2012 Mark VI Jetta 009218
DiscountTeramont
C?ID=604108
Got a check engine light and this was the autoscan...
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CJ HW: 07K 907 309 B
Component: 2,5l R5/4V G01 1156
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 78AE37FD7ED41D7AB63-802C
VINID: 0E69D480745A2137431C410720FA7E9CB9
009218 - EVAP Leak Detection Pump Control Circuit
P2402 - 000 - Short to Plus - MIL ON
Fault Status: 11100000
Mileage: 240928 km
Date: 2020.04.01.
Time: 07:07:10
Temperature: 90.0°C
Temperature: 34.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.446 V
I've never played around with the vacuum system before - do you guys rent / buy a smoke machine to test this or are there other diagnostic steps to take first? If I should buy / rent a machine, can anyone recommend one?
Dr Sheldon
Windsor UK
C?ID=334979
This is where you will go wrong !!
You have fallen flat on your face at the first Hurdle !!
READ THE FAULT CODE !!
009218 - EVAP Leak Detection Pump Control Circuit P2402 - 000 - Short to Plus - MIL ON
There is no leak !
It is the Pump and or its Control Circuit - Short to Plus !!
Output Test ?
Wiring Diagram from ERWIN and some testing !!
The forum would like a Full Autoscan posted !
DiscountTeramont
C?ID=604108
There is no leak !
Output Test ?
You are absolutely right! I appreciate your guidance - I'm very much a novice here and with all car repair. I gotta read more carefully.
Here's the full autoscan.
Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 25.3.2(x64) Data version: 20250822 DS365.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,09,November,2025,16:39:06:30059
VIN: 3VWDP7AJ8CM374478 License Plate: JTZ6388
Mileage: 240970km-149731mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDP7AJ8CM374478 Mileage: 240970km-149731miles
Self-Diagnosis Log
Page 2
Coding: 0000075
Mileage: 240928 km
Date: 2020.04.01.
Time: 07:07:10
Temperature: 90.0°C
Temperature: 34.0°C
Voltage: 12.446 V
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2175
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 005E5F1D260455BA8E3-8054
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: B14B400C492908FE8D0F02EB92211061A71000
VCID: 7DA026E95DF63852E55-8028
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000751623
VCID: 6FBC0CA10B9A5AC2679-803A
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371337110406
Coding: 7B994FB808AB0B0000382000240884CC00C2502E60000000302000000000
Shop #: WSC 00066 123 12345
VCID: 2F3CCCA1C71A1AC2279-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0742629
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
01598 - Drive Battery Voltage
Reset counter: 207
Mileage: 207337 km
Date: 2020.04.01.
Time: 15:16:43
Self-Diagnosis Log
Page 5
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM03RHD1 Dataset Number: 160003v____ 0154
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3436C3CD2EBC391A5AB-8060
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000ASP70/
Coding: 303036
Serial number: 3572MSME04274566ZZZR
Serial number: 3582MSME24514166ZZZN
Serial number: 3516KSME54102A16ZZZI
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME1E621116ZZZM
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME08637714ZZZU
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME7D517E14ZZZ4
Self-Diagnosis Log
Page 6
Part No SW: 5C6 920 951 B HW: 5C6 920 951 B
Component: KOMBI H04 0604
Coding: 170200
Shop #: WSC 00066 123 00123
VCID: 2A0ADDB5FC787FEAF07-807E
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: 70BE0FDD1AA4453A7E3-8024
Component: IMMO H04 0604
VCID: 6A8A1DB53CF8BFEA307-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660991358
VCID: 290822B9F9FE74F2F9D-807C
Self-Diagnosis Log
Page 7
Part No SW: 1K0 035 164 C HW: 1K0 035 164 C
Component: LOW NAR SDARS H02 0004
Revision: -----03S Serial number: VWZ4Z6M3275426
Coding: 01000400020006
VCID: 221A359584C8A7AAB87-8076
Reset counter: 242
Mileage: 207319 km
Date: 2020.04.01.
Time: 11:16:19
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661139378 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270C2481EF6A4282EF9-8072
End----(Elapsed Time: 01:09, VBatt start/end: 11.9V/11.7V. VIgn 11.6V)-----
------------------------------3 Faults Found-------------------------------
Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
DiscountTeramont
C?ID=604108
I'll do that going forward!
DiscountTeramont
C?ID=604108
Note that "Short to Plus" can be caused by a missing/bad ground in the circuit.
Well - at least I correctly interpreted one thing here this evening! Ha. Currently trying to source wiring diagrams, the provided links from @Dr Sheldon seem to require a subscription for users in the US and I'd rather not pay to subscribe if I can avoid it. I already own a multimeter. So my next step is to find the pump and control circuits and begin looking for shorts!
Dr Sheldon
Windsor UK
C?ID=334979
I would pay the dollar and download all the factory information and diagrams. For one payment you have them forever !! And they will be accurate !!
Bruce
Near Philadelphia, PA, USA
You can buy access to erWin in the US for $35 for a day. Download everything you want to a flash drive and keep for the future. You do not need a long term subscription.
DiscountTeramont
C?ID=604108
That's a good point as well. I'm gonna see if I can trace it out on my own first, this is a third car and a beater so it's a great opportunity for me to learn and if I make something worse it's ultimately not a big deal. If I can't sort it on my own, I'll subscribe and get the diagrams then cancel.
DiscountTeramont
C?ID=604108
The subscription Bruce refers to is only for 24 hours, there's no need to cancel as it self-cancels!
Not gonna lie that makes it so much more appealing haha
