Audi Allroad C5 Xenon to Halogen coding
s_o_n_y
Sweden
Hi !
Im new here and got my self a Hex-v2.
I have change my headlights to halogen due to broken and ugly OG xenon. I bought the clearglass front headlights from a Audi C5 and everything works. I though have faultcode on the dash for headlight adjustment. Where can i code in Halogen instead ?
s_o_n_y
Sweden
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: WAUZZZ4BZ1N006844   License Plate:
Mileage: 310450km-192904mi   Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
VIN: WAUZZZ4BZ1N006844   Mileage: 310450km-192904miles
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 B
   Component: 2.7l V6/5VT     G   0002
   Coding: 10712
   VCID: 42DD46D1ED99C3FAD87-5160
   WAUZZZ4BZ1N006844     AUZ7Z0Y1356896
17956 - Boost Pressure Regulation Valve (N75)
            P1548 - 35-10 - Open Circuit - Intermittent
17834 - EVAP Purge Valve (N80)
            P1426 - 35-10 - Open Circuit - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389
   Component: ABS/ESP allrad      D36
   Coding: 06395
   Shop #: WSC 02325
   VCID: 094F91FD902F50A2D9D-5184
18036 - Powertrain Data Bus
            P1628 - 35-10 - Missing Message from Steering Angle Sensor - Intermittent
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 L
   Component: A6-Klimavollautomat D64
   Coding: 00060
   Shop #: WSC 02325
   VCID: 2313E35512C3EAF2B31-25AE
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4Z7 920 900
   Component: C5-KOMBIINSTR. VDO D05
   Coding: 00164
   Shop #: WSC 00222
   VCID: 79AFE13DC0CF4022C9D-5160
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 A
   Component:  - 2C1A1          X019
   Coding: 25500
   Shop #: WSC 85904
   VCID: 43D343D5F283CAF2D31-513C
            79-10 - Please Check Fault Codes - Intermittent
01776 - Control Head for Vehicle Leveling System (E281)
            57-10 - Electric Circuit Failure - Intermittent
00774 - Level Control System Sensor; Rear Left (G76)
01400 - Suspension Level Control
            08-10 - Control Limit Surpassed - Intermittent
00775 - Level Control System Sensor; Rear Right (G77)
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 D
   Component: Zentralverriegelung D33
   Coding: 06721
   Shop #: WSC 02325
   VCID: 2A0D0E7175E93BBAF07-4F2E
7 Faults Found:
01560 - Passenger Door
            59-10 - Can't Unlock - Intermittent
01561 - Rear left door
            59-00 - Can't Unlock
01562 - Rear right door
            61-10 - Won't De-Safe - Intermittent
            61-00 - Won't De-Safe
End----(Elapsed Time: 03:23, VBatt start/end: 11.9V/4.9V. VIgn 11.8V)------
------------------------------16 Faults Found------------------------------
Like this ?
The car has been out of power for a long time so therefor it is some faultcodes aswell :)
s_o_n_y
Sweden
And the 55 Headlight range because of tha change to Halogen headlights.
VIN: License Plate: SAO
Address 55: Headlight Range Labels: 4Z7-907-357.LBL
Control Module Part Number: 4Z7 907 357
Component and/or Version: dynamische LWR D03
Software Coding: 00030
Work Shop Code: WSC 02325
VCID: 045180C9B70D0DCAAAB-4B9A
35-00 - -
30-00 - Open or Short to Plus
siLc
Tallinn, Estonia
C?ID=330192
Generally module 55 needs to be removed from the vehicle as halogen headlights can't make use of it - those have a manual dial next to the headlight switch for leveling the headlights, which you've fitted, right? ;)
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Welcome! Please do:
s_o_n_y
Sweden
Welcome! Please do:
Ahh, ive registered it with another email. Can i put in serialnumber in my profile here ?
s_o_n_y
Sweden
Hi ! Thanks.
But ive read earlier posts that you can code halogen to xenon. No i havent change the light switch. Didnt think it was nesseceary just to get rid of faultcode. I know you need it later for adjustment and mot. Is that enough to make it work ? :)
siLc
Tallinn, Estonia
C?ID=330192
A6 C5 has no digital electronics providing voltage for the exterior lighting, so no coding the CECM or BCM as in newer vehicles. Module 55 has no use for halogen headlights. What have you got to lose? Try it :)
Is it different than the one you posted scans from? Because that one is registered in a different name as well.
s_o_n_y
Sweden
No thats the one im helping with the car :o
