Hi , so i need to change the rear breakepads on my audi , and i was woundering how to do it? im not that good with the vagcom
yes sir! i cant do a scan right now thoI'm guessing(!) your A6 has EPB?
Please post an Auto-Scan made with the English version of VCDS, as not all C7 A6 are equipped the same.
Guaranteed. Even the previous generation C6 had 'em.I'm guessing(!) your A6 has EPB?
thank you so much, this did the trick
my only problem now is that i ordered the front ones , so i guess im doing both even tho the fronts would hold a bit longer!
You'll need the fronts eventually. Why not keep those parts "in stock" until the fronts actually need to be done?my only problem now is that i ordered the front ones , so i guess im doing both even tho the fronts would hold a bit longer!
that is exactly what im doingYou'll need the fronts eventually. Why not keep those parts "in stock" until the fronts actually need to be done?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
