Maps WANTED A3 8Y / Q3 F3 TFSIe Hybrid with factory paddles (Auto-scan & gateway map)
Maps
Anthony63
Portugal
C?ID=630316
Hi everyone,
I need VCDS logs from cars with factory paddles to compare please.
  • Q3 F3 TFSIe Hybrid, with paddles from factory
  • A3 8Y TFSIe Hybrid, with paddles from factory
Please post:
  1. Full Auto-Scan
  2. 19-Gateway adaptation map
My car: Q3 45 TFSI-e (F3) with GW 3Q0 907 530 AS (MQB EV)
Thank you very much! 🙏
Jef
HQ
So we are thinking of adding a new rule for this section... he/she/it/whatever that ask for Auto-Scan and maps should post an Auto-Scan and maps from their own car. Kind of a don't ask for what you didn't do. It has been suggested to me that this should be a "two way petting zoo".... just wash your hands when you leave I guess. :)
I would also say it is fine to search through the forums and maybe find a car that looks like a match for what you are seeking... send that person a single private message asking them to do maps and post them up.
Anthony63
Portugal
C?ID=630316
Thanks Jef, fait point.
Here are my own logs for reciprocity:
Auto-Scan:
Sunday,26,October,2025,12:05:46:12378
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)
VCDS Version: 25.3.2.0 (arm64)  HEX-V2 CB: 0.4671.5
VIN: WAUZZZF33R1103873   License Plate:
Mileage: 28067km-17440mi   Repair Order:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 3C 42 44 4B 51 52 5F 6C
          6D 75 8C A5 BB BC C0 C6 CF D6 D7
VIN: WAUZZZF33R1103873   Mileage: 28067km-17440miles
Address 01: Engine (J623-DGEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 024 CJ    HW: 04E 907 309 CG
   Component: 1.4 TFSI hy   H20 2868
   Revision: DCH20000    CVN: FBF50708
   Coding: 021D0012632405083000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906024CJ 003002
   ROD: EV_ECM14TFS011_AU37.rod
   VCID: 6B841B8C8306F5F24B1-803E
   VINID: 9D196AAAA5830E20410032070CC84FF202
Readiness: 0010 0001
   Part No SW: 0DD 300 046 K    HW: 0DD 927 770 E
   Component: GSG DQ400E    H32 2303
   Revision: 00032120    Serial number: 5ZV02308200255 CVN: AF405F2F
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 303ECCE06AA0562A3E3-8064
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 HB    HW: 5QM 614 517
   Component: ESC           H26 0157
   Revision: 00000000    Serial number: 63163000002674 Dataset Number: F3A909504E  0003 CVN: 34230982
   Coding: 3AFF727F53203B6F8B7F0E076AC6685C4ECADCD1705616FD12A1557492BD4A0B00022E64121A83902F35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
   ROD: EV_Brake1UDSContiMK100OMG_060.rod
   VCID: 78AE34C0C2504E6AB63-802C
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0638434824 Dataset Number: 83A909577A  0006
   Coding: 030C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   VCID: 48CE8400F230FEEA063-801C
   Subsystem 1 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 44783646
   Part No SW: 83A 820 043 AD    HW: 83A 820 043 AD
   Component: AC Automat    H04 0021
   Revision: 20026000    Serial number: 00000001584729 Dataset Number: 83B909862A
   Coding: 070000000000100108000000000011000100000000000000
   ASAM Dataset: EV_AirCondiFrontPHEVAU326 001002
   ROD: EV_AirCondiFrontPHEVAU326.rod
   VCID: 629A76A874CCB4BAF87-8036
   Subsystem 1 - Part No SW: 5QF 963 231 C    HW: 5QF 963 231 C
   Component: J848 HV-PTC  H13 1000
   Serial number: LT240293014604000506
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: C0D9ACB700PAG0MUFU04
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 816 803 L    HW: 5QE 816 803 L
   Component: J842 eKK  H03 0010
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 0511
   Serial number: 05102401000259 Dataset Number: 83A909514H  0072
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA025D4ED726B42E55-8028
   Subsystem 1 - Part No SW: 83B 955 119 B    HW: 83B 955 119
   Component: J400FRWISCH  063 0051
   Serial number: 890153F0302400901354
   Coding: 5DC72F
   Component: G397_RLFSS  H06 0004
   Serial number: 22838870X81A955555B0
   Coding: 00005D
   Subsystem 3 - Part No SW: 4K1 941 501 K    HW: 4K1 941 501 K
   Component: E1 - LTM  H05 0010
   Serial number: 92160WIB000LN    10S
   Steering Column Switch:
   Subsystem 4 - Part No SW: 82A 953 521 NB    HW: 5Q1 953 549 D
   Serial number: 00000029012420241237
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H10 0075
   Serial number: 000150058324033 Dataset Number: 83A909526D  0033
   Coding: 9471155011
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   VCID: 53F4A36C3B764D32631-8006
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H12 0396
   Dataset Number: 83F909863E  0006
   Coding: 520460D218FF8728747C64640050A700080000000000000044
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B403ECDB362D32831-8026
   Part No SW: 5Q0 959 655 CC    HW: 5Q0 959 655 CC
   Component: AirbagVW21    011 0421
   Serial number: 003J5RAZFNW/ Dataset Number: 83A909602L  0005
   Coding: 88CCF0C0002000009C5400DFC048005400C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 0354532C8B961DB2931-8056
   Left seat belt tensioner:
   Component: BeltPretRevFL  506 1062
   Serial number: 83A857705K0036Y00487
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  506 1062
   Serial number: 83A857706K0037Y01889
   Coding: 802006
   Subsystem 3 - Part No SW: -----------    HW: 480 002 601 24
   Serial number: 357000000004540DDD6U
   Subsystem 4 - Part No SW: -----------    HW: 480 002 601 24
   Serial number: 35800000000F2D35DD60
   Subsystem 5 - Part No SW: -----------    HW: 480 403 101 24
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A91277AE1A31%
   Subsystem 6 - Part No SW: -----------    HW: 480 403 101 24
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A0AFC9103E7FL
   Subsystem 7 - Part No SW: -----------    HW: 480 403 101 24
   Component: FrontSensor_D  003 6149
   Serial number: 3550001BF1277AE36228
   Subsystem 8 - Part No SW: -----------    HW: 480 402 601 24
   Component: FrontSensor_P  003 6149
   Serial number: 3560001A71277AE54714
   Part No SW: 83A 920 704 G    HW: 83A 920 704 G
   Component: KOMBI         H08 6190
   Dataset Number: 83A909525T  0036
   Coding: 0D2514086A8800080681A0501100000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_001_AU37.rod
   VCID: 29082184497A27E2F9D-807C
          U1014 00 [00001001] - -
                    Reset counter: 56
                    Mileage: 28035 km
                    Date: 2025.10.23
                    Time: 23:37:37
   Part No SW: 3Q0 907 530 AS    HW: 3Q0 907 530 H
   Component: GW MQB EV     627 6504
   Serial number: 03022411602857 Dataset Number: 83A909515K  0046
   Coding: 020100172FE200005B10124E5A1000000001010100010000000300000000
   GVL: 01463C000800040850CC80009002C81800040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 005E5C209A8006AA8E3-8054
   Subsystem 1 - Part No SW: 83A 951 523 A    HW: 83A 951 523 A
   Component: J453 MFL  H07 0004
   Serial number: 20210505180518 31834
   Subsystem 2 - Part No SW: 5QA 915 181 G    HW: 5QA 915 181 G
   Component: J367-BDMHella  H11 9070
   Serial number: 1070723606
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AK    HW: 3Q0 909 059 D
   Component: EBKV          H09 0272
   Serial number: BPA085190124018 Dataset Number: F3A909524C  0001
   Coding: 4402C504400000DE7BEFBDF7000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015.rod
   Part No SW: 3Q0 907 566 L    HW: 3Q0 907 566
   Component: MRR1Rear      H27 0550
   Revision: --------    Dataset Number: 83A909535B  0009
   Coding: 06C002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 41D89924D10ACFA2C1D-8014
1188157 - Databus
          [databus unreasonable message - Perso_Status]
                    Reset counter: 56
                    Mileage: 28035 km
                    Date: 2025.10.23
                    Time: 23:37:54
                    Control Module temperature: 34 ∞C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 14.50 V
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007XAI1821D Dataset Number: 83A909872D  0030
   Coding: 001E9F005000008000001030
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACABE08EC3C0CFA107-801E
   Part No SW: 5TA 907 145 F    HW: 5TA 907 145
   Component: BASGEN1MQB37  502 1063
   Serial number: 03091991 Dataset Number: 83A909852AB 0004
   Coding: 01000001010001010001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
   ROD: EV_SteerAssisBASGEN1MQB37_010.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0367
   Serial number: 03022411602126 Dataset Number: 83A909583E  0011
   Coding: 00000005090019EA02202B10020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372CF7FC8FCE81127F9-8062
Address 51: Electric Drive (J841)       Labels:. 5NA-907-080.clb
   Part No SW: 5NA 907 080     HW: 5NA 907 080
   Component: LE Gen 3.3H30 1403
   Revision: 00H30000    CVN: 65F1EF1E
   Coding: 03090000000000000000
   ASAM Dataset: EV_DMCM08530115NA907080 001002
   ROD: EV_DMCM08530115NA907080.rod
   VCID: 7CA628D0F668624AD2B-8028
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007XAH06336 Dataset Number: 83A909873D  0030
   Coding: 001E9F005C00008000001030
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49C88104E93A07E219D-801C
   Part No SW: 82A 035 010 L    HW: 82A 035 010 B
   Component: MU-TB-D-EU    044 3843
   Serial number: GRO-63309.01.24 Dataset Number: 83C909545Q  0033
   Coding: 13261020804100000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 201E3CA03A40E6AAAE3-8074
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 83A 919 620 A    HW: 83A 919 620 A
   Component: CenterDisplay  H40 0132
   Serial number: AUZ8ZHP2202RBF
   Compact disc data bank:
   Volume Control 1:
   Subsystem 3 - Part No SW: 83A 919 616 A    HW: 83A 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00008324000004073005
   Media socket:
   Component: RVC Compact   H19 0231
   Dataset Number: 83A909460A  0007
   Coding: 0223160102002001400040
   VCID: 3928F1C4B9DA976289D-806C
   Part No SW: 5WB 959 107 A    HW: 5WB 959 107 A
   Component: HDSG-Modul    H05 0433
   Revision: --------    Serial number: A2-C767-1201-5 Dataset Number: 83A909541G  0013
   Coding: 4728
   ASAM Dataset: EV_DeckLidCONTIAU536 001002
   ROD: EV_DeckLidCONTIAU536_001_AU49.rod
   VCID: 4EC2B218105420DA4CF-801A
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000203VIFW4 Dataset Number: 83A909612N  0023
   Coding: 013261101FE829009005460120012607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 5NA 915 183 B    HW: 5NA 915 183 A
   Component: J840 K8C  BMC 004 1043
   Serial number: 000000201123020 CVN: CE40F9634C4A4147C6E4041FC6E4041FC6E4041FC6E4041FC6E4041FC6E4041F
   ASAM Dataset: EV_BMCeVWBSMQB48 001010
   ROD: EV_BMCeVWBSMQB48_VW41.rod
   Cell module control module 1:
   Subsystem 1 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Component: CMC            H04 0501
   Serial number: 23916591AH0405010969
   Cell module control module 2:
   Subsystem 2 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23916591AH0405010971
   Cell module control module 3:
   Subsystem 3 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23916591AH0405010892
   Cell module control module 4:
   Subsystem 4 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23916591AH0405010902
   Cell module control module 5:
   Subsystem 5 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23907591AH0405012186
   Cell module control module 6:
   Subsystem 6 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23907591AH0405012189
   Cell module control module 7:
   Subsystem 7 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23907591AH0405012177
   Cell module control module 8:
   Subsystem 8 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23907591AH0405012178
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H19 1421
   Serial number: EB7792611240330 Dataset Number: 83A909466J  0003
   Coding: 0004088801684020489E00000020008000010000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW48.rod
   VCID: 3632FAF888C4781A64F-8062
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007XAJ10111 Dataset Number: 83A909897D  0030
   Coding: 000E9D004000008000001020
   VCID: 4CC6B810E64812CA22B-8018
   Component: TSG HBFS005 0350
   Serial number: YE007XAJ12836 Dataset Number: 83A909896D  0030
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 R    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H11 0309
   Serial number: E2403021480000 Dataset Number: 83A909470C  0004
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007_VW37.rod
   VCID: 50FEAC600A60362A5E3-8004
   Part No SW: 5QE 915 682 AR    HW: 5QE 915 682 AR
   Component: OBC KOSTAL    H63 4031
   Revision: --------    Serial number: 290124RA401280 Dataset Number: 83A909811A  0002
   Coding: 115069622008
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
   ROD: EV_OBCSinglPhaseKLOMQB15P_001.rod
   VCID: 1D6005540D32CB42855-8048
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BapErr_Timeout_Heartbeat]
                    Reset counter: 97
                    Mileage: 28039 km
                    Date: 2025.10.25
                    Time: 14:58:37
   Part No SW: 3Q0 907 590 L    HW: 3Q0 907 590
   Revision: --------
   Coding: 06C002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 3E22E2D8A0F4B05ABCF-806A
   Part No SW: 4K0 941 591 CG    HW: 4K0 941 591 C
   Component: LMS_MQB       H20 0132
   Dataset Number: 83A909471F  0015
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: 76B23AF8C844381AA4F-8022
   Dataset Number: 83A909472F  0015
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
End----------(Elapsed Time: 02:01, VBatt start/end: 13.2V/13.2V)-----------
------------------------------3 Faults Found-------------------------------
Gateway Map:
;SW:3Q0-907-530-AS   HW:3Q0-907-530-H ---  CAN Gateway
;Component:GW MQB EV     627 6504, Coding:020100172FE200005B10124E5A1000000001010100010000000300000000
;EV_GatewNF,013026,EV_GatewNF_VW37.rod
;Sunday,26,October,2025,12:08:30:12378
;VCDS Version: Release 25.3.2 (arm64)  Data version: 20250822 DS365.0
;VCID: 005E5C209A8006AA8E3-8054
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,coded ,32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,coded ,32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,coded ,32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistance 2,coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,58 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,34020331EE ,15
IDE03903-Production process data 1,FF CA ,2
IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,not activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,not activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),not activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,not activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,not activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,not activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),not activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,not activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,not activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips only in ECO mode ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,4 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,-15000 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,0 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,0 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,15 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,1.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,1.0 l/100km,48
IDE10735-Number requests autonomous recharging,3 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,not activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,not activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,not activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,not activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
IDE12132-Dynamic reserve capacity,2550 W,1
MAS16372-Security version number,3 ,2
SFT272190-Steering Wheel Touch Recognition Control Module,No Response From Subnet Component,2
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,activated ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,activated ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistance 2,activated ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Elapsed Time: 00:25
It had been posted already on another topic, yet not it this section. Let me know if I should make a separate post about it. Happy to swap logs and follow the new rules :)
Also thanks for the PM advice, will try it.
Anthony63
Portugal
C?ID=630316
More Admaps:
Admap 17 - Instruments
;SW:83A-920-704-G   HW:83A-920-704-G ---  Instruments
;Component:KOMBI         H08 6190, Coding:0D2514086A8800080681A0501100000000000000
;EV_DashBoardVDDMQBA0,001046,EV_DashBoardVDDMQBA0_001_AU37.rod
;Monday,10,November,2025,16:28:05:12378
;VCDS Version: Release 25.3.2 (arm64)  Data version: 20250822 DS365.0
;VCID: 29082184497A27E2F9D-807C
IDE00295-Oil temperature display,Conditions not correct or request sequence error,3
IDE00342-ESI: Resetting ESI,Warning active ,1
IDE00343-Language variant,French ,1
IDE00500-Hour,15 H,1
IDE00501-Minute,27 min,1
IDE00502-Year,2025 yr,2
IDE00503-Month,11 Months,1
IDE00504-Day,10 d,1
IDE00510-ESI: distance driven from inspection,14785 km,3
IDE00511-ESI: time from inspection,348 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,15000 km,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,18300 km,2
IDE00819-Day counter,630 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE02489-Display depiction,Variant 1 ,1
IDE03329-Driving profiled for range remaining,8.5 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS02201-Units adjusted-Temperature, C ,3
IDE03346-MAS03032-Units adjusted-Volume,Liters ,3
IDE03348-MAS01456-Speed warning-Speed,180 ,2
IDE03348-Speed warning-,active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,28500 km,2
IDE03352-FIX: Time since last time-dependent inspection,580 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE07161-temporary VIN,Conditions not correct or request sequence error,1
IDE07221-Cylinder shut-off,No display ,1
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE11086-Service notification,0 d,1
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
IDE12467-Tubes illustration,Variant 0 ,1
IDE12722-Driving profile display,No ,1
IDE12986-ENG245035-BAP configuration-BAP_clima_master,not active ,3
IDE12986-ENG183590-BAP configuration-BAP_eCall,not active ,3
IDE12986-ENG168418-BAP configuration-BAP_exterior_light,not active ,3
IDE12986-ENG244953-BAP configuration-BAP_info_settings,not active ,3
IDE12986-ENG168420-BAP configuration-BAP_interior_light,not active ,3
IDE12986-ENG168421-BAP configuration-BAP_online_function,not active ,3
IDE12986-ENG168422-BAP configuration-BAP_optical_parksystem,not active ,3
IDE13094-Tachometer end value,Variant 0 ,1
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,No ,1
IDE14220-Vehicle speed warning for India-,0 s,1
IDE14984-R Logo,no R logo ,1
IDE14986-ACC illustration China,No display ,1
IDE15113-Shift exit warning,Car exit warning ,1
IDE15132-Activate/deactivate development messages via Ethernet,not active ,1
MAS03555-Lap counter,Conditions not correct or request sequence error,1
ENG114742-Activation of Development Messages,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG119880-ENG101574-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X1,FF ,12
ENG119880-ENG99557-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X2,FF ,12
ENG119880-ENG102140-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X3,FF ,12
ENG119880-ENG102936-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X4,FF ,12
ENG119880-ENG103548-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X5,FF ,12
ENG119880-ENG113992-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X6,FF ,12
ENG119880-ENG99777-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y1,FF ,12
ENG119880-ENG100480-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y2,FF ,12
ENG119880-ENG100773-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y3,FF ,12
ENG119880-ENG100631-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y4,FF ,12
ENG119880-ENG102174-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y5,FF ,12
ENG119880-ENG113993-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y6,FF ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,C8 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,05 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,23 ,12
ENG119881-ENG101574-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X1,FF ,12
ENG119881-ENG99557-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X2,FF ,12
ENG119881-ENG102140-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X3,FF ,12
ENG119881-ENG102936-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X4,FF ,12
ENG119881-ENG103548-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X5,FF ,12
ENG119881-ENG113992-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X6,FF ,12
ENG119881-ENG99777-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y1,FF ,12
ENG119881-ENG100480-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y2,FF ,12
ENG119881-ENG100773-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y3,FF ,12
ENG119881-ENG100631-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y4,FF ,12
ENG119881-ENG102174-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y5,FF ,12
ENG119881-ENG113993-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y6,FF ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,64 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,05 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,05 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,32 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,4B ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,5F ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,05 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,05 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,32 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,4B ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5F ,12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 C8 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 FA ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,01 F4 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,03 20 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 C8 ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0D ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0D ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 37 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 82 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,02 58 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 1E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG128742-Gauge_dimming_condition,OFF ,1
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG103063-Mileage,28596 km,3
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4  C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6  C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25  C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0  C,16
ENG135292-phev_stat_intervall-,1.0 ,3
ENG135292-phev_stat_intervall-,64 m,3
ENG135292-phev_stat_intervall-,00 min,3
ENG153765-Second_digital_speed,No display ,1
ENG98918-Sport,No display ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG262832-Switching_Networking,CAN ,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,65 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
ENG252008-MAS05866-variant_kombi-lock,Yes ,1
ENG252008-variant_kombi-,Variant 1 ,1
Elapsed Time: 00:31
Admap 5F - Informations Electr.
;SW:82A-035-010-L   HW:82A-035-010-B ---  Information Electr.
;Component:MU-TB-D-EU    044 3843, Coding:13261020804100000000000000000000000000000000000000
;EV_MUTI,001010,EV_MUTI_VW53.rod
;Monday,10,November,2025,16:29:48:12378
;VCID: 201E3CA03A40E6AAAE3-8074
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,none ,1
IDE00768-Country identification: country of sale,PT ,2
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT00078-Installation list: specified installations-Display/operating unit rear right,No ,3
IDE01996-SFT00094-Installation list: specified installations-Display/operating unit rear left,No ,3
IDE01996-SFT00200-Installation list: specified installations-Auxiliary display/control head 2,No ,3
IDE01996-SFT00222-Installation list: specified installations-charging device 1 for mobile end device,No ,3
IDE01996-SFT00223-Installation list: specified installations-charging device 2 for mobile end device,No ,3
IDE01996-SFT00224-Installation list: specified installations-Auxiliary display/control head 1,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head,No ,3
IDE01996-ENG262683-Installation list: specified installations-Reserved_Bit_0,No ,3
IDE01996-ENG171864-Installation list: specified installations-reserved_Bit_1,No ,3
IDE01996-ENG262679-Installation list: specified installations-reserved_Bit_2,No ,3
IDE01996-ENG262684-Installation list: specified installations-Reserved_Bit_3,No ,3
IDE01996-ENG262685-Installation list: specified installations-Reserved_Bit_4,No ,3
IDE01996-ENG262686-Installation list: specified installations-Reserved_Bit_5,No ,3
IDE01996-ENG262687-Installation list: specified installations-Reserved_Bit_6,No ,3
IDE01996-ENG262688-Installation list: specified installations-Reserved_Bit_7,No ,3
IDE02125-MAS08233-Voice operation for telephone-other,not installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,126
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,18 ,126
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,22 ,126
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,18 ,126
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,22 ,126
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,18 ,126
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,22 ,126
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,18 ,126
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,22 ,126
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,18 ,126
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,22 ,126
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,18 ,126
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,22 ,126
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,18 ,126
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,22 ,126
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,18 ,126
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,22 ,126
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,18 ,126
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,22 ,126
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,18 ,126
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,22 ,126
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,18 ,126
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,22 ,126
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,2 ,126
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,15 ,126
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,18 ,126
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,22 ,126
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,18 ,126
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,22 ,126
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,18 ,126
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,22 ,126
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,18 ,126
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,22 ,126
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,18 ,126
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,22 ,126
IDE02476-ENG260193-Electrical test of speakers-channel_25_lower_threshold,18 ,126
IDE02476-ENG259500-Electrical test of speakers-channel_25_upper_threshold,22 ,126
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,2 ,126
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,15 ,126
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,18 ,126
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,22 ,126
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,18 ,126
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,22 ,126
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,18 ,126
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,22 ,126
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,18 ,126
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,22 ,126
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,18 ,126
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,22 ,126
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,18 ,126
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,22 ,126
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,126
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,126
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,126
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,126
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,126
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,126
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,126
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,126
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,126
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,126
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,126
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,126
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,126
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,126
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,126
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,126
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,126
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,27 ,126
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,126
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,27 ,126
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,126
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,27 ,126
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,126
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,126
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,126
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,27 ,126
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,126
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,27 ,126
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,126
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,27 ,126
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,126
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,27 ,126
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,126
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,27 ,126
IDE02476-ENG260707-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_25_Test_Frequency,19000 Hz,126
IDE02476-ENG259929-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_25_Test_Volume,27 ,126
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,126
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,126
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,126
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,126
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,126
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,126
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,126
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,126
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,126
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,126
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,126
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,126
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,126
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,126
IDE02502-Confirmation of installation change,05 82 ,2
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,not activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,not activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,not activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,not activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,not activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,not activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,not activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,not activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,not activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,not activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,not activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,not activated ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,Terminal 15 ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Terminal 15 ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,not activated ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Terminal 15 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Terminal 15 ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,Terminal 15 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Terminal 15 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Infotainment data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,Terminal 15 ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,not activated ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Infotainment data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,not activated ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,not activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Infotainment data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Terminal 15 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Terminal 15 ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Infotainment data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,Ethernet ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Terminal 15 ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Terminal 15 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Terminal 15 ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,not activated ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Terminal 15 ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Terminal 15 ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Terminal 15 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Terminal 15 ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,not activated ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Terminal 15 ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Terminal 15 ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Terminal 15 ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Terminal 15 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,none ,1
IDE04522-Awakening ability on optical databus,OFF ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,OFF ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,Available ,1
IDE10082-ENG278502-Telephone functions configuration-Icon_for_data_connection,Hide ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dB V,34 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,50 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11105-Brand-specific display of connect application, ,64
IDE11122-Country identification: country of sale HMI,PT ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,Master ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
IDE14729-ENG258620-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_bus_number,0 ,22
IDE14729-ENG260754-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_channel_uplink_high,0 ,22
IDE14729-ENG258987-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_channel_uplink_low,0 ,22
IDE14729-ENG259482-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_downlink_availability,OFF ,22
IDE14729-ENG260069-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_uplink_availability,OFF ,22
IDE14729-ENG259265-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_bus_number,0 ,22
IDE14729-ENG260504-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_channel_uplink_high,0 ,22
IDE14729-ENG260890-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_channel_uplink_low,0 ,22
IDE14729-ENG258681-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_downlink_availability,OFF ,22
IDE14729-ENG258531-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_uplink_availability,OFF ,22
IDE14729-ENG259867-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_bus_number,0 ,22
IDE14729-ENG259148-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_channel_uplink_high,0 ,22
IDE14729-ENG258419-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_channel_uplink_low,0 ,22
IDE14729-ENG259263-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_downlink_availability,OFF ,22
IDE14729-ENG260988-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_uplink_availability,OFF ,22
IDE14729-ENG259725-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_bus_number,0 ,22
IDE14729-ENG260426-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_channel_uplink_high,0 ,22
IDE14729-ENG260243-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_channel_uplink_low,0 ,22
IDE14729-ENG260582-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_downlink_availability,OFF ,22
IDE14729-ENG260045-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_uplink_availability,OFF ,22
IDE14729-ENG258744-Automotive audio bus (A2B): function configuration-Booster_bus_number,1 ,22
IDE14729-ENG261041-Automotive audio bus (A2B): function configuration-Booster_channel_uplink_high,14 ,22
IDE14729-ENG259938-Automotive audio bus (A2B): function configuration-Booster_channel_uplink_low,6 ,22
IDE14729-ENG258241-Automotive audio bus (A2B): function configuration-Booster_downlink_availability,OFF ,22
IDE14729-ENG260543-Automotive audio bus (A2B): function configuration-Booster_uplink_availability,OFF ,22
IDE14729-ENG258951-Automotive audio bus (A2B): function configuration-Con_Box_bus_number,0 ,22
IDE14729-ENG261246-Automotive audio bus (A2B): function configuration-Con_Box_channel_uplink_high,0 ,22
IDE14729-ENG259052-Automotive audio bus (A2B): function configuration-Con_Box_channel_uplink_low,0 ,22
IDE14729-ENG260513-Automotive audio bus (A2B): function configuration-Con_Box_downlink_availability,OFF ,22
IDE14729-ENG260873-Automotive audio bus (A2B): function configuration-Con_Box_uplink_availability,OFF ,22
IDE14729-ENG376570-Automotive audio bus (A2B): function configuration-DDM3i1_bus_number,0 ,22
IDE14729-ENG376571-Automotive audio bus (A2B): function configuration-DDM3i1_channel_uplink_high,0 ,22
IDE14729-ENG376572-Automotive audio bus (A2B): function configuration-DDM3i1_channel_uplink_low,0 ,22
IDE14729-ENG376573-Automotive audio bus (A2B): function configuration-DDM3i1_downlink_availability,OFF ,22
IDE14729-ENG376574-Automotive audio bus (A2B): function configuration-DDM3i1_uplink_availability,OFF ,22
IDE14729-ENG376804-Automotive audio bus (A2B): function configuration-OCU3_UNECE_bus_number,0 ,22
IDE14729-ENG376805-Automotive audio bus (A2B): function configuration-OCU3_UNECE_channel_uplink_high,0 ,22
IDE14729-ENG376806-Automotive audio bus (A2B): function configuration-OCU3_UNECE_channel_uplink_low,0 ,22
IDE14729-ENG376807-Automotive audio bus (A2B): function configuration-OCU3_UNECE_downlink_availability,OFF ,22
IDE14729-ENG376808-Automotive audio bus (A2B): function configuration-OCU3_UNECE_uplink_availability,OFF ,22
IDE14729-ENG281991-Automotive audio bus (A2B): function configuration-OCU4_bus_number,0 ,22
IDE14729-ENG282001-Automotive audio bus (A2B): function configuration-OCU4_channel_uplink_high,0 ,22
IDE14729-ENG281909-Automotive audio bus (A2B): function configuration-OCU4_channel_uplink_low,0 ,22
IDE14729-ENG282039-Automotive audio bus (A2B): function configuration-OCU4_downlink_availability,OFF ,22
IDE14729-ENG281931-Automotive audio bus (A2B): function configuration-OCU4_uplink_availability,OFF ,22
IDE14729-ENG260986-Automotive audio bus (A2B): function configuration-PASD_bus_number,0 ,22
IDE14729-ENG258579-Automotive audio bus (A2B): function configuration-PASD_channel_uplink_high,0 ,22
IDE14729-ENG261104-Automotive audio bus (A2B): function configuration-PASD_channel_uplink_low,0 ,22
IDE14729-ENG259739-Automotive audio bus (A2B): function configuration-PASD_downlink_availability,OFF ,22
IDE14729-ENG261262-Automotive audio bus (A2B): function configuration-PASD_uplink_availability,OFF ,22
IDE14729-ENG398439-Automotive audio bus (A2B): function configuration-RearMic_bus_number,0 ,22
IDE14729-ENG398440-Automotive audio bus (A2B): function configuration-RearMic_channel_uplink_high,0 ,22
IDE14729-ENG398441-Automotive audio bus (A2B): function configuration-RearMic_channel_uplink_low,0 ,22
IDE14729-ENG398442-Automotive audio bus (A2B): function configuration-RearMic_downlink_availability,OFF ,22
IDE14729-ENG398443-Automotive audio bus (A2B): function configuration-RearMic_uplink_availability,OFF ,22
IDE14730-ENG258862-Automotive audio bus (A2B): diagnostic configuration bus 1-discovery_type,optimized ,10
IDE14730-ENG185820-Automotive audio bus (A2B): diagnostic configuration bus 1-Master,activated ,10
IDE14730-ENG261149-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _1,Deactivated ,10
IDE14730-ENG260380-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _2,Deactivated ,10
IDE14730-ENG260854-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _3,Deactivated ,10
IDE14730-ENG259870-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _4,Deactivated ,10
IDE14730-ENG260765-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _5,Deactivated ,10
IDE14730-ENG258502-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _6,Deactivated ,10
IDE14730-ENG261272-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _7,Deactivated ,10
IDE14730-ENG261221-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _8,Deactivated ,10
IDE14730-ENG259340-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _9,Deactivated ,10
IDE15222-ENG259093-Configuration of DK1 components-capacitive_volume_knob,not activated ,3
IDE15222-ENG398379-Configuration of DK1 components-Disable_Haptic_Feedback_Initially,OFF ,3
IDE15222-ENG260047-Configuration of DK1 components-display_audio_feedback,MU_speaker ,3
IDE15222-ENG260185-Configuration of DK1 components-shutter_foil,not activated ,3
IDE15335-ENG253480-Vehicle name information electronics-default_value_prefix_MMI_name,Audi_MMI_ ,42
IDE15335-ENG253482-Vehicle name information electronics-Postfix_2.4_GHz_SSID, ,42
IDE15335-ENG253481-Vehicle name information electronics-Postfix_5_GHz_SSID,_5GHz ,42
IDE15361-ENG259850-WLAN settings-2.4_GHz_max_channel_bandwidth,20_MHz ,7
IDE15361-ENG260321-WLAN settings-2.4_GHz_visibility,activated ,7
IDE15361-ENG258978-WLAN settings-5_GHz_max_channel_bandwidth,40_MHz ,7
IDE15361-ENG258896-WLAN settings-5_ghz_visibility,activated ,7
IDE15361-ENG248412-WLAN settings-5_ghz_wlan,On ,7
IDE15361-ENG248626-WLAN settings-channel_number_for_2_4GHz,6 ,7
IDE15361-ENG248627-WLAN settings-channel_number_for_5GHz,0 ,7
IDE15361-ENG253479-WLAN settings-DHCP_lease_time,72 H,7
IDE15361-ENG261211-WLAN settings-internet_over_WLAN_default_setting,activated ,7
IDE15361-ENG260341-WLAN settings-location_of_BT_WLAN_chip,not active ,7
IDE15361-ENG259649-WLAN settings-WLAN_password_sync,Synchronized ,7
IDE15362-ENG253478-Smartphone configuration-Apple_car_play_wireless,On ,3
IDE15362-ENG398367-Smartphone configuration-AppleMapsEvRouting,On ,3
IDE15362-ENG185765-Smartphone configuration-Baidu_Car_Life_ios_Wireless,OFF ,3
IDE15362-ENG185766-Smartphone configuration-Baidu_Car_Life_Wireless,OFF ,3
IDE15362-ENG253483-Smartphone configuration-Google_android_auto_wireless,OFF ,3
IDE15387-ENG259927-Settings for navigation with e-vehicles-Built_In_Booster,0 kW,10
IDE15387-ENG259118-Settings for navigation with e-vehicles-Charging_Time_Factor,0 ,10
IDE15387-ENG258929-Settings for navigation with e-vehicles-Charging_Time_Offset,0 min,10
IDE15387-ENG259085-Settings for navigation with e-vehicles-Max_Battery_Ampere,0 A,10
IDE15387-ENG259058-Settings for navigation with e-vehicles-Max_Battery_Voltage,0 V,10
IDE15387-ENG261213-Settings for navigation with e-vehicles-Range_Assurance_Level_1_NumChargers,0 ,10
IDE15387-ENG259231-Settings for navigation with e-vehicles-Range_Assurance_Level_1_SOC,0 %,10
IDE15387-ENG258257-Settings for navigation with e-vehicles-Range_Assurance_Level_2_NumChargers,0 ,10
IDE15387-ENG259808-Settings for navigation with e-vehicles-Range_Assurance_Level_2_SOC,0 %,10
IDE15947-Back end configuration,255 ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,On ,12
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,0 ms,12
ENG117918-ENG126188-Audio_Management_Audio_Delay_Lines-Headphone_Delay_On_Off,OFF ,12
ENG117918-ENG126189-Audio_Management_Audio_Delay_Lines-Headphone_Delay_Time,0 ms,12
ENG117918-ENG126190-Audio_Management_Audio_Delay_Lines-Headphone_wireless_Delay_On_Off,OFF ,12
ENG117918-ENG126191-Audio_Management_Audio_Delay_Lines-Headphone_wireless_Delay_Time,0 ms,12
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,On ,12
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,0 ms,12
ENG264032-ENG264184-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264185-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264186-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264187-Automotive_audio_bus_configuration_EMC_bus-Master_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264188-Automotive_audio_bus_configuration_EMC_bus-Master_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264208-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264209-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264210-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264211-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264212-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264213-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264214-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264215-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264216-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264217-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264218-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264219-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264220-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264221-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264222-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264223-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264224-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264225-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264226-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264227-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264228-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264229-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264230-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264231-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264232-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264233-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264234-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264235-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264236-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264237-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264238-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264239-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264240-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264241-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264242-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264243-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264244-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264245-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264246-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264247-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264248-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264249-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264250-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264251-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264252-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264253-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264254-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264255-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264256-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264257-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264258-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264259-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264260-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264261-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264262-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264263-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264264-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264265-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264266-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264267-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264268-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264269-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264270-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXBCTL_TXBOVREN,Disable ,29
ENG277053-ENG273739-battery_charging_curve-Charging_power_01,0 ,30
ENG277053-ENG273716-battery_charging_curve-Charging_power_02,0 ,30
ENG277053-ENG273749-battery_charging_curve-Charging_power_03,0 ,30
ENG277053-ENG273698-battery_charging_curve-Charging_power_04,0 ,30
ENG277053-ENG273834-battery_charging_curve-Charging_power_05,0 ,30
ENG277053-ENG273839-battery_charging_curve-Charging_power_06,0 ,30
ENG277053-ENG273868-battery_charging_curve-Charging_power_07,0 ,30
ENG277053-ENG273719-battery_charging_curve-Charging_power_08,0 ,30
ENG277053-ENG273828-battery_charging_curve-Charging_power_09,0 ,30
ENG277053-ENG273624-battery_charging_curve-Charging_power_10,0 ,30
ENG277053-ENG273852-battery_charging_curve-Soc_01,0 ,30
ENG277053-ENG273701-battery_charging_curve-Soc_02,0 ,30
ENG277053-ENG273861-battery_charging_curve-Soc_03,0 ,30
ENG277053-ENG273825-battery_charging_curve-Soc_04,0 ,30
ENG277053-ENG273654-battery_charging_curve-Soc_05,0 ,30
ENG277053-ENG273816-battery_charging_curve-Soc_06,0 ,30
ENG277053-ENG273836-battery_charging_curve-Soc_07,0 ,30
ENG277053-ENG273870-battery_charging_curve-Soc_08,0 ,30
ENG277053-ENG273677-battery_charging_curve-Soc_09,0 ,30
ENG277053-ENG273801-battery_charging_curve-Soc_10,0 ,30
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,MOST ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,MOST ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,MOST ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,1 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,MOST ,8
ENG152376-ENG101574-Dimming_ambient_illumination_for_volume_control-X1,0 ,6
ENG152376-ENG99557-Dimming_ambient_illumination_for_volume_control-X2,100 ,6
ENG152376-ENG102140-Dimming_ambient_illumination_for_volume_control-X3,50 ,6
ENG152376-ENG99777-Dimming_ambient_illumination_for_volume_control-Y1,50 %,6
ENG152376-ENG100480-Dimming_ambient_illumination_for_volume_control-Y2,0 %,6
ENG152376-ENG100773-Dimming_ambient_illumination_for_volume_control-Y3,100 %,6
ENG152377-ENG101574-Dimming_illumination_for_display_unit_1_for_multimedia_system-X1,0 ,18
ENG152377-ENG99557-Dimming_illumination_for_display_unit_1_for_multimedia_system-X2,10 ,18
ENG152377-ENG102140-Dimming_illumination_for_display_unit_1_for_multimedia_system-X3,50 ,18
ENG152377-ENG102936-Dimming_illumination_for_display_unit_1_for_multimedia_system-X4,100 ,18
ENG152377-ENG103548-Dimming_illumination_for_display_unit_1_for_multimedia_system-X5,150 ,18
ENG152377-ENG113992-Dimming_illumination_for_display_unit_1_for_multimedia_system-X6,253 ,18
ENG152377-ENG99777-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y1,256.0 %,18
ENG152377-ENG100480-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y2,256.0 %,18
ENG152377-ENG100773-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y3,896.0 %,18
ENG152377-ENG100631-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y4,2483.2 %,18
ENG152377-ENG102174-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y5,2406.5 %,18
ENG152377-ENG113993-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y6,4966.7 %,18
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,not activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG262676-ENG331832-function_configuration_AED-AED_Version,1 ,18
ENG262676-ENG262680-function_configuration_AED-debbug_trace_profile,0 ,18
ENG262676-ENG262691-function_configuration_AED-shutdown_timer,0 ,18
ENG262676-ENG262692-function_configuration_AED-suspend_2_RAM_timer,0 ,18
ENG262676-ENG262693-function_configuration_AED-temperature_profile,0 ,18
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,On ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_with_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,one ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,usb_only ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,On ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,On ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,On ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,On ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG253093-ENG152554-function_configuration_connectivity_extended-Phone_HMI_Privacy,0 ,5
ENG253093-ENG152555-function_configuration_connectivity_extended-Privacy_WithPINRequest,0 ,5
ENG253093-ENG152556-function_configuration_connectivity_extended-scon_telephony,OFF ,5
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,0 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,On ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG253085-ENG376580-function_configuration_online-Devmode,Deactivated ,1
ENG253085-ENG258874-function_configuration_online-hmi_sdk,OFF ,1
ENG253085-ENG376833-function_configuration_online-PSO_data_export,Deactivated ,1
ENG253085-ENG138663-function_configuration_online-Smartphone_interface_for_rhmi,activated ,1
ENG253085-ENG376900-function_configuration_online-SPIN_timer,Deactivated ,1
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,OFF ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,On ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,Deactivated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,not installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,activated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,OFF ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,two ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,Deactivated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,not activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,activated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,automatic_with_time_scaling ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,OFF ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,0 ,8
ENG248438-ENG248523-function_configuration_sound-brand_sound,Default ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,EU ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,REGION_EU ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,OFF ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,On ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG244879-ENG297725-function_configuration_sw_update-UOTA_T_Box,Not available ,1
ENG248440-function_configuration_swap_fod,swap_active_fod_not_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,Full_System ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,activated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG277065-ENG273775-navigation_settings_e_vehicles_extended-base_load,0 W,15
ENG277065-ENG273758-navigation_settings_e_vehicles_extended-Charging_station_preference,0 min,15
ENG277065-ENG106054-navigation_settings_e_vehicles_extended-Efficiency,0 %,15
ENG277065-ENG273815-navigation_settings_e_vehicles_extended-first_arrival_soc_factor,0 %,15
ENG277065-ENG273776-navigation_settings_e_vehicles_extended-max_arrival_soc,0 %,15
ENG277065-ENG273653-navigation_settings_e_vehicles_extended-max_target_soc,0 %,15
ENG277065-ENG273844-navigation_settings_e_vehicles_extended-min_arrival_soc,0 %,15
ENG277065-ENG273690-navigation_settings_e_vehicles_extended-multistop_routing,OFF ,15
ENG277065-ENG398429-navigation_settings_e_vehicles_extended-plugType,GB/T2015 ,15
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG248467-number_to_name_matching_algorithm,compare_last_digits ,1
ENG262674-region_coding_truffles,EU ,1
ENG167432-MAS19716-RSE_function_configuration-Services,Tracking Data group selected ,10
ENG167432-MAS19722-RSE_function_configuration-Data collector,activated ,10
ENG167432-MAS19797-RSE_function_configuration-Basic setting not recognized Guest: services,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19798-RSE_function_configuration-Basic setting not recognized Guest: campaigns with interest weighting,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19799-RSE_function_configuration-Basic setting not recognized Guest: campaigns with consent,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19887-RSE_function_configuration-Display info window for current privacy settings,Display ,10
ENG167432-MAS19892-RSE_function_configuration-Display selection for recurring dialog display,Display ,10
ENG167432-MAS19893-RSE_function_configuration-Selection for recurring dialog display availability,for personalized users ,10
ENG167432-ENG398388-RSE_function_configuration-IAA_online_offline_screen_control,Use_old_business_logic_via_serviceID ,10
ENG167432-ENG167528-RSE_function_configuration-RSE_navigation_coding,not activated ,10
ENG167432-ENG138661-RSE_function_configuration-RSE_software_component,not activated ,10
ENG167432-ENG398364-RSE_function_configuration-TTDSG_consent_screen,No_Display ,10
ENG248469-same_ssid_for_2_4_and_5_ghz,No ,1
ENG117912-ENG117775-Select_Remote_Test_DAB_Service-Parameter_Adaption_Service_ID,00 00 00 00 ,5
ENG117912-ENG117776-Select_Remote_Test_DAB_Service-Parameter_Adaption_Subservice_ID,00 ,5
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,5
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,5
ENG117909-Shift_Remote_Test_Frequency_DAB,Conditions not correct or request sequence error,5
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,5
ENG248470-sortorder,sortorder_1 ,1
ENG253041-ENG260670-speechinput_properties_for_activation-use_microphone_1_for_speech_input,Yes ,1
ENG253041-ENG260799-speechinput_properties_for_activation-use_microphone_2_for_speech_input,Yes ,1
ENG253041-ENG261039-speechinput_properties_for_activation-use_microphone_3_for_speech_input,No ,1
ENG253041-ENG259276-speechinput_properties_for_activation-use_microphone_4_for_speech_input,No ,1
ENG253041-ENG260534-speechinput_properties_for_activation-Voice_barge_in,OFF ,1
ENG253041-ENG258983-speechinput_properties_for_activation-Wake_up_phrase,OFF ,1
ENG253124-ENG261068-subsystem_identifier_version_implementation-abt_1,slave_component_lists ,2
ENG253124-ENG259782-subsystem_identifier_version_implementation-abt_2,slave_component_lists ,2
ENG253124-ENG253445-subsystem_identifier_version_implementation-actuator,slave_component_lists ,2
ENG253124-ENG260508-subsystem_identifier_version_implementation-display_1,individual_identifier_for_each_slave ,2
ENG253124-ENG260946-subsystem_identifier_version_implementation-display_2,slave_component_lists ,2
ENG253124-ENG260037-subsystem_identifier_version_implementation-display_3,slave_component_lists ,2
ENG253124-ENG286255-subsystem_identifier_version_implementation-display_4,slave_component_lists ,2
ENG253124-ENG258562-subsystem_identifier_version_implementation-display_5,slave_component_lists ,2
ENG253124-ENG99668-subsystem_identifier_version_implementation-Reserved_3,slave_component_lists ,2
ENG253124-ENG154261-subsystem_identifier_version_implementation-Reserved_4,slave_component_lists ,2
ENG253124-ENG154330-subsystem_identifier_version_implementation-Reserved_5,slave_component_lists ,2
ENG253124-ENG154188-subsystem_identifier_version_implementation-Reserved_6,slave_component_lists ,2
ENG253124-ENG154256-subsystem_identifier_version_implementation-Reserved_7,slave_component_lists ,2
ENG253124-ENG154341-subsystem_identifier_version_implementation-Reserved_8,slave_component_lists ,2
ENG253124-ENG154185-subsystem_identifier_version_implementation-Reserved_9,slave_component_lists ,2
ENG253124-ENG259851-subsystem_identifier_version_implementation-volume_controler_mmi,individual_identifier_for_each_slave ,2
Elapsed Time: 01:36
Reactions: Jef
