2011 Audi A4 All Steering buttons not Working(Volume,Mode etc)
lebohang.bulane
Maseru, Lesotho
C?ID=601784
I changed my battery after the vehicle was idle without a battery for about a week. When i got a new battery all battons on the steering were not functioning. Please help below is the scan results
Saturday,08,November,2025,10:00:05:04520
VCDS Version: 25.3.2.0  HEX-V2 CB: 0.4671.5
VIN: WAUZZZ8K3AA073959   License Plate: A955BDR
Mileage: 88140km-54767mi   Repair Order: 08_11_2025
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 52 53 55
          56 57 62 72
VIN: WAUZZZ8K3AA073959   Mileage: 88140km-54767miles
Address 01: Engine (------CDHB)       Labels:| 06H-907-115-V1.clb
   Part No SW: 8K1 907 115 M    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H11 0002
   Revision: A5H11---    CVN: 0944C810
   Coding: 0104000C02070020
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM18TFS8K1907115M A01002
   ROD: EV_ECM18TFS.rod
   VCID: 382DF99802D2914A763-806C
   VINID: 9D196AAAA21B0D14401C32452490558CEB
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00101111] - -
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 28 °C
                    Intake air temperature: 23 °C
                    Ambient air pressure: 840 mbar
                    Voltage terminal 30: 11.756 V
4714 - Steering Column Control Module
          U0212 00 [00101111] - No Communications
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
2886 - Catalyst System; Bank 1
          P0420 00 [01100101] - Efficiency Below Threshold
                    Mileage: 88051 km
                    Date: 2025.11.05
                    Time: 10:45:27
                    Engine speed: 1271.50 /min
                    Normed load value: 56.1 %
                    Vehicle speed: 45 km/h
                    Coolant temperature: 78 °C
                    Voltage terminal 30: 14.041 V
Readiness: 0000 0001
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 T    HW: 0AW 927 156 H
   Component: 0AW 18TFSIRdW H03 0009
   Revision: --H03---    Serial number: 0000001216 CVN: 00009912
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381.rod
   VCID: 44D59D684E1AC5AAEAB-8010
5676 - Steering Column Control Module
          [Lost Communication With Steering Column Control Module No communication]
                    Fault Frequency: 33
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Engine speed: 100.00 /min
                    Transmission input speed: 1 /min
                    Transmission output speed: 1 /min
                    Engine torque: -32 Nm
                    ATF temperature: 24 °C
                    Accelerator pedal position: 0.0 %
                    Clutch status: 1
5677 - No Communications with Steering Angle Sender (G85)
          [Steering angle sender -G85 No communication]
                    Fault Frequency: 33
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Clutch status: 1
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Coding: 050500
   VCID: 02595B70140E0B9A987-8056
                    Fault Frequency: 22
                    Reset counter: 199
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:12:14
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x001C
                    Hex Value: 0x7A90
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DR    HW: 8K0 907 064 DR
   Component: BCM2 1.1      H02 0326
   Coding: 017200
   VCID: 03575E740B140292931-8056
   Subsystem 1 - Part No SW: 8T0 959 754 C    HW: 8T0 959 754 C
   Serial number: 0509000053238019
   Serial number: 0209000075051001
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 199
                    Mileage: 88137 km
                    Date: 2025.11.07
                    Time: 11:37:20
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 S    HW: 4E0 035 729 C
   Component: Interfacebox    H41 2090
   Revision: 00000000    Serial number: 337J/097519095
   Coding: 0000108
   VCID: 49CB8C5C65B818C219D-801C
   Subsystem 1 - Part No: 8T0 919 609 B
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000338390
   Subsystem 3 - Serial number: 0118.09.090000000100010073ÿ
   Subsystem 4 - Serial number: 010073ÿ
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01101020090634
   Coding: 64046000
   VCID: 76B137A048C6273AA4F-8022
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000364319
   Coding: 3E02108040F0BF434D21004400001D0D0F1D430800010141000000
   Shop #: WSC 06325 123 12345
   VCID: 3A29E3903C5E835A807-806E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 121009  H05 0070
   Serial number: SWF09100125173
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10634843
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001210091440
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
03395 - Control Module for High Beam Assistant
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H45 0390
   Revision: 00045004    Serial number: AUZ5ZBI8894987
   VCID: 2B07D6D4CF042AD20B1-807E
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD06EJPN   Dataset Number: 8K0909602F  0004
   Coding: 30373435363030303030554A3052384B3053
   VCID: 41DB947C5108D082C1D-8014
   Serial number: 6334MSME4B652C4AR
   Serial number: 6344MSME4C12751EK
   Serial number: 6352QSME343F1906I
   Serial number: 6362QSME433F3C10J
   Serial number: 63732SME053F2428
   Serial number: 63832SME093F2012W
12658176 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001001] - -
          [Steer Angle Control Unit no signal/communication]
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:56
   Revision: --------    Serial number: 90304IJD000KT
   Coding: 000002
   VCID: 3D23E88C2D70B462A55-8068
   Part No SW: 8K0 920 930 B    HW: 8K0 920 930 B
   Component: KOMBIINSTR.   H20 0255
   Revision: 00000000    Serial number: CIV21TDA9
   Coding: 6F9708000201870C010001
   VCID: 2C05D5C8C60A2DEA02B-8078
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:47:39
00771 - Fuel Level Sensor (G)
                    Fault Status: 01101000
                    Reset counter: 199
                    Mileage: 88147 km
                    Date: 2025.11.08
                    Time: 09:18:33
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E09A1080FF
   Coding: 00C303
   VCID: 52F9AB3084EE5B1A687-8006
   Component: J367-BDM  H06 0170
   Serial number: 190926DC220909
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 236
                    Mileage: 88061 km
                    Date: 2025.11.05
                    Time: 11:03:13
                    Bin. Bits:    10000
                    Voltage: 12.40 V
                    Count: 19
                    Bin. Bits:    10000
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H20 0850
   Revision: 00000000
   VCID: 2B07D6D4C3042AD20B1-807E
Address 37: Navigation (J0401)       Labels: None
   Part No SW: 8T0 919 888 A    HW: 8T0 919 888
   Component: J0401 NAV JP  H32 0340
   Revision: 0000005S    Serial number: AUZBZ7J2716804
   VCID: 48CD895872B2E1CA063-801C
   Subsystem 1 - Part No SW: 4F0 035 503 C    HW: 4F0 035 503 C
   Component: ETC-VICS-Ant.  H02 0020
   Subsystem 2 - Part No SW: 4F0 919 813 C    HW: 4F0 919 813 C
   Component: Card reader  H02 0100
   Subsystem 3 - Part No SW: 4E1 910 336     HW: 4E1 862 335
   Component: Interface Han  H09 0050
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009446224
   Coding: 011C02205001410001
   VCID: 45D3806C45A0FCA2FD5-8010
   Revision: 00002001    Serial number: 0122571037
   Coding: 01000622003904800130010000000000
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AG    HW: 8T0 035 223 G
   Component: DSP STD       H08 0310
   Revision: S2700000
   Coding: 010201
   Shop #: WSC 38298 001 104857
   VCID: 73B70EB45BB43212831-8026
02247 - Subwoofer (R148/R157)
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:11:51
                    Voltage: 11.80 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
00417 - Left Front DSP Mid-Bass Speaker (R101)
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:11:51
                    Voltage: 11.80 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009476227
   VCID: 44D59D684E9AC5AAEAB-8010
   Revision: 00000003    Serial number: 10000000342968
   VCID: 3435CDA81E3A752A5AB-8060
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77AF3AA443CC5E32BF9-8022
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 196
                    Mileage: 88093 km
                    Date: 2025.11.05
                    Time: 15:40:09
   Part No SW: 4E0 910 541 N    HW: 4F0 035 541 K
   Component: TUNER Japan     H42 0180
   Revision: 00000000    Serial number: 338J.097513790
   Coding: 0000003
00856 - Radio Antenna
                    Fault Frequency: 52
                    Reset counter: 194
                    Mileage: 84730 km
                    Date: 2025.05.19
                    Time: 15:29:43
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                    Fault Frequency: 193
                    Reset counter: 199
                    Mileage: 84730 km
                    Date: 2009.07.22
                    Time: 01:22:00
Address 57: TV Tuner        Labels: None
   Part No SW: 4F0 919 148 B    HW: 4F0 919 148
   Component: R78 DTV-JP          0180
   Revision: R0H06000    Serial number: 79300600791102
   Coding: 0000016
   VCID: 2C05D5C8CA0A2DEA02B-8078
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0180
   Subsystem 2 - Serial number: -ÿ†72800600325204 HKO-00028.09
   Subsystem 3 - Serial number: KO-00028.09.09R0H0700000017137ÿ
   Subsystem 4 - Serial number: 0000017137ÿ
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102095244
   Coding: 010C02204001210001
   VCID: 42D99B70548ECB9AD87-8016
   Revision:             Serial number: 0000102095241
End----(Elapsed Time: 01:40, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
------------------------------19 Faults Found------------------------------
          56 57 62 72
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Mileage: 88051 km
                    Date: 2025.11.05
                    Time: 10:45:27
                    Fault Frequency: 33
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Clutch status: 1
                    Fault Frequency: 33
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:58
                    Clutch status: 1
   Coding: 050500
                    Fault Frequency: 22
                    Reset counter: 199
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:12:14
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x001C
                    Hex Value: 0x7A90
                    Hex Value: 0x00FF
   Coding: 017200
00956 - Key 2
                    Reset counter: 199
                    Mileage: 88137 km
                    Date: 2025.11.07
                    Time: 11:37:20
   Coding: 0000108
   Coding: 64046000
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:56
   Coding: 000002
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:47:39
                    Reset counter: 199
                    Mileage: 88147 km
                    Date: 2025.11.08
                    Time: 09:18:33
   Coding: 00C303
                    Reset counter: 236
                    Mileage: 88061 km
                    Date: 2025.11.05
                    Time: 11:03:13
                    Bin. Bits:    10000
                    Voltage: 12.40 V
                    Count: 19
                    Bin. Bits:    10000
   Revision: 00000000
   Revision: S2700000
   Coding: 010201
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:11:51
                    Voltage: 11.80 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:11:51
                    Voltage: 11.80 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
   Coding: 0000004
            000 - - - MIL ON
                    Reset counter: 196
                    Mileage: 88093 km
                    Date: 2025.11.05
                    Time: 15:40:09
   Coding: 0000003
                    Fault Frequency: 52
                    Reset counter: 194
                    Mileage: 84730 km
                    Date: 2025.05.19
                    Time: 15:29:43
                    Reset counter: 199
                    Mileage: 84730 km
                    Date: 2009.07.22
                    Time: 01:22:00
   Coding: 0000016
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Welcome.
This is fine and enough, don't open new threads, please.
lebohang.bulane
Maseru, Lesotho
C?ID=601784
I have cleared the faults, thies is the results
Monday,10,November,2025,17:22:04:04520
Chassis Type: 8K (8T0)
          56 57 62 72
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
   Coding: 050500
                    Fault Frequency: 27
                    Reset counter: 200
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:12:14
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x001C
                    Hex Value: 0x7A90
                    Hex Value: 0x00FF
   Coding: 017200
00956 - Key 2
                    Reset counter: 199
                    Mileage: 88137 km
                    Date: 2025.11.07
                    Time: 11:37:20
   Coding: 0000108
   Coding: 64046000
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:46:00
Address 15: Airbags
   Coding: 000002
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:47:39
                    Reset counter: 199
                    Mileage: 88147 km
                    Date: 2025.11.08
                    Time: 09:18:33
   Coding: 00C303
                    Reset counter: 236
                    Mileage: 88061 km
                    Date: 2025.11.05
                    Time: 11:03:13
                    Bin. Bits:    10000
                    Voltage: 12.40 V
                    Count: 19
                    Bin. Bits:    10000
   Revision: 00000000
   Revision: S2700000
   Coding: 010201
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:11:51
                    Voltage: 11.80 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.04
                    Time: 10:11:51
                    Voltage: 11.80 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
   Coding: 0000003
                    Fault Frequency: 52
                    Reset counter: 194
                    Mileage: 84730 km
                    Date: 2025.05.19
                    Time: 15:29:43
                    Fault Frequency: 194
                    Reset counter: 200
                    Mileage: 84730 km
                    Date: 2009.07.22
                    Time: 01:22:00
   Coding: 0000016
End----(Elapsed Time: 01:17, VBatt start/end: 11.9V/12.0V. VIgn 0.0V)------
------------------------------12 Faults Found------------------------------
lebohang.bulane
Maseru, Lesotho
C?ID=601784
Appologies for the confusion on the earlier send scan. latest scan is below attached
Monday,10,November,2025,18:51:04:04520
          56 57 62 65 72 77
57-TV Tuner -- Status: Malfunction 0010
65-Tire Pressure -- Status: Cannot be reached 1100
Readiness: 1110 0101
   Coding: 050500
   Coding: 011200
   Coding: 0000108
02244 - Button in Control Head is Stuck
                    Reset counter: 186
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:28:50
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      000
                    Bin. Bits: 11000000
   Coding: 64046000
   Coding: 260010800030AF010001000000001D0D0F1D430800010141000000
   Coding: 00FD11
   Coding: 025028
   Coding: 000012
                    Reset counter: 194
                    Mileage: 88030 km
                    Date: 2025.11.03
                    Time: 18:47:39
                    Reset counter: 199
                    Mileage: 88147 km
                    Date: 2025.11.08
                    Time: 09:18:33
   Coding: 00C303
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:31:38
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 25.40 s
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:32:37
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10011
   Revision: 00000000
   Revision: S2700000
   Coding: 010201
   Shop #: WSC 38298 001 1048576
   Coding: 011C02205E01410001
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:22:39
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:22:39
   Coding: 0000004
   Coding: 0000006
                    Fault Frequency: 16
                    Reset counter: 146
                    Mileage: 84730 km
                    Date: 2025.05.19
                    Time: 15:29:43
                    Fault Frequency: 99
                    Reset counter: 146
                    Mileage: 84730 km
                    Date: 2009.07.22
                    Time: 01:22:00
   Coding: 0000016
02261 - Data Medium
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:22:43
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:22:38
                    Reset counter: 146
                    Mileage: 86676 km
                    Date: 2025.10.02
                    Time: 12:22:39
Address 65: Tire Pressure
Address 77: Telephone
End----(Elapsed Time: 01:41, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
------------------------------10 Faults Found------------------------------
