T5.1 Cruise Control Retrofit - Coding Help!
Cooper680
C?ID=592717
Hi all,
New to all of this and must say I'm loving it so far and can't wait to learn more!
I have retrofitted cruise control to my VW T5.1 - wiring and stalks install completed. I have been doing some research into the VCDS adjustments that I need to make and can only find info on how to code the non UDS modules by entering code 11463 into Engine(01) coding 2.
With the UDS module how do I go about coding this in, long coding helper has nothing mentioning CCS in either modules (cent. elec. - 09 or engine - 01)
Thanks in advance :)
Saturday,08,November,2025,21:33:53:19062
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
Dealer/Shop Name: 001
Workshop Code: 001 00001 000001
VIN: WV1ZZZ7HZBH118192   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZBH118192   Mileage: 150420km-93466miles
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CD    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H41 9970
   Revision: 26H41---    Serial number: 00000000000000 CVN: CCAEB9E1
   Coding: 01114010230400080000
   Shop #: WSC 00816 210 97011
   ASAM Dataset: EV_ECM20TDI01103L906022CD 002014
   ROD: EV_ECM20TDI01103L906019AM_002.rod
   VCID: 6988647409FD452239D-803C
   VINID: 9E606AAAA1D8A92601048049083DDDD1C1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 508724AD89A50A9D24A3917AA96010
   Shop #: WSC 02736 790 49152
   VCID: 3632FF080843DADA64F-8062
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Revision: BO047001    Serial number: 0396 078110710
   Coding: B8A0303A0E612431802048103C2B8C500000430F60060000300000000000
   Shop #: WSC 02734 790 12345
   VCID: 372CF20C0F4923D27F9-8062
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Part No SW: 7E0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0010
   Revision: --------    Serial number: 47301100401609
   Coding: 008001
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K A01005
   ROD: EV_VW75XParkAssis4K_A01_VN75.rod
   VCID: 3138CC14E1ADFDE231D-8064
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL004MYCR Dataset Number: 7E0003v____ 0471
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3530F80415C5D1C26D5-8060
   Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
   Component: KOMBI         H04 0204
   Coding: 460200
   VCID: 29082474C97D8522F9D-807C
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 042300
   VCID: 70BE09102AA7B4EA7E3-8024
   Component: IMMO          H04 0204
   VCID: 6A8A1B780CFB4E3A307-803E
Address 56: Radio (J503)       Labels: None
   Part No SW: -----------    HW: -----------
   Component: Radio         --- 5814
   Coding: 16000440040000
   VCID: 6FBC0A6C3799AB12679-803A
                    Reset counter: 224
                    Mileage: 150427 km
                    Date: 2020.03.31.
                    Time: 02:17:01
                    Reset counter: 224
                    Mileage: 150427 km
                    Date: 2020.03.31.
                    Time: 02:17:01
                    Reset counter: 224
                    Mileage: 150427 km
                    Date: 2020.03.31.
                    Time: 02:17:02
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 224
                    Mileage: 150427 km
                    Date: 2020.03.31.
                    Time: 02:17:02
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
------------------------------4 Faults Found-------------------------------
NEtech
Denmark
C?ID=56995
Please try again, [01] Byte 5, [09] Byte 17.
It is documented.
Cooper680
C?ID=592717
Thank you so much @NEtech and @iichel. All working perfectly now. You forced me to look harder and it was so simple. Now for my admission of stupidity - it is quite funny..... I didn't realise you could scroll through Bytes in the long coder 😂. Now on to the MFSW - hopefully with my new knowledge it shouldn't be too difficult......
