- Jan 19, 2021
- 9
- 1
- Somerset, UK
- C?ID=425169
i have added a tow bar to my 2010 Audi A6 C6 Allroad.
I had no issues adding a Tow bar in CAN Gateway module 69
No issues in Backup Cam module 6C
No issues in Park Assist module 76
But I seem to have problems with coding the ABS Module to add a Tow Bar. (Brake Electronics J104) coding
My Original coding was 0016780.
When adding the ABS Module a Yellow hint box pops up advising to Subtract 0016384
when adding Towing Recognition Control Module (J345)
I calculated this to be 0000396
This figure is accepted
But it later produces an error to do with ABS Coding in Level Control.
Have I calculated the resulting code of 0000396 correctly?
Sunday,09,November,2025,21:25:13:34297
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: WAUZZZ4F4AN051373 License Plate: 24LYC
Mileage: 245210km-152366mi Repair Order: ABS Trailer
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 34 36 3C 42 46 4C 4F 52 53
55 56 5C 5F 62 69 6C 6D 72 76
VIN: WAUZZZ4F4AN051373 Mileage: 245210km-152366miles
4C-Tire Pressure II -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: OK 0000
69-Trailer -- Status: Sporadic communication error 1000
Address 01: Engine (CDY) Labels:. 059-907-401-CDY.clb
Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
Component: 3.0TDI EDC17G000AG 0080
Revision: 16H03--- Serial number:
Coding: 0125002C190F0128
Shop #: WSC 02145 785 00200
VCID: 2411E7C9F2D3A0BACAB-8070
VINID: 9D196AAAA1161117801410C70C7444CF5D
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent
Mileage: 244240 km
Date: 2025.09.29
Time: 14:49:26
RPM: 1449 /min
Speed: 48.2 km/h
(no units): -14.0
(no units): 112.0
Inj. Quantity: 12.0 mg/str
Absolute Pres.: 1183.2 mbar
Temperature: 29.7°C
U1017 - 007 -
Fault Status: 01100111
Mileage: 245215 km
Date: 2025.11.09
Time: 21:15:40
RPM: 819 /min
Bin. Bits: 00101100
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 02: Auto Trans
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AM HW: 4F0 614 517 BD
Component: ESP8 quattro H03 0100
Coding: 0016780
VCID: 6FBBD8E56B9553E2679-803A
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Reset counter: 115
Mileage: 245215 km
Date: 2025.11.09
Time: 21:17:37
Hex Value: 0x0000
Hex Value: 0x42A2
Hex Value: 0x0014
Hex Value: 0x07B2
Hex Value: 0x00FF
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 115
Mileage: 245215 km
Date: 2025.11.09
Time: 21:17:37
Hex Value: 0x0000
Hex Value: 0x42A2
Hex Value: 0x0014
Hex Value: 0x08B2
Hex Value: 0x00FF
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601470480
Coding: 0000151
VCID: 2517FACDF9E959B2DD5-8070
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01110010
Reset counter: 87
Mileage: 243157 km
Date: 2025.09.05
Time: 13:39:37
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000074 Serial number: 00000000699317
Coding: 0001302
VCID: 1D67D22DD1B99172855-8048
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Coding: 0033121
Shop #: WSC 02335 785 00200
VCID: 343117894233303A5AB-8060
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 02335
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 1577CA0D2589C9324D5-8040
Address 15: Airbags (J234) Labels:* 4F0-910-655-10.clb
Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003F9002055$ Dataset Number: 4F0909602AC 0013
Coding: 30314236303630303033554A305234463053
Shop #: WSC 02323 785 00200
ROD: EV_Airba10AURB4_AU56.rod
VCID: 35372A8D45C929326D5-8060
Serial number: 3574SRB40000A4A869CJ
Serial number: 3584SRB40000A490AA7B
Serial number: 3516HRB40259V7KGVKGG
Serial number: 3526HRB401V9V7KH341R
Serial number: 3554NRB4000052CB4FEG
Serial number: 3564NRB4000052CA5F9C
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90025093510169
Coding: 0122142
VCID: 270BF0C583E54BA2EF9-8072
Component: E0221 H06 0030
Address 17: Instruments (J285) Labels:. 4F0-920-KOM-V3.clb
Part No SW: 4F0 920 985 E HW: 4F0 920 985 E
Component: KOMBIINSTR. H06 0138
Revision: 00300000 Serial number: BGY026869
Coding: 2F566A030B012600010400
Shop #: WSC 02391 823 56573
VCID: 30391B99BA2B0C1A3E3-8064
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 N HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0035
Revision: MB200030 Serial number: 3000M09C0201DF
Coding: 000303
VCID: 3A2D39B16C57C64A807-806E
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Serial number: 00000000002790865723
Fault Frequency: 243
Reset counter: 155
Mileage: 241937 km
Date: 2009.01.09
Time: 00:43:20
Bin. Bits: 11000
Voltage: 13.00 V
Count: 12
Bin. Bits: 10011
Time: 25.40 s
Address 34: Level Control Labels: 4F0-910-553.clb
Part No SW: 4F0 910 553 D HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0030
Serial number: 00872000638400
Coding: 0000210
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 115
Mileage: 245215 km
Date: 2025.11.09
Time: 21:06:54
Fault Status: 11101101
Reset counter: 115
Mileage: 245215 km
Date: 2025.11.09
Time: 21:15:40
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001379940
Coding: 00781B00004011110000
VCID: 313F1E9DB121051231D-8064
03330 - Motor for Fore/Aft Adjustment
Fault Status: 01100101
Reset counter: 29
Mileage: 241924 km
Date: 2009.01.08
Time: 23:59:13
03333 - Motor for Cushion Angle Adjustment
Reset counter: 63
Mileage: 243422 km
Date: 2025.09.09
Time: 07:57:22
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 D HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 009 014-15
Coding: 0001104
VCID: 2F3B18E5AB1513E2279-807A
Subsystem 1 - Part No: 4L0 910 568 D
Component: J0770_SWA_Slave_H01 0020
Subsystem 2 - Serial number: 6PZ 009 014-35
Subsystem 3 - Serial number: 5F22.11.0900H010003CN11312ÿ
Subsystem 4 - Serial number: N11312ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000102563361
Coding: 011F56205E41410003
VCID: 46D55D4128AFB2AAF4F-8012
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01246796830000
Coding: 3285755
VCID: 323D1191B8273E0A487-8066
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 A HW: 4F0 907 274
Component: J793 RKA+ H02 0100
Revision: 00000506 Serial number: 00005061091023
Coding: 0623569
VCID: 221DE1D1E8C7AE8AB87-8076
Reset counter: 115
Mileage: 245215 km
Date: 2025.11.09
Time: 21:15:41
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0005
Voltage: 14.40 V
Temperature: 14.0°C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000677449
Coding: 0001103
VCID: 5EE595219C3FCA6ADCF-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000102544487
VCID: 45D75A4D15A9B9B2FD5-8010
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000321
VCID: 211FEEDDEDC1B592A1D-8074
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Coding: 0000027
Shop #: WSC 02325 785 00200
VCID: 698FB6FD5571BDD239D-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4F0 035 061 D HW: 4F0 035 061
Component: Radio U DAB H45 0024
Revision: AB001007 Serial number: 343L1097542857
Coding: 010103020100000000
VCID: 1D67D22DDDB99172855-8048
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H07 0070
Revision: 00H07018 Serial number: 800209C0300002
Coding: 0001205
VCID: 2019EBD9E6CBBC9AAE3-8074
Part No SW: 4E0 035 666 C HW: 4E0 035 666 C
Component: H-BN-EU H47 0047
Revision: -------- Serial number: 454AW0A7533663
Coding: 010101050002F3EF59000315EF6300030001
VCID: 2615FDC188EF52AAD4F-8072
Subsystem 1 - Part No: 8R0 060 884 J
Component: EUR 2010 1005
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356L/091157943
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
Component: Bedienteil MM H01 0060
Serial number: 00000001469838
Component: CD-Database 1293
00658 - Control Head
Reset counter: 155
Mileage: 242698 km
Date: 2025.08.20
Time: 17:00:42
Voltage: 12.40 V
02244 - Button in Control Head is Stuck
Fault Frequency: 18
Reset counter: 115
Mileage: 242698 km
Date: 2025.08.20
Time: 16:55:28
Voltage: 12.30 V
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000102551100
Coding: 010E54204041220003
VCID: 43D344551B9D8782D31-8016
Address 69: Trailer
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J9Z21OS
Coding: 1030505
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4F9 910 591 HW: 4F9 827 851 G
Component: ValeoHeckdeckel H29 0410
Revision: --H29001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81CFE95A83A8FA42B-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD11.12.09--H29001001B0214ÿ
Subsystem 4 - Serial number: 1B0214ÿ
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000102550991
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12620934201248
Coding: 0231416
VCID: 2A0D09F190F776CAF07-807E
End----------(Elapsed Time: 02:23, VBatt start/end: 14.4V/14.5V)-----------
------------------------------13 Faults Found------------------------------
Address 03,4F0 910 517 AM,recoded (Short coding),from,0016780,to,0000000,(02145/785/00200),
Address 03,4F0 910 517 AM,recoded (Short coding),from,0016780,to,0016384,(02145/785/00200),
Address 03,4F0 910 517 AM,recoded (Short coding),from,0016780,to,0000396,(02145/785/00200),
Address 03: DTCs cleared
Address 34: DTCs cleared
