0AM/DQ200/ Adaptation
ErikHM
Norway
C?ID=165552
Hello.
I've just got my DSG 7-speed back from the dealer after a clutch change.
I am going to install the box today, and do the adapation: Adaptation
My only question is: Do I have to drive the car to get the gearbox to temperature?
I belive it won't be warm from just ideling, or am I wrong? (the mech gets warm, but I'm talking about the transmissionoil itself) :)
siLc
Tallinn, Estonia
C?ID=330192
  • Transmission oil temperature between 30°C – 60°C for Basic Settings. The Measuring Block value for G510 is found in group 011.1
Like it says, "oil temperature" as in hydraulic oil temperature inside the mechatronic.
ErikHM
Norway
C?ID=165552
This is why I love forums 🙌
But, I went to measuring Block 011.1 to see the value for G510 (on another car) and it didnt get any warmer the 10-15 minutes the car was on idle.
So the question still stands. Do I have to drive it a bit, or is there something else I can do?
Am I doing it wrong?
Bruce
Near Philadelphia, PA, USA
Please do not take offense at my answer.... I am asking you to think about this....
What is the by product of most work?
In most mechanical and electrical systems, the by product of doing any work is heat.
If the transmission is standing at idle, is it doing work?
The engine is doing some work - not much... the combustion heat will heat the engine. But what heats the transmission and drive train? They do the work of turning the wheels. When the wheels turn the by product will be heat.
I would say your belief is correct. Drive it to warm it. Sure, it may not shift exactly as you want or exactly at the optimum moments. Baby it and be gentle. The adaptation sets the shift points if memory serves.
Are you following the factory recommended procedure? That procedure should tell how to warm up that transmission.
Such procedures are available on erWin. See the "How To" in the blue bar at the top of the page if you need a link to the Official Factory Repair Information available there.
ErikHM
Norway
C?ID=165552
No offence taken 👍🏼😊
The reason for my question is that some say that it should not be driven before adaptation. Other says it’s not that harmfull. Since I haven’t done this before I start to wonder. Fearing I will damage the clutchpack because of wrong clutchpreassure.
the solition came from an older post on another forum. Leave the car on idle for as long as it takes. For me it tok 2.5 hours to reach 30degrees Celsius.
Aparently this is the safest way to do it without risking to damage the clutch. 🤷‍♂️
Anyways. I appriciate your reply, and it would probably work just as well :)
TTT
C?ID=547002
I've seen professionals using electric heater fans placed towards gearbox. Smart, one does not glaze the cylinders, keeping engine idling for hours.
Vdub
C?ID=57533
start the car and let it idle, engine of, ignition on, then start a basic setting, handbrake on, foot on the brake, then start the engine, keep foot on the brake until it stops changing numbers end stays something like 253 0 0
Engine off, restart engine, drive in manual 3rd gear foor approx 5mins, then shift to 4th gear for 4mins, also a Reverse drive a few meters then continue drive in D.
After a minute or 15 it should be good.
siLc
Tallinn, Estonia
C?ID=330192
I've done the adaptation drive on my own vehicle a couple of times. My personal experience is that you simply need to drive in varied conditions and don't need to manually shift gears. The few very first gearshifts after basic settings are really rough but smoothen out quite quickly.
Vdub
C?ID=57533
if you have a new clutch, it needs to adapt the clutch 1 and clutch 2, it does its job better if you drive manual in 3rd and 4th gear for a few minutes, NOT on Cruisecontrol. I fit a few of those clutches a year, in the end it will still adapt after the 15mins drive if you check the clutch adaption mm's
siLc
Tallinn, Estonia
C?ID=330192
I did basic settings because of DSG software update. The clutch was the same "old" on both times. Come to think about it, when driving the adaptation drive, cruise control didn't engage. During the same ignition cycle, at some point, it started to engage again. That was probably a sign that the "mandatory" part of the adaptation drive had ended.
Vdub
C?ID=57533
you dont need to do a basic settings after a softwareupdate because that doesnt alter the settings/adaptations
TTT
C?ID=547002
Correct!
ErikHM
Norway
C?ID=165552
Tanks. It started to shift really good after 2 min 👍
