2014 Passat 2.0 tdi with 02E DSG. Whining noise coming from trans 2-3 weeks after DMF replacement
Aslaught3r45
Texas, USA
C?ID=635125
Wednesday,05,November,2025,12:37:04:63205
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: 1VWBN7A32EC088239   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
          62 72 75 77
VIN: 1VWBN7A32EC088239   Mileage: 220650km-137105miles
37-Navigation -- Status: Cannot be reached 1100
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:                CVN: D240C61F38D3FF82
   Coding: 001D0012042400000000
   Shop #: WSC 25038 444 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B24EB5343EACE829B1-806E
   VINID: 0669D27874430954C0208083247F018179
12642 - Charge Air Cooler
          P026A 00 [11101101] - Efficiency Below Threshold
                    Fault Frequency: 13
                    Mileage: 216560 km
                    Date: 2025.09.26.
                    Time: 04:26:32
                    Engine speed: 1949.00 /min
                    Normed load value: 61.2 %
                    Vehicle speed: 103 km/h
                    Coolant temperature: 101 °C
                    Intake air temperature: 72 °C
                    Voltage terminal 30: 13.920 V
                    Air mass at air mass meter 1: 101.6 kg/h
                    Temp sensor for low-pressure EGR after cooler: raw value: 116.0 °C
                    Outside temperature: 33.5 °C
                    Intake air temperature before throttle valve: calculated: 46.4 K
                    Sensor for temp after charge air cooler: raw value: 72.5 °C
                    Coolant pump for charge-air cooling: spec. value: 95.00 %
5552 - Intake Air Temp. Sensor (G42)
          P0111 00 [11101101] - Implausible Signal
                    Fault Frequency: 11
                    Mileage: 216583 km
                    Date: 2025.09.26.
                    Time: 16:52:59
                    Engine speed: 156.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 30 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 9.320 V
                    Coolant temperature at radiator outlet: actual value: 29.1 °C
                    Fuel temperature: 28.4 °C
                    Outside temperature: 25.0 °C
                    Control Module temperature: 28.4 °C
                    Shut-off timer: last engine shut-off time: 32926 s
                    Sensor for temp after charge air cooler: raw value: 65.9 °C
Readiness: 1 2 0 0 0
   Component: GSG DSG AG6     521 9437
   Revision: 05652104    Serial number: 00001401101290
   Shop #: WSC 09003 957 00200
   VCID: 147660EF0274E1FA3AB-8040
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Reset counter: 1
                    Mileage: 220555 km
                    Date: 2020.03.27.
                    Time: 22:13:31
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V4.clb
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F5492A0002A30D03E792220042A1100012
   VCID: 7EA2224710F81BAAFCF-802A
                    Reset counter: 128
                    Mileage: 219142 km
                    Date: 2020.03.11.
                    Time: 17:41:40
                    Count: 17472
                    Count: 12
                    Count: 12800
                    Count: 81
                    Count: 50461
                    Count: 2
                    Count: 2808
                    Count: 5632
                    Reset counter: 137
                    Mileage: 219918 km
                    Date: 2020.03.17.
                    Time: 06:46:43
                    Count: 16387
                    Count: 12
                    Count: 4096
                    Count: 128
                    Count: 44032
                    Count: 4352
                    Count: 507
                    Count: 10496
                    Fault Frequency: 53
                    Reset counter: 140
                    Mileage: 195863 km
                    Date: 2019.05.23.
                    Time: 00:21:33
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 50432
                    Count: 512
                    Fault Status: 00100011
                    Fault Frequency: 31
                    Reset counter: 106
                    Mileage: 215288 km
                    Date: 2020.02.02.
                    Time: 00:24:28
                    Count: 2
                    Count: 29184
                    Count: 83
                    Count: 50445
                    Count: 1
02214 - Tire Pressure Warning
                    Fault Status: 01100010
                    Reset counter: 0
                    Mileage: 195863 km
                    Date: 2019.05.23.
                    Time: 00:21:24
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 16401
                    Count: 50688
                    Count: 512
                    Fault Status: 01101100
                    Fault Frequency: 74
                    Reset counter: 108
                    Mileage: 195863 km
                    Count: 16387
                    Count: 12
                    Count: 20480
                    Count: 88
                    Count: 44544
                    Count: 512
                    Count: 512
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0323048766 Dataset Number: 560116v____ 0002
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW41.rod
   VCID: 3436C06F6EB401FA5AB-8060
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW41.rod
   VCID: 1D6005CBFD3EA0B2855-8048
9473905 - Motor for Temperature Flap
          B108F 71 [00001000] - Actuator Stuck
                    Reset counter: 141
                    Mileage: 220225 km
                    Date: 2025.11.03.
                    Time: 08:16:17
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0173
   Revision: BL122001
   Coding: EF200E1B902B08D4098800010600854800F1A086448015B064806000AC70
   VCID: 78AE345F32DC259AB63-802C
7 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00101010
                    Fault Frequency: 32
                    Reset counter: 147
                    Mileage: 215714 km
                    Date: 2020.02.07.
                    Time: 14:19:19
                    Voltage: 13.60 V
                    Reset counter: 110
                    Mileage: 195863 km
                    Date: 2019.05.25.
                    Time: 14:45:55
                    Voltage: 13.80 V
                    Fault Frequency: 27
                    Reset counter: 148
                    Mileage: 215726 km
                    Date: 2020.02.07.
                    Time: 18:23:29
                    Voltage: 13.45 V
                    Fault Status: 01101010
                    Reset counter: 25
                    Mileage: 215287 km
                    Date: 2020.02.02.
                    Time: 00:03:03
                    Voltage: 13.60 V
                    Fault Frequency: 22
                    Reset counter: 95
                    Mileage: 195863 km
                    Date: 2019.05.25.
                    Time: 16:14:42
                    Voltage: 13.70 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Reset counter: 108
                    Mileage: 219840 km
                    Date: 2020.03.15.
                    Time: 18:10:21
                    Voltage: 13.95 V
03189 - Bulb for Side Marker Light; Front Right
                    Fault Frequency: 69
                    Reset counter: 117
                    Mileage: 195893 km
                    Date: 2019.05.27.
                    Time: 19:35:21
                    Voltage: 13.65 V
   Serial number: 003MWM04J0M    Dataset Number: 560003v____ 0061
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B03D6B254E58F2AD5-8020
   Serial number: 6940000Y1400012ZMJ08
   Coding: 303044
   Serial number: 3572MSME42745C41ZZZW
   Serial number: 3582MSME574B6D41ZZZ2
   Serial number: 3516KSME4212092BZZZK
   Serial number: 3526KSME1D53082BZZZX
   Serial number: 3556LSME4345512AZZZS
   Serial number: 3566LSME6E4A512AZZZ4
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001000] - Open or Short to Ground
                    Mileage: 216038 km
                    Date: 2025.09.20.
                    Time: 15:59:47
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
                    Reset counter: 148
                    Mileage: 195863 km
                    Date: 2025.01.01.
                    Time: 14:46:10
   Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140115300928
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EA2224710781BAAFCF-802A
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 1E6202C7F038BBAA9CF-804A
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 09031403000294
   Coding: 461000
   VCID: 7BA42B5303EA0E82DB1-802E
                    Reset counter: 42
                    Mileage: 216193 km
                    Date: 2020.02.14.
                    Time: 00:00:06
   Coding: 000007
   VCID: 6A8A1E177CF0870A307-803E
   Revision: 00000000    Serial number: 13000296096001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW41.rod
   VCID: 303ECC7F9AAC3DDA3E3-8064
Address 2E: Media Player 3
Address 37: Navigation
   Revision: 13110009    Serial number: 0007928565
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE44BD3A3AAEE82BB1-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140224130552
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 3928F15B4556FC9289D-806C
                    Fault Status: 00101101
                    Fault Frequency: 255
                    Reset counter: 148
                    Mileage: 220655 km
                    Date: 2020.03.28.
                    Time: 12:32:55
                    Voltage: 13.88 V
                        DU
                    Temperature: 42.0°C
                    RPM: 826 /min
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBC0F0347926222679-803A
   Serial number: 53388786011331800688
   Coding: 181100
   Revision: 15110009    Serial number: 0007915858
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE648CFA6A4E9BAB2B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631140304160521
   Coding: 800000
Address 56: Radio        Labels:
   VCID: 55F05DEBCC0E38F28D5-FFFE
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140513
   Coding: 02140102C2423A007F1606000000
   ROD: EV_OCULow_001_VW41.rod
   VCID: 53F4A3F3CB7A26C2631-8006
0036 - Databus
          [CAN TO GPS data]
                    Fault Frequency: 110
                    Reset counter: 108
                    Mileage: 216193 km
                    Date: 2025.09.23.
                    Time: 00:00:38
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 108
                    Mileage: 220655 km
                    Date: 2025.11.05.
                    Time: 12:36:13
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007665849515 Dataset Number: 5N0035729A  0001
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
   VCID: 2E02D20780982B2A2CF-807A
End----------(Elapsed Time: 01:24, VBatt start/end: 13.9V/13.9V)-----------
------------------------------23 Faults Found------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Surely this is a question for whoever manufactured the part and whoever fitted it ?
Maybe hold your phone near the noise and ask AI to fix it for you !!
How in gods name can VCDS help you ?
