Hi All, I'm getting a recurring engine light with P0401 and P26F4 from the Auto-Scans. See details below in the format from Jacks Professional Problem Solver Guide.
Step 1: PR-Build
Step 2: Status of Car
Stock with the Dieselgate fixes.
Step 3: VCDs Auto-Scans
Scan 1, 8/1/25:
Scan 2: 9/27/25
Scan 3: 10/30/25
Scan 4: 11/4/25
Step 4: Recent Repairs And Services
9/5/25: Replaced Timing Belt, Water Pump and Associated Parts
9/5/25: Oil Change
4/2/25: Replaced Oil Filter
Step 5: Are Parts OEM or AFT?
OEM
Step 6: Identify specific issues to be addressed
I'd like to get an idea of how to fix the issues that are causing the P0401 and P26F4 codes. I won't be doing it myself, I'll take it to a shop to let the professionals handle it, but I want to be able to point them in the right direction.
Thanks for taking a look!
Step 1: PR-Build
Scan 1, 8/1/25:
Friday,01,August,2025,17:45:21:59029
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
VIN: 3VWFA7AU0FM518906 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75
VIN: 3VWFA7AU0FM518906 Mileage: 116046km-72107miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 M HW: 04L 907 309
Component: R4 2.0l TDI H23 9458
Revision: 85H23--- CVN: 500D7A2038D3FF82B866C2AD
Coding: 01190012032410081000
Shop #: WSC 17496 007 1048576
ASAM Dataset: EV_ECM20TDI01104L997022M 004002
ROD: EV_ECM20TDI01104L997022M.rod
VCID: 3A2AEFDF2CD1F08A81D-806E
VINID: 0E69D64474650167450482401880286959
27014 - EGR System
P0401 00 [01100000] - Insufficient Flow
Fault Frequency: 18
Mileage: 114870 km
Date: 2025.05.28
Time: 07:36:24
Engine speed: 1773.00 /min
Vehicle speed: 30 km/h
Coolant temperature: 76 °C
Intake air temperature: 59 °C
Ambient air pressure: 900 mbar
Voltage terminal 30: 13.600 V
EGR travel diagnosis: strongly increased NOx emission: -39.8 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 80.10 %
EGR travel diagnosis: marginally increased NOx emission: -39.2 kg/h
Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.00 %
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.00 %
Pressure after throttle valve: calculated: 1016.0 hPa
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 15.9998
28388 - Coolant Pump 3
P26F4 00 [10101100] - Electrical Malfunction / Open Circuit
Fault Frequency: 27
Mileage: 115202 km
Date: 2025.06.06
Time: 11:36:33
Engine speed: 2314.50 /min
Normed load value: 25.1 %
Vehicle speed: 20 km/h
Coolant temperature: 39 °C
Intake air temperature: 47 °C
Ambient air pressure: 910 mbar
Heater support pump 1 bank 1 second.circuit: activat.: 94.79 %
Outside temperature sensor 1: B1: raw value: 23.5 °C
Shut-off timer: last engine shut-off time: 32872 s
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51395000000279
Coding: 04FA6AA1242109740080020081C92520562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
VCID: 47CC862B6F239D620E3-8012
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 18
Mileage: 115240 km
Date: 2025.06.09
Time: 11:51:30
Revision: 00021000 Serial number: 0364333354 Dataset Number: V03935208L0003
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 02020124202100000005000012111400
VCID: 42DA973F4401B84AD9D-8016
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Revision: -------- Serial number: 86582104150059 Dataset Number: 5GM063v____ 0050
Coding: 00510846404182E969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 00205
ROD: EV_BCMBOSCH_014.rod
VCID: 4ACABF1F7C31600A11D-801E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150411 043 0581
Serial number: 150609122352
Component: RLHS 037 0059
Serial number: S3Y15M04D28H13M17S10
Coding: 90A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0008MZTM00000
Coding: 191800
Roof shade control module:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0008N0E900000
Coding: 191800
Humidity sensor: interior:
B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
Fault Frequency: 14
Reset counter: 20
Mileage: 115057 km
Date: 2025.05.30
Time: 13:00:40
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.3 V
Outside temperature: 25.5 °C
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01W82F Dataset Number: 5GM003V____ 0044
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150002R36K00
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 005 15
Serial number: 357000000006C975941P
Subsystem 3 - Part No SW: ----------- HW: 480 002 005 15
Serial number: 358000000001D365941F
Subsystem 4 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3510002991A87865D168
Subsystem 5 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3520002991A8786641D8
Subsystem 6 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 35500029B1A878641262
Subsystem 7 - Part No SW: ----------- HW: 480 401 404 15
Component: FrontSensor_P 001 6149
Serial number: 35600029B1A87861C2BG
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150422500724
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 045651271E95767AAB1-8050
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA412122180CF0502086A001000000000000000
VCID: 65906CA3F5EFAF721CF-8030
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 02061510001018 Dataset Number: 5G0067v____ 2011
Coding: 0901000800087300EF000208080F00000001050000000000000000000000
Shop #: WSC 00066 790 07030
GVL: 01503C0000000600400C00008000480000000000000000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 71B808F3312773D2707-8024
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29150000654850015172
Coding: 30FFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0066620
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000108868001
Coding: 5500000000000000
VCID: 3436C1E70EB506FA5B1-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 080515060501R6 Dataset Number: V03935206HY 0006
Coding: 003A13200000040000000000
VCID: 40DE9D374A0DAA5ACF9-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001279878
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Dataset Number: 5GM074V____ 0515
Coding: 0102
Shop #: WSC 00066 790 00218
VCID: 43D4923B5B1BB142D2B-8016
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0070
Serial number: VWZ8Z1FC402RWL/ Dataset Number: 5GM050v____ 0011
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: 639472BBFBDBD142F2B-8036
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 220515060502FQ Dataset Number: V03935206HZ 0006
VCID: 3FDC9ECB37F3D5A2B63-806A
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001235763
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0655
Serial number: V7B01704150474 Dataset Number: 5G0CV1v____ 0001
Coding: 027302020000000021220002001800001F0100340100010546
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 6988609319F78B12387-803C
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS600NGM
Subsystem 2 - Part No SW: 5G0 919 866 S HW: -----------
Component: NAR 2015 --- 0022
Reset counter: 206
Mileage: 115074 km
Date: 2025.06.02
Time: 07:57:24
Voltage terminal 30: 13.9 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Dataset Number: 561098V____ 0409
Coding: 02730202C2823A017F1E06000000
Shop #: WSC 00066 790 00323
ROD: EV_OCULowMQB_VW37.rod
9458451 - Cellular Antenna
B1053 13 [00001000] - Open Circuit
[GSM antenna open load]
End----------(Elapsed Time: 01:40, VBatt start/end: 12.3V/12.3V)-----------
------------------------------6 Faults Found-------------------------------
Saturday,27,September,2025,09:59:44:59029
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: 3VWFA7AU0FM518906 Mileage: 118631km-73713miles
VCID: 3A2AEFDF2CD1F08A807-806E
27014 - EGR System
Fault Frequency: 13
Mileage: 116081 km
Date: 2025.08.07
Time: 12:02:21
Engine speed: 2106.00 /min
Vehicle speed: 82 km/h
Coolant temperature: 68 °C
Voltage terminal 30: 13.920 V
EGR travel diagnosis: strongly increased NOx emission: -41.9 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 96.57 %
EGR travel diagnosis: marginally increased NOx emission: -41.1 kg/h
Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 14.01 %
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 59.23 %
Pressure after throttle valve: calculated: 1044.0 hPa
P26F4 00 [00101000] - Electrical Malfunction / Open Circuit
Fault Frequency: 36
Mileage: 116051 km
Date: 2025.08.05
Time: 11:52:44
Engine speed: 2196.00 /min
Normed load value: 34.9 %
Vehicle speed: 19 km/h
Coolant temperature: 69 °C
Intake air temperature: 71 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 13.340 V
Heater support pump 1 bank 1 second.circuit: activat.: 93.56 %
Outside temperature sensor 1: B1: raw value: 27.0 °C
Shut-off timer: last engine shut-off time: 6092 s
19208 - EGR System
Mileage: 116486 km
Date: 2025.08.29
Time: 07:34:35
Engine speed: 2038.50 /min
Vehicle speed: 55 km/h
Coolant temperature: 52 °C
Intake air temperature: 36 °C
Unlearning counter according OBD: 32
EGR travel diagnosis: strongly increased NOx emission: -54.6 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 100.00 %
EGR travel diagnosis: marginally increased NOx emission: -57.3 kg/h
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.33 %
Pressure after throttle valve: calculated: 1124.0 hPa
Readiness: 0 1 0 0 0
VCID: 47CC862B6F239D620F9-8012
Reset counter: 37
Mileage: 116229 km
Date: 2025.08.21
Time: 16:58:59
Coding: 030C0C
Revision: 00001K01
VCID: 42DA973F4401B84AD87-8016
Air quality sensor:
1048835 - Functionality limited due to Engine Control Module
P1719 00 [00001000] - -
[PTC-Reduzierung durch MSG]
Reset counter: 44
Mileage: 116820 km
Date: 2025.09.05
Time: 10:50:28
Voltage terminal 30: 12.7 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
VCID: 4ACABF1F7C31600A107-801E
Coding: 90A8DD
Coding: 191800
Coding: 191800
Fault Frequency: 13
Reset counter: 57
Mileage: 116050 km
Date: 2025.08.01
Time: 18:12:11
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: operated
Voltage: 12.3 V
Outside temperature: 22.0 °C
Coding: 303137
Coding: 0400
VCID: 045651271E95767AAAB-8050
VCID: 65906CA3F5EFAF721D5-8030
1048578 - No Basic Setting
B2010 00 [00001000] - -
[Steuergerät keine oder falsche Grundeinstellung]
Reset counter: 44
Mileage: 116818 km
Date: 2025.09.05
Time: 10:40:18
VCID: 71B808F3312773D271D-8024
Generator:
Coding: 30FFFF
VCID: 3436C1E70EB506FA5AB-8060
VCID: 40DE9D374A0DAA5ACE3-8014
Coding: 011000
Coding: 0102
VCID: 43D4923B5B1BB142D31-8016
VCID: 639472BBFBDBD142F31-8036
VCID: 3FDC9ECB37F3D5A2B79-806A
Coding: 091000
VCID: 6988609319F78B1239D-803C
Reset counter: 238
Mileage: 116046 km
Date: 2025.08.01
Time: 17:59:34
Voltage terminal 30: 11.9 V
Address 75: Telematics (J949) Labels:| 5QE-035-28X-V1.clb
End----(Elapsed Time: 01:38, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
------------------------------8 Faults Found-------------------------------
Scan 3: 10/30/25
Thursday,30,October,2025,21:46:55:59029
VIN: 3VWFA7AU0FM518906 Mileage: 119544km-74281miles
27014 - EGR System
Mileage: 119319 km
Date: 2025.10.20
Time: 07:37:16
Engine speed: 1693.50 /min
Vehicle speed: 34 km/h
Coolant temperature: 63 °C
Intake air temperature: 61 °C
Voltage terminal 30: 14.420 V
Unlearning counter according OBD: 33
EGR travel diagnosis: strongly increased NOx emission: -50.0 kg/h
EGR travel diagnosis: marginally increased NOx emission: -50.3 kg/h
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.09 %
Pressure after throttle valve: calculated: 1061.0 hPa
P26F4 00 [10101000] - Electrical Malfunction / Open Circuit
Fault Frequency: 29
Mileage: 118631 km
Date: 2025.09.27
Time: 11:52:40
Engine speed: 1318.50 /min
Normed load value: 58.0 %
Coolant temperature: 12 °C
Intake air temperature: 12 °C
Ambient air pressure: 920 mbar
Voltage terminal 30: 14.480 V
Heater support pump 1 bank 1 second.circuit: activat.: 50.70 %
Outside temperature sensor 1: B1: raw value: 8.0 °C
Shut-off timer: last engine shut-off time: 32920 s
Reset counter: 85
Mileage: 119118 km
Date: 2025.10.10
Time: 07:14:44
Coding: 030C0C
Revision: 00001K01
Air quality sensor:
Coding: 90A8DD
Coding: 191800
Coding: 191800
U1400 00 [00001000] - -
Reset counter: 85
Mileage: 119317 km
Date: 2025.10.20
Time: 07:32:34
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 10.4 V
Outside temperature: 7.0 °C
Reset counter: 82
Mileage: 119026 km
Date: 2025.10.03
Time: 13:55:25
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
Outside temperature: 19.5 °C
Coding: 303137
Coding: 0400
Generator:
Coding: 30FFFF
Coding: 011000
Coding: 0102
Coding: 091000
Reset counter: 28
Mileage: 118631 km
Date: 2025.09.27
Time: 10:05:14
Voltage terminal 30: 11.6 V
End----(Elapsed Time: 01:40, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Scan 4: 11/4/25
Tuesday,04,November,2025,07:11:36:59029
VIN: 3VWFA7AU0FM518906 Mileage: 119652km-74348miles
27014 - EGR System
P0401 00 [01100101] - Insufficient Flow
Mileage: 119571 km
Date: 2025.10.31
Time: 13:18:09
Vehicle speed: 48 km/h
Coolant temperature: 62 °C
Intake air temperature: 44 °C
Voltage terminal 30: 14.260 V
EGR travel diagnosis: strongly increased NOx emission: -37.8 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 82.62 %
EGR travel diagnosis: marginally increased NOx emission: -37.1 kg/h
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.06 %
Pressure after throttle valve: calculated: 1014.0 hPa
Mileage: 119598 km
Date: 2025.11.03
Time: 08:35:29
Engine speed: 874.00 /min
Normed load value: 38.0 %
Coolant temperature: 21 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.240 V
Heater support pump 1 bank 1 second.circuit: activat.: 67.85 %
Outside temperature sensor 1: B1: raw value: 7.5 °C
Shut-off timer: last engine shut-off time: 32942 s
Coding: 030C0C
Revision: 00001K01
Air quality sensor:
Coding: 90A8DD
Coding: 191800
Coding: 191800
Coding: 303137
Coding: 0400
Generator:
Coding: 30FFFF
Coding: 011000
Coding: 0102
Coding: 091000
Reset counter: 48
Mileage: 119544 km
Date: 2025.10.30
Time: 21:52:17
Voltage terminal 30: 11.7 V
End----(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
------------------------------3 Faults Found-------------------------------
9/5/25: Oil Change
OEM
