VW Golf 2011. ABS ESP MK60EC1 incorrect coding.
Souriau
Newry, NI
C?ID=86928
This car came to me to try to recode the ABS.
The customer told me that the engine ECU was water damage and he got a replacement ECU.
When I checked and did a full scans.
I notice the chassis bunber of the scan was in correct
Orginal vIN is WVWZZZ1KZBP020341.
The Engine is WVWZZZ1KZBP068144,
Can anyone help , tp get the correct long coding for the ABS?
The cuatomer given me a partial code
13 3b 20 0d 09 28 00 02 00.
Saturday,08,November,2025,12:19:34:46973
VCDS Version: 25.3.2.0 (x64)  HEX-NET CB: 0.4671.4
VIN: WVWZZZ1KZBP068144   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZBP068144   Mileage: 158330km-98381miles
   Part No SW: 03L 906 023 DQ    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 6302
   Revision: --------    Serial number: 00000000000000 CVN: 48297BF5
   Coding: 00114034032501080000
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_ECM16TDI02103L906023DQ 003007
   ROD: EV_ECM16TDI02103L906023DQ_003.rod
   VCID: 78BC21BDC364365BEB-802C
   VINID: 9E69EAAAA05BA9280018804410D8579941
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [01100100] - -
                    Mileage: 158322 km
                    Date: 2025.11.07.
                    Time: 07:49:57
                    Engine speed: 921.25 /min
                    Normed load value: 22.7 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 64 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.569 V
                    Engine speed: 921 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 14.6 V
Readiness: 0010 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 113B200D092400FA880E04E8901A0040350000
   Shop #: WSC 00028 028 1048576
   VCID: 0444454D87AC62BBF7-8050
03306 - Coding Not Valid
                    Reset counter: 214
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:33:04
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 4161
                    Count: 45056
                    Count: 1
                    Count: 1024
                    Reset counter: 213
                    Mileage: 158322 km
                    Date: 2025.11.07.
                    Time: 07:49:57
                    Count: 16386
                    Count: 32768
                    Count: 12800
                    Count: 4233
                    Count: 51970
                    Count: 16
                    Count: 7936
                    Fault Status: 01100101
                    Reset counter: 213
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:30:30
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 45824
                    Count: 1
                    Count: 1024
                    Reset counter: 213
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:30:30
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 45824
                    Count: 1
                    Count: 1024
                    Reset counter: 213
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:30:30
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 8192
                    Count: 45824
                    Count: 1
                    Count: 1024
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000003
   Shop #: WSC 00028 028 00304
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D9200E9BC2683F308-8038
          B10AB F0 [00001001] - Too Low
                    Reset counter: 213
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 05:35:44
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AD
   Coding: 48180A3A8825F1C040080080340000E443510088436D8160648087200041
   Shop #: WSC 00028 028 00001
   VCID: 2F2EDAE17EAA31E37A-807A
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 16061  21  0512
   Coding: 009795
   Component: RLS 280610 05  54  0403
   Coding: 0330AD
                    Reset counter: 212
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:27:13
                    Voltage: 12.80 V
                        Term 50 On
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 212
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:27:13
                    Voltage: 12.80 V
                        Term 50 On
03020 - Local databus 2
                    Fault Status: 01101100
                    Reset counter: 214
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:27:17
                    Voltage: 12.75 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 C    HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0008
   Revision: --------    Serial number: 12991016151988
   Coding: 100001
   VCID: 3620EF8581F0002B39-8062
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA9M6TC   Dataset Number: 5K0003v____ 0085
   Coding: 00003133
   Shop #: WSC 01383 790 00056
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B36FEB1B2D2DD43C6-806E
   Serial number: 3572MSME5D403155ZZZT
   Serial number: 3582MSME10727354ZZZN
   Serial number: 3512QSME0C055340ZZZK
   Serial number: 3522QSME2C29661EZZZ1
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JFT00097 Dataset Number: 5K0953507BC D005
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 72A81395A5185C0BD5-8026
   Serial number: 70000000000000037532
   Coding: E20000
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Component: KOMBI         H03 0406
   Coding: 470B00
   VCID: 2D12C0E97CA643F348-8078
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 0602
   Revision:   H25       Serial number: 220610F2000497
   Coding: E9A07F0600061204000003
   VCID: 2E10C7E5B9A038EB71-807A
   Component: IMMO          H03 0406
   VCID: 6A980BF58DC894CB6D-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668220639
   VCID: 271E32C1565A69A3B2-8072
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 213
                    Mileage: 158316 km
                    Date: 2025.10.24.
                    Time: 04:37:43
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2140
   Coding: 0131764
   VCID: 3326D691528215031E-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 312ADC99A89E27136C-8064
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Coding: 0132020
   VCID: 3522E8895CF60B3330-8060
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3K6478262
   Coding: 0100040004
   VCID: 26003FC5515070AB89-8072
   Component: Batt.regelung H25 0602
   Coding: 030B185A
   VCID: 71AA1C99A81E67132C-8024
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790278205
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0131216
   Shop #: WSC 00028 028 1012545
   VCID: 3424D58D578C123B07-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0131216
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668222209 Dataset Number: 7P6035730B  0001
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 312ADC99609E27136C-8064
End----(Elapsed Time: 01:29, VBatt start/end: 11.5V/11.7V. VIgn 11.7V)-----
------------------------------11 Faults Found------------------------------
                Address 01: Engine
Control Module Part Number: 03L 906 023 DQ
  Component and/or Version: 1,6l R4 CR td H23 6302
           Software Coding: 00114034032501080000
            Work Shop Code: WSC 99999
Advanced Identification/FAZIT
     Identification: SJ8-FST
     Revision: --------
     Date: 06.10.10
     Manufacturer number: 0014
     Test stand number: 0033
Flash Status
     Programming Attempts(application): 0/0/0
     Successful Attempts(application): 0/0/0
     Programming Status: 00000000
     Flash Date-Workshop ID-Status:
     00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK)
Misc.
     Hardware number: 03L 906 023 A
     Workshop System Name: J623
     Workshop ID (Adaptation): 00000 000 00000
     Workshop ID (Coding): 83333 999 99999
     ASAM Dataset Revision: 003007
Car Info
     Chassis Number: WVWZZZ1KZBP068144
     Engine code: CAYC
Immobilizer
     General immobilizer info :
          Life status: 1
          Identity counter: 0
          Brand identification: 1
          Power class: 0x3A
          Count of adapted keys: 0
          Count of keys to be adapted by adaptation: 0
          Minutes remaining for Terminal 15 ON: 0
          Configuration status: 0
          Reserved: 0
     Lock times in minutes :
          Lock time password reset: 0
          Lock time login/Terminal 15 ON: 0
          Lock time key adaptation: 0
          Lock time leaving key adaptation: 0
          Lock time login special function: 0
     Immo Challenge: 00000000
VCDS Info:
     Labels: 03L-906-023-CAY.clb
     Readiness: No script available
Control Module Part Number: 1K0 907 379 AT
  Component and/or Version: ESP MK60EC1   H30 0105
           Software Coding: 113B200D092400FA880E04E8901A0040350000
            Work Shop Code: WSC 00028
     Identification: TT1-000
     Revision: 00H30001
     Date: 25.06.10
     Manufacturer number: 0301
     Test stand number: 0382
Flash Status
     Flash Date: 2000.14.00
     Flash Tool Code: 00000 000 00000
Misc.
     Hardware number: 1K0 907 379 AT
     Workshop System Name: J104
     Workshop ID (Coding): 1048576 028 00028
VCDS Info:
     Labels: 1K0-907-379-EC1-V1.clb
Control Module Part Number: 5K0 920 971 A
  Component and/or Version: KOMBI         H03 0406
           Software Coding: 470B00
     Identification: VDD-024
     Date: 28.06.10
     Manufacturer number: 1901
     Test stand number: 3852
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
     00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK)
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 920 971 A
     Workshop System Name: J285
     Workshop ID (Adaptation): 12345 790 00078
     Workshop ID (Coding): 00304 028 00028
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A04089
Car Info
     Chassis Number: WVWZZZ1KZBP020341
VCDS Info:
     Labels: 5K0-920-xxx-17.clb-SRI1
Control Module Part Number: 7N0 907 530 A
  Component and/or Version: J533  Gateway   H25 0602
           Software Coding: E9A07F0600061204000003
     Revision:   H25
     Date: 22.06.10
     Test stand number: 00F2
     Manufacturer number: 0497
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Required Conditions: 00000000
     Flash Date: 22.06.10
Software
     A5.6.6
     D3.7.9
     I3.7.9
     K3.7.9
     C5.6.6
     XKM_PQ35_V31.5
     XBL_8.10
Misc.
     Hardware number: 1K0 907 951
     Lot Number: 000
     Type Lock: 0000
VCDS Info:
     Labels: 7N0-907-530-V1.clb
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H03 0406
           Software Coding: 000000
            Work Shop Code: WSC 00000
     Date: 28.06.10
Flash Status
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Workshop ID (Adaptation): 00056 790 01383
     Workshop ID (Coding): 00000 000 00000
     ASAM Dataset Revision: A03008
Car Info
Immobilizer
     Transponder ID (Current val.): 160A66DC
     Transponder ID 1: 160A66DC
     Transponder ID 2: 16107245
          Life status: 6
          Identity counter: 0
          Power class: 0x3A
          Count of adapted keys: 2
          Count of keys to be adapted by adaptation: 2
          Reserved: 0
     Immo Challenge: F094354B
VCDS Info:
     Labels: 5K0-920-xxx-25.clb
Spacewalker
Poland
C?ID=159607
ABS use a VIN from cluster , not from ECU
WVWZZZ1KZBP020341 this is vin from 25th
this coding is right for that VIN 113B200D092400FA880E04E8901A0040350000
113B200D092400FA880E04E8901A0080350000 check this, because in old coding was LHD, not RHD
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Both codings starting with 11 are LHD.
First try for RHD w/o TPMS: 133B200D092400FAC80E04E8901A0081310000
With TPMS (PR-7K9): 133B200D092400FAC80E04E8901A0081350000
Souriau
Newry, NI
C?ID=86928
Monday,10,November,2025,15:54:57:46973
VCDS Version: Release 25.3.2 (x64) Running on Windows 11 x64
                Address 03: ABS Brakes       Labels: 1K0-907-379-EC1-V1.clb
Control Module Part Number: 1K0 907 379 AT    HW: 1K0 907 379 AT
           Software Coding: 133B200D092400FAC80E04E8901A0081310000
            Work Shop Code: WSC 00028 028 104857
                      VCID: 0444454D97AC62BBF7-8050
Fault Codes have been Erased
                    Reset counter: 214
                    Mileage: 158334 km
                    Date: 2002.14.01
                    Time: 05:33:49
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 8192
                    Count: 39168
                    Count: 1
                    Count: 64512
                    Reset counter: 214
                    Mileage: 158334 km
                    Date: 2002.14.01
                    Time: 05:33:49
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 39168
                    Count: 1
                    Count: 64512
                    Reset counter: 214
                    Mileage: 158334 km
                    Date: 2002.14.01
                    Time: 05:33:49
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 39168
                    Count: 1
                    Count: 64512
Monday,10,November,2025,16:03:49:46973
           Software Coding: 133B200D092400FAC80E04E8901A0081350000
                    Reset counter: 214
                    Mileage: 158334 km
                    Date: 2002.14.01
                    Time: 05:35:56
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 8192
                    Count: 39168
                    Count: 1
                    Count: 64512
                    Reset counter: 214
                    Mileage: 158334 km
                    Date: 2002.14.01
                    Time: 05:35:56
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 39168
                    Count: 1
                    Count: 64512
                    Reset counter: 214
                    Mileage: 158334 km
                    Date: 2002.14.01
                    Time: 05:35:56
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 39168
                    Count: 1
                    Count: 64512
Westbury, UK
PLEASE use the forum editor </> icon when posting an Auto-Scan to proerly add code tags instead of just using quote, it makes them MUCH easier to read.
Souriau
Newry, NI
C?ID=86928
@Souriau, next try: 133B200D092400FAC80E04E8901A0091310000
Thanks,
This code match perfect.
Monday,10,November,2025,21:03:07:46973
Readiness: 0010 1000
   Revision: 00H30001
   Coding: 133B200D092400FAC80E04E8901A0091310000
   Revision: 00009001
   Coding: 0000000003
   Revision: 00103 AD
   Coding: 009795
   Coding: 0330AD
                    Reset counter: 215
                    Mileage: 158335 km
                    Date: 2025.11.10.
                    Time: 21:00:40
                    Voltage: 12.40 V
                        Term 50 On
                    Reset counter: 215
                    Mileage: 158335 km
                    Date: 2025.11.10.
                    Time: 21:00:40
                    Voltage: 12.40 V
                        Term 50 On
                    Reset counter: 215
                    Mileage: 158335 km
                    Date: 2025.11.10.
                    Time: 21:01:15
                    Voltage: 12.40 V
                        Term 50 On
   Coding: 100001
   Coding: 00003133
   Coding: 1082140000
   Coding: E20000
   Coding: 470B00
                    Reset counter: 215
                    Mileage: 158335 km
                    Date: 2025.11.10.
                    Time: 21:01:48
   Coding: 0131764
   Revision: 00H17000
   Coding: 0132020
   Coding: 0100040004
   Coding: 030B185A
   Coding: 0131216
   Coding: 0131216
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.4V)-----------
------------------------------4 Faults Found-------------------------------
Boki Ar
C?ID=57300
NIV Jetta 2,0 High 103 TDI
Type 162X9M
Eng CJA MSV
Paint L041 QR 6328
X9A CK4 G1A H4B J1D K8B 4UM D91 U5C
1ZP V0A OA2 ON9 1AT 1C2 1G4 2ZM 2JG 5RR
7K6 2VA 5SH 7KK 4X3 7GB 3L3 3Q6 QGO 3YQ 4A3 8ES
L14 G18 8AX B0D 1N3 3FE 4K0 4R4 8Y0 8L6 9AB
This is how every request for coding calculation should contain. If we had all the data, we would have succeeded on the first try.
It is important that You finish job, we took the hard way, based on experience. :cool:
