Resolved ABS module coding, new 2nd hand module wont accept coding from previous module
Resolved
A.Penny91
C?ID=212287 (NRRT)
Borrowed a friends cable to have a go, probably shouldn't have, but i like to try atleast
Bought the car last week, came with a abs pump/module in the boot as a replacement
2009 Seat Leon Cupra, 2.0 tfsi
Same part numbers, apart from the last 2 letters are different, original one is 1K0 907 379 AM, new/replacement has AH at end instead.
knew it wouldn't be this easy, but i tried copy and pasting the long coding from the old one to the other and it wont accept it, says its too short.
The long coding i'm trying to copy over is:
163B8012892300FD680F01EC911E00813408
The coding on the 2nd hand replacement module is just a load of zeros.
Any help appreciated.
Full scan below:
Wednesday,05,November,2025,15:17:25:35161
VCDS Version: 25.3.2.0 (x64)
VIN: VSSZZZ1PZAR013485   License Plate: DG59KBK
Mileage: 135850km-84413mi   Repair Order:
Chassis Type: 1P-SE35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZAR013485   Mileage: 135850km-84413miles
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
   Part No SW: 1P0 907 115 C    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: SEZ7Z0G3774401
   Coding: 0303000318070160
   Shop #: WSC 66051 000 00000
   VCID: 2B550B858A8C69C356-807E
   VINID: 9A38EAAAA060A91880043108144F4D9B2A
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
                    Fault Status: 01100010
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:04:36
                    Temperature: 23.0 C
                    Temperature: 18.0 C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.065 V
                    Temperature: -40.0 C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0100
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Shop #: WSC 09550 758 180955
   VCID: 78FFE4C9CB5A125BEB-802C
                    Reset counter: 59
                    Date: 2020.03.28.
                    Time: 00:57:34
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 42240
                    Fault Status: 01100101
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:45:40
                    Count: 3
                    Count: 12800
                    Count: 279
                    Count: 42496
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:45:40
                    Count: 3
                    Count: 12800
                    Count: 295
                    Count: 42496
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:45:40
                    Count: 3
                    Count: 12800
                    Count: 270
                    Count: 42496
   Part No SW: 5P0 907 044 M    HW: 5P0 907 044 M
   Component: Climatronic   H14 0401
   Revision: 00001001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 3A7B3EC1BDD6C04BDD-806E
          B10AB F0 [00001001] - Too Low
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2025.11.05.
                    Time: 00:04:56
   Part No SW: 5K0 937 086     HW: 5K0 937 086
   Component: BCM PQ35 M    008 0019
   Revision: BC008001
   Coding: 46180A3C9025B0C04688008085008104076900A8425D89605C8040000000
   Shop #: WSC 04941 123 12345
   VCID: 71E9D9EDA82043132C-8024
   Subsystem 1 - Part No: 1P0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 13011  22  0611
   Coding: 00DB90
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:28:52
                    Voltage: 11.85 V
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:04:43
                    Voltage: 11.95 V
                    Fault Frequency: 200
                    Reset counter: 99
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:04:43
                    Voltage: 11.95 V
03020 - Local databus 2
                    Fault Status: 00101100
                    Fault Frequency: 34
                    Reset counter: 99
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:17:07
                    Voltage: 11.90 V
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5P0 919 475 C    HW: 5P0 919 475 A
   Component: PARKHILFE 8K  H07 0005
   Revision: --------    Serial number: 89040915401541
   Coding: 100004
   Shop #: WSC 04941 000 00000
   VCID: 3B753BC5BAECF943C6-806E
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__A0E VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PD5KDU$
   Coding: 0012357
   Shop #: WSC 06402 785 00200
   VCID: 44874039071286BBB7-8010
   Subsystem 1 - Serial number: 6332MTS624701549
   Subsystem 2 - Serial number: 6342MTS605561679
   Subsystem 3 - Serial number: 6351HTS6GN6TU8KR
   Subsystem 4 - Serial number: 6361HTS6I7DB26KR
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           855 0111
   Coding: 0000732
   VCID: 78FFE4C90B5A125BEB-802C
   Subsystem 1 - Part No: 1P0 959 538 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   01  0100
   Coding: 00000226
   Part No SW: 1P0 920 952     HW: 1P0 920 952
   Component: KOMBI         H17 0109
   Coding: 410A00
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 6CD7C8998702AEFB1F-8038
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K097020A93
   Coding: E9A07F06400612001203
   Shop #: WSC 02017 476 86467
   VCID: 66C3BAB151EE94AB49-8032
                    Reset counter: 59
                    Mileage: 135851 km
01304 - Radio
                    Reset counter: 59
                    Mileage: 135851 km
03272 - Control Module for Audio Interface
                    Reset counter: 59
                    Mileage: 135851 km
   Component: IMMO          H17 0109
Address 2E: Media Player 3
Address 37: Navigation
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1518
   Revision: 71009005    Serial number: 00000925898601
   Coding: 0004784
   VCID: 408F4C29130A9A9B93-8014
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:04:49
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 142    2901
   Revision: 00H17000
   VCID: 2F6D1F95BE9415E37A-807A
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:04:49
                    Battery Volts: 12.0 V
                        DD
                    Temperature: 21.0 C
                    Count: 2
                    Steering Angle: 0.00
                    Count: 1
                        SteerAng n.Init
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1518
   Revision: 71009005    Serial number: 00000508498212
   Coding: 0004784
   VCID: 4189492D180093939C-8014
Address 56: Radio
   Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000004130137
   Coding: 0000144
   VCID: 74E7D0F91732763BC7-8020
   Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000004065727
   Coding: 0000144
   VCID: 75E1EDFD1C486F33F0-8020
00935 - Electric Window Motor; Rear Right (V27)
                    Fault Status: 00100101
                    Reset counter: 80
                    Mileage: 135515 km
                    Date: 2020.03.28.
                    Time: 13:53:24
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
   Component: FSE_2P8x        H35 0170
   Revision: 00000000    Serial number: 00000005064160
   Coding: 0010555
   VCID: 387F24C94BDAD25B2B-806C
01304 - Radio
                    Reset counter: 59
                    Mileage: 135851 km
                    Date: 2020.03.28.
                    Time: 00:05:08
End-------------------------(Elapsed Time: 02:37)--------------------------
------------------------------18 Faults Found------------------------------
I'm not the ABS guy on this forum, but from what I have viewed in the past when this occurs, try to add a couple (two) zeros on the end of that coding string.
You will then have to do the basic settings in that (the) same session.
If that does not work , you will need to wait for additional help.
A.Penny91
C?ID=212287 (NRRT)
Absolute legend thankyou, it kept forgetting the code once accepted after a few ignition cycles, but after a bit of faffing around with the basic settings ive finally sorted it.
Much appreciated.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
