Resolved TPMS -07 Jetta 2.5 automatic.
Resolved
markg612
Bay Area, CA, USA
C?ID=322711
I spoke to Jeff yesterday regarding TPMS and realized I forgot to ask about the 0625 "vehicle speed" fault at address 65.
Reset DTCs and the 0625 fault reappears immediately, as did the wheel sensor signals; I'm working on that; only concerned at this point with the 0625 fault.
Searching the forums, the fault appears in discussion repeated at address 65, but is always associated with ABS; however, this vehicle isn't throwing any ABS faults.
Thoughts??
Monday,03,November,2025,09:01:37:64403
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: 3VWRF81K97M017226   License Plate: 7WAA996
Mileage: 214927   Repair Order:
                Address 01: Engine       Labels: 06A-906-032-BGP.lbl
Control Module Part Number: 07K 906 032 S    HW: 07K 906 032 Q
  Component and/or Version: 2.5l R5/4V      G   9652
           Software Coding: 0000003
            Work Shop Code: WSC 22803 444 59526
                      VCID: 392FD31835562BF289D-806C
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - Intermittent
                    Mileage: 344814 km
                    Time: 06:31:12
                    RPM: 867 /min
                    Load: 54.9 %
                    Temperature: 36.0∞C
                    Temperature: 36.0∞C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.335 V
000802 - Engine Speed Sensor (G28)
               P0322 - 004 - No Signal - Intermittent
                    Mileage: 345208 km
                    Time: 01:51:04
                    Speed: 1.0 km/h
                    Temperature: 45.0∞C
                    Temperature: 47.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.049 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - Intermittent
                    Mileage: 345898 km
                    RPM: 172 /min
                    Load: 97.2 %
                    Temperature: 30.0∞C
                    Temperature: -40.0∞C
                    Voltage: 11.811 V
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low - Intermittent
                    Mileage: 345898 km
                    Time: 02:27:17
                    RPM: 795 /min
                    Load: 52.5 %
                    Temperature: 30.0∞C
                    Voltage: 12.065 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High - Intermittent
                    Mileage: 345898 km
                    Time: 02:27:17
                    RPM: 839 /min
                    Load: 53.7 %
                    Temperature: 30.0∞C
                    Voltage: 12.065 V
Readiness: 0000 1100
Address 01: DTCs cleared
Address 09: DTCs cleared
Address 0F: DTCs cleared
Address 17: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
                Address 65: Tire Pressure       Labels: 3C0-959-433-65.lbl
Control Module Part Number: 1K0 959 433 CD    HW: 1K0 959 433 CD
  Component and/or Version:    RDK              0420
           Software Coding: 0100101
            Work Shop Code: WSC 131071 1023 2097151
                      VCID: 74B1222C52B4969A9AB-8020
00625 - Vehicle Speed Signal
                    Fault Status: 00111000
                    Reset counter: 199
                    Mileage: 345529 km
                    Time: 00:10:49
                    Fault Status: 01110100
                    Reset counter: 163
                    Mileage: 345805 km
                    Time: 04:06:23
                    Reset counter: 199
                    Mileage: 345529 km
                    Time: 00:10:49
                    Reset counter: 163
                    Mileage: 345805 km
                    Time: 04:06:23
Address 65,1K0 959 433 CD,channel 5,adapted from,23,to,23,
Sequential Output Tests
Address 65,1K0 959 433 CD,channel 0,adapted from,---,to,000,
                Address 65: Tire Pressure       Labels: 3C0-959-433-65.LBL
                    Reset counter: 199
                    Mileage: 345529 km
                    Time: 00:10:49
                    Reset counter: 163
                    Mileage: 345805 km
                    Time: 04:06:23
Address 65: DTCs cleared
Address 72: DTCs cleared
markg612
Bay Area, CA, USA
C?ID=322711
Wednesday,05,November,2025,09:33:51:64403
VIN: 3VWRF81K97M017226   License Plate: 7WAA997
Mileage: 345910km-214938mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRF81K97M017226   Mileage: 345910km-214938miles
   Part No SW: 07K 906 032 S    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9652
   Revision: --H01---    Serial number: VWZ7Z0F4158454
   Coding: 0000003
   Shop #: WSC 22803 444 59526
   VINID: 0E69E258805B24774004708218D749FDDF
Readiness: 0000 1000
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H25000    Serial number:
   Coding: 0000072
   Shop #: WSC 00066 000 00000
   VCID: 00597EFC160CBA3A8E3-8054
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3213057BA91A2831-8026
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 6889465C1E7C627A263-803C
   Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000000408809
   Coding: 14050E234004150007140000001400000008730B5C0000
   VCID: 3635D8240448C48A64F-8062
   Component: Wischer 170102 020  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F7020630
   VCID: 2A0DFC54C0F0906AF07-807E
                    Reset counter: 163
                    Mileage: 345898 km
                    Time: 21:02:13
   Part No SW: 1K0 909 605 Q    HW: 1K0 909 605 Q
   Component: 69 AIRBAG VW8R  033 7900
   Revision: 04033000    Serial number: 0038LD09LJ08
   Coding: 0013881
   VCID: 3A2DCC14305020EA807-806E
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME107670530
   Subsystem 3 - Serial number: 6342MSME113A59438
   Subsystem 4 - Serial number: 6351HSME0A0E5E26I
   Subsystem 5 - Serial number: 6361HSME0A2057743
   Subsystem 6 - Serial number: 63727SME0A17612F2
   Subsystem 7 - Serial number: 63827SME0A030924W
   Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
   Component: J0527           035 0070
   Coding: 0010021
   VCID: 025D74F41800A82A987-8056
   Part No SW: 1K0 920 953 H    HW: 1K0 920 953 H
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4158454
   Coding: 0023203
   Shop #: WSC 00000 000 444096
   VCID: 3039EE3CE62CEABA3E3-8064
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001065181209
   Coding: 3FBF036007001002
   VCID: 2C01FA4CCA048E5A02B-8078
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1125
   Revision: 12006001    Serial number: 00000026968704
   Coding: 0001205
   VCID: 3B23C9103F6A19E29B1-806E
                    Fault Status: 01101000
                    Reset counter: 164
                    Mileage: 345911 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Fault Frequency: 16
                    Reset counter: 203
                    Mileage: 345898 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: 3431E22C1234D69A5AB-8060
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 03900F880186283F0904058FB0880F0488DCA0
   Shop #: WSC 07020 993 55679
   Component: J387  TUER-SG BT    1125
   Revision: 12006001    Serial number: 00000523368703
   Coding: 0001204
   VCID: 3C21CA0C3A641EDA92B-8068
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio DE2       145 0175
   Revision: 00145000    Serial number: VWZ4Z7F2120071
   Coding: 0040401
   VCID: 2411126CA2D4461ACAB-8070
   Component: J388   TUER-SG HL   1115
   Revision: 12004001    Serial number: 00000000262145
   Coding: 0001168
   VCID: 3E25C0042C780CCABCF-806A
   Component:    RDK              0420
   Coding: 0100101
                    Fault Status: 00111110
                    Reset counter: 164
                    Mileage: 345911 km
                    Time: 05:58:33
   Component: J389   TUER-SG HR   1115
   Revision: 12004001    Serial number: 00000000259478
   Coding: 0001168
   VCID: 3FDBBD002B7205C2B79-806A
End----------(Elapsed Time: 01:24, VBatt start/end: 12.8V/12.3V)-----------
------------------------------4 Faults Found-------------------------------
Wednesday,05,November,2025,09:48:19:64403
Readiness Status: 0110 1101
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Failed or Incomplete
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Failed or Incomplete
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
markg612
Bay Area, CA, USA
C?ID=322711
Wednesday,05,November,2025,09:51:09:64403
VIN: 3VWRF81K97M017226   License Plate: 7WAA997-1
   Coding: 0000003
Readiness: 0110 1101
   Coding: 0000072
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 163
                    Mileage: 345898 km
                    Time: 21:02:13
   Coding: 0013881
   Coding: 0010021
   Coding: 0023203
   Coding: 0001205
                    Reset counter: 164
                    Mileage: 345911 km
                    Fault Frequency: 16
                    Reset counter: 203
                    Mileage: 345898 km
   Coding: 0001204
   Coding: 0040401
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100101
                    Reset counter: 164
                    Mileage: 345911 km
                    Time: 05:58:33
   Coding: 0001168
End----------(Elapsed Time: 01:26, VBatt start/end: 14.1V/14.1V)-----------
markg612
Bay Area, CA, USA
C?ID=322711
Jef, I attempted all of the ideas you suggested with the secondary air readiness reset; no luck yet, however, I was able to activate the air pump just fine with the sequential test. It cycled on and off repeatedly as expected. Needless to say, the monitors that have been setting need to set again.
Also, reference the TPMS "vehicle speed implausible" fault, 0625, is gone, so all is good there for now.
Jef
HQ
OK, and as noted on the phone, live TPMS data is found:
  • Wheel #1 = Measuring Block groups 001, 002, and 003
  • Wheel #2 = Measuring Block groups 004, 005, and 006
  • Wheel #3 = Measuring Block groups 007, 008, and 009
  • Wheel #4 = Measuring Block groups 010, 011, and 012
No clue what wheel is where, trial and error while looking at live pressure data (001.3, 005.3, 007.3 and 010.3) as you deflate a tire. Tire pressure sensor part number is 1K0 907 253 D.
markg612
Bay Area, CA, USA
C?ID=322711
Got it-thanks Jef. will advise results.
