Resolved 2016 Audi Q7 4M, replace EPS-module with used one (coding issue)
Resolved
EiVes
Bergen, Norway
C?ID=594599
I have replaced my Q7s power steering module after it going dead (no communication, module J500 address 44 not present in scan). FlexRay branch 2 bus measured and found ok. Gearbox on the same branch works fine. After installing the new used module and clearing codes, some functions are back and communication are working. I can see from the scan that the coding of the new module are diffrent than the old, but have no clue if that is a problem and should be the same. Still no power assist. I have tried to delete adaption on the new module, but without success.
Old scan from before module died:
Chassis Type: 4M-AU73 (4M2)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 28 29 36 39 3C 42 44 46
          47 50 52 5F 69 6C 6D 74 81 82 8B A5 AC BB BC CA CB CF D6 D7
VIN: WAUZZZ4M8GD005445   Mileage: 115290km-71637miles
50-Seat Adj. 3rd row -- Status: OK 0000
AC-Reductant Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H45 0009
   Revision: 91H45---    CVN: 5D7B42084F8B6DFB92F1EF3C
   Coding: 2A2A403A057E050335380000000000000000000000000000
   Shop #: WSC 12242 004 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401 001013
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 66926E9D08E9357AC57-8032
   VINID: 9D196AAAA11D217500005104141A05E0A2
16928 - Control Circuit for Reductant Pump 1
          P208A 00 [00100000] - Open Circuit
                    Mileage: 113193 km
                    Date: 2024.09.06
                    Time: 15:37:49
                    Engine RPM: 729.00 /min
                    Normed load value: 33.3 %
                    Vehicle speed: 9 km/h
                    Coolant temperature: 89  C
                    Intake air temperature: 10  C
                    Voltage terminal 30: 13.980 V
                    Unlearning counter according OBD: 37
                    Outside temperature: 6.0  C
                    Pressure sensor for reducing agent: measured pressure: 8976 hPa
                    Pump for reducing agent: speed: 0.0 /min
                    Sensor for reducing agent tank temperature: temperature: 15.7  C
                    Reducing agent pump: activation: 30.00 %
                    Sensor for reducing agent fill level: fill level height: 122 mm
                    Sensor 2 for temp. reducing agent: act. value: 14.5  C
9644 - Reductant
          P20E9 00 [01101000] - Pressure too High
                    Mileage: 113193 km
                    Date: 2024.09.06
                    Time: 15:37:44
                    Engine RPM: 877.50 /min
                    Normed load value: 26.7 %
                    Vehicle speed: 43 km/h
                    Coolant temperature: 91  C
                    Intake air temperature: 6  C
                    Voltage terminal 30: 14.240 V
                    Outside temperature: 5.0  C
                    Pressure sensor for reducing agent: measured pressure: 7907 hPa
                    Sensor for reducing agent tank temperature: temperature: 16.3  C
                    Reducing agent pump: activation: 0.00 %
                    Sensor for reducing agent fill level: fill level height: 114 mm
                    Sensor 2 for temp. reducing agent: act. value: 15.5  C
9646 - Reductant
          P20E9 00 [00100000] - Pressure too High
                    Mileage: 113201 km
                    Date: 2024.09.06
                    Time: 17:57:53
                    Engine RPM: 0.00 /min
                    Coolant temperature: 63  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 12.820 V
                    Unlearning counter according OBD: 17
                    Outside temperature: 12.5  C
                    Pressure sensor for reducing agent: measured pressure: 1293 hPa
                    Pump for reducing agent: speed: -2504.0 /min
                    Sensor for reducing agent tank temperature: temperature: 13.8  C
                    Sensor for reducing agent fill level: fill level height: 134 mm
                    Sensor 2 for temp. reducing agent: act. value: 13.0  C
9642 - Reductant
          P20E9 00 [01100000] - Pressure too High
                    Fault Frequency: 8
                    Mileage: 113194 km
                    Date: 2024.09.06
                    Time: 15:57:10
                    Engine RPM: 1217.50 /min
                    Normed load value: 75.3 %
                    Vehicle speed: 28 km/h
                    Coolant temperature: 81  C
                    Intake air temperature: 15  C
                    Voltage terminal 30: 14.060 V
                    Outside temperature: 9.0  C
                    Pressure sensor for reducing agent: measured pressure: 6446 hPa
                    Pump for reducing agent: speed: 696.0 /min
                    Sensor for reducing agent tank temperature: temperature: 15.0  C
                    Reducing agent pump: activation: 50.00 %
                    Sensor for reducing agent fill level: fill level height: 113 mm
                    Sensor 2 for temp. reducing agent: act. value: 14.0  C
Readiness: 0 1 0 0 0
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H03 1013
   Revision: --H03---    CVN: 228458AD
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B24EFE923EB58924A9-806E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0521
   Dataset Number: 4M0909504G  0029 CVN: 5BF8C31D
   Coding: 249830B230A20A9BD6A25895188256AAE6A6DA240C0C506B1A186A5567655B
   Shop #: WSC 33229 001 1048576
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3FDC9BF937F344B2661-806A
454400 - Databus
          U1123 00 [00101000] - Received Error Message
          [Signal_ARA_Status_error_(2)]
                    Mileage: 113766 km
                    Date: 2024.09.28
                    Time: 09:26:47
   Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
   Component: MEM-BFS       008 0014
   Serial number: 00000149699735 Dataset Number: 4M0909866B  0013
   Coding: 000010000000B0410000210101010000110000313100000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3A2AEAED2CD1619A51F-806E
   Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
   Component: Klima Zone 4  H52 0060
   Coding: 6618481C5549411102620180800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 2D00D1B1ED9FC622C4D-8078
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000423643
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 6928C9A7000000000001
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0215
   Dataset Number: 4M0909514L  0038
   Coding: 07501943C12900CD010D5719583F18F913033D009000000000000000E20016810A4502AB32B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 014003
   ROD: EV_BCM1BOSCHAU736_014.rod
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 150330  042 0792
   Serial number:         150415223236
   Coding: 1BC7F7
   Serial number: 20298502
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 P    HW: 4M0 941 531 P
   Component: E1 - LDS  H05 0007
   Serial number: 17 05 2015  00023719
   Subsystem 4 - Part No SW: 4M0 907 410     HW: 4M0 907 410
   Component: EHL2 V8  H05 0040
   Serial number: 0000009600331Z017502
   Coding: 310000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20150529113038 00121
   Subsystem 6 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE119051511520226
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 AK    HW: 4M0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00012954
   Subsystem 8 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000004822
327714 - Pitch Angle Sensor
          C1179 F2 [00001000] - Implausble Signal Relationship
                    Reset counter: 158
                    Mileage: 113766 km
                    Date: 2024.09.28
                    Time: 09:26:47
                    average_Voltage_terminals: 14.90 V
                    Outside air temperature sensor-Resistance: 645.12 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 6.00  C
                    interior_temperature: 14926.00  C
                    Vehicle speed: 486.47 km/h
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 C    HW: 4M0 907 561
   Component: LRR4          H08 0160
   Dataset Number: 4M0909863J  0022
   Coding: 3477E7FB78FFEC08949880A4
   ASAM Dataset: EV_ACCBOSCHAU736 001016
   ROD: EV_ACCBOSCHAU736.rod
   VCID: 303EC8C5FAADABCAEFB-8064
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 132
                    Mileage: 111386 km
                    Date: 2024.07.05
                    Time: 12:09:35
                    Control Module temperature: 21  C
                    Voltage terminal 15: 14.1 V
                    Velocity_vehicle_reference: 17.48 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.77 m/s
1542 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 156
                    Mileage: 113662 km
                    Date: 2024.09.24
                    Time: 07:52:13
                    Control Module temperature: 28  C
                    Voltage terminal 15: 14.5 V
                    Velocity_vehicle_reference: 7.68 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.28 m/s
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0081
   Serial number: 003L10005K9G Dataset Number: 4M0909602G  0002
   Coding: AAFCF0D80C80000098F650F3C00C00000000
   Shop #: WSC 37164 001 1048576
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 78AE30E5525DB38A67B-802C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705D0149P00094
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0152P00456
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 062 105 15
   Serial number: 3577Y00B3193B854337
   Subsystem 4 - Part No SW: -----------    HW: 442 062 105 15
   Serial number: 3587Y00B1193B850D0E4
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 405 15
   Serial number: 35177000429352E966EB
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 405 15
   Serial number: 35277000229352E5672
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 405 15
   Serial number: 3557500B51B50DF0E16L
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 405 15
   Serial number: 3567500B51B50DF3837M
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 405 15
   Serial number: 2307500B71B9D75131CC
   Subsystem 10 - Part No SW: -----------    HW: 442 420 805 15
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00B9193B85242BP
   Subsystem 11 - Part No SW: -----------    HW: 442 420 805 15
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00B9193B854040F
   Central crash sensor X/Y:
   Subsystem 12 - Part No SW: -----------    HW: 410 201 505 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800AB1656923525-
1060613 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
                    Reset counter: 156
                    Mileage: 113662 km
                    Date: 2024.09.24
                    Time: 07:52:13
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 156
                    Mileage: 113662 km
                    Date: 2024.09.24
                    Time: 07:52:14
1060615 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 156
                    Mileage: 113662 km
                    Date: 2024.09.24
                    Time: 07:52:14
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 156
                    Mileage: 113662 km
                    Date: 2024.09.24
                    Time: 07:52:14
   Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7CA62CF566659FAA033-8028
   Part No SW: 4M0 920 790     HW: 4M0 920 790
   Component: FBenRDW       H12 0280
   Coding: 040400E07C98000801A369603000600000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 6C861CB516050F2A933-8038
Address 18: Aux. Heat (J364)       Labels:| 4M0-265-105.clb
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H09 0060
   Dataset Number: 4M0909858B  0014
   Coding: 0D0F01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 290825A1D977DA02285-807C
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 4079
   Revision: 3C010050    Serial number: 5043C002015503 Dataset Number: 4M0909515H  0057
   Coding: 0301000100800F407F07000000590032DC9200071C0000000100000000000000
   Shop #: WSC 23430 002 1048576
   GVL: 01503C0C08040000C0FCC8000106C800110C2000000000000000000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU73.rod
   VCID: 3632FEDD18C985FAB57-8062
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20150513024054 RD279
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9041
   Serial number: 5024296603
16646147 - Databus
          [PSD_EHR_CONSTRUCT_ERROR_NAV_ERROR_RESET]
                    Fault Frequency: 32
                    Reset counter: 132
                    Mileage: 111386 km
                    Date: 2024.07.05
                    Time: 12:09:35
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0060
   Coding: 000040000000000100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
524289 - Rear Left Seat Heater
          B1117 01 [00001001] - Electrical Failure
                    Reset counter: 105
                    Mileage: 113191 km
                    Date: 2024.09.06
                    Time: 15:12:40
                    Voltage terminal 30: 14.43 V
524288 - Rear Right Seat Heater
          B1118 01 [00001001] - Electrical Failure
                    Reset counter: 105
                    Mileage: 113191 km
                    Date: 2024.09.06
                    Time: 15:12:40
524291 - Heated Seat Back; Rear Left
          B142A 01 [00001001] - Electrical Failure
                    Reset counter: 105
                    Mileage: 113191 km
                    Date: 2024.09.06
                    Time: 15:12:40
524290 - Heated Seat Back; Rear Right
          B142B 01 [00001001] - Electrical Failure
                    Reset counter: 105
                    Mileage: 113191 km
                    Date: 2024.09.06
                    Time: 15:12:40
   Part No SW: 4M0 907 397 B    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0011
   ASAM Dataset: EV_LCMLeftHELLAAU736 001006
   Component: MEM-FS        008 0014
   Serial number: 00000149699858 Dataset Number: 4M0909856B  0013
   Coding: 00181B000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   ASAM Dataset: EV_LCMRightHELLAAU736 001006
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566     HW: 4M0 907 566
   Component: MRR1Rear      H13 0161
   Revision: --------    Dataset Number: 4M0909535J  0009
   Coding: 1EE002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 72BA02CD3421D9DA59F-8026
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000151306224  Dataset Number: 4M0909872F  0026
   Coding: 005D9A015E000080000130B2
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 42DA920D4401295A09F-8016
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H17 0004
   Serial number: 0000840237 Dataset Number: 4M0909852G  0022
   Coding: B0150101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 3334C7C90BBB90D2929-8066
   Part No SW: 8W0 907 064 CD    HW: 4M0 907 064 D
   Component: BCM2 MLBevo   015 0344
   Dataset Number: 4M0909501VF 0001
   Coding: 01341E000F110060630980006E00580203004004004F03502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 005E58050A8DFB4A5FB-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY150641E91
   Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000062561929
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4M0 907 133     HW: 4M0 907 133
   Component: J505-FSH  H03 0040
   Serial number: 00000000000000000879
   Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0815
   Serial number: 94005282
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000004324 Dataset Number: 4M1909510C  0008
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 21183D81A1471242705-8074
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0014
   Serial number: 00000151440186 Dataset Number: 4M0909467B  0014
   Coding: FF001020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C26ECF526E55FAA433-8068
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0036
   Serial number: 0000151327217  Dataset Number: 4M0909873D  0021
   Coding: 005D9A015E000480000130B0
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 3E22E6FD30F94DBA6D7-806A
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 035 K    HW: 4M0 035 035
   Component: MU-P-LND-EU   041 1421
   Serial number: A270E0FB004659 Dataset Number: 4M0909545C  0024
   Coding: 013706010000000013111102000A00332F001BE5017001009E
   VCID: 2C06DCB5D685CF2AD33-8078
   Subsystem 1 - Part No SW: V03 959 802 TP    HW: -----------
   Component: ECE 2022/2023  --- 0197
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ4007P3
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0209
   Serial number: 26051500000000000059
   Compact disc data bank:
   Component: Gracenote2  --- 1010
3086 - Antenna for Telephone Mount
          B1564 01 [00001000] - Electrical Failure
                    Fault Frequency: 11
                    Reset counter: 169
                    Mileage: 110734 km
                    Date: 2024.06.21
                    Time: 08:11:57
                    Voltage terminal 30: 14.8 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): selected
                    Status of telephone-Handset holder (cradle): connected
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [00001000] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 168
                    Mileage: 113644 km
                    Date: 2024.09.24
                    Time: 07:16:30
                    Voltage terminal 30: 11.8 V
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0208
   Revision: 9A001003    Serial number: 0370411072 Dataset Number: 4M0909527C  0021
   Coding: 0110000202010000
   Bend angle sensor for trailer:
   Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
   Component: G820 KNWINSEN  H18 0019
   Serial number: 4027
656394 - Bulb for Left Tail Light on Trailer
          C10F5 15 [00001000] - Open or Short to Plus
                    Mileage: 111500 km
                    Date: 2024.07.13
                    Time: 21:43:25
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [00001000] - Open or Short to Plus
                    Reset counter: 158
                    Mileage: 113778 km
                    Date: 2024.09.28
                    Time: 09:54:30
   Part No SW: 4M0 907 428     HW: 4M0 907 428
   Component: Areaview 2    H11 0282
   Serial number: C854606JG000326 Dataset Number: 4M1909460B  0012
   Coding: 02370601B70FA10000404440
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 003013
   ROD: EV_CamSysRVAV2CE2MLBEv_003.rod
   VCID: 6FBC0BB92713F432B61-803A
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30027352100000 Dataset Number: 4M0909541E  0020
   Coding: 00F0
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70BE08C53A2DEBCAAFB-8024
0024 - Hall Sensors in Motor 1 for Rear Lid
          B1211 02 [00001000] - Signal Failure
                    Reset counter: 139
                    Mileage: 112881 km
                    Date: 2024.08.22
                    Time: 14:14:05
                    Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply: OFF
                    Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply: OFF
                    Status of hall sensor in motor for tailgate-Motor 1: Sensor 1: 00000000
                    Status of hall sensor in motor for tailgate-Motor 1: Sensor 2: 00000000
                    Status of hall sensor in motor for tailgate-Motor 2: Sensor 1: 00000000
                    Status of hall sensor in motor for tailgate-Motor 2: Sensor 2: 00000000
                    Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1: 00000000
                    Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply: On
0069 - Rear Lid Closing Assistance
          B113E 07 [00001000] - Mechanical Failure
                    Mileage: 112860 km
                    Date: 2024.08.18
                    Time: 15:45:22
                    Status of closing assist-Limit switch for pull-shut assist.: Not operated
                    Status of rear lid lock-pre-latch: closed
                    Status of rear lid lock-Main latch: Open
                    Status of rear lid lock-Rear lid lock: Rear lid lock in safety catch
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M0 907 777     HW: 4M0 907 777
   Component: Fahrwerk-SG   H10 0102
   Serial number: 2805150206 Dataset Number: 4M0909576J  0031
   Coding: B8505050F8
   ASAM Dataset: EV_ChassContrContiAU736 002013
   ROD: EV_ChassContrContiAU736.rod
   VCID: 76B23EDD5849C5FA757-8022
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
   Component: V66LFKompOLV  H06 0012
   Serial number: 00000000004130009006
   Coding: 303030
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0066
   Revision: 0L0D5012    Serial number: 20150519001135
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU72.rod
   VCID: 26122E9DC869F57A057-8072
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617     HW: 4M0 919 617
   Component: HeadUpDisplay H25 1507
   Coding: 4F00C0
   ASAM Dataset: EV_HudNSEIKAU736 001012
   ROD: EV_HudNSEIKAU736_AU73.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 C    HW: 4M0 907 541
   Dataset Number: 4M0909885G  0020
   ASAM Dataset: EV_ACC2BOSCHAU736 001016
   ROD: EV_ACC2BOSCHAU49X_001.rod
   VCID: 2E02D6BDE099BD3AFD7-807A
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLIND]
                    Reset counter: 156
                    Mileage: 113662 km
                    Date: 2024.09.24
                    Time: 07:52:13
                    Control Module temperature: 27  C
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 7.63 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.38 m/s
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 B
   Component: BVS           H11 0042
   Dataset Number: 4M0909466J  0038
   Coding: 0407030600000404032023A7CD0000B4B0F0C020E280
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F3CCBB9E793B432F61-807A
1123593 - Databus
          [PSD_04_PSD_Segmente]
                    Fault Frequency: 25
                    Reset counter: 132
                    Mileage: 111386 km
                    Date: 2024.07.05
                    Time: 12:09:35
                    Control Module temperature: 26  C
                    Voltage terminal 15: 14.20 V
1123600 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
                    Fault Frequency: 22
                    Reset counter: 170
                    Mileage: 110654 km
                    Date: 2024.06.13
                    Time: 13:46:34
                    Control Module temperature: 22  C
                    Voltage terminal 15: 14.70 V
1123601 - Predictive Route Data
                    Fault Frequency: 8
                    Reset counter: 159
                    Mileage: 111464 km
                    Date: 2024.07.10
                    Time: 18:07:03
                    Voltage terminal 15: 14.80 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   Dataset Number: 4M0909571E  0012
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   VCID: 6E8216BD2019FD3ABD7-803A
196689 - Control Circuit for Reductant Pump 1
          P208A 00 [00001000] - Open Circuit
                    Reset counter: 167
                    Mileage: 113193 km
                    Date: 2024.09.06
                    Time: 15:37:45
                    Terminal 30A voltage: 14.38 V
                    Terminal 30B voltage: 14.41 V
                    Supply voltage for external components: 5.00 V
                    Reducing agent quality sensor: voltage terminal 31: 0.00 V
                    Pump for reducing agent: speed: -1540 /min
                    Pump for reducing agent: current: 0.05 A
                    Reducing agent pump: operating state: recirc. mode
                    Reducing agent pump: end stage activation status: active
                    Reducing agent pump: end stage temperature: 33  C
                    Heating circuit 1 f. red. agent metering sys.: end stage temp.: 27  C
                    Sensor for reducing agent tank temperature: temperature: 21  C
                    Pressure sensor for reducing agent: voltage: 4.49 V
                    Sensor for reducing agent fill level: fill level height: 138 mm
                    Reducing agent quality sensor: urea concentration: 107.00 %
                    Sensor 2 for temp. reducing agent: act. value: -45.00  C
                    Heating circuit 1 for reducing agent: power: 0 W
                    Heating circuit 1 for reducing agent: power set value: 0 W
                    Heating circuit 1 for reducing agent: power limitation: 140 W
                    Heating circuit 3 for reducing agent: power: 0 W
                    Heating circuit 3 for reducing agent: power set value: 0 W
                    Heating circuit 3 for reducing agent: power limitation: 78 W
                    Heating circuit 2 for reducing agent metering: power: 0 W
                    Heating circuit 2 for reducing agent metering: activation: not active
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0036
   Serial number: 0000150312158  Dataset Number: 4M0909897D  0022
   Coding: 004D980000000480000030A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 41D89D0141073242105-8014
   Component: TSG HBFS      009 0036
   Serial number: 0000150309975  Dataset Number: 4M0909896D  0022
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: 4M0909469E  0013
   Coding: 608000053602
   VCID: 73B407C94B3BD0D2529-8026
Address CB: Rear Axle Steering (J1019)       Labels:* 4M0-909-145.clb
   Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
   Component: HAL_MLBevoH07 0607
   Revision: --------    Serial number: CCC_007_D_07_03 Dataset Number: 4M0909904H  0017
   Coding: 00852C
   ASAM Dataset: EV_RearAxleSteerZFAU736 005010
   ROD: EV_RearAxleSteerZFAU736_005.rod
   VCID: 3436C4D50EB597EA8B3-8060
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590     HW: 4M0 907 590
   Revision: --------
   Coding: 1EE002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CA    HW: 7PP 941 592 C
   Component: LED1L         H09 2002
   Dataset Number: 4M0909471C  0011
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1968156189174A82B85-804C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 2002
   Dataset Number: 4M0909472C  0011
End----------(Elapsed Time: 02:58, VBatt start/end: 14.8V/14.8V)-----------
Scan with new module installed:
VIN: WAUZZZ4M8GD005445   Mileage: 128379km-79771miles
CB-Rear Axle Steering -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
   VCID: 66926E9D08E9357A14F-8032
   Coding: 100000
   VCID: 3B24EFE923EB58929B1-806E
   VCID: 3FDC9BF937F344B2B79-806A
178432 - Databus
          U1123 00 [00101111] - Received Error Message
          [Signal_EPS_Lenkmoment_error_(1023)]
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:53
179200 - Databus
          [Signal_EPS_Unterstuetzungsleistung_error_(255)]
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:53
   VCID: 3A2AEAED2CD1619A807-806E
   VCID: 2D00D1B1ED9FC622155-8078
   Coding: 1BC7F7
   Coding: 0200FF
   Coding: 310000
   Coding: 030000
9 Faults Found:
131945 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
                    average_Voltage_terminals: 12.00 V
                    Outside air temperature sensor-Resistance: 419.84 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 14.50  C
                    interior_temperature: 17998.00  C
                    Vehicle speed: 0.00 km/h
196760 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
196761 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
196901 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
196904 - Parking Assist Not Available
          B1928 F0 [00001001] - Steering Assist Incorrectly Coded
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
327700 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
327701 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
327729 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
327730 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
   VCID: 303EC8C5FAADABCA3E3-8064
7 Faults Found:
2171 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FAULT_EPS_ESS_CODING]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Control Module temperature: 40  C
                    Voltage terminal 15: 11.8 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
2150 - Databus
          [FAULT_EPS_SUPPORTPOWER_FAIL]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Control Module temperature: 39  C
                    Voltage terminal 15: 11.6 V
0852 - Databus
          [FAULT_EPS_ZAHNSTANGENPOSITION_ERROR]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
1392 - Databus
          [FAULT_LRRS_SELFDIAG]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
2120 - Databus
          [FAULT_STA_CODED_PLAUS_FAIL]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
   VCID: 78AE30E5525DB38AB63-802C
   Coding: 88001B
   Coding: 88001B
1061893 - Databus
          [NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1060613 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1060614 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1060615 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1060617 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:53
   VCID: 7CA62CF566659FAAD2B-8028
   VCID: 6C861CB516050F2A42B-8038
   Coding: 0D0F01
   VCID: 290825A1D977DA02F9D-807C
   VCID: 3632FEDD18C985FA64F-8062
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Voltage terminal 30: 12.13 V
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
   Coding: 1EE002
   VCID: 72BA02CD3421D9DA887-8026
1192224 - Databus
          [databus error value received - EPS_Zahnstangen_Pos]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Voltage terminal 30: 11.80 V
                    Terminal 15 status: OFF
                    Voltage terminal 15: Measuring value not available
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
   VCID: 42DA920D4401295AD87-8016
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000584449 Dataset Number: 4M0909852P  0002
   Coding: 90040001010000
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 3436C4D50EB597EA5AB-8060
2125873 - Limp Mode not Possible
          C10CB 00 [10001001] - -
          [Sensor_failsafe_not_possible]
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 15:36:52
                    FreezeFrame_mw_1206_SNL-Steering torque sensor 1: 0.00 Nm
                    FreezeFrame_mw_1206_SNL-Steering torque sensor 2: 0.00 Nm
                    FreezeFrame_mw_1206_SNL-Output stage voltage: 11.13 V
                    FreezeFrame_mw_1206_SNL-Statusmask_basis_software: 00 00
                    FreezeFrame_mw_1206_SNL-Statusmask_SNL: 00 00
                    FreezeFrame_mw_1206_SNL-steering_angle_sender_calibration_traceability: 00 53
4208000 - Steering Angle Sensor
          B1168 F1 [10001001] - Synchronization Failed
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    FreezeFrame_1210_LKF_BLW-Steering wheel angle: 0.00
                    FreezeFrame_1210_LKF_BLW-Long term adaptation value: 0.00
                    FreezeFrame_1210_LKF_BLW-Steering pinion angle: offset corrected: 0.00
                    FreezeFrame_1210_LKF_BLW-Actual state of BLW state machine: 7
                    FreezeFrame_1210_LKF_BLW-Angle_super_poisition: 4094
                    FreezeFrame_1210_LKF_BLW-LWI_sub_Daten: 0
                    FreezeFrame_1210_LKF_BLW-SCU state: OK
                    FreezeFrame_1210_LKF_BLW-Status_EKO_BSW: 00 00
                    FreezeFrame_1210_LKF_BLW-steering_angle_sender_calibration_traceability: 00 53
                    FreezeFrame_1210_LKF_BLW-Variant Coding Signal: Series
2108032 - Steering Torque Sensor 1
          C10F0 29 [00001001] - Signal Implausible
          [STS_SENT_Channel1]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    FreezeFrame_mw_1205_DME-Sensor 1 supply: 63.75 V
                    FreezeFrame_mw_1205_DME-Sensor 2 supply: 63.75 V
                    FreezeFrame_mw_1205_DME-Steering torque sensor 1: 0.00 Nm
                    FreezeFrame_mw_1205_DME-Steering torque sensor 2: 0.00 Nm
                    FreezeFrame_mw_1205_DME-Combined information: FF
                    FreezeFrame_mw_1205_DME-DME Active Error Information: FF FF FF FF
                    FreezeFrame_mw_1205_DME-DME Debounced Event Information: FF FF FF FF
2112128 - Steering Torque Sensor 2
          C10F1 29 [00001001] - Signal Implausible
          [STS_SENT_Channel2]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
   ROD: EV_BCM2HellaAU736_012_AU73.rod
   VCID: 005E58050A8DFB4A8E3-8054
   VCID: 21183D81A1471242A1D-8074
   VCID: 3C26ECF526E55FAA92B-8068
   VCID: 3E22E6FD30F94DBABCF-806A
   VCID: 2C06DCB5D685CF2A02B-8078
   Multimedia display unit 1:
   VCID: 3334C7C90BBB90D2431-8066
   Serial number: 4027
   VCID: 6FBC0BB92713F432679-803A
   Coding: 00F0
   VCID: 70BE08C53A2DEBCA7E3-8024
   Coding: B8505050F8
   VCID: 76B23EDD5849C5FAA4F-8022
   Coding: 303030
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 26122E9DC869F57AD4F-8072
   Coding: 4F00C0
   VCID: 2E02D6BDE099BD3A2CF-807A
0852 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Control Module temperature: 42  C
   VCID: 2F3CCBB9E793B432279-807A
7 Faults Found:
1123157 - Databus
          [LH_EPS_03_EPS_Berechneter_LW]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
                    Voltage terminal 15: 12.00 V
1123158 - Databus
          [LH_EPS_03_EPS_Lenkmoment]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1123159 - Databus
          [LH_EPS_04_EPS_Zahnstangen_Pos]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1123160 - Databus
          [LH_EPS_02_EPS_Unterstuetzungsleistung]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
1123733 - Databus
          [SWA_01_SWA_rel_Fehler]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
0659 - Steering
          C10AC F2 [00001001] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
4195334 - Steering
          C10AC F4 [00001001] - Traffic Jam Assistance Not Coded
          [STA_deactivated]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:52
   VCID: 6E8216BD2019FD3A6CF-803A
   VCID: 41D89D0141073242C1D-8014
   VCID: 73B407C94B3BD0D2831-8026
   Coding: 00852C
0192 - Databus
          [KFC_FLEXRAY_EPS_02_FAULT_VALUE]
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Expanded ambient data 1-Terminal 75 status: 0
                    Expanded ambient data 1-Internal voltage supply 5V: 3.75 V
                    Expanded ambient data 1-Internal malfunction: 0
                    Expanded ambient data 1-Terminal 15 signal: 0
                    Expanded ambient data 1-Power reduction: 0 %
                    Expanded ambient data 1-Restart: 0
                    Expanded ambient data 1-Terminal 30 voltage filtered: 12.04 V
                    Expanded ambient data 1-Power reduction due to overvoltage: 100 %
                    Expanded ambient data 1-Power reduction due to undervoltage: 100 %
                    Expanded ambient data 1-Internal voltage supply 1.2V: 1.20 V
   Revision: --------
   Coding: 1EE002
1192224 - Databus
                    Reset counter: 79
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 17:59:51
                    Voltage terminal 30: 11.90 V
   VCID: 1968156189174A8269D-804C
End----------(Elapsed Time: 02:59, VBatt start/end: 14.5V/14.6V)-----------
------------------------------43 Faults Found------------------------------
Jef
HQ
Original:
Used replacement:
So right off the bat, not the same part number. This might be an issue. :confused: What happens when you try to apply the coding from the original unit to the used unit? What color is the steering wheel light in the dash?
So this code... I have very limited feedback on it, but I think this is physical damage to the hardware. Here are photos of a car that had the same code. And another example of that code I got just the other day, car rolls into shop with a good J500 (no codes in first Auto-Scan), tech remove the subframe but lets the J500 dangle by the steering column and with that, C10CB and a red steering wheel light in the dash.
EiVes
Bergen, Norway
C?ID=594599
Thank you Jef for your feedback. I am aware of the part number issue and has it as a risk that it will be impossible to use this controller card, but it was for sale close to my home. As I understand ETKA and Audi part number coding I can use this later revision of the same card. I have a 2016, while the replacement are from a 2017.
The steering wheel light are red with no assistance. And as I understand, it would have been yellow/orange if limp mode was possible and I would have had about 60% reduction in assistance.
I am not sure what the coding gives the module, but I guess it is input about options on the car, maybe also address for the steering angle sensor? I was not able to reset adaption on the J500 and are working with a theory that it might be old adaption values that are holding me back.
After installation and clear DTCs, back up sensors and 360 camera came back to life.
Edit: When I try to copy the coding from the old unit into the new one I get an error message that wont let me write it to the module. Will check the exact wording later today.
Edit2: Error message when trying to code new module with coding from old module.
Westbury, UK
Later version letters are not always backwards compatible, it's necessary to check in every case.
Ziddywerks
Northern NJ USA
C?ID=208579
Yeah it's fucked because of this fault:
B1168 F1. I doubt coding is your issue. This is a mechanical issue within the rack. Was the whole rack changed?
EiVes
Bergen, Norway
C?ID=594599
Ok, I'll see if I can have a dealer check it for me.
EiVes
Bergen, Norway
C?ID=594599
No, I just moved the control module over. I have the rack that it came with too, so maybe I just have to do the job and change the whole thing over. The old module died completly, no communication on the bus, so *I fugured it was the module that failed due to an old battery or something. Battery was ten years, but seemed fine, no other sypthomes. Have replaced it now.
Ziddywerks
Northern NJ USA
C?ID=208579
Needs a whole rack.
EiVes
Bergen, Norway
C?ID=594599
Needs a whole rack.
Ok, I'll change the whole thing. But the angle sensor is in the steering colum right? and they communicate over the FlexRay bus, is'nt that correct?
Ziddywerks
Northern NJ USA
C?ID=208579
Steering rack has sensor in it.
EiVes
Bergen, Norway
C?ID=594599
Rack changed and only two faults left in J500. Coding from the old module was accepted as well. But still no limp mode :(
Thursday,06,November,2025,21:22:16:61316
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: WAUZZZ4M8GD005445   Mileage: 128425km-79799miles
   Coding: 100000
178432 - Databus
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:22
179200 - Databus
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:22
   Coding: 1BC7F7
   Coding: 0200FF
   Coding: 310000
   Coding: 030000
9 Faults Found:
131945 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
                    average_Voltage_terminals: 12.20 V
                    Outside air temperature sensor-Resistance: 463.36 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 12.50 °C
                    interior_temperature: 17358.00 °C
196760 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
                    Outside air temperature sensor-Resistance: 460.80 kOhm
196761 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
196897 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
196901 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
327700 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
327701 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
327729 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
327730 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
2179 - Databus
          [FAULT_EPS_ESS_REQ_NOT_POSSIBLE_HIGH_POWER_FAIL]
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Voltage terminal 15: 12.1 V
2150 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
0852 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
1392 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
0800 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
   Coding: 88001B
   Coding: 88001B
1061893 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
1060613 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
1060614 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
1060615 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
1060617 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:21
   Coding: 0D0F01
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Voltage terminal 30: 12.31 V
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
   Coding: 1EE002
1192224 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Control Module temperature: 37 °C
                    Voltage terminal 30: 12.00 V
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Voltage terminal 30: 12.10 V
5258753 - Steering End Stops Not Learned
          C10AC F0 [10001001] -
          [End_stop_not_learned]
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    FreezeFrame_mw_1216_EAL-Steering wheel angle: 00 03
                    FreezeFrame_mw_1216_EAL-Reason of EA unlearn: 00
                    FreezeFrame_mw_1216_EAL-SCU motor angle BUS: 4094 °
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 15:36:52
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 AJ    HW: 4M0 959 754 AJ
   Component: ID-Geber  H32 0102
   Serial number: 3615000120340001
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Subsystem 4 - Part No SW: 4M0 907 133     HW: 4M0 907 133
   Subsystem 5 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
          B1564 01 [00001001] - Electrical Failure
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:22
                    Voltage terminal 30: 12.3 V
   Serial number: 4027
   Coding: 00F0
   Coding: B8505050F8
   Coding: 303030
   Coding: 4F00C0
0852 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Control Module temperature: 35 °C
1123157 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 12.30 V
1123158 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
1123159 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
1123160 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
1123733 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
4195330 - Databus
          [HC_requirement_not_workable]
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
   Coding: 00852C
0192 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Expanded ambient data 1-Terminal 30 voltage filtered: 12.31 V
   Revision: --------
   Coding: 1EE002
1192224 - Databus
                    Reset counter: 79
                    Mileage: 128425 km
                    Date: 2025.11.06
                    Time: 21:16:20
                    Control Module temperature: 38 °C
                    Voltage terminal 30: 12.20 V
End----------(Elapsed Time: 02:55, VBatt start/end: 12.2V/12.1V)-----------
------------------------------40 Faults Found------------------------------
Hmm. C10CB is suspicious but if the new used rack and control module are mated with reasonable toe adjustment I would cling onto hope.
I'm not in a wiring diagram but I think G85 is inside the slip ring (address 16) on this vehicle. With the engine at idle and steering wheel straight connect to address 16 and see if these Advanced Measuring values are close to 0 °:
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value​
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset​
If they are pretty close to zero I would steer to full lock right and hold that position for 5+ seconds. Note the numbers (or Add to Log) and wait to see if the instrument cluster beeps because address 44 may learn the end-stops while you are doing that. Then, turn to the extreme left side stop, keep holding and note those values while waiting to see if it beeps at you.
If there isn't any improvement on the DTCs but the G85 values looked good I would stay in address 16, straighten the wheel back up to 0.0° and then use Security Access code 40168 followed by Basic Settings:
[*IDE02284*] Steering angle sensor: carry out zero calibration
If that is successful you would need to repeat the right and left extreme end stop dance.
EiVes
Bergen, Norway
C?ID=594599
Lifted the front wheels for this :) its a good workout going lock to lock with no assist. This was in 16 indeed, but i hear no beeps.
Steering wheel center (fideled into 0.0 degrees):
Full right lock:
Full left lock:
When doing the [*IDE02284*] Steering angle sensor: carry out zero calibration it goes directly to Not running, but a beep and error message on dampers go off in the dash:
Baby steps, now down to one error code from J500. From the total of 40 codes I think that more than 30 of them are related to the J500 issue. The [Sensor_failsafe_not_possible] are holding me back. Is it possible to find the criterias that are not met?:
Friday,07,November,2025,12:31:09:61316
VIN: WAUZZZ4M8GD005445   License Plate:
VIN: WAUZZZ4M8GD005445   Mileage: 128429km-79802miles
   Coding: 100000
178432 - Databus
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:29
179200 - Databus
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:29
   Coding: 1BC7F7
   Coding: 0200FF
   Coding: 310000
   Coding: 030000
9 Faults Found:
131945 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
                    Outside air temperature sensor-Resistance: 458.24 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 13.00 °C
                    interior_temperature: 17230.00 °C
196760 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
196761 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
196897 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
196901 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
327700 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
327701 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
327729 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
327730 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
7 Faults Found:
2179 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Voltage terminal 15: 11.9 V
2106 - Databus
          [FAULT_EPS_REQ_DISCARD_FAIL]
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:27:07
                    Voltage terminal 15: 11.0 V
2150 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
0852 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
1392 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
0800 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
   Coding: 88001B
   Coding: 88001B
1061893 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
1060613 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
1060614 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
1060615 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
1060617 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:28
   Coding: 0D0F01
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Voltage terminal 30: 12.06 V
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
   Coding: 1EE002
1192224 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Control Module temperature: 46 °C
                    Voltage terminal 30: 11.70 V
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Mileage: 128379 km
                    Date: 2025.11.04
                    Time: 15:36:52
   Serial number: 4027
   Coding: 00F0
   Coding: B8505050F8
   Coding: 303030
   Coding: 4F00C0
0852 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Control Module temperature: 36 °C
7 Faults Found:
1123157 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 12.10 V
1123158 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
1123159 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
1123160 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
1123733 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
4195330 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:27
4195335 - Databus
          [STA_requirement_not_workable]
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:27:08
                    Voltage terminal 15: 11.40 V
   Coding: 00852C
0192 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Expanded ambient data 1-Terminal 30 voltage filtered: 12.01 V
   Revision: --------
   Coding: 1EE002
1192224 - Databus
                    Reset counter: 79
                    Mileage: 128429 km
                    Date: 2025.11.07
                    Time: 12:26:26
                    Control Module temperature: 47 °C
End----------(Elapsed Time: 02:55, VBatt start/end: 14.7V/14.8V)-----------
EiVes
Bergen, Norway
C?ID=594599
My gut feeling tells me that there are something not calibrated or reset from the donor car settings:
Not able to reset the counter though, but since it is 00, it probably does'nt mather:
NEtech
Denmark
C?ID=56995
It is better to post all data values, with Controller map.
[Applications]
[Controller Channel Map]
- Controller Address = 16 and 44
- Login or security code: Leave blank
- Function: Measuring values And Adaptations
- Output: CSV file
[Go]
Files is placed in C:\Ross-Tech\VCDS\Logs
Try Security access 43702 or 20103
EiVes
Bergen, Norway
C?ID=594599
Thank you NEtech. When trying to reset the mechanical load counter code 20103 was successfully used, will try 43702 if I get more privileges. Will post controller map as soon as I have them.
EiVes
Bergen, Norway
C?ID=594599
Ignition ON, engine OFF, wheels straight.
Blockmap 16:
;SW:4M0-907-129-JE   HW:4M0-907-129-JE ---  Steering wheel
;Component:Lenks.Modul   H11 0008, Coding:
;EV_SMLSKLOAU736,006008,EV_SMLSKLOAU736_006.rod
;Saturday,08,November,2025,22:21:43:61316
;VCDS Version: Release 25.3.2 (x64)  Data version: 20250822 DS365.0
;VCID: 7CA62CF566659FAAD2B-8028
Group,Description,Actual
IDE00333,Driver assistance systems button,Not operated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,On,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Cruise control switch with ACC,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Tap acceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,8 positions,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,Not operated,
IDE02068-MAS00106,Time stamp-Year,2025, yr
IDE02068-MAS00107,Time stamp-Month,11, m
IDE02068-MAS00108,Time stamp-Day,7, d
IDE02068-MAS00109,Time stamp-Hours,12, H
IDE02068-MAS00110,Time stamp-Minutes,15, min
IDE02068-MAS00111,Time stamp-Seconds,50, s
IDE02068-MAS00711,Time stamp-Odometer reading,128429, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 55 5A 5A 5A 34 4D 38 47 44 30 30 35 34 34 35,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Not operated,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 3,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,Not operated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,Not operated,
IDE02743-IDE05742,High Beam-Light switch position,Not operated,
IDE02744-MAS02201,Steering wheel heating-Temperature,13,  C
IDE02744-MAS02324,Steering wheel heating-Voltage at sensor,0.00, V
IDE02744-MAS03746,Steering wheel heating-Current: actual value,0.00, A
IDE02744-MAS04457,Steering wheel heating-PWM pulse duty factor,0, %
IDE03504-MAS03692,Personalized settings-Key 1,not detected,
IDE03504-MAS03693,Personalized settings-Key 2,detected,
IDE03504-MAS03694,Personalized settings-Key 3,not detected,
IDE03504-MAS03695,Personalized settings-Key 4,not detected,
IDE03504-MAS11282,Personalized settings-Status steering wheel heater key 1,OFF,
IDE03504-MAS11283,Personalized settings-Status steering wheel heater key 2,On,
IDE03504-MAS11284,Personalized settings-Status steering wheel heater key 3,OFF,
IDE03504-MAS11285,Personalized settings-Status steering wheel heater key 4,OFF,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,11988.28, mV
IDE03680-IDE00618,Supply voltages-5V voltage supply,4978.13, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,10026.56, mV
IDE05726-IDE01763,Dimmer terminal 58xd-Dimming,98, %
IDE05726-MAS03873,Dimmer terminal 58xd-Duty cycle,0, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Negative,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in correct range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0,  /s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,not initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,in correct range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,2.8,
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,2.0,
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,No malfunction,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,4.8,
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Negative,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Positive,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Negative,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in correct range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,not initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,in correct range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,2.8,
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,No malfunction,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,4.8,
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in correct range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Negative,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,2.2,
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,7.8,
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Negative,
Elapsed Time: 00:05
Adpmap 16:
;Saturday,08,November,2025,22:21:49:61316
IDE00820-IDE80001-Activating and deactivating all development messages-Analysis 1,OFF ,1
IDE00820-IDE80002-Activating and deactivating all development messages-Analysis 2,OFF ,1
IDE00820-IDE80003-Activating and deactivating all development messages-Analysis 3,OFF ,1
IDE00820-IDE80004-Activating and deactivating all development messages-Analysis 4,OFF ,1
IDE00820-IDE80005-Activating and deactivating all development messages-Analysis 5,OFF ,1
IDE02744-Steering wheel heating,34 °C,1
Elapsed Time: 00:01
Blockmap 44:
;SW:4M0-909-144-H   HW:4M0-909-144-B ---  Steering Assist
;Component:EPS_MLBEVO1BS H20 0005, Coding:B0150101000101
;EV_EPSVWBSAU736,009023,EV_EPSVWBSAU736_009.rod
;Saturday,08,November,2025,22:22:14:61316
;VCID: 3436C4D50EB597EA5AB-8060
IDE00102-MAS02954,Control Module temperature-Temperature model value,10.29, °C
IDE00102-MAS02955,Control Module temperature-Engine temperature,10.40, °C
IDE00102-MAS02956,Control Module temperature-Magnet Temperature,10.27, °C
IDE00102-MAS04448,Control Module temperature-Output stage temperature,10.40, °C
IDE00609-IDE10203,Communication status of data bus 1-Audi drive select: drive program,Communication,
IDE00609-MAS00772,Communication status of data bus 1-Battery Monitoring Control Module,Communication,
IDE00609-MAS00795,Communication status of data bus 1-Data Bus On Board Diagnostic Interface,Communication,
IDE00609-MAS00796,Communication status of data bus 1-Engine Control Module,Communication,
IDE00609-MAS00802,Communication status of data bus 1-Control module for distance control,Communication,
IDE00609-MAS00805,Communication status of data bus 1-Lane assistance control module,Communication,
IDE00609-MAS00807,Communication status of data bus 1-Parallel parking assistance control module,Communication,
IDE00609-MAS00811,Communication status of data bus 1-Active steering control module,Communication,
IDE00609-MAS00821,Communication status of data bus 1-Central ctrl. unit for comfort system,Communication,
IDE00609-MAS00824,Communication status of data bus 1-Steering column electronics control module,Communication,
IDE00609-MAS00830,Communication status of data bus 1-Towing recognition control module,Communication,
IDE00609-MAS01172,Communication status of data bus 1-Development messages,No communication,
IDE00609-MAS08787,Communication status of data bus 1-Maneuvering assistant,Communication,
IDE00609-MAS09196,Communication status of data bus 1-Rear Axle Steering,Communication,
IDE00609-MAS11240,Communication status of data bus 1-ABS Control Module,Communication,
IDE00609-MAS13015,Communication status of data bus 1-Routing assistant with park-steering system,Communication,
IDE00609-MAS13018,Communication status of data bus 1-Front sensor for drivers assistant systems,Communication,
IDE00609-MAS13019,Communication status of data bus 1-Chassis Control,Communication,
IDE00924-MAS02125,Steering angle-Steering wheel angle speed,0.00, °/s
IDE00924-MAS02126,Steering angle-Steering angle sensor: status,System OK,
IDE00924-MAS02961,Steering angle-Engine angle,200.92, °
IDE00924-MAS02981,Steering angle-Overlay angle,409.40, °
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.80, °
IDE00924-MAS02984,Steering angle-Steering angle speed,0.57, °/s
IDE00924-MAS13060,Steering angle-Steering pinion angle: offset corrected,-4.79, °
IDE02068-MAS00108,Time stamp-Day,8, d
IDE02068-MAS00109,Time stamp-Hours,22, H
IDE02068-MAS00110,Time stamp-Minutes,22, min
IDE02068-MAS00111,Time stamp-Seconds,14, s
IDE03008-MAS05361,Stop process prevented-Manual steering torque too high,not active,
IDE03008-MAS05409,Stop process prevented-Calculated steering angle too large,not active,
IDE03008-MAS14902,Stop process prevented-Limp home mode active,not active,
IDE03010-MAS05361,Number of prevented stop processes-Manual steering torque too high,0,
IDE03010-MAS05409,Number of prevented stop processes-Calculated steering angle too large,0,
IDE03010-MAS14902,Number of prevented stop processes-Limp home mode active,0,
IDE03011-ENG139175,Number of requested start processes-Frequency_counter_values_Restart,0,
IDE03471-IDE10940,Vehicle configuration-Steering assist. without eng. running,not active,
IDE03471-MAS01891,Vehicle configuration-Lane assist,coded,
IDE03471-MAS02145,Vehicle configuration-ESP ADS coding,Active steering not coded,
IDE03471-MAS02672,Vehicle configuration-Start-stop,coded,
IDE03471-MAS03400,Vehicle configuration-Audi drive select,coded,
IDE03471-MAS08071,Vehicle configuration-Hybrid drive,Not coded,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,coded,
IDE03471-MAS08786,Vehicle configuration-Parallel Parking Assistance,coded,
IDE03471-MAS08940,Vehicle configuration-Collision warning,coded,
IDE03471-MAS12072,Vehicle configuration-Active Steering,Not coded,
IDE03471-MAS12200,Vehicle configuration-Steering recommendation,coded,
IDE03471-MAS12217,Vehicle configuration-Constant steering ratio,Not coded,
IDE03471-MAS12218,Vehicle configuration-Variable steering ratio,Not coded,
IDE03471-MAS13015,Vehicle configuration-Routing assistant with park-steering system,Not coded,
IDE03471-MAS13016,Vehicle configuration-Parking assistant with cross-parking function,coded,
IDE03471-MAS13017,Vehicle configuration-Traffic jam assistant,coded,
IDE03471-ENG111917,Vehicle configuration-Dev_Messages_Test_1,not active,
IDE03471-ENG135409,Vehicle configuration-Development_PDU_DEV_02,not active,
IDE03471-ENG110609,Vehicle configuration-Development_PDU_S100,not active,
IDE03471-ENG110610,Vehicle configuration-Development_PDU_S101,not active,
IDE03471-ENG110611,Vehicle configuration-Development_PDU_S102,not active,
IDE03471-ENG135408,Vehicle configuration-Development_PDU_XCP,not active,
IDE03471-ENG110581,Vehicle configuration-PDU_DEV_01,not active,
IDE03471-ENG160901,Vehicle configuration-Power_class_2,Not coded,
IDE03471-ENG110616,Vehicle configuration-Update_programming_without_bus_simulation,not active,
IDE03471-ENG140514,Vehicle configuration-Variable_Gear_Ration_Steering_2,Not coded,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,12.17, V
IDE03680-MAS02953,Supply voltages-Battery status,connected,
IDE03680-MAS03838,Supply voltages-Output stage voltage,12.20, V
IDE03680-MAS03839,Supply voltages-GDU status,not active,
IDE03681-MAS01853,Wheel speed-Left front,0.00, km/h
IDE03681-MAS01854,Wheel speed-Right front,0.00, km/h
IDE03681-MAS01855,Wheel speed-Left rear,0.00, km/h
IDE03681-MAS01856,Wheel speed-Right rear,0.00, km/h
IDE03682-MAS00371,motor position sensor-Engine speed,0.00, /min
IDE03682-MAS02282,motor position sensor-Position,159.08, °
IDE03682-MAS02960,motor position sensor-Actuation,1763,
IDE03682-MAS02961,motor position sensor-Engine angle,200.92, °
IDE03682-MAS03083,motor position sensor-Cosine signal,0.07, °
IDE03682-MAS03211,motor position sensor-Sine signal,0.09, °
IDE03682-MAS03840,motor position sensor-Engine position test value,0.50,
IDE03723-MAS11513,End stops for steering-End stop left,Adapted,
IDE03723-MAS11514,End stops for steering-End stop right,Adapted,
IDE03723-MAS13021,End stops for steering-Permissible deviation of the calculated offset,OK,
IDE03723-MAS13061,End stops for steering-calculated rack position in right mechanical end-stop,-68.66, mm
IDE03723-MAS13062,End stops for steering-calculated rack position in right mechanical end-stop,67.05, mm
IDE03723-MAS13063,End stops for steering-calculated engine angle in the right mechanical end-stop,183.87, °
IDE03723-MAS13064,End stops for steering-calculated engine angle in the left mechanical end-stop,106.00, °
IDE03723-MAS15438,End stops for steering-LWI fine synchronization,not performed,
IDE03724-MAS02998,Straight line running-Angle value offset,0.00, °
IDE03724-MAS03528,Straight line running-Long term adaptation value,0.00, °
IDE03724-MAS03529,Straight line running-Short term adaptation value,0.00, °
IDE03725-IDE09693,Steering Assistance-Charisma driving program: system status,Available,
IDE03725-MAS02974,Steering Assistance-Target force,-61, N
IDE03725-MAS03002,Steering Assistance-Driving program,no function,
IDE03726-MAS02974,Parallel Parking Assistance-Target force,0, N
IDE03726-MAS05631,Parallel Parking Assistance-System status,1,
IDE03726-MAS12323,Parallel Parking Assistance-Steering wheel angle control: P-term,0.00, °/s
IDE03726-MAS12324,Parallel Parking Assistance-Steering wheel angle control: I-term,0.00, °/s
IDE03726-MAS12326,Parallel Parking Assistance-Park. steer. funct.: reason for abort,0,
IDE03734-MAS02965,Support power-Performance percentage,0.00, %
IDE03734-MAS12809,Support power-Power reduction factor: low voltage,100.00, %
IDE03734-MAS12810,Support power-Power reduction factor: temperature,100.00, %
IDE03735-MAS02961,Steering torque-Engine angle,200.92, °
IDE03735-MAS03841,Steering torque-Engine steering torque: limited required torque,0.00, Nm
IDE03735-MAS03842,Steering torque-Engine steering torque: setpoint,0.00, Nm
IDE03735-MAS03843,Steering torque-Engine steering torque: actual,0.00, Nm
IDE04561-MAS00370,Switch-on and shut-off conditions-Vehicle speed,0.00, km/h
IDE04561-MAS00371,Switch-on and shut-off conditions-Engine speed,0.00, /min
IDE04561-MAS03680,Switch-on and shut-off conditions-Terminal 15 status measured,On,
IDE04561-MAS06982,Switch-on and shut-off conditions-Terminal 15 status signal,On,
IDE04561-MAS09828,Switch-on and shut-off conditions-Status of drive readiness hybrid,not ready to drive,
IDE04562-MAS02976,Steering torque sensor-Sensor 1 supply,0.63, V
IDE04562-MAS02977,Steering torque sensor-Sensor 2 supply,0.64, V
IDE04562-MAS02978,Steering torque sensor-Steering torque sensor 1,-0.06, Nm
IDE04562-MAS02979,Steering torque sensor-Steering torque sensor 2,-0.07, Nm
IDE04562-MAS03791,Steering torque sensor-Actual steering torque value,-0.06, Nm
IDE04562-MAS03844,Steering torque sensor-Engine steering torque sensor: model value,0.00, Nm
IDE04562-MAS03845,Steering torque sensor-Engine steering torque sensor: average value,-0.06, Nm
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Limp home mode active,
IDE06307,Stop prevention history data,Manual steering torque too high,
IDE06307,Stop prevention history data,Calculated steering angle too large,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Start request,
IDE11509-MAS03401,Cutoff 1-Parameter 1,FF FF,
IDE11509-MAS03402,Cutoff 1-Parameter 2,FF FF,
IDE11509-MAS03403,Cutoff 1-Parameter 3,FF FF,
IDE11509-MAS03404,Cutoff 1-Parameter 4,-1,
IDE11509-MAS03405,Cutoff 1-Parameter 5,-1,
IDE11509-MAS03406,Cutoff 1-Parameter 6,FF FF,
IDE11509-MAS03407,Cutoff 1-Parameter 7,-1,
IDE11509-MAS03408,Cutoff 1-Parameter 8,-1,
IDE11509-MAS03409,Cutoff 1-Parameter 9,-1,
IDE11509-MAS03410,Cutoff 1-Parameter 10,Unknown (255),
IDE11509-MAS03411,Cutoff 1-Parameter 11,Unknown (255),
IDE11510-MAS03401,Cutoff 2-Parameter 1,FF FF,
IDE11510-MAS03402,Cutoff 2-Parameter 2,FF FF,
IDE11510-MAS03403,Cutoff 2-Parameter 3,FF FF,
IDE11510-MAS03404,Cutoff 2-Parameter 4,-1,
IDE11510-MAS03405,Cutoff 2-Parameter 5,-1,
IDE11510-MAS03406,Cutoff 2-Parameter 6,FF FF,
IDE11510-MAS03407,Cutoff 2-Parameter 7,-1,
IDE11510-MAS03408,Cutoff 2-Parameter 8,-1,
IDE11510-MAS03409,Cutoff 2-Parameter 9,-1,
IDE11510-MAS03410,Cutoff 2-Parameter 10,Unknown (255),
IDE11510-MAS03411,Cutoff 2-Parameter 11,Unknown (255),
IDE11511-MAS03401,Cutoff 3-Parameter 1,00 6F,
IDE11511-MAS03402,Cutoff 3-Parameter 2,00 00,
IDE11511-MAS03403,Cutoff 3-Parameter 3,2C 68,
IDE11511-MAS03404,Cutoff 3-Parameter 4,0,
IDE11511-MAS03405,Cutoff 3-Parameter 5,0,
IDE11511-MAS03406,Cutoff 3-Parameter 6,02 42,
IDE11511-MAS03407,Cutoff 3-Parameter 7,1965,
IDE11511-MAS03408,Cutoff 3-Parameter 8,2466,
IDE11511-MAS03409,Cutoff 3-Parameter 9,2056,
IDE11511-MAS03410,Cutoff 3-Parameter 10,Text 2,
IDE11511-MAS03411,Cutoff 3-Parameter 11,Text 1,
IDE11887-MAS00976,Mechanical load: status-Counter,1A EC,
IDE11887-MAS13723,Mechanical load: status-Limit value for activation of red warning light,FF FF,
IDE11887-MAS13725,Mechanical load: status-Limit value for activation of yellow warning light,FF FF,
IDE11887-MAS13726,Mechanical load: status-Steering assistance while yellow warning light is on,1.00,
IDE11887-MAS13727,Mechanical load: status-Steering assistance while red warning light is on,1.00,
IDE11887-MAS13728,Mechanical load: status-Resetting the load counter: status,00,
IDE11887-MAS16824,Mechanical load: status-Load counter end stops,00 00,
IDE11887-MAS16825,Mechanical load: status-Aggregate load counter,00 02 D1 1E,
IDE13069-MAS16512,Tick learner-Programmer status,Programmer ended,
IDE13069-MAS16516,Tick learner-Phase W high,-6.14,
IDE13069-MAS16517,Tick learner-V phase high,-4.89,
IDE13069-MAS16518,Tick learner-U phase high,-7.42,
IDE13069-MAS16519,Tick learner-U phase low,7.95,
IDE13069-MAS16520,Tick learner-V phase low,5.39,
IDE13069-MAS16521,Tick learner-Phase Wlow,9.34,
ENG158325-ENG161744,Unintended_reset_counter-counter_for_unintended_reset,0,
Elapsed Time: 00:17
Adpmap 44:
;Saturday,08,November,2025,22:22:32:61316
IDE00820-ENG135538-Activating and deactivating all development messages-DEV_EPS_01,not activated ,1
IDE00820-ENG135535-Activating and deactivating all development messages-DEV_EPS_S100,not activated ,1
IDE00820-ENG135536-Activating and deactivating all development messages-DEV_EPS_S101,not activated ,1
IDE00820-ENG135537-Activating and deactivating all development messages-DEV_EPS_S102,not activated ,1
IDE00820-ENG111917-Activating and deactivating all development messages-Dev_Messages_Test_1,not activated ,1
IDE00820-ENG135539-Activating and deactivating all development messages-DEV_X_03,not activated ,1
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not activated ,1
IDE04555-MAS05425-Activation of pwr steering asst without engine running-100%,not activated ,5
IDE04555-MAS05427-Activation of pwr steering asst without engine running-80%,not activated ,5
IDE04555-MAS11217-Activation of pwr steering asst without engine running-20%,not activated ,5
IDE04555-MAS11219-Activation of pwr steering asst without engine running-40%,not activated ,5
IDE04555-MAS11221-Activation of pwr steering asst without engine running-60%,not activated ,5
Elapsed Time: 00:01
EiVes
Bergen, Norway
C?ID=594599
[Applications]
- Output: CSV file
[Go]
Code 43702 is not accepted, but 20103 are. Still, with 20103 accepted I get this when trying to reset counter for mechanical load: 1762687024690.png
EiVes
Bergen, Norway
C?ID=594599
Immidiatly after pressing start, either to start the car or just ignition on, I get four beeps from the dash and the red steering wheel MIL ON warning. So I think this must be the J500 locked up somehow even before power on, but I do not understand what is holding it back. Looks like J500 communicates fine with alle the other modules, but the J500 tells the world that they cannot trust anything comming from it.
