New beetle 1.8t avc engine. O2 sensor, 16516 - Oxygen (Lambda) Sensor B1 S1 P0132 - 35-10 - Signal too High - Intermittent
tonyjgetb
Sweden
C?ID=292168
Hi
our New Beetle 1,8t -2000 has faultcodes on the o2 sensor.
I cant find any leaks (exhaust and intake).
i have post a csv file with , km/h, rpm, voltage on both sensor. Can anyone se and think about the data.
Regards Tony
Address 01: Engine Labels: 06A-906-032-AWD.lbl
Control Module Part Number: 06A 906 032 CK
Component and/or Version: 1.8l 5VT NB HS 3099
Software Coding: 00001
Work Shop Code: WSC 00066
VCID: 69E1FA2F1333FFD364-FFFE
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - Intermittent
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-10 - Open Circuit - Intermittent
LOG-01-013-054-332-361-413.CSV
Dr Sheldon
Windsor UK
C?ID=334979
First post an autoscan !!
Those fault codes you posted are not worth a toss !! Waste of time !!
For one the valuable Freeze Frame data is missing !!
Post the autoscan.
That's an ancient KW-1281 ECU. The KW-1281 protocol does not support freeze-frame data.
There might be freeze-frame for one of those fault codes in Generic OBD, Mode 2, if this ECU properly supports OBD-II, something that's also questionable since it has RDW software in it.
