2013 Passat TDI - High Pressure fuel reading all over the place
npow_pow
Ontario, Canada
C?ID=600096
Hey Everyone I am new here.
I have 2013 Passat tdi that has a fuel pressure issues. I have swap the rail reg, fuel temp sensor, fuel metering valve, ECU, engine wiring harness and fuel injectors.
It's throwing a P0191 - Implausible Signal. Which I think points to a bad rail pressure sensor. I swapped the sensor and no difference in performance leading to the above part canon list....
There is a voltage dip at a consistent interval at any RPM or load. It seems like the voltage rail is getting shorted to GND or pulled to GND by a controller at a relatively consistent interval. At the voltage dip the metering valve on top of the high pressure pump make a clicking noise (like a solenoid getting slammed closed or open). After replacing the metering valve nothing changes. I'm not sure if this is a cause or affect from the ECU reading a bad sensor. But I assume the P0191 is from the voltage dipping to the low threshold throwing the code. The fuel pressure control deviation is all over the place. I have checked and cleaned all GND points...
Has anyone dealt with something like this before?
What sensors is the ECU reading to stay running?
Does the ECU supply these sensor voltage?
I have VCDS but I'm not very good at using it. The car is also deleted.
Thanks a bunch for any input!
Nolan
npow_pow
Ontario, Canada
C?ID=600096
Saturday,08,November,2025,16:29:16:02933
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250228 DS364.1
VIN: 1VWBN7A39DC100031   License Plate: NOV8TH2025
Chassis Type: A3-VW41 (7N0)
          77
   Component: R4 2.0l TDI   X21 9982
   Revision: 71X21---    Serial number: 00000000000000 CVN: 85510A3700000000
   Coding: 001D0012042400000000
   Shop #: WSC 23116 035 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B24EF4213E517829A3-806E
   VINID: 0669D27874432544C100000304BF109791
8784 - Fuel Pressure Sensor (G247)
          P0191 00 [11101101] - Implausible Signal
                    Fault Frequency: 110
                    Mileage: 351757 km
                    Date: 2127.14.31
                    Time: 04:52:26
                    Engine speed: 1292.00 /min
                    Normed load value: 44.3 %
                    Vehicle speed: 10 km/h
                    Coolant temperature: 52 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 13.460 V
                    Engine status: COENG_RUNNING
Readiness: 1 1 0 X X
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05651213    Serial number: 00001211281096
   Shop #: WSC 00211 003 1048576
   VCID: 2416343E82DB487ACB9-8070
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 219
                    Reset counter: 2
                    Mileage: 351721 km
                    Date: 2063.14.31
                    Time: 05:18:57
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 36
                    Mileage: 353185 km
                    Date: 2063.14.31
                    Time: 01:48:13
   Revision: 00H31001
   Coding: C54BC0F5492200FAA30B03E7921A0042271000
   Shop #: WSC 09003 957 00200
   VCID: 7DA0215A4DF1D9B2E47-8028
   Part No SW: 561 907 044 R    HW: 561 907 044 R
   Component: Climatronic   H03 0405
   Revision: 00001K01
   Coding: 0030001002
   VCID: 26122E36F867BA6AD5D-8072
9473137 - Motor for Left Temperature Flap
          B108C 71 [00001000] - Actuator Stuck
                    Reset counter: 194
                    Mileage: 358149 km
                    Date: 2127.14.31
                    Time: 07:35:04
          B10AB F0 [00001001] - Too Low
                    Reset counter: 20
                    Mileage: 346022 km
                    Date: 2127.14.31
                    Time: 23:47:01
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B802B2AD408880001160085480071008640801560648060000C70
   VCID: 74B6047E7EBB98FA9B9-8020
00984 - Left Tail Light (M4)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 28
                    Reset counter: 161
                    Mileage: 346022 km
                    Date: 2063.14.31
                    Time: 23:47:08
                    Voltage: 14.25 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Fault Status: 00101010
                    Reset counter: 195
                    Mileage: 346266 km
                    Date: 2063.14.31
                    Time: 10:48:50
                    Voltage: 14.30 V
   Serial number: 003MWM05GJ6$   Dataset Number: v0030126560 0126
   Coding: 00004D4A
   Shop #: WSC 00000 999 99916
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B0397A754181F2AC7-8020
   Serial number: 6940000Y130000PFNN0E
   Coding: 303044
   Serial number: 3572MSME216A1476ZZZU
   Serial number: 3582MSME77471073ZZZU
   Serial number: 3516KSME334B4121ZZZI
   Serial number: 3526KSME400A4421ZZZF
   Serial number: 3556LSME3D6D0E20ZZZ2
   Serial number: 3566LSME18290420ZZZL
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20121105100728
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B23E7668478AEAA5D-8022
   Coding: E20000
Address 17: Instruments
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 16011303290446
   Coding: 461000
   VCID: 76B23E7668C78AEAA5D-8022
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R3AKR06
   Coding: 0000002
   VCID: 63947722C7550F42F23-8036
   Component: IMMO          H07 0705
   VCID: 6A8A1A062CFF5E0A315-803E
   Revision: A1001003    Serial number: 7663795689
   Coding: 010100
   VCID: 2A0ADA06ECFF9E0AF15-807E
   Revision: 13110009    Serial number: 0006110688
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE44FC2F3A53782BA3-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 372CF372234D33E27EB-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FBC0B12179DBB2266B-803A
   Serial number: 53388786011231500248
   Coding: 181100
   Revision: 15110009    Serial number: 0006090751
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE64CDEF6AB30BAB39-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6N3491993
   Coding: 2100040002000B
   VCID: 2510293A85E1B172DC7-8070
                    Reset counter: 20
                    Mileage: 346022 km
                    Date: 2063.14.31
                    Time: 23:47:02
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663971334 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002_VW25.rod
   VCID: 3A2AEA461CDF2E8A815-806E
End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
------------------------------8 Faults Found-------------------------------[/code]
Address 0x01,03L 997 009 J,UDS Selective Output Tests,IDE00219-Fuel pump electronics
Address 0x01,03L 997 009 J,UDS Basic Settings,IDE00468-Resetting of learned values of difference pressure sensor
Address 0x01,03L 997 009 J,UDS Basic Settings,IDE02147-Resetting of learned values of average quantity adaptation
Address 01,03L 997 009 J,channel IDE02637-Adaptation for metering quantity measurement,adapted from,04 ,to,03 ,
Address 01,03L 997 009 J,channel IDE02637-Adaptation for metering quantity measurement,adapted from,03 ,to,04
