Resolved 2005 Jetta MKIV Immobilizer light lit on the dashboard
Resolved
Jesterking
Michigan, USA
C?ID=537333
If this scan ( one posted above on 11 / 03/ 2025 ) is showing address 03, then going to Address 15, it is not seeing address 09, am I Correct?
09 Being the Cent. Elect. or Body Module... wouldn't this mean that I am not talking properly to the following functions:
  • Lighting systems: Headlights, turn signals (indicators), interior lights, hazard lights, and brake/reverse lights.
  • Central locking: Operation of the power door locks and the fuel filler flap.
  • Window regulators: Control of the power windows.
  • Wipers and washers: Operation of the windshield wipers and screen washer systems.
  • Anti-theft system: Management of the alarm system and immobilizer features.
  • Remote control integration: Processing signals from the key fob for central locking and alarm functions.
If so, how do I re-connect with address 09?
   #22
Jesterking
Michigan, USA
C?ID=537333
duplicate message removed
   #23
what would I need to just re-write the immobilizer information as it should read? Can I just re-learn the key fobs
In cars of that generation, the fobs have nothing to do with the immobilizer. The fobs are battery powered radio transmitters that communicate with the Central Convenience Module to lock and unlock the car's doors. The immobilizer in the car queries a passive transponder in the key that's powered inductively by the pickup coil at the ignition switch.
Dr Sheldon
Windsor UK
C?ID=334979
   #25
Jesterking
Michigan, USA
C?ID=537333
Now then @Jesterking
What you saying boy ?
What you saying boy? - I am not sure how you mean this... clarify this statement please.
You have the chronological order of those messages wrong. It appears that was done on purpose as an attempt to give prominence to the fact that I didn't know something, and add unnecessary insult to injury. You can see that I am open and honest with what I believe I did. I did click the Activate Transport Mode button, ( It didn't do anything for me at the time, but I didn't know that my model doesn't use it, nor did I know what to expect when it was activated) and I clicked the Transport Mode De-Activate, as well. Uwe was kind enough to inform me that "An Mk.4 Jetta does not have any kind of Transport Mode. ;)" ( Notice he didn't have to be an a$$ about it?) The learning curve is steep, as I don't do auto repair for a living, unlike others on this forum. I appreciate the vast knowledge that some have here, and the fact that they are willing to attempt to share that with those of us who are not as fortunate to have the wealth of knowledge and competence that they have. I applaud the patience that they practice in their attempts to resolve other's requests for help.
I understand that watching someone fumble with something, take VCDS for example, that you may know quite well, is difficult to do. In the end, you are left with two choices, try to help the best that you can, or keep scrolling...
   #26
Ziddywerks
Northern NJ USA
C?ID=208579
Just out of curiosity, what would I need to just re-write the immobilizer information as it should read? Can I just re-learn the key fobs as if I am starting fresh with a new car at the dealership in 2005?
You would need the pincode for the vehicle. Which the dealership is no longer able to provide AFAIK. You would need someone like a locksmith with 3rd party tools to pull the pin for you then you can match keys to immo.
   #27
Jesterking
Michigan, USA
C?ID=537333
I have it now... will play around with the keys later today..
   #28
Jesterking
Michigan, USA
C?ID=537333
So, after getting the SKC for the Instrument cluster, I started the car with Key 1, and ran the procedure to tell the Instrument module how many keys I have ( it already knew I had 2, but I changed that to 3, and then back to 2 and tested each of them. Key 1 was in the ignition and the blinking Immobilizer light stopped blinking ( extinguished). I shut the car off and inserted key 2, turned key to start, Immobilizer came on, then went off.
   #29
Ziddywerks
Northern NJ USA
C?ID=208579
And? Is the light off?
Ziddywerks
Northern NJ USA
C?ID=208579
Perfect so we can mark this one resolved @Uwe.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Just out of curiosity what did you use to pull SKC/Pin?
Glad you got it solved.
Not gonna be this easy on newer models.
Good Luck
   #33
Ziddywerks
Northern NJ USA
C?ID=208579
Good Luck
Newer models can be done with the right tools and knowledge. Having said that older cars are easier yes, but the new stuff just builds on the old its just more security the rest is pretty much the same procedure.
   #34
Jesterking
Michigan, USA
C?ID=537333
I used Kw1281test.exe
It's a freeware product from a guy ( Gmenounos ) on TDIClub forums.. DOS based using a KLL - Serial Cable... Pretty easy to learn the functions... Maybe someone will incorporate it into a Graphic User Interface someday..
