1543 - Control Module Incorrectly Coded U1014 00 [00001001]
NORDYN
London, UK
C?ID=81674
Hi Guys,
I've got Skoda Octavia 1.4 TSI MK3 2017 and I need help on the following fault code, could you help please? Thanks
Part No SW: 5Q0 035 842 C HW: 5Q0 035 842 C
Component: MU-S-D-ER H41 0456
Serial number: SKZAZ2T5238781 Dataset Number: V03935263XV 0001
Coding: 03730100FF00000051111201008800002F0208C60120050007
Shop #: WSC 73430 790 00063 ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod VCID: 2F69458E763707E363-807A
Subsystem 1 - Part No SW: 5E0 919 605 N HW: 5E0 919 605 N
Component: ABT_Std-2 H50 8120 Serial number: SKZ6ZHT1563513
1 Fault Found: 1543 - Control Module Incorrectly Coded
U1014 00 [00001001] -
Freeze Frame: Fault Priority: 4
Fault Frequency: 1 Reset counter: 131
Mileage: 163609 km Date: 2025.07.10
Time: 18:33:37
Voltage terminal 30: 12.0 V
VCDS Self-Diagnosis Log
Monday,03,November,2025,19:16:37:10827
NORDYN
London, UK
C?ID=81674
Wednesday,05,November,2025,16:12:47:10827
VCDS Version: 25.3.1.1
Data version: 20250415 DS365.0
Dealer/Shop Name: NORDYN Automotive
VIN: TMBBC7NE9J0102380   License Plate:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBC7NE9J0102380   Mileage: 165252km-102682miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---    CVN: 65239CB2
   Coding: 01250032232419080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6DD59F86BCBBB5F311-8038
   VINID: 91D4924C779525A0010020C8008BA5D2FD
Readiness: 1110 0001
   Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1006
   Revision: 00005026    Serial number: CU501705305144 CVN: 1265A98F
   ROD: EV_TCMDQ200021.rod
   VCID: 34634AE29F11243B1E-8060
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 61437000001186
   Coding: 24078A912420216E407A060840C3242451248402600224722021F070C002430000000012121212B8586C384E4484EE
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 000BD6329B29489BCA-8054
   Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
   Component: Climatronic   H04 2001
   Revision: 00001K00    Dataset Number: 0000
   Coding: 0111000400011001100500080010102A
   Shop #: WSC 73430 031 00000
   VCID: 73E189FEDA9F6303C7-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H36 0253
   Serial number: 01001712501229 Dataset Number: V03935259NV 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0607C02AB90D66ABF0-8052
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170411  051 0915
   Serial number: 887253F0401710101886
   Coding: 164DDD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY170522RUD
   Serial number: 00000000000069481491
   Humidity sensor: interior:
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 71880495
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419617146 Dataset Number: V03935256AE 0001
   Coding: 0601050011
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_SK37.rod
   VCID: 499D0B16E89349D35D-801C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0702
   Revision: --------    Serial number: 003W4P9DV71$ Dataset Number: V03935260FW 0001
   Coding: 98CCC000000000005C5400CC008800000065
   VCID: 0505C726840B6DB3F9-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 001 805 17
   Serial number: 3570000000055171052+
   Subsystem 2 - Part No SW: -----------    HW: 454 001 605 17
   Serial number: 3580000000054D79842P
   Subsystem 3 - Part No SW: -----------    HW: 454 802 105 17
   Serial number: 35100B7EE8410000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 802 205 17
   Serial number: 352006BF28410000000E
   Subsystem 5 - Part No SW: -----------    HW: 454 803 004 17
   Serial number: 355001708F20F000000I
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20181207400213
   Coding: 1410
   Shop #: WSC 53299 002 1048576
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C7362C2B741EC7BD6-8068
   Part No SW: 5E0 920 980 E    HW: 5E0 920 980 E
   Component: KOMBI         203 1440
   Coding: 27A402082180860001082B001001000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009008
   ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
   VCID: 2B51519E422F7BC34F-807E
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    432 4303
   Revision: --------    Serial number: 0006385547 Dataset Number: V03935258RY 0001
   Coding: 030100047F085700EB0002481C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00000
   GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 326F4CFA65052A0B0C-8066
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000D2160220517
   Serial number: 75886000001705260188
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 0000260396801  Dataset Number: V03935252QV 0001
   Coding: 001000208001040000001100
   VCID: 45850726C48BADB3B9-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000014975767
   Coding: 1D0200
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: V03935242GR 0001
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 0000259209186  Dataset Number: V03935252QY 0001
   VCID: 44831A22CFB194BBAE-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000014990244
   Coding: 050200
          U1014 00 [00001001] - -
                    Reset counter: 239
                    Mileage: 165252 km
                    Date: 2025.11.01
                    Time: 01:52:12
                    Voltage terminal 30: 12.2 V
End-------------------------(Elapsed Time: 04:20)--------------------------
-------------------------------1 Fault Found-------------------------------
I have posted the full scan as requested.
What's the back-story here? How did it get to be incorrectly coded? Is it a retrofit? Or did you attempt some "tweaks" that were improper for it? Or....?
NEtech
Denmark
C?ID=56995
I guess "Tweak", somebody tried to add Navigation by Coding.
Try this coding:
03730100FF00000051111201008800002F0208C60120010002
NORDYN
London, UK
C?ID=81674
I tried to recalibrate the throttle body after cleaning it, but I did the wrong coding. Any tips please? Thanks
NORDYN
London, UK
C?ID=81674
Try this coding:
Thanks.
Does this code work please? Because I tried to calibrate the throttle body not adding anything else.
NEtech
Denmark
C?ID=56995
Thanks.
You tell us.
It is changed coding for [5F], where you have this DTC:
NORDYN
London, UK
C?ID=81674
You tell us.
Yes, I was trying to calibrate the throttle body-nothing else- (after cleaning it) following some video about on YouTube ( ) and I ended up with this fault. Before that the scan report was 100% clear no faults at all. Thanks again for your time.
NEtech
Denmark
C?ID=56995
I answered on the first post you made.
Westbury, UK
Why did you change the coding in 5F (the infotainment) when you wanted to calibrate the throttle body which is in the engine 01?
  • Agree
NORDYN
London, UK
C?ID=81674
Thanks I’ll do that. Your support much appreciated it. Should I code this from infotainment please? If you send me guidance I really appreciate it. Thanks again.
NORDYN
London, UK
C?ID=81674
I really don’t know how that happened.
I know that the boot switch release button (for my Octavia MK3 2017 1.4 TSI Petrol) has been faulty for some time — it sometimes works and sometimes doesn’t. Usually, I have to either open the boot with the car key or open and close the rear driver-side door; only then does the boot switch start working again. I think I need to replace the boot release switch.
I really appreciate any advice and support please. Thank you
The directions in that video do not involve accessing the 5F-infotainment module, nor any coding. :confused:
NORDYN
London, UK
C?ID=81674
Morning @PetrolDave, @Uwe & @NEtech,
Yes, yes, yes — you’re right, guys! My bad, I just remembered it was me who did it! 🙃😞🗒️
It happened when I started having issues with the trunk/boot release button. I wanted to change it to the reverse camera option, so I adjusted the settings. Then I totally forgot about it. I didn’t realise there was a fault because I didn’t perform a scan at the time — only after I worked on the throttle body.
I really appreciate everyone’s support. Sorry for the trouble, guys!
You 🌟
Westbury, UK
@NORDYN FYI VCDS keeps a log of changes you make to coding and adaptation, look in C:\Ross-Tech\VCDS\Debug for CodingLog.csv and AdpLog.csv.
Even though these are csv files they're best opened using Notepad.
NORDYN
London, UK
C?ID=81674
@PetrolDave and guys, your support is extremely outstanding!!! Honestly, whatever words I use to thank you are not enough. THANK YOU. 🌅🍀👨🏻‍💻
NORDYN
London, UK
C?ID=81674
I found them:
Address 5F5Q0 035 842 Crecoded (Long Coding)from03730100FF00000051111201008800002F0208C60120050003to03730100FF00000051111201008800002F0208D60120050007(73430/790/00063)TuesdayFebruary11:57:34:10827
Address 5F5Q0 035 842 Crecoded (Long Coding)from03730100FF00000051111201008800002F0208D60120050007to03730100FF00000051111201008800002F0208C60120050007(73430/790/00063)TuesdayFebruary12:01:21:10827
Address 5F5Q0 035 842 Crecoded (Long Coding)from03730100FF00000051111201008800002F0208C60120050007to03730100FF00000051111201008800002F0208D60120050007(73430/790/00063)TuesdayFebruary12:16:15:10827
Address 5F5Q0 035 842 Crecoded (Long Coding)from03730100FF00000051111201008800002F0208D60120050007to03730100FF00000051111201008800002F0208C60120050007(73430/790/00063)TuesdayFebruary12:18:10:10827
