Hi All I need help coding the TPMS I want to code it out or switch it off . This car failed the full TUV inspection in Germany because there is a fault with the system. Currently the vehicle has been coded for EU spec via Convenience channel so the rear fog light works . I want it coded off so the TPMS fault notification is not on any more please , regards Richard
This is not the latest scan sorry
Wednesday,08,October,2025,13:37:32:44133
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
Dealer/Shop Name: THE GREASE MONKEY
VIN: WVWAF63DX48008943 License Plate:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAF63DX48008943 Mileage: 304660km-189306miles
Address 01: Engine Labels: 4D0-907-560-BGH.lbl
Part No SW: 4D0 907 560 CS HW: 8E0 907 560
Component: 4.2L V8/5V G 0040
Coding: 0007873
Shop #: WSC 33804 142 87002
VCID: 79AB3D12E5C39492C9D-5160
VINID: 9E69D15860D4A042000082440C9B207D09
Readiness: 0110 1101
Part No SW: 09L 927 760 A HW: GS1 904 1
Component: AG6 09L 4,2L V8 0901
Coding: 0001102
VCID: 3533F122895BB0F26D5-5160
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 R
Component: ESP 5.7 allrad H33 0043
Coding: 0008376
Shop #: WSC 44580 000 00000
VCID: 313BC5327D339CD231D-5160
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 E HW: 5WK 485 09
Component: G1 Kessy 6840
Revision: 68406620 Serial number: VWZ3Z0C7109082
Coding: 0137452
Shop #: WSC 33804 142 97064
VCID: 290B2D5255E3E412F9D-5160
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 B
Component: Sitzmemory D1 BF 1520
Coding: 0000003
Shop #: WSC 01065 000 00000
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 008 Q
Component: ZAB COCKPIT 0223
Coding: 0500345
Shop #: WSC 06490 444 58963
VCID: 280D28564EE9DD1AE63-5160
7 Faults Found:
00857 - CD Changer Unit (R41)
003 - Mechanical Failure
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
00856 - Radio Antenna
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 G
Component: Climatronic D1 1132
Coding: 0000002
VCID: 22193A7E28D5374AB87-5160
014 - Defective
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 G
Component: STG.Bordnetz 5001
Coding: 0000003
VCID: 2E01DE4E6C0D832A2CF-5160
00968 - Right Turn Signals
01498 - Bulb for Parking Lamps; Right (M3)
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 D
Component: 0A Airbag 8.4E+ H07 0934
Coding: 0012353
VCID: 24153C6632C1397ACAB-5160
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000232
VCID: 2F3FC34A6B078A22279-5160
Address 17: Instruments Labels: 3D0-920-INS-V1.lbl
Part No: 3D0 920 981 A
Component: KOMBIINSTRUMENT RB4 0321
Coding: 0007221
Shop #: WSC 33804 142 84454
VCID: 2513216239FBC072DD5-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70BD0036B6B9D5DA7E3-5160
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 F
Component: Klima-Bedienteil D1 0117
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000001
VCID: 6691666E847D0B6A14F-518C
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3D0 907 553 B
Component: LUFTFDR.-CDC- 3C1V0 1101
Coding: 0017700
VCID: 2611266E44FDCB6AD4F-5160
01598 - Drive Battery Voltage
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 B
Component: Sitzmemory D1 F 1520
Coding: 0000004
VCID: 2D03D942610BF832155-5160
Address 37: Navigation Labels: 3D0-919-887.lbl
Part No: 3D0 919 887 A
Component: NAVIGATION 0147
Coding: 0400000
VCID: 3239CA3E7835A7CA487-5160
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 C
Component: Dachmodul 0708
Coding: 0000043
VCID: 23173F7A37CF3E42B31-5160
00220 - Connection to Sunroof
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000001
VCID: 678F6B6A837712622F9-5180
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 E
Component: 6P HSG 3211
Coding: 0000040
VCID: 3239CA3E7835A7CA487-4AF8
Subsystem 1 - Part No: 3D1 959 701 E
Component: Tuersteuergeraet FS 0104
Subsystem 2 - Part No: 3D1 959 702 E
Component: Tuersteuergeraet BF 0104
Subsystem 3 - Part No: 3D0 959 703 E
Component: Tuersteuergeraet HL 0104
Subsystem 4 - Part No: 3D0 959 704 E
Component: Tuersteuergeraet HR 0104
Subsystem 5 - Part No: 3D0 909 610 B
Component: 3I HDSG 2320
Subsystem 6 - Part No: 7L0 907 719
Component: Neigungssensor 0020
00984 - Left Tail Light (M4)
009 - Open or Short to Ground
00253 - Taillight Assembly - Rear Right
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 466
Component: 12K-AUDIOVERST 0115
VCID: 5F9F738A5B275AA2D79-5160
00871 - Bass Speaker Front Right (R23)
00421 - Rear Left DSP Midrange Speaker (R105)
Address 65: Tire Pressure Labels: None
Part No: 3D0 907 273 C
Component: Reifendruckueberw. 0021
Coding: 0011204
Shop #: WSC 44580 136 08015
Address 66: Seat, Rear Labels: None
Part No: 3D0 959 860 B
Component: Sitzmemory D1 H 1513
Coding: 0000001
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V1.clb
Part No: 3D1 955 119
Component: Front Wiper 2005
VCID: 6691666E847D0B6A14F-5160
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 B
Component: Batteriemanagement 2600
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 HW: 3D0 035 617
Component: Telematik NAR1 0101
Coding: 0061860
Shop #: WSC 06490 444 01052
VCID: 5DE34982512B48B2C55-5160
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 C
Component: 03 Einparkhilfe 0807
VCID: 2A09D25E50E5EF0AF07-5160
End----(Elapsed Time: 07:22, VBatt start/end: 11.2V/10.5V. VIgn 0.0V)------
------------------------------24 Faults Found------------------------------
