I need "help reading VCDS codes" and figuring out what is wrong.
sheffieldyorky
South Wales, UK
C?ID=518372
Good morning, ladies & gents,
As stated in the title, I need "help reading VDCS codes" and figuring out what is wrong.
My background is that I am a retired Electro-Mechanical Engineer [H N D] with a degree. I now repair laptops to keep my brain happy.
Looking at this data, I have concluded that I am out of my depth. Please give me a laptop any day.
The reason for the thread is that I do not want to be sending the wrong part off for repair, only to be told that "this is not faulty, there will be an inspection and return postage charge"
I have registered with Ross-Tech (the VCDS people), and I am now waiting for verification !!!
My vehicle is an A3 1.9Tdi 8P1
The car has been running fine, as of yesterday, all the dash lights came on, and neither the REV counter nor the SPEEDO were working. While this was happening, the car drove as normal, no limp mode or anything out of the ordinary except for the "dash lights"
Some months back, I installed a media centre (see the images). Now here's the thing, more often than not it works fine, BUT sometimes it does not load, only occasionally, in addition to I also fitted a front dash cam, a rear camera, a GPS module and finally a DAB facility, all of these purchased at the same time as recommended by the supplier.
Any help, please would be more than welcome.
Tony
Sunday,09,November,2025,08:31:56:25455
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: WAUZZZ8P69A065216   License Plate:
Chassis Type: 8P-AU35 (1K0)
VIN: WAUZZZ8P69A065216   Mileage: 163250km-101438miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 S    HW: 03G 906 021 AB
   Component: R4 1,9L EDC  000SG  2917
   Revision: --H09---    Serial number: AUX7Z0H9FNM04K
   Coding: 0000071
   Shop #: WSC 00999 444 64523
   VCID: 372B2532034BB2427F9-8062
   VINID: 9D196AAAA220189440185081180B6FB7DA
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Mileage: 162102 km
                    Date: 2023.12.27
                    Time: 00:22:43
                    RPM: 819 /min
                    Load: 65.5 %
                    Voltage: 10.34 V
                    Bin. Bits: 00000100
                    Temperature: 2.7°C
                    Bin. Bits: 01110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 162102 km
                    Date: 2023.12.27
                    Time: 00:22:43
                    RPM: 819 /min
                    Load: 65.5 %
                    Voltage: 10.34 V
                    Bin. Bits: 00000100
                    Temperature: 2.7°C
                    Bin. Bits: 01110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Mileage: 162102 km
                    Date: 2023.12.27
                    Time: 00:22:43
                    RPM: 819 /min
                    Load: 65.5 %
                    Voltage: 10.34 V
                    Bin. Bits: 00000100
                    Temperature: 2.7°C
                    Bin. Bits: 01110000
Address 03: ABS Brakes (-----)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 13422012092800FFC80D04E5901F00813800
   Shop #: WSC 06314 000 00000
   VCID: 74B1D23E5EBD195A9AB-8020
Address 08: Auto HVAC        Labels: 8P0-820-047.clb
   Part No: 8P0 820 047 B
   Component: J255  Klima Man H07 0030
   VCID: 2F3B1D52FB1B7A82279-807A
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009056053
   Coding: 10A82F07A0141380EF00001C4F00000000084A1564010001002000000000
   Shop #: WSC 06314 000 08192
   VCID: 48C956CE7EB5CDBA063-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
                    Fault Status: 01101100
                    Reset counter: 66
                    Mileage: 162118 km
                    Date: 2023.12.27
                    Time: 00:01:00
                    Voltage: 14.20 V
00984 - Left Tail Light (M4)
                    Fault Status: 00101100
                    Fault Frequency: 8
                    Reset counter: 104
                    Mileage: 162499 km
                    Date: 2024.03.21
                    Time: 01:18:00
                    Voltage: 11.30 V
                    Reset counter: 66
                    Mileage: 162118 km
                    Date: 2023.12.27
                    Time: 00:01:00
                    Voltage: 14.15 V
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000 Dataset Number: 8P0909602L  0001
   Coding: 303142413039303030384A55305238503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 49CF53CA693F34B219D-801C
   Serial number: 34928RB400004632AB5N
   Serial number: 35028RB4000046745B9K
   Serial number: 35128RB400004632A79G
   Serial number: 35228RB4000046752066
   Serial number: 35547RB400006A2FB66-
   Serial number: 35647RB400006A2FB35X
12583424 - Powertrain Databus
          U0002 00 [00001000] - No Communications
          [High Speed CAN Communication Bus no signal/communication]
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Coding: 0000002
   VCID: 78A9E60E4ED57D3AB63-802C
   Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 2249H006008514
   Coding: 0006428
   Shop #: WSC 00186 785 00200
   VCID: 392F230A355FA43289D-806C
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Reset counter: 66
                    Mileage: 163252 km
                    Date: 2024.10.18
                    Time: 00:10:29
                    Reset counter: 66
                    Mileage: 163252 km
                    Date: 2024.10.18
                    Time: 00:10:29
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 158077 km
                    Date: 2020.12.18
                    Time: 02:23:00
   Component: J533__Gateway   @ 0202
   Revision:   @       Serial number: 2700
   Coding: E9801F060002020101
   VCID: 35372F3A194740526D5-8060
                    Reset counter: 106
                    Mileage: 162243 km
                    Date: 2024.02.17
                    Time: 02:30:34
01304 - Radio
                    Reset counter: 106
                    Mileage: 162243 km
                    Date: 2024.02.17
                    Time: 02:30:37
   Revision: D0H18006    Serial number: AUX7Z0H9FNM04K
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000564
   VCID: 43D341E24793EEE2D31-8016
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 232    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D0C46C0F91FAAF07-807E
00750 - Warning Lamp
                    Fault Status: 11101101
                    Reset counter: 66
                    Mileage: 163241 km
                    Date: 2024.10.18
                    Time: 08:36:57
                    Voltage: 10.88 V
                        DD
                    Temperature: 15.0°C
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 163252 km
                    Time: 31:63:63
                    Battery Volts: 12.1 V
                        PD
                    Temperature: 22.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980202002186D2D8505489AC637
   Shop #: WSC 00137 211 56823
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000564
   VCID: 44D142FE429DE9DAEAB-8010
Address 56: Radio
End----(Elapsed Time: 00:58, VBatt start/end: 11.5V/11.4V. VIgn 11.4V)-----
------------------------------17 Faults Found------------------------------
TTT
C?ID=547002
If this would be mine.
You repair laptops you say. Do you pay attention to power supply output do you?
What does above tell you?
So you have a scope, if you see this below fault code in a laptop, you would monitor the supply for a while to catch some spikes, do you?
Supply Voltage B+
If confirmed, you would work backwards in the laptop, to see what's up and where's the overvoltage coming from.
Suspect high resistance circuit between alternator and battery. You need to prove this with evidence.
sheffieldyorky
South Wales, UK
C?ID=518372
I got 3x Panasonic Toughbooks here (CF 52) that wont switch on ?
On one of them slide both batteries out and plug in your charger and now try and switch it on, it all down to a process of elimination, send me a P.M & let me know how you get on Tony
