID: 1675CB084800BE5A44F-8042-R
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 3WA 907 007 F HW: 3WA 907 007
Component: Climatronic H01 5089
Serial number: 226112417292960 Dataset Number: 83H909862C 0045
Coding: 106100110011120120200000101011000000032100200000000000000000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: EV_ACClimaBHBE3ADV_AUE3.rod
VCID: 48C955705234D8AA063-801C-R SFD+SFD2
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001290325162718515
Air quality sensor:
Subsystem 2 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 10000000000000161137
Front A/C control head:
Subsystem 3 - Part No SW: 89A 820 043 F HW: 89A 820 043 F
Component: MEB SH H04 0151
Serial number: 11 S08.04.2500450232
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 086 CQ HW: 5WA 937 086 BL
Component: BCM37w_H238 0451
Serial number: BXJ53F040425951 Dataset Number: 8Y1909514C 0032
ASAM Dataset: EV_BCMwBL 004001
ROD: EV_BCMwBL_004_AU38P.rod
VCID: 221DE7D89448D2FAB87-8076-R SFD+SFD2
Subsystem 1 - Part No SW: 8Y2 955 119 B HW: 8Y2 955 119
Component: J400FRWISCH 067 0100
Serial number: 907353F0402505701430
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 25247557X81A955555B0
Subsystem 3 - Part No SW: 4K2 941 501 AC HW: 4K2 941 501 AC
Component: E1 - LTM H05 0013
Serial number: 92160XL20001W 11S
Valve block 1 in front seat driver side:
Subsystem 4 - Part No SW: 8Y0 907 182 HW: 8Y0 907 182
Component: J873 MKS_FSv H11 0012
Serial number: 714002020A0244821208
Valve block 1 in front seat passenger side:
Subsystem 5 - Part No SW: 8Y0 907 182 HW: 8Y0 907 182
Component: J872 MKS_BFSv H11 0012
Serial number: 714002020A0244823859
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 PF HW: 5Q1 953 549 E
Component: J527 SMLS MQB 005 0080
Serial number: 00000003042520240058
Subsystem 7 - Part No SW: 80A 962 243 HW: 80A 962 243
Component: GEB.F.Heckoef H17 0911
Serial number: 40919101
left tail lamp 1:
Subsystem 8 - Part No SW: 8Y0 945 423 B HW: 8Y0 945 423 B
H08 0003
Serial number: 0023106806L285240957
left tail lamp 2:
Subsystem 9 - Part No SW: 8Y0 945 429 A HW: 8Y0 945 429 A
H08 0003
Serial number: 0023139406L038250036
Right rear tail lamp 1:
Subsystem 10 - Part No SW: 8Y0 945 424 B HW: 8Y0 945 424 B
H08 0003
Serial number: 0023106906R017251459
Right rear tail lamp 2:
Subsystem 11 - Part No SW: 8Y0 945 430 A HW: 8Y0 945 430 A
H08 0003
Serial number: 0023139506R023251657
393216 - invalid data record
B2005 00 [00101110] - -
Mileage: 8639 km
Date: 2025.11.08
Time: 12:36:56
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status drive readiness: not ready to drive
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Operating condition: Normal mode
Voltage: 12.60 V
Outside temperature: 23.00 C
Light switch position: automatic
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5QS 919 298 A HW: 5QS 919 298
Component: PLA 12ch mid H01 0171
Serial number: 000028032594560 Dataset Number: V03935456B 0001
Coding: 8306026013
ASAM Dataset: EV_EPHBO2CVW3360000 001013
ROD: EV_EPHBO2CVW3360000.rod
VCID: 6099ADD0DAC480EAEE3-8034-R
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 567 HW: 5WA 907 819
Component: ACC Bosch MQB H50 0576
Dataset Number: 8Y0909863S 0001
Coding: 0E0B0807407140452247400000944008AA4020000200000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 005024
ROD: EV_FRONTRADARBOSCHVW380.rod
VCID: 0F7BBE6C77DA4F92079-805A-R SFD+SFD2
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3WA 907 376 E HW: 3WA 907 376 E
Component: DAEMPFUNGS-SG H10 0508
Serial number: 2C7752680823102 Dataset Number: 8Y0909554G 0003
ASAM Dataset: EV_DCC3CONTITEMIC 003014
ROD: EV_DCC3CONTITEMIC.rod
VCID: 50F97D10AA64106A5E3-8004-R
Address 15: Airbags (J234) Labels:| 5QS-959-655.clb
Part No SW: 5QS 959 655 T HW: 5QS 959 655 T
Component: AirbagVW50 004 0131
Serial number: 000000003C0TXRD Dataset Number: 8Y0909602BD 0001
Coding: A8CC008000CCC000000000800000000091540000A1540000C000003080AB4000
ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
ROD: EV_AirbaVW50SMEVW49X.rod
VCID: 74B1D1807E3C0C4A9AB-8020-R SFD+SFD2
Left seat belt tensioner:
Subsystem 1 - Part No SW: 85E 980 945 E HW: 85E 980 945 E
Component: BeltPretRevFL 007 0640
Serial number: 16042500170273000000
Right seat belt tensioner:
Subsystem 2 - Part No SW: 85E 980 946 E HW: 85E 980 946 E
Component: BeltPretRevFR 007 0640
Serial number: 17042500160154000000
Subsystem 3 - Part No SW: ----------- HW: 480 000 B04 19
Serial number: 3570000D8685522E5910
Subsystem 4 - Part No SW: ----------- HW: 480 000 B04 19
Serial number: 35800009768D29637D30
Subsystem 5 - Part No SW: ----------- HW: 480 050 704 19
Component: SideSensor_Dr 000 0149
Serial number: 3510000BEE093A56A380
Subsystem 6 - Part No SW: ----------- HW: 480 050 704 19
Component: SideSensor_Pr 000 0149
Serial number: 3520000C0E08A152E420
Subsystem 7 - Part No SW: ----------- HW: 480 051 C03 19
Component: FrontSensor_D 000 014A
Serial number: 35500009CDF74E06A5F0
Subsystem 8 - Part No SW: ----------- HW: 480 051 C03 19
Component: FrontSensor_P 000 014A
Serial number: 35600009CDF74E06E7F0
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8Y0 920 790 H HW: 8Y0 920 790 E
Component: FBenRDW------ H31 0550
Dataset Number: 8Y1909525H 0032
Coding: AC0D1AC47E9800080180E644200000180800000800
ASAM Dataset: EV_DashBoardFPK2pAU38X 004063
ROD: EV_DashBoardFPK2pAU38X_004.rod
Part No SW: 5QS 907 530 B HW: 5QS 907 530
Component: GW MQB 23 005 3093
Serial number: SMERBG110425009 Dataset Number: 8Y1909515G 0049
Coding: 000000000000000000000000000000000000000000000300000000000000000000000000000000000000000000000000
GVL: 3D08000002C840DCC0008002CC00104004004002004000300200000000000044
ASAM Dataset: EV_GatewMQBwBL 001018
ROD: EV_GatewMQBwBL_001_SK49.rod
VCID: 53F3721C9B726B72631-8006 SFD+SFD2
Generator:
Component: 5-01-18-01-03
Subsystem 2 - Part No SW: 3WA 915 181 A HW: 3WA 915 181 A
Component: J367-BDMHella H01 2362
Serial number: 6329566106
Subsystem 3 - Part No SW: 82A 951 523 L HW: 82A 951 523 L
Component: J453 MFL H09 0020
Serial number: 02S090020012506603GL
Subsystem 4 - Part No SW: 8B3 419 508 HW: 8B3 419 508
Component: J1158 KLR H02 0006
Serial number: 00000000000000065481
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 AH HW: 3Q0 909 059 D
Component: EBKV H10 0563
Serial number: BPA085260325018 Dataset Number: 8YF909524BC 0001
Coding: D703C5000000000000420821000049120000002000
ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005
ROD: EV_BrakeBoostVW37WUNECE_013.rod
VCID: 1675CB084800BE5A44F-8042-R SFD+SFD2
Address 2B: Steer. Col. Lock (J764) Labels:. 3WA-905-861.clb
Part No SW: 3WA 905 861 HW: 3WA 905 861
Component: ELV-MQB_UNECE H05 0063
Serial number: 25000085860004 Dataset Number: 8Y0909564B 0005
Coding: 8820000000000000
Shop #: WSC 00021 790 03034
ASAM Dataset: EV_ELVMarqUNECE 003006
ROD: EV_ELVMarqUNECE_003_VW27.rod
VCID: 0849957012B418AAC63-805C-R SFD+SFD2
Part No SW: 8Y4 959 760 HW: 8Y4 959 760
Component: MEM-FS 011 0372
Serial number: 2540401KA00891 Dataset Number: 8Y0909856C 0008
Coding: 01781A000000B0010083010101010000000000000000000000000000004000
Shop #: WSC 00021 790 03056
ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
VCID: 094F907409BE61A2D9D-805C-R
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 H HW: 2Q0 907 686 H
Component: HRE_Master H26 0320
Serial number: 14520070395447 Dataset Number: 8Y0909535E 0062
Coding: 9AA54750
ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
VCID: 3FDB4EAC07FA9F12B79-806A-R
Subsystem 1 - Part No SW: 2Q0 907 685 H HW: 2Q0 907 685 H
Component: HRE_Slave H26 0320
Serial number: 14520067964438
Part No SW: 3WA 959 593 A HW: 3WA 959 593
Component: TSG FS 001 0222
Serial number: Y3007YCQ003K7 Dataset Number: 8Y1909872D 0027
Coding: 003C0B005201008102001020
ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
ROD: EV_DCU4DriveSideMAXHKLO_VW41.rod
VCID: 54F171009E7C6C4A7AB-8000-R SFD+SFD2
Part No SW: 8YA 907 145 F HW: 8YA 907 145 E
Component: BASGEN1MQB37 504 1122
Serial number: 04654900 Dataset Number: 8Y0909852AB 0002
Coding: 00000000000000010001020101000100000001010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37.rod
VCID: 52FD7718A468627A687-8006-R SFD+SFD2
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5QS 907 338 D HW: 5QS 907 338 B
Component: FCM Baseline 019 3094
Serial number: 780542040025104 Dataset Number: 8Y1909583B 0008
Coding: 00000000090025F606202913020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiWBL 001008
ROD: EV_MultiModulContiWBL.rod
VCID: 5BE39A3CF3A2A332BB1-800E-R SFD
Part No SW: 3WA 959 592 A HW: 3WA 959 592
Component: TSG BFS 001 0222
Serial number: Y3007YD200HZE Dataset Number: 8Y1909873D 0027
Coding: 003C09005E01008102001020
ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
VCID: 53F3721C9B726B72631-8006-R SFD+SFD2
Part No SW: 8Y0 035 048 M HW: 8Y0 035 048 C
Component: MU-TH-ND-RW 057 4318
Serial number: GRO-63307.03.25 Dataset Number: 8Y1909545B 0018
Coding: 13810008004120000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU38P.rod
VCID: 42DD47587408F2FAD87-8016-R SFD+SFD2
Multimedia display unit 1:
Subsystem 1 - Part No SW: 8Y0 919 620 A HW: 8Y0 919 620 A
Component: CenterDisplay H40 0132
Serial number: AUZ8ZHR3201AEJ
Subsystem 2 - Part No: V03 959 823 MC
Component: MIB3_RW_ 1453
Compact disc data bank:
Component: Gracenote2 4012
Volume Control 1:
Subsystem 4 - Part No SW: 8Y0 919 616 E HW: 8Y0 919 616 B
Component: Sensoric LSR H33 0210
Serial number: 01S28.03.25007400107
Android control module:
Subsystem 5 - Part No SW: 8W0 919 806 C HW: 8W0 919 806
Component: AED2_AU_WW H54 0621
Serial number: YD700205042503191811
Media socket:
Digital Sound System Control Module 2:
Subsystem 7 - Part No SW: 8Y0 035 465 A HW: 8Y0 035 465 A
Component: B_A_3_P_0_AU H11 0100
Serial number: HHA-07317.02.2542960
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 8S0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0004
Serial number: 30000000028688 Dataset Number: 8Y0909850A 0007
ROD: EV_RDKHUFAU736_AU38.rod
VCID: 392F20B419DEB12289D-806C-R
Part No SW: 5QS 907 556 A HW: 5WA 907 556 E
Component: TV eEntry H35 0675
Serial number: FZ6ESP260325000 Dataset Number: 8Y1909460F 0001
Coding: 01014F0039040000
ASAM Dataset: EV_CamSysTVFicosBL 001004
ROD: EV_CamSysTVFicosBL_VW41.rod
VCID: 5AED9F38FC985A3AA07-800E-R
Front peripheral camera slave:
Subsystem 1 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R243 UmfKamSV H23 0070
Serial number: FCLMAR0601250004273B
Peripheral camera slave: left:
Subsystem 2 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R244 UmfKamSL H23 0070
Serial number: FCLMAR18032501060FB5
Right peripheral camera slave:
Subsystem 3 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R245 UmfKamSR H23 0070
Serial number: FCLMAR15032501090E50
Rear peripheral camera slave:
Subsystem 4 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R246 UmfKamSH H23 0070
Serial number: V6DCHN26022501060417
282656 - Cable for Video Signal to Display
C135B 01 [00101000] - Electrical Failure
[Video link to display unit - connection error]
Reset counter: 37
Mileage: 8639 km
Date: 2025.08.00
13820160 - Ethernet Databus Branch 6
U1231 00 [00101000] - No Communication
[Ethernet data bus branch 6 no communication]
Reset counter: 37
Mileage: 8639 km
Date: 2025.08.00
Part No SW: 571 035 286 A HW: 571 035 286
Component: OCUMQBW2023_H H09 0618
Serial number: 0000000412VIDNE Dataset Number: 8Y0909612L 0042
Coding: 01080601021111211000010003012E07111112111012111110
ASAM Dataset: EV_OCUMWB2023 001066
ROD: EV_OCUMWB2023_VW49.rod
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 8Y2 919 617 B HW: 8Y2 919 617 B
Component: HeadupDisplay H02 2417
Dataset Number: 8Y0909463C 0011
Coding: C6007000
ASAM Dataset: EV_HUDMQBwBL 002013
ROD: EV_HUDMQBwBL_002_VW42.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 F HW: 5WA 980 653 A
Component: MQB MFK 3.0 H12 3609
Serial number: EAF282204251040 Dataset Number: 8Y1909466B 0006
Coding: 00040C08216CC044109E44001020008000430000E00000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005071
ROD: EV_MFK3ValeoMQB_AU38P.rod
Part No SW: 3WA 959 595 A HW: 3WA 959 595
Component: TSG HFS 001 0222
Serial number: Y2007YCS011OE Dataset Number: 8Y1909897D 0027
Coding: 002C01000001008100001020
ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
ROD: EV_DCU4RearDriveMAXHKLO_VW41.rod
VCID: 56F58B0888807E5A84F-8002-R SFD+SFD2
Part No SW: 3WA 959 594 A HW: 3WA 959 594
Component: TSG HBFS 001 0222
Serial number: Y2007YCT002X2 Dataset Number: 8Y1909896D 0027
ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
ROD: EV_DCU4RearPasseMAXHKLO_VW41.rod
VCID: 55F78C04958675428D5-8000-R SFD+SFD2
Part No SW: 8Y1 907 594 AB HW: 4K1 907 594
Component: SAD_STG_1 010 0010
Dataset Number: 8Y0909469C 0013
Coding: 728008038101
VCID: 074B964C1FAA17D2CF9-8052-R
Part No SW: 4K0 941 592 BL HW: 4K0 941 592 B
Component: LMS_MQB H20 0153
Dataset Number: 8Y0909471J 0023
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 7BA3FABC53624332DB1-802E-R
Dataset Number: 8Y0909472J 0024
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4N0 035 502 D HW: 4N0 035 502 D
Component: WLC Front H14 0061
Dataset Number: 4N0909485A 0007
Coding: 400080
VCID: 2517FCC4856625C2DD5-8070-R
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 G HW: 5WA 962 133 E
Component: Kessy RSAD 122 0770
ASAM Dataset: EV_RSADVL37w 004018
ROD: EV_RSADHR37w_004_VW38.rod
VCID: 4CC16960464C348A22B-8018-R
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 004018
ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 004018
Address 8126: Trq distrib RearL axle (J492) Labels: 08E-907-554.clb
Part No SW: 08E 907 554 AA HW: 08E 525 130 A
Component: 4Motion H06 1059
Serial number: MC2000022503201
ASAM Dataset: EV_TorquSplitLeftMAGNA 002013
ROD: EV_TorquSplitLeftMAGNA_002.rod
VCID: 6D87C4E41D16DD82555-8038-R
Address 8127: Trq distrib RearR axle (J492) Labels: 08E-907-554.clb
ASAM Dataset: EV_TorquSplitRightMAGNA 002013
ROD: EV_TorquSplitRightMAGNA_002.rod
End----------(Elapsed Time: 02:43, VBatt start/end: 12.4V/12.3V)-----------
