Car:
Audi A6 Allroad C7.5 (2016)
Control unit: J519 – BCM1 2.0
Part number: 4H0 907 063 DH (HW: 4H0 907 063 AH)
Current light switch: 4G0 941 531 BE (no Night Vision button)
Project goal:
I’m in the process of retrofitting the OEM Night Vision system (J853 – Address 8E).
All hardware (camera, controller, cabling, etc.) is already installed or prepared.
At the current stage, I need to enable the light switch with Night Vision button and make BCM1 (J519) recognize it correctly.
What I know so far:
Additional details:
Current BCM1 long coding:
0105C01440349FE2C901408320001800CF9C67082E08020100000894E10117020040003D030000
Subsystem (light switch):
Subsystem 3 - Part No SW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 29 02 2016 00000085
Summary:
I’m looking for the correct long coding bits in J519 to make BCM1 accept the NV-capable light switch
(e.g. 4G0 941 531 F / AM / BF), before activating and coding the Night Vision module (8E).
Any example scans, confirmed byte/bit info, or known working configurations for A6/A7/A8 (MLB platform) would be highly appreciated.
If you have an A6, A7, or A8 with Night Vision (with or without HUD),
please share the relevant parts of your Auto-Scan — especially Address 09 (J519) and Address 8E (Image Processing).
This would be very helpful for identifying the correct coding pattern.
Thank you!
John, Norway
___scan from my Allroad___
Project goal:
What I know so far:
- The light switch (E1–LDS) is a LIN slave under BCM1.
- When correctly configured, it appears as a subsystem under Address 09.
- Night Vision itself is a CAN module (Address 8E – Image Processing).
- The NV button signal travels: Light switch → BCM1 → NV controller (via CAN).
- HUD (Address 82) is not installed, so I’m looking for the NV-only coding variant (no HUD).
- Which byte/bit in BCM1 long coding (Address 09) enables the light switch with Night Vision button (without HUD)?
- If available, VCDS scans (Address 09 + 8E) from A6/A7/A8 vehicles with Night Vision (with or without HUD), so I can compare long coding.
- Confirmation if activating Night Vision requires additional long coding changes in J519 beyond the light switch type (e.g., NV enable bits or CAN routing).
Additional details:
Summary:
Thank you!
John, Norway
Wednesday,29,October,2025,20:18:58:08472
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: WAUZZZ4G1GN173867 License Plate: DP94388
Mileage: 110944km-68937mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 3B 3C 42 44 46
52 53 55 5F 62 69 6C 6D 72 85 8B 8E 8F 90 47
VIN: WAUZZZ4G1GN173867 Mileage: 110944km-68937miles
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G2 907 551 B HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0001
Revision: --H10--- CVN: F9B2AEF9
Coding: 3225003C0576090B3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551B 002001
ROD: EV_ECM30TFS0214G2907551B_002.rod
VCID: 2A0ADF9ACC7D38DAF07-807E
VINID: 9D196AAAA1170577811C32061C1028AA2A
Readiness: 1110 0001
Part No SW: 4G0 927 166 J HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H03 0003
Revision: --H03--- CVN: 0000F8F5
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 3436C1E21EB97E2A5AB-8060
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 44A6DE4D22657BB2BB00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41D89836510BDB82C1D-8014
Part No SW: 4H0 907 064 GP HW: 4H0 907 064 GP
Component: BCM2 2.0 H37 0572
Coding: 05A96F0E000000000000
VCID: 7DA024C66DF37F62E55-8028
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 22031600041322
Coding: 661211782D0000
VCID: 639472BEEBD7A992F31-8036
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001318480002
Coding: 0105C01440349FE2C901408320001800CF9C67082E08020100000894E10117020040003D030000
VCID: 71B808F621AB0B0271D-8024
Component: WWS57X 160207 H38 0080
Serial number: 160217200624
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61546959
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: AQ_Hum_Sensor H03 0005
Serial number: 92584C1800PAG0MUFU01
Component: ACC3 H21 0055
Serial number: 00000000000000 Dataset Number: 4G0909863D 0041
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002_AU57.rod
VCID: 29082096C97B33C2F9D-807C
Revision: -------- Serial number: 003P10093536 Dataset Number: 4G0909602M 0003
Coding: 30333130313730323630554A304C34473053
VCID: 3B24EADE33E7B1529B1-806E
Serial number: 3575HRB401055BUG6OPU
Serial number: 3585HRB40553VRKKEHMT
Serial number: 3515JRB400A558KGOOQ+
Serial number: 3525JRB400A558KOAI04
Serial number: 3554VRB40673L0623GK2
Serial number: 3564VRB40573R9V848G.
Revision: -------- Serial number: 90372PCK0000O
Coding: 0000FD
VCID: 372CF6EE0F4F95327F9-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 02 02 2016 B0008919
Part No SW: 4G9 920 901 D HW: 4G9 920 901 D
Component: TBenRdwAccNv H11 0106
Revision: 09001102 Serial number: 658080316596041
Coding: 138721081F550008010600
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 2D00D486FD932FE2155-8078
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 H HW: 4H0 265 105 H
Component: Standheizung H26 0270
Revision: 77007007 Serial number: 20160219181449
Coding: 4D3D01
VCID: 270C26AEDFEF05B2EF9-8072
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002190631 Dataset Number: 4G0909515K 0022
Coding: C0CD073018
GVL: FD8FD944DCA5600D40040800
ASAM Dataset: EV_GatewPkoUDS 001028
Serial number: 6761179703
Voltage stabilizer:
Serial number: 16011000000000000605
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
VCID: 678C66AE1F6FC5B22F9-8032
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 29031600040034
Coding: 21
VCID: 3D20E4C62DF3BF62A55-8068
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Dataset Number: 4G0909553G 0036
Coding: 008003
ROD: EV_AirSuspe_AU57.rod
VCID: 2F3CCE8EF79F5DF2279-807A
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820B752T Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3632FBEA08C56C3A64F-8062
Component: SWA Master H08 0060
Serial number: 0398825528 Dataset Number: 4G0909535C 0010
Coding: 040321
ROD: EV_LaneChangAssis_AU48.rod
VCID: 3928F0D639DB834289D-806C
Component: SWA Slave H08 0060
Serial number: 0397999602
Coding: 040321
Component: TSG FA H04 0511
Coding: 011F16015C00628002080013
VCID: 45D08C2645A3F7A2FD5-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000758869 Dataset Number: 4G0909852L 0037
Coding: 101001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2AEFDA3CDD885A807-806E
Revision: 00002001 Serial number: 0398605966
Coding: 013A0E20A0B93095C33009842E010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J245 PS20.403 H03 0004
Serial number: 0000FST000UNY0F00000
Coding: 901F00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Serial number: 0000000AP00019506889
Subsystem 5 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J394 PS20.403 H03 0004
Serial number: 0000FST000UNXT700000
Coding: 801F00
Component: TSG BF H03 0511
Coding: 011F16015E00628002080002
VCID: 46D28B2A78A5FCBAF4F-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001779460 Dataset Number: 4G0909522F 0008
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 3138C8F6E1AB4B0231D-8064
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G0909865D 0018
Coding: 04FA02102A630200
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 020 S HW: 4G1 035 020 D
Component: MU-H-ND-EU 051 0389
Serial number: A735C0GB002107 Dataset Number: 4G1909545D 0029
Coding: 017542010000000013111102000A00002F000AE5F17001009F
Subsystem 1 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY804K5C
Serial number: 90349PCG0010X
Compact disc data bank:
Component: Gracenote2 --- 1012
Component: TSG HL H03 0511
Coding: 010F14004000628002080002
VCID: 49C8801669BB13C219D-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001002 Serial number: 0398812142 Dataset Number: 4G0909527B 0009
Coding: 0100000202000000
VCID: 3334C2FE1BB77912431-8066
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Dataset Number: 4G0909460D 0013
Coding: 0275000103002007000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78AE35D242515A4AB63-802C
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 065600310 Dataset Number: 4G0909541E 0004
Coding: 093205C031
ROD: EV_HDSGAu571_AU57.rod
Component: TSG HR H03 0511
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000 Dataset Number: 4G0909547D 0007
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C06D982C68926EA02B-8078
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
ROD: EV_AdaptCruisContr2AU57X_002_AU57.rod
VCID: 270C26AEDF6F05B2EF9-8072
Component: BV-SG H33 0090
Serial number: 005000621403167 Dataset Number: 4G0909548G 0008
Coding: 04C0BB1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H15 0080
Dataset Number: 4G0909614C 0001
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H15 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323AC7FAE4AD701A487-8066
Part No SW: 4G5 035 223 C HW: 4G5 035 223
Component: MIB2_amp_P H02 0420
Serial number: 00000000037850 Dataset Number: 4G1909510L 0011
Coding: 01758208018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 221A37BAB44DE09AB87-8076
End----------(Elapsed Time: 02:36, VBatt start/end: 12.3V/12.3V)-----------
---------------------------No fault code found.----------------------------
