Hello!
I was driving and suddenly lost power and the engine wouldn't start back and the amber coil light on the dashboard appears. Any idea what troubleshooting steps I should go through?
Here are the new engine failure (full scan further below):
Full scan:
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number: CVN: D240C61FD45710C1
Coding: 001D0012842400000000
Shop #: WSC 91117 999 00000
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B23386D03E1AA929AB-806E
VINID: 0669D27874430944C0208048203E1A0E31
8 Faults Found:
5205 - Fuel Rail/System Pressure
P0087 00 [01100101] - Too Low
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:07
Engine speed: 1772.00 /min
Vehicle speed: 89 km/h
Coolant temperature: 99 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.400 V
Unlearning counter according OBD: 80
Fuel temperature: 29.3 °C
Mean injection quantity: 0.00 mg/stroke
Rail pressure regulation: status-Bits 0-7: 17
Fuel high-pressure: actual value: 117100 hPa
High fuel pressure: specified value: 484400 hPa
Pressure control valve adaptation factor: 1.1425
Fuel level: 13.00 l
5227 - Fuel Rail/System Pressure
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:08
Engine speed: 1712.50 /min
Vehicle speed: 87 km/h
Coolant temperature: 100 °C
Voltage terminal 30: 14.420 V
Fuel temperature: 29.4 °C
Rail pressure regulation: status-Bits 0-7: 4
Fuel high-pressure: actual value: 85300 hPa
High fuel pressure: specified value: 476500 hPa
Fuel level: 13.00 l
5228 - Fuel Rail/System Pressure
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:44
Engine speed: 878.50 /min
Normed load value: 99.6 %
Vehicle speed: 14 km/h
Coolant temperature: 102 °C
Intake air temperature: 32 °C
Voltage terminal 30: 14.180 V
Fuel temperature: 28.8 °C
Mean injection quantity: 10.21 mg/stroke
Fuel high-pressure: actual value: 4700 hPa
High fuel pressure: specified value: 237300 hPa
Fuel level: 13.00 l
5231 - Fuel Rail/System Pressure
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:08
Engine speed: 1749.00 /min
Vehicle speed: 88 km/h
Voltage terminal 30: 14.340 V
Fuel high-pressure: actual value: 100000 hPa
High fuel pressure: specified value: 478400 hPa
Fuel level: 13.00 l
8809 - Cylinder 3 Internal Pressure Sensor
P13D6 00 [01100101] - Implausible Signal
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:09
Engine speed: 1688.50 /min
Vehicle speed: 86 km/h
Intake air temperature: 34 °C
Maximum cylinder 3 cylinder pressure: 20.141 bar
Cylinder 3 max pressure position in deceleration mode: 0.46 °
Cylinder_pressure_offset_cylinder_3: -1.539 bar
Malfunction status of combustion chamber pressure of cylinder 3-Bits 0-7: 32
Group run time cylinder pressure sensor 3: 9.9 µs
8215 - Exhaust Gas Recirculation System
P2457 00 [01100000] - Insufficient Cooling Performance
4114 - Camshaft Position Sensor (G40)
P0340 00 [01100101] - Malfunction
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:06
Engine speed: 1893.00 /min
Normed load value: 76.1 %
Vehicle speed: 93 km/h
Intake air temperature: 31 °C
Voltage terminal 30: 14.480 V
Engine start: start synchronization: EPM_MODE_OK
Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
7934 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [01100101] - Implausible Signal
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:41
Engine speed: 1179.00 /min
Vehicle speed: 25 km/h
Coolant temperature: 101 °C
Charge Pressure Actuator: activation: 100.00 %
Charge air pressure actuator: acknowledgment: 77.16 %
Turbocharger boost control: offset closed: -20.81 %
High press turbocharger actuator: status-Bits 0-7: 0
High press turbocharger actuator: status-Bits 0-7: 55
High press turbocharger actuator: status-Bits 0-7: 64
High press turbocharger actuator: actual uncond volt value: 1862.0 mV
Full scan:
Monday,20,October,2025,14:44:37:16548
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
Mileage: 213010km-132358mi Repair Order:
Chassis Type: A3-VW41 (7N0)
77
VIN: 1VWBN7A32DC088188 Mileage: 213010km-132358miles
8 Faults Found:
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:07
Fuel level: 13.00 l
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:08
Fuel level: 13.00 l
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:44
Fuel level: 13.00 l
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:08
Fuel level: 13.00 l
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:09
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:06
Mileage: 213016 km
Date: 2025.10.20.
Time: 12:51:41
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9436
Revision: 05651213 Serial number: 00001210260066
Shop #: WSC 02656 003 1048576
VCID: 2411E31192DFF56ACB1-8070
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F5492A0002A30C03EC92210042271000
Shop #: WSC 09003 957 00200
VCID: 7DA7F6755DF564A2E4F-8028
Part No SW: 561 907 044 M HW: 561 907 044 M
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0030001002
VCID: 211FEA05814DE042A07-8074
9474161 - Motor for Defroster Flap
B1090 71 [00001000] - Actuator Stuck
Reset counter: 142
Mileage: 212106 km
Date: 2025.10.20.
Time: 11:06:29
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B802B2AD408880001160085480071008640801560648060000C70
VCID: 74B1D3516EBF25EA9B1-8020
Reset counter: 113
Mileage: 213016 km
Date: 2020.03.12.
Time: 14:09:01
Voltage: 12.05 V
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM004W7- Dataset Number: 560003v__A_ 0126
Coding: 00004D4A
Shop #: WSC 58875 002 1048576
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B7EE5565453CE2ACF-8020
Serial number: 6940000Y120000NR470V
Coding: 303046
Serial number: 3572MSME61456472ZZZS
Serial number: 3582MSME122D2272ZZZP
Serial number: 3516KSME086F6120ZZZR
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME375C5D20ZZZ.
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME466C601FZZZ1
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME7138631FZZZ$
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121016101324
Coding: 089A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 76B5E959784337FAA55-8022
Component: E221__MFL-YVJ H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 C HW: 561 920 870 C
Component: KOMBI H07 0705
Coding: 381E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 196FC2E5A91DB882687-804C
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 12121203291205
Coding: 461000
VCID: 76B5E95978C337FAA55-8022
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1829227R37TL06
Coding: 0000002
VCID: 6393A00DD751B252F2B-8036
Component: IMMO H07 0705
VCID: 6A8DCD293CFBE31A31D-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Revision: A1001003 Serial number: 7663809954
Coding: 010100
VCID: 2A0D0D29FCFB231AF1D-807E
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 113
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0005968447
Coding: 0404F5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE398EDE3A18A92BAB-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
67331 - Interior Switch for Central Locking
B1230 29 [00001000] - Signal Implausible
Mileage: 204782 km
Date: 2025.07.02.
Time: 23:50:57
67589 - Turn Signal in Exterior Mirror
B11FD 01 [00001000] - Electrical Failure
Reset counter: 153
Mileage: 204544 km
Date: 2025.06.30.
Time: 09:31:22
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
VCID: 372B245D33498EF27E3-8062
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FBBDC3D07990632663-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011227403906
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0005903156
Coding: 0404F4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE19BF1E6AF8DAAB31-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
Component: LOW NAR SDARS H03 0005
Revision: -----07S Serial number: VWZ4Z6M3482177
Coding: 2100040002000B
VCID: 2517FE1595E50C62DCF-8070
Reset counter: 31
Mileage: 202113 km
Date: 2019.09.24.
Time: 15:08:48
Reset counter: 31
Mileage: 202113 km
Date: 2019.09.24.
Time: 15:08:44
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663683769 Dataset Number: 7P6035730K 0001
Coding: 0C10040000010110
Shop #: WSC 94774 999 85622
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002_VW25.rod
VCID: 3A2D3D690CDB939A81D-806E
End----------(Elapsed Time: 01:11, VBatt start/end: 12.1V/12.1V)-----------
------------------------------15 Faults Found------------------------------
