PQ25 BCM - cannot learn remotes for central locking
iichel
Netherlands, Operation Market Garden
C?ID=284912
So the test button is and stays greyed out, regardless of the value I give it
I noticed this behaviour earlier when changing 1S0 BCMs (1S0 937 087x / 090x) but I was too focused to document it..
I managed to do it with another tool though. Fun fact, the VW O-tool also didnt succeed...
I dont do a BCM change every week but it feels like this is new in the 25.x versions of VCDS.
Monday,03,November,2025,11:00:06:11868
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: WVWZZZ6RZCY221xxx   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
04-Steering Angle -- Status: Sporadic communication error 1000
56-Radio -- Status: Not registered 0011
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2l TDI   H07 9978
   Revision: 11002001    Serial number:                Dataset Number: 4F0909444AA D001 CVN: F391907C
   Coding: 00114014002400080000
   Shop #: WSC 27482 002 104857
   ASAM Dataset: EV_ECM12TDI03103P906021 001023
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65974CD595E323E21D5-8030
   VINID: 9E69EAAAA1A2A93A420811851C43A4C28D
16263 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [10001000] - Open Circuit
                    Mileage: 319602 km
                    Date: 2026.14.29
                    Time: 10:46:29
                    Engine speed: 0.00 /min
                    Coolant temperature: 54  C
                    Intake air temperature: 0  C
                    Voltage terminal 30: 11.960 V
                    Unlearning counter according OBD: 0
                    Accelerator pedal travel-Position: 0.0 %
                    Charge Pressure Actuator: activation-PWM rate: 0.0 %
                    Charge air pressure absolute position feedback-Position: 80.0 %
                    Turbocharger boost control: offset closed: 0 %
                    Sensor for engine block temperature: raw value: 54  C
                    High press turbocharger actuator: actual uncond volt value: 4.004 V
13173 - Mass Air Flow Sensor (G70)
          P0104 00 [10001000] - Intermittent
                    Mileage: 319602 km
                    Date: 2026.14.29
                    Time: 10:46:29
                    EGR Solen.val.: actual value-PWM rate: 51.0 %
                    Charge air pressure: 1020 hPa
Readiness: 0 0 0 0 X
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3416F00B3842B24E782D800421300
   Shop #: WSC 00788 648 00255
   VCID: 00597D416A41E6CA8E3-8054
                    Reset counter: 107
                    Mileage: 319602 km
                    Date: 2026.14.29
                    Time: 10:18:20
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x12AE
                    Hex Value: 0x1B9E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D5A172516E0A763-806C
                    Fault Status: 00101101
                    Reset counter: 107
                    Mileage: 315347 km
                    Date: 2024.14.04
                    Time: 16:05:39
01272 - Positioning Motor for Central Flap (V70)
                    Reset counter: 67
                    Mileage: 317116 km
                    Date: 2024.14.30
                    Time: 09:26:43
01273 - Fresh Air Blower (V2)
                    Reset counter: 92
                    Mileage: 319081 km
                    Date: 2026.14.08
                    Time: 09:08:38
   Part No SW: 6R0 937 087 P    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Serial number: 0581 025140546
   Coding: 3CB02BBF08B3040009300E006C2B0FD80080412F60850010200000010000
   Shop #: WSC 124697 483 00190
   VCID: 4ACD9F691CBDEC9A107-801E
   Component: RLS 060212 05  54  0403
   Coding: 02302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU008.07.1012621
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU013021200012894
   Coding: 18BC30
   Subsystem 4 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
   Component: J245 PS25.255  H02 0007
   Serial number:     WOO1492231$
   Coding: 081001
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU016021200014403
   Coding: 18BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU020021200011265
   Coding: 18BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01414DW Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC9A107-801E
   Serial number: 3575HRB404R14TPI49SD
   Serial number: 3585HRB404R14TPIE962
   Serial number: 3515RRB406913B6CIGF8
   Serial number: 3525RRB405N12QE47194
          B1000 1B [10001000] - Resistance Too High
                    Mileage: 319602 km
                    Date: 2026.14.29
                    Time: 10:18:22
Address 17: Instruments
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Coding: 002200
   VCID: 70B92D815AA1F64A7E3-8024
                    Reset counter: 107
                    Mileage: 319602 km
                    Date: 2026.14.29
                    Time: 10:29:11
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: IMMO          H04 0014
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25_VW25.rod
   VCID: 3A2DCFA94CDD7C1A807-806E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F3BEEFD8E5FA9B2279-807A
Address 56: Radio
End----(Elapsed Time: 02:03, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
------------------------------10 Faults Found------------------------------
NEtech
Denmark
C?ID=56995
To be sure.
Did you make an controller map, channel 15 + 99 are 0 ?
Let me know if you want to test some previous versions.
