ASAM / rod data updates
Gizmo
S.E.Kent UK
C?ID=49193
Do you have an idiots guide into installing ASAM and rod data updates anywhere?
I manage to update the software without issue each time they are released, however when I get to rod updates it is now just not updating:
Yet when I again check for updates it still says “Updated rod data needed"
If I try updating via VCDS-Mobile I get:
Sometimes it will start the ASAM update download, but I do not think I have ever had a ‘you are up to date’ when updating via VCDS-Mobile, it always fails.
So am I doing something wrong or do I have other issues?
It has got to the point where I pick up my HEX+CAN overtime as this ‘just works’.
(I know I could use the HEX-NET with the USB cable...)
I have tried this on various 2014 and 2015 Škoda’s and Audi’s always with the same result.
andyvee
Rossendale, Lancashire, UK
C?ID=159389
I'm getting the same on the ROD data, everytime it seems to want to update ..........
romad
Oroville, California People's Republic
C?ID=208765
I find that even when an update has succeeded I sometimes get a message it has failed. Running the update again tells me I'm up to date. Try running the update a second time.
andyvee
C?ID=159389
Can run it 3 times on the trot, always needs new ROD data
Shaun
Usually this indicates that a rod file doesn't exist yet or that information is missing necessary to find it. However, in this case the rod files do definitely exist and are being found by the server, so I don't see any obvious reason this is causing problems. I will look into this some more and see if I can find something. Some fresh autoscans showing which modules have ASAM data and which show missing rod files wouldn't hurt.
--Shaun
Gizmo
S.E.Kent UK
C?ID=49193
Sorry for the delay,
I tried updating the ROD and ASAM today, with the same results as before
Todays scan:
#hndoc:?docid=00001679&xt=hnh:C071DB6D76DE2D58AA7FB8B9C00D8D05344EAC9B97DA719C9D778EF350BC15DD
VCDS Mobile 0.4301.0.4
VIN: TMBBJ9NP9G7029918
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
     5F 6C 6D A5
Address 01: Engine  (DFCA2 J623)    Labels: 04-01.lbl
    Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
    Component: R4 2,0L EDC   X23 1195
    Revision: B4X23---
    Coding: 011D0032036501083000
    Shop #: WSC 92521 052 00000
    ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
    ROD: N/A
    VCID: 7BB964EF62E4E8BFF6D14DD78F-802E
    No ASAM data for: "EV_ECM20TDI01104L906026FN"
No fault codes found.
Address 02: Auto Trans  (J743)    Labels: 0D-02.lbl
    Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
    Component: DQ250-6F MQB  H53 4803
    Revision: 06253104
    Shop #: WSC 33361 790 00063
    ROD: N/A
    VCID: 1771585F7E8C2CDF72E90107E3-8042
    No ASAM data for: "EV_TCMDQ250021"
Address 03: ABS Brakes  (J104)    Labels: None
    Revision: 00000000
    Coding: 1D07929C34220B750780060141CB49B8492CD0E0608292F53861F0F8C2A90000000000000000000000000000000000000000000000000000000000000000000000
    ROD: N/A
    VCID: 7AB761EB6DDED1B7EDC740ABF8-802F
    No ASAM data for: "EV_Brake1UDSContiMK100IPB"
Address 05: Acc/Start Auth.  (J518)    Labels: None
    Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
    Component: VWKESSYMQB    036 0710
    Revision: 00036000
    Coding: 030C1C0703
    ROD: N/A
    VCID: 3A37A1EB2D5E11B7AD4780AB38-806F
    No ASAM data for: "EV_KessyHellaMQBAB"
    Subsystem 1 -
Address 08: Auto HVAC  (E87)    Labels: None
    Part No SW: 3V0 907 044 AN    HW: 3V0 907 044 AN
    Component: AC Automat    H32 3601
    Revision: 20K04000
    Coding: 11110104000400011005104100101102
    ASAM Dataset: EV_ACClimaPrehVW37X 002009
    ROD: N/A
    VCID: 804393038B020B67230382134E-80D5
    No ASAM data for: "EV_ACClimaPrehVW37X"
Address 09: Cent. Elect.  (J519)    Labels: 5Q-09.lbl
    Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
    Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
    ROD: N/A
    VCID: 89558E27B8384A2F745DE77F35-80DC
    No ASAM data for: "EV_BCMMQB"
    Subsystem 1 -     Part No SW: 3V2-955-119
    Component: ]Ý
    Subsystem 2 -     Component: ˆß
    Subsystem 3 -
    Subsystem 4 -
    Subsystem 5 -     Component: ]�
    Subsystem 6 -
    Subsystem 7 -
Address 10: Park/Steer Assist  (J791)    Labels: None
    Part No SW: 5QA 919 298    HW: 5Q0 919 298 C
    Component: PLA 3.0 12K
    Coding: 0371167851
    ASAM Dataset: EV_EPHVA2CAU3700000 009017
    ROD: N/A
    VCID: 0D5D3A374C50D60FD885938F61-8058
    No ASAM data for: "EV_EPHVA2CAU3700000"
Address 13: Auto Dist. Reg  (J428)    Labels: None
    Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
    Coding: 320067C355FFC428949C804D
    ROD: N/A
    VCID: 342B8FD30F3AE7C7770B3E636A-8061
    No ASAM data for: "EV_ACCBOSCHVW48X"
Address 14: Susp. Elect.  (J250)    Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
    Component: DAEMPFUNGS-SG H17 0120
    Shop #: WSC 00000 000
    ROD: N/A
    VCID: 3731B8DF1E4C0CDF5229618703-8062
    No ASAM data for: "EV_DRCONTITEMIC"
Address 15: Airbags  (J234)    Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
    Component: AirbagVW21    005 0130
    Coding: 98FCC0C0000000005C5400CF00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
    ROD: N/A
    VCID: 83499C0F9A14107F3E21A53767-80D6
    No ASAM data for: "EV_AirbaVW20SMEVW37X"
    Subsystem 1 -     Part No SW: 4M0-980-945-A
    Component: €
    Subsystem 2 -     Component: €
    Subsystem 3 -     Component: ---
    Subsystem 4 -     Component: ---
    Subsystem 5 -     Component: ---
    Subsystem 6 -     Component: ---
Address 16: Steering wheel  (J524)    Labels: None
    Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
    Component: Lenks.Modul   075 0195
    Revision: FF033033
    Coding: 6010
    ROD: N/A
    VCID: 70A343C33BA29BE75363D2537E-8025
    No ASAM data for: "EV_SMLSVALEOMQB"
Address 17: Instruments  (J285)    Labels: None
    Part No SW: 3V0 920 911    HW: 3V0 920 911
    Component: KOMBI         305 6422
    Coding: 27A5011A7F84A600008B7A0B5001000000000000
    Shop #: WSC 73430 031 00063
    ROD: N/A
    VCID: EFA1C0BFA69C041FCA594927EB-80BA
    No ASAM data for: "EV_DashBoardVDDMQBAB"
Address 19: CAN Gateway  (J533)    Labels: None
    Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
    Component: GW MQB High   212 2227
    Revision: --------
    Coding: 030100044F087300FB00025E9C0F00010001070000000000000000000000
    Shop #: WSC 73430 790 00063
    ROD: N/A
    VCID: 75AD72D744C0BECF80950B6F39-8020
    No ASAM data for: "EV_GatewConti"
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
Address 2B: Steer. Col. Lock  (J764)    Labels: None
    Part No SW: 3Q0 905 861    HW: 3Q0 905 861
    Coding: 0800000000000000
    ROD: N/A
    VCID: F1A5C6C7B0A812EFDC6D5F5F8D-80A4
    No ASAM data for: "EV_ELVMarquMQBB"
Address 36: Seat Mem. Drvr  (J810)    Labels: None
    Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
    Component: Sitzmemory    H06 0009
    Coding: 001400000000010001A080808080000000008181000000D4
    ASAM Dataset: EV_SeatMemorDriveSide 001015
    ROD: N/A
    VCID: 3B39A4EF226428BFB6518DD7CF-806E
    No ASAM data for: "EV_SeatMemorDriveSide"
Address 3C: Lane Change  (J1086)    Labels: None
    Component: HRE_Master    H11 0071
    Coding: 02011203
    ROD: N/A
    VCID: 3C3BA7F3276A2F87BF5B96C3C2-8069
    No ASAM data for: "EV_HREntryHella"
Address 42: Door Elect, Driver  (J386)    Labels: 5Q-42.lbl
    Coding: 001D0820DE01048000001100
    ROD: N/A
    VCID: 43C9DC0F5A94507FFEA1E537A7-8016
    No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
Address 44: Steering Assist  (J500)    Labels: 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
    Component: EPS_MQB_ZFLS  125 1063
    Coding: 9303
    ROD: EV_SteerAssisMQB.rod
    VCID: 44CBDF135F9A5747C7ABEE23BA-8011
Address 52: Door Elect, Pass.  (J387)    Labels: 5Q-52.lbl
    Coding: 001D0220DE01048000001100
    ROD: N/A
    VCID: 42C7D90B458E5977F597D80B90-8017
    No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
Address 55: Xenon Range  (J745)    Labels: 7P6-907-357.clb
    Revision: --------
    Coding: 06D602007F010000
    ROD: N/A
    VCID: 40C3D3034B824B67E383C2138E-8015
    No ASAM data for: "EV_HeadlRegulVWAFSMQB"
    Subsystem 1 -     Part No SW: 4H0-941-329
    Component: ³
Address 5F: Information Electr.  (J794)    Labels: None
    Part No SW: 3V0 035 020 A    HW: 3V0 035 020
    Component: MU-H-ND-EU    H42 0318
    Coding: 038401010000000011111202008808002F0003E6012001009E
    ROD: N/A
    VCID: 240B7F93BFDA7747E76B8EA31A-8071
    No ASAM data for: "EV_MUHig4CGen2HBAS"
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
    Subsystem 4 -
    Subsystem 5 -
    Subsystem 6 -
    Subsystem 7 -
    Subsystem 8 -
    Subsystem 9 -
    Subsystem 10 -
    Subsystem 11 -
    Subsystem 12 -
    Subsystem 13 -
    Subsystem 14 -
Address 6C: Back-up Cam.  (J772)    Labels: None
    Part No SW: 5Q0 980 556    HW: 5Q0 980 556
    Component: RVC Compact   H07 0100
    Coding: 04840101A600201F000040
    ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
    ROD: N/A
    VCID: F7B1F8DFDECC4CDF12A9A18743-80A2
    No ASAM data for: "EV_CamSysRVRVCPANAMQBAB"
Address 6D: Trunk Elect.  (J605)    Labels: None
    Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
    Component: HDSG-Modul    H12 0250
    Revision: --------
    Coding: 1008
    ASAM Dataset: EV_DeckLidCONTIAU736 001011
    ROD: N/A
    No ASAM data for: "EV_DeckLidCONTIAU736"
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: None
    Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
    Component: MQB_B_MFK     H04 0024
    Coding: 020408010000040100062346C040A00098000E100040
    ROD: N/A
    VCID: 3833BBE3135203A75B336AB316-806D
    No ASAM data for: "EV_MFKBoschMQBB"
Gizmo
S.E.Kent UK
C?ID=49193
Any news on this yet?
andyvee
C?ID=159389
Any further news guys - I'm still getting exactly the same as Gizmo - always wants to update ROD data, and ASAM updates fail with the same error message as Gizmo gets.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Andy,
Can you please post your interface serial number, and a current Auto-Scan from the car that you're having trouble with?
Your HEX-NET maintains a list of ROD files it's interested in, and will keep trying to download missing ROD files until it's either a) successful or b) you choose to clear out your ASAM/ROD data cache from the Options menu. As Shaun mentioned earlier in the thread, the repeat attempts to update ASAM/ROD data means there's a ROD file your interface wants, something it needs to service a vehicle you've scanned in the past, that it can't seem to obtain.
ROD files are individually tailored to a control module, so there are hundreds if not thousands of variants. And, the process of looking up the right ROD file can be complicated on the Cloud side. If there's a problem getting data for your car, there can be any of a number of causes, many of which are specific to the module/ROD file involved. Ross-Tech has to look into this on a case-by-case basis, and will need more info about your specific case to start looking.
Jason
andyvee
C?ID=159389
Autoscan from a couple of weeks ago - looks like it is module 13
Also, it doesn't seem to be interrogating sub-modules at all? There is a corresponding VCDS Autoscan in that same post that shows the differences.
http://forums.ross-tech.com/showthr...ing-values-on-5F&p=50606&viewfull=1#post50606
Serial number HN1-001508 or VCDS shows it as hxn6d61-000005-e40fe5-fc748e-folahh-5cd7 when connected via USB
Just tried the ASAM update again and it seems to download then you see
Retrying Block 1
Retrying Block 2
Retrying Block 6
Then a pop up saying that the Update has failed and to check my internet connection. This is the same from an Android phone, an iPad and using Chrome on my laptop.
blairautomotive
C?ID=215159
I am experiencing the exact same issue on my hex-net. I have another computer running an out of date version of vcds that is letting me keep my shop open right now but I would love to get the rest of my guys back online ASAP.
I'm confused. If your're using your HEX-NET for VCDS running on a PC, it should not matter what ASAM/ROD data is or isn't present on the HEX-NET. VCDS on the PC does require reasonably up-to-date software in the HEX-NET, but the ASAM/ROD data on the HEX-NET is simply not relevant.
andyvee
C?ID=159389
OK - after the recent update tried an autoscan with the HEX-NET in Infrastructure mode - there are more ROD/ASAM files missing than before! I couldn't perform any updates at all, they all failed.
#hndoc:?docid=00001730&xt=hnh:EEA2C86D301A9313235B1B2CEFB2FC5CDE3A87239E7FBA596E94DB2067482640
Sun,Feb,21,2016,18:57:03
VCDS Mobile 0.4304.0.4
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
	 A5
Address 01: Engine  (CKFC2 J623)	Labels: 04L-907-309-V1.clb
	Part No SW: 04L 906 021 DT	HW: 04L 907 309 D
	Component: R4 2,0L EDC   H22 7545
	Revision: 83H22---
	Coding: 111D0032046501091000
	Shop #: WSC 73430 031 00000
	ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
	ROD: N/A
	VCID: 7AB761EB603BD16227C740ABE5-802F
	No ASAM data for: "EV_ECM20TDI01104L906021DT"
	Part No SW: 0D9 300 041 P	HW: 02E 927 770 AQ
	Component: DQ250-6F MQB  H53 4507
	Revision: 03253104
	ROD: N/A
	VCID: 250D6297B9058E9A3A759BAF34-8070
Address 03: ABS Brakes  (J104)	Labels: 5Q0-907-379.clb
	Part No SW: 5Q0 907 379 M	HW: 5Q0 907 379 H
	Component: ESC           H31 0571
	Revision: 00000000
	Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
	ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
	VCID: 46CFC51B6443658213BF045B41-8013
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 A	HW: 5Q0 959 435
	Revision: 00021000
	Coding: 030C0C
	Shop #: WSC 73430 790 00000
	ROD: EV_KessyHellaMQBAB_AU37.rod
	VCID: 3A37A1EB20BB1162674780AB25-806F
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5E0 907 044 N	HW: 5E0 907 044 N
	Component: Climatronic   H03 0907
	Revision: 00001K06
	Coding: 02110104000100011005000100101000
	ASAM Dataset: EV_ACClimaBHBVW37X 003017
	ROD: EV_ACClimaBHBVW37X_SK37.rod
	VCID: 302383C3F6C7DB32D9E31253A3-8065
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q0-937-08X-HV1.clb
	Part No SW: 5Q0 937 086 AA	HW: 5Q0 937 086 AA
	Component: BCM PQ37BOSCH 028 0106
	Revision: --------
	Coding: 0F511B76424722FB0FA44086B11C17280800000000000000000000000000
	Shop #: WSC 73430 790 12345
	ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
	ROD: EV_BCMBOSCH_AU37.rod
	VCID: 79B57EE7653DDA7A2EBD37BFF8-802C
	Subsystem 1 - 	Part No SW: 5E2-955-119
	Component: ]Ý
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	Subsystem 5 - 	Component: ™
	Subsystem 6 - 	Component: ™
	Subsystem 7 -
Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
	Part No SW: 5Q0 919 298 F	HW: 5Q0 919 298
	Component: PARKHILFE PLA H12 0047
	Revision: --------
	Coding: 0131161051
	ASAM Dataset: EV_EPHVA2CAU3700000 003019
	ROD: EV_EPHVA2CAU3700000_VW37.rod
	VCID: 42C7D90B486B59A23F97D80B8D-8017
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 D	HW: 5Q0 907 572 D
	Coding: 00081600FE0739
	ROD: N/A
	VCID: 3833BBE31EB7037291336AB30B-806D
	No ASAM data for: "EV_ACCMRRBoschVW372"
	Part No SW: 3Q0 959 655 AA	HW: 3Q0 959 655 AA
	Component: Airbag VW20   012 0200
	Revision: --------
	Coding: 98FCC000000000005C5400CC008800000065
	ROD: EV_AirbaVW20TS6VW48X_VW48.rod
	VCID: 7DBD6AF77115E65A02E563CF8C-8028
	Subsystem 1 - 	Part No SW: 5G0-980-945-B
	Component: 315
	Subsystem 2 - 	Component: 315
Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 507 EJ	HW: 5Q0 953 549 C
	Revision: --------
	Coding: 6C10
	ROD: EV_SMLSKLOMQB_SE37.rod
	VCID: 8247990B88EB19A2FF17980B4D-80D7
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5E0 920 911	HW: 5E0 920 911
	Component: KOMBI         304 4270
	Coding: 27A50A186D94A60001887A031000000000000000
	Shop #: WSC 00123 123 12345
	VCID: E083B38366A7ABB289C3A293B3-80B5
	Part No SW: 5Q0 907 530 T	HW: 5Q0 907 530 F
	Component: GW MQB High   128 1188
	Revision: --------
	Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
	ASAM Dataset: EV_GatewLear 011016
	ROD: EV_GatewLear.rod
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: EV_ELVMarquMQB_AU37.rod
	VCID: 342B8FD302DFE712BD0B3E6377-8061
	Coding: 001400000000010001A081808080000000008181000000D4
	ROD: N/A
	VCID: 3B39A4EF2F81286A7C518DD7D2-806E
Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
	Part No SW: 5Q4 959 593 B	HW: 5Q4 959 593 B
	Component: TSG FS        009 0014
	ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
	VCID: 44CBDF13527F57920DABEE23A7-8011
	Part No SW: 5Q0 909 144 P	HW: 5Q0 909 144 P
	Component: EPS_MQB_ZFLS  122 1043
	Coding: 9302
	VCID: 41C5D6074D6D42BA268DCF1F80-8014
Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
	Part No SW: 5Q4 959 592 B	HW: 5Q4 959 592 B
	Component: TSG BFS       009 0014
	Coding: 001D0020DE01048000001100
	ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
	VCID: 43C9DC0F577150AA34A1E537BA-8016
	Revision: --------
	Coding: 03CE02003F010000
	ROD: N/A
	VCID: 40C3D30346674BB22983C21393-8015
	Subsystem 1 - 	Part No SW: 1T0-941-329-B
	Component: >
	Part No SW: 5E0 035 020 C	HW: 5E0 035 020 C
	Component: MU-H-ND-EU    H43 0390
	Coding: 03730201000000001111120200A800002F0003F601000100F6
	Shop #: WSC 47024 001 1048576
	ASAM Dataset: EV_MUHig6C3HBAS 001041
	ROD: EV_MUHig6C3HBAS_SK37.rod
	VCID: 1771585F73692C0AB8E90107FE-8042
	Subsystem 1 - 	Part No SW: 5E0-919-606
	Component: ABT_High
	Subsystem 2 -
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 5E0 959 107 A	HW: 5E0 959 107
	Component: HDSG-Modul    H01 0746
	Revision: 42001001
	Coding: 1233074002
	ASAM Dataset: EV_HDSGSk462 301136
	ROD: EV_HDSGSk462_SK37.rod
	VCID: 2A1791ABD01BA1E217A7D0EBF5-807F
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 5Q0-980-653.clb
	Part No SW: 5Q0 980 653 F	HW: 5Q0 980 653
	Component: MQB_MFK       H06 0052
	Coding: 0101010001030303000400000100010100
	ROD: EV_MFKBoschAU370_AU37.rod
